New Topic
[General] Armbian and LibreELEC for rk3288
1013
vip
Rank: 6Rank: 6
General Armbian and LibreELEC for rk3288
Posted at 3/21/2021 17:30:37      View12976 | Replies12        Print      Only Author   [Copy Link] 1#
Versions of ArmbianTV and Libreelec.
Download links for new versions are now located here.
Dir rk3288
https://disk.yandex.ru/d/fRZwre9HDgAKHw?w=1
https://users.armbian.com/balbes150/
https://mega.nz/#F!j9QSDQSQ!6WpasOlbZYIInfw6yo4phQ
Using ArmbianTV.
1. Download,
2. Unpack,
3. burn the resulting image to the SD card.
4. Connect the SD card and turn on the power.
Launch LE
New image Libreelec (unoficcicial)
For rk3288, I release special images LE , there is no need to change anything, the system works immediately after writing to the SD card. All this works with almost all hardware (LAN WiFi HDMI sound) without additional settings.
dir rk3288 \ armv7 (name image rk3288)
https://yadi.sk/d/8vNYuuxynz1L0w?w=1
A prerequisite for starting - you must first erase the u-boot on the eMMC. This can be done using the USB tools, or you can use a special Multitool image created by Jock at this link. Please note DO NOT use Mulltitoo to install the system in eMMC, this will create a serious problem.
https://forum.armbian.com/topic/ ... 8-tv-box-boards-q8/
vip
Rank: 6Rank: 6
Posted at 3/21/2021 17:57:30        Only Author  2#
I checked the installation of ArmbianTV in eMMC with the standard armbian-config utility. Everything works. The system is installed in eMMC and normally starts from eMMC. After installing Armbian in eMMC. I checked the launch of Libreeelc from a USB flash drive. Everything starts perfectly and works with USB and SD cards. Thus, you can easily use different systems by simply connecting the media to the desired system. You can also install Libreelec in eMMC.
vip
Rank: 6Rank: 6
Posted at 4/10/2021 15:33:18        Only Author  3#
Ver 20210409 ArmbianTV and Libreelec
vip
Rank: 6Rank: 6
Posted at 5/6/2021 14:39:51        Only Author  4#
Ver ArmbianTV  20210505 kernel 5.10.34
vip
Rank: 6Rank: 6
Posted at 5/6/2021 22:01:18        Only Author  5#
LibreELEC ver 20210505 kernel 5.10.34
vip
Rank: 6Rank: 6
Posted at 5/18/2021 19:53:58        Only Author  6#
Ver kernel 5.10.37
vip
Rank: 6Rank: 6
Posted at 6/9/2021 21:30:55        Only Author  7#
Armbian and Libreelec kernel 5.10.42
vip
Rank: 6Rank: 6
Posted at 6/15/2021 19:51:00        Only Author  8#
Armbian and Libreelec kernel 5.10.43
add image Hirsute
vip
Rank: 6Rank: 6
Posted at 7/22/2021 20:59:45        Only Author  9#
ver 20210721 kernel 5.10.52
vip
Rank: 6Rank: 6
Posted at 9/7/2021 23:00:05        Only Author  10#
LibreELEC ver 20210907 kernel 5.14
Return to List
12
