Issues with HDMI display resolution
5
Posted at 2/6/2018 21:47:51      View5979 | Replies4        Print      Only Author   [Copy Link] 1#
Hello,
I have an RK-3288 and I'm running into issues getting the correct display resolution over HDMI. It looks like i'm maybe getting 720 or lower, which is then upscaled in my monitor and looks horrible.
If I instead plug in VGA cable it looks good though.
I've tried forcing the HDMI to 1080p but I'm having issues. It looks like xrandr does not properly detect the HDMI port:
sudo xrandr --newmode "1920x1080_60.00"  173.00  1920 2048 2248 2576  1080 1083 1088 1120 -hsync +vsync
xrandr: Failed to get size of gamma for output default
sudo xrandr --addmode HDMI-0 1920x1080_60.60
xrandr: cannot find output "HDMI-0"
sudo xrandr --query
Screen 0: minimum 1920 x 1080, current 1920 x 1080, maximum 1920 x 1080
default connected 1920x1080+0+0 0mm x 0mm
   1920x1080      60.0*
  1920x1080_60.00 (0x6c)  173.0MHz
        h: width  1920 start 2048 end 2248 total 2576 skew    0 clock   67.2KHz
        v: height 1080 start 1083 end 1088 total 1120           clock   60.0Hz
I'm using the built in Ubuntu version which was delivered with the device. I've run "apt-get update/upgrade" to download patches.
Additional commands that I've tried:
firefly@firefly:~$ sudo lspci
pcilib: Cannot open /proc/bus/pci
lspci: Cannot find any working access method.
firefly@firefly:~$ sudo lshw -C display
firefly@firefly:~$ cat /etc/X11/xorg.conf.d/*
Section "InputClass"
        Identifier "gslX680 evdev touchscreen"
        MatchProduct    "gslX680"
        MatchDevicePath "/dev/input/event*"
        Option "EmulateThirdButton" "true"
        Option "EmulateThirdButtonTimeout" "500"
        Option "EmulateThirdButtonMoveThreshold" "50"
        Driver "evdev"
EndSection
        Identifier "evdev gsl680"
        #MatchIsTouchscreen "on"
        MatchProduct "gsl680"
        Driver "evdev"
EndSection
Thanks for your help
Posted at 10/11/2025 15:34:34        Only Author  2#
Boost your financial management expertise with comprehensive study resources designed for real exam success. Each question is paired with a clear, detailed answer to enhance your understanding of financial planning and analysis. Practicing CMA-Financial-Planning-Performance-and-Analytics Questions and Answers ensures you grasp every concept and perform confidently in the actual test. For accurate, expert-verified materials and guaranteed success, trust CertsDone your reliable partner for CMA certification preparation.
Posted at 10/13/2025 12:32:11        Only Author  3#
You may improve your knowledge of financial management by using comprehensive study tools that are designed to help you succeed on real exams. The purpose of this exercise is to improve retro bowl 26 your grasp of financial planning and analysis by providing you with a clear and complete solution to each question.
Posted at 1/21/2026 02:59:08        Only Author  4#
Huawei인증 H11-861_V4.0시험을 어떻게 공부하면 패스할수 있을지 고민중이시면 근심걱정 버리시고ITDumpsKR 의 Huawei인증 H11-861_V4.0덤프로 가보세요. 문항수가 적고 적중율이 높은 세련된Huawei인증 H11-861_V4.0시험준비 공부자료는ITDumpsKR제품이 최고입니다.
Posted at 4/20/2026 02:09:15        Only Author  5#
D-PWF-OE-00ԇYˆ}ʤѸ٤˺ϸ񤹤뷽 𤨤ϡЄǃ줿D-PWF-OE-00ȥ`˥󥰥ɤˤޤ ȤD-PWF-OE-00ȥ`˥YϤ⤷Ƥޤ ϡ^ΥץD-PWF-OE-00gYϤǤ οΤSݤǤ˼Ӥơ3ĤΥЩ`Τ٤ƤD-PWF-OE-00ԇYYϤϡ10Ϥˤ錄äƤηҰΌTҤˤäƾƤޤ
