Quiz High-quality Esri - EAEP2201 - Exam Enterprise Administration Professional
Posted at 1/26/2026 13:17:17
DOWNLOAD the newest PracticeVCE EAEP2201 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=16BZDs6AYc7VMfl0QP5pSoJ4PjKILf766
Our EAEP2201 study guide provide you with three different versions including PC、App and PDF version. Each version has the same questions and answers, and you can choose one from them or three packaged downloads of EAEP2201 training materials. In addition to a wide variety of versions, our learning materials can be downloaded and used immediately after payment. We believe you will understand the convenience and power of our EAEP2201 Study Guide through the pre-purchase trial.
Esri EAEP2201 (Enterprise Administration Professional 2201) Certification Exam is designed for GIS professionals who want to demonstrate their expertise in managing and administering enterprise GIS systems. Enterprise Administration Professional 2201 certification exam is meant for professionals who have a deep understanding of Esri’s ArcGIS platform and can manage complex GIS systems.
Esri EAEP2201 Certification Exam is comprised of multiple-choice questions that cover a wide range of topics. These topics include installation and configuration, security and authentication, performance tuning and optimization, backup and disaster recovery, and troubleshooting and maintenance. EAEP2201 Exam is designed to test the skills and knowledge of professionals who have experience in managing ArcGIS Enterprise environments.
Latest Esri EAEP2201 Test Notes | EAEP2201 Valid Vce DumpsWe have harmonious cooperation with exam candidates. The relation comes from the excellence of our EAEP2201 training materials. We never avoid our responsibility of offering help for exam candidates like you, so choosing our EAEP2201 practice dumps means you choose success. Moreover, without the needs of waiting, you can download the EAEP2201 Study Guide after paying for it immediately. And we have patient and enthusiastic staff offering help on our EAEP2201 learning prep.
Esri Enterprise Administration Professional 2201 Sample Questions (Q39-Q44):NEW QUESTION # 39
An organization must limit the users who can publish services that reference data in a user-managed database.
At the same time, all users must be able to access and edit the data in that user-managed data store.
How should the database be registered?
- A. As a data store item in the ArcGIS Enterprise portal
- B. As an ArcGIS-managed data store in Server Manager
- C. As a relational data store in ArcGIS Data Store
Registering the database as a data store item in the ArcGIS Enterprise portal allows administrators to control who can publish services referencing the data. By sharing the data store item with specific groups or individuals, administrators can restrict publishing capabilities to authorized users. At the same time, all users can be granted appropriate permissions to access and edit the data directly in the user-managed database, independent of the publishing privileges.
Registering the database as an ArcGIS-managed data store in Server Manager does not provide the same level of control over publishing permissions. Registering it as a relational data store in ArcGIS Data Store is intended for managed data storage and does not apply to user-managed databases.
Reference Source:ArcGIS Enterprise documentation on registering user-managed data stores and controlling access.
NEW QUESTION # 40
An ArcGIS Pro user receives the following error when trying to publish to ArcGIS Enterprise:
"Unable to publish to ArcGIS Server, error 001369: failed to create service" The ArcGIS Server logs reveal:
* Failed to create service
* Internal server error
* Unable to instantiate class for XML schema type
* Invalid XML registry file
* 390 ArcSOC processes running
* Server uses only half of available RAM
Which action should the administrator perform?
- A. Use more dedicated instances instead of shared
- B. Scale up the ArcGIS Server machine resources
- C. Increase the non-interactive desktop heap size
This issue is consistent with desktop heap exhaustion, especially when a high number of ArcSOC processes (e.g., 390) are running on Windows. Desktop heap is a limited memory resource used for GUI and system object management. When it runs out, services can fail to start and produce XML-related errors.
Increasing the non-interactive desktop heap size in the Windows registry resolves this.
From Esri documentation:
"If the Windows desktop heap size is too low, ArcGIS Server may be unable to create new processes (ArcSOC), causing service failures and related internal server errors."
* Option B is a generic fix and won't address the specific heap exhaustion issue.
* Option C doesn't help if the root issue is OS-level heap size limits.
Reference:ArcGIS Enterprise - ArcSOC process limits and Windows desktop heap size
NEW QUESTION # 41
A GIS administrator is analyzing the usage statistics of ArcGIS Enterprise. The administrator needs to pull tabular statistics on various groups and users about the type of content that they produce and consume.
- A. Use ArcGIS Monitor to capture desired information over a period of time in a report.
- B. Run usage reports in Portal for ArcGIS to determine the effect on the organization.
- C. Open ArcGIS Server statistics to create a report for commonly used items.
Portal for ArcGIS provides built-in usage reports that allow administrators to monitor how members are using, sharing, and contributing resources. These reports offer insights into content creation, usage patterns, and group activities. Administrators can generate and export these reports in tabular formats for further analysis.
ArcGIS Server statistics focus on service-level metrics and do not provide detailed user or group content statistics. ArcGIS Monitor captures system performance metrics but is not designed for detailed content usage analysis by users or groups.
Reference Source:ArcGIS Enterprise documentation on usage reports in Portal for ArcGIS.
NEW QUESTION # 42
A GIS administrator is architecting a new ArcGIS Enterprise deployment. The organization has grown and evolved since the initial deployment. The organization is having difficulty meeting the existing Service Level Agreement.
Recently, the team rolled out a series of web tools that are used in various applications throughout the organization. In the existing deployment, users report poor performance when the web tools are used.
Which action should the GIS administrator perform?
- A. Dedicate an ArcGIS Server site for analysis to use workload separation
- B. Install an additional ArcGIS Enterprise deployment for analysis workflows
- C. Configure additional ArcGIS Server machines within the existing ArcGIS Server site
Workload separation is a best practice in ArcGIS Enterprise architecture. By dedicating a separate ArcGIS Server site for analysis tasks, such as geoprocessing services used in web tools, system resources can be managed more effectively, and performance can be improved. This configuration avoids overloading a single site and ensures that interactive web applications are not affected by resource-intensive analysis tools.
Adding more machines to the same site (Option A) does not isolate workloads and may still result in contention. Installing an entirely new ArcGIS Enterprise deployment (Option C) increases complexity and administration effort unnecessarily. The recommended solution is to implementa dedicated ArcGIS Server site for analysisas part of a federated multi-site deployment.
Reference Source:ArcGIS Enterprise System Design Strategies - Workload separation practices
NEW QUESTION # 43
A GIS analyst is running raster analysis in the ArcGIS Enterprise portal Map Viewer. The input data is an image layer, but the output of the raster analysis is a feature layer.
Which ArcGIS Server will host the output feature service?
- A. ArcGIS Hosting Server site
- B. ArcGIS Raster Analytics Server site
- C. ArcGIS Image Hosting Server site
NEW QUESTION # 44
We have compiled the EAEP2201 test guide for these candidates who are trouble in this exam, in order help they pass it easily, and we deeply believe that our EAEP2201 exam questions can help you solve your problem. Believe it or not, if you buy our study materials and take it seriously consideration, we can promise that you will easily get the certification that you have always dreamed of. We believe that you will never regret to buy and practice our EAEP2201 latest question as the high pass rate of our EAEP2201 exam questions is 99% to 100%.
Latest EAEP2201 Test Notes: https://www.practicevce.com/Esri/EAEP2201-practice-exam-dumps.html
- First-grade Exam EAEP2201 Labs Covers the Entire Syllabus of EAEP2201 😥 Search for ( EAEP2201 ) on ➤ [url]www.troytecdumps.com ⮘ immediately to obtain a free download 🟠EAEP2201 Minimum Pass Score[/url]
- Pass-Sure Exam EAEP2201 Labs - Pass EAEP2201 in One Time - Latest Latest EAEP2201 Test Notes 🍼 Search for ☀ EAEP2201 ️☀️ and download it for free immediately on { [url]www.pdfvce.com } 🦎Related EAEP2201 Exams[/url]
- EAEP2201 Exam Fees 🏃 New EAEP2201 Test Answers 🍽 Test EAEP2201 Result ↙ Download ➡ EAEP2201 ️⬅️ for free by simply entering ⮆ [url]www.validtorrent.com ⮄ website 🏴Formal EAEP2201 Test[/url]
- How to Obtain Excellent Results Here on Esri EAEP2201 Exam 🥢 Easily obtain free download of { EAEP2201 } by searching on ➤ [url]www.pdfvce.com ⮘ 🐟Test EAEP2201 Result[/url]
- EAEP2201 Exam Fees 👐 Exam EAEP2201 Pass4sure 🥑 New EAEP2201 Test Answers ☔ Download ➤ EAEP2201 ⮘ for free by simply entering 【 [url]www.prepawayexam.com 】 website 🟫New EAEP2201 Test Answers[/url]
- HOT Exam EAEP2201 Labs - The Best Esri Latest EAEP2201 Test Notes: Enterprise Administration Professional 2201 🧅 Go to website ➤ [url]www.pdfvce.com ⮘ open and search for ⏩ EAEP2201 ⏪ to download for free 📖Valid EAEP2201 Exam Fee[/url]
- Esri - EAEP2201 - Marvelous Exam Enterprise Administration Professional 2201 Labs 📱 Open ⏩ [url]www.testkingpass.com ⏪ and search for ▶ EAEP2201 ◀ to download exam materials for free 🏘Formal EAEP2201 Test[/url]
- EAEP2201 Latest Exam Papers 🔏 EAEP2201 Minimum Pass Score 🚔 Valid EAEP2201 Exam Tips 🏴 The page for free download of { EAEP2201 } on ( [url]www.pdfvce.com ) will open immediately 🍏Valid EAEP2201 Exam Tips[/url]
- Pass-Sure Exam EAEP2201 Labs - Pass EAEP2201 in One Time - Latest Latest EAEP2201 Test Notes 🕛 Open website ▷ [url]www.prepawayexam.com ◁ and search for 《 EAEP2201 》 for free download 🧝EAEP2201 Latest Exam Papers[/url]
- EAEP2201 Test Vce Free ⏭ Valid EAEP2201 Exam Tips 📗 Answers EAEP2201 Free 💒 ➡ [url]www.pdfvce.com ️⬅️ is best website to obtain ➽ EAEP2201 🢪 for free download 🔖Formal EAEP2201 Test[/url]
- 2026 Authoritative Esri Exam EAEP2201 Labs 🙍 Search for ➽ EAEP2201 🢪 and easily obtain a free download on ▶ [url]www.verifieddumps.com ◀ 👽EAEP2201 Reliable Exam Pdf[/url]
- www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
2026 Latest PracticeVCE EAEP2201 PDF Dumps and EAEP2201 Exam Engine Free Share: https://drive.google.com/open?id=16BZDs6AYc7VMfl0QP5pSoJ4PjKILf766
