[General] ROC-RK3399-PC Plus Six-Core 64-Bit High-Performance Main Board
1661
administrator
Rank: 9Rank: 9Rank: 9
General ROC-RK3399-PC Plus Six-Core 64-Bit High-Performance Main Board
Posted at 7/8/2020 17:45:18      View10193 | Replies6        Print      Only Author   [Copy Link] 1#
ROC-RK3399-PC Plus Six-Core 64-Bit High-Performance Main Board, equipped with high-performance RK3399 processor and adopts multiple power supply modes. It supports WIFI or BT wireless connection and can be connected to the expansion board, making the performance stronger and superior. When combined with the all-aluminum alloy case, it becomes a pocket portable personal computer.
High-performance Core Processor
With"server-level" dual-core Cortex-A72+ quad-core Cortex-A53 architecture, the frequency is up to 1.8 GHz, and 4GB LPDDR4 dual-channel 64-bit RAM high-performance memory is configured to comprehensively improve the performance of mainboard.
Portable Personal Computer
With unique model design and the size is only 120 x 72 x 11.2mm. When combined with the all-aluminum alloy case, it becomes a pocket portable personal computer.
Expansion Board Combination
Expansion board onboard balanced charging circuit can charge the battery, and it can also be powered by POE+. The equipped M.2 M-Key and M.2 E-Key interface can be separately used to expand SSD and provide SDIO 3.0 and USB 2.0 signals. ROC-RK3399-PC Plus is combined with the expansion board, which can greatly improve its performance.
Strong Network Capability
Supports Gigabit Ethernet, 2.4GHz Wifi and Bluetooth4.2, as well as owns strong Network expansion capability.
Multiple Operating Systems
Supports xserver, wayland display framework and multiple operating systems such as Android, Ubuntu, Debian9 and Linux+QT. It has onboard SPI flash and supports boot with TF card, EMMC, SSD and USB flash disk, making it more convenient to start the system.
Multiple Power Supply Modes
The main board can be powered by DC 12V, POE+ (802.3 AT, output power: 30W) via the expansion board or dual-cell battery. With multiple power supply modes, it can cater to the demands of users in different scenarios, making it more flexible and convenient to use.
Rich Peripheral Interface
With rich interfaces, such as MIPI DSI/eDP screen interface, dual-channel MIPI CSI camera interface(built-in ISP), Type-C(USB3.0+DP1.2), USB 2.0, USB3.0, HDMI 2.0, Gigabit Ethernet (RJ45), PCle, GPIO, etc.
Posted at 7/25/2025 20:34:09        Only Author  2#
Discretion and quality are paramount when seeking out exceptional companionship in Delhi. A professional Russian Delhi Call Girls aims to meet these standards, offering a reliable and elegant partner for various occasions. Clients appreciate the professionalism and the assurance of a comfortable and private encounter.
Posted at 1/11/2026 01:50:49        Only Author  3#
Fast2testһҌIľWվoÿλԪṩ|ķգǰպՃɷNҪ҂Fast2test GIACGICSPԇӖYϣʹ҂MԇõIJֿ}𰸣mm㣬@Hԙz҂Fast2test GIACGICSPԇӖYϵƷ|ٛQُIʹáܲҵě]ͨ^҂߀ُIȫMãKṩһM£ֱͨ^ֹ
Posted at 1/15/2026 23:22:18        Only Author  4#
Die CompTIA 220-1101-Deutsch Zertifizierungsprfung zu bestehen ist nicht einfach. Die richtige Ausbildung zu wählen ist der erste Schritt zu Ihrem Erfolg. Und eine zuverlässige Informationensquelle zu wählen ist die Garantie fr den Erfolg. DeutschPrfung hat gute und zuverlässige Informationensquellen. Wenn Sie Produkte von DeutschPrfung wählen, versprechen wir Ihnen nicht nur, die CompTIA 220-1101-Deutsch Zertifizierungsprfung 100% zu bestehen, sondern Ihnen auch einen einjährigen kostenlosen Update-Service zu bieten.
Posted at 1/17/2026 03:47:20        Only Author  5#
Wir sind der Schnellste, der daa HP HPE0-G04 Zertifikat erhält; wir sind noch der höchste, der Ihre Interessen schtzt. Wir sind Pass4Test. Pass4Test kann Ihnen versprechen, dass die Testaufgaben von HP HPE0-G04 Zertifizierungsprfung 100% richtig und ganz umfassend sind. Nachdem Sie die Testfragen zur HP HPE0-G04 Zertifizierung gekauft haben, werden Sie kostenlos die einjährige Aktualisierung genießen.
Posted at 1/22/2026 13:20:57        Only Author  6#
I was really impressed with how much I learned from the article. The 220-1101 latest test guide questions are available for free. Wishing you the best of luck in your exams!
Posted at 2/19/2026 00:53:01        Only Author  7#
This article is a great source of inspiration, thank you! Latest 1Y0-204 dumps sheet questions are essential for your career successget them for free!
