New Topic
[Linux] Core-3308Y CAN
87
Linux Core-3308Y CAN
Posted at 9/1/2023 07:46:06      View3664 | Replies10        Print      Only Author   [Copy Link] 1#
Hi everyone!
I am working with Core-3308Y board. I have not found any ways to activate CAN module using a Device Tree.
DTS entry which I use:
&can {
    assigned-clocks = <&cru PCLK_CAN>;
    assigned-clock-rates = <200000000>;
    pinctrl-names = "default";
    pinctrl-0 = <&canm2_pins>;
    status = "okay";
rk3308b.dtsi contains only CAN pin declarations, therefore compilation fails with "Label or path can not found" error.
Could you propose a correct CAN declaration for RK3308B?
Posted at 9/2/2023 17:35:31        Only Author  2#
In fact, the soc RK3308 does not yet have support for the CAN pin.
We are using the spi to can solution. https://en.t-firefly.com/product ... index.html?theme=pc
Posted at 9/5/2023 02:17:49        Only Author  3#
ʱĺ Posted at 9/2/2023 17:35
We are using the spi to can solu ...
Thank you for the answer!
Could you provide any more details on the question? Maybe there are some plans for adding CAN support? Or the chip itself does not contain the module?
Adding the extra chip is the way to go, but the space constraints does not always allow to use it
Posted at 9/5/2023 11:27:41        Only Author  4#
ivan.p Posted at 9/5/2023 02:17
Could you provide any more details on the question? Maybe there are s ...
As I know, there are no plans for it. Currently, only RK356X and RK3588 support CAN pin.
https://wiki.t-firefly.com/en/Core-3568J/driver_can.html
Posted at 9/6/2023 05:39:43        Only Author  5#
Okay, thank you!
Posted at 1/9/2026 15:33:14        Only Author  6#
Im really inspired after reading this article, thanks so much for sharing! Free Latest test guide CISSP files test questionsunlock promotions and salary growth today!
Posted at 1/11/2026 14:14:20        Only Author  7#
Your article was incredibly refreshing and inspiring, thank you! The Valid exam collection SPLK-4001 file helped me secure a promotion and salary raise. Now its free to all. Best wishes for your career advancements!
Posted at 1/12/2026 09:37:58        Only Author  8#
Im deeply appreciative of your article, it was truly enlightening. Sharing the JN0-224 latest exam dumps free test that led to my promotion and raise, now free to all. Best wishes in your pursuit of career success!
Posted at 1/27/2026 14:59:25        Only Author  9#
This article is truly inspiring, and it has given me a new understanding of the related topic. Boost your IT knowledge with free C_P2W81_2505 valid exam cram pdf. Wishing you all the best in your studies!
Posted at 1/29/2026 13:16:11        Only Author  10#
ʤΉϺΤǤʤΥꥢǤĤxIФȤޤʤΤǤäǤǤ礦ǤϡԷ򥢥åץ`ɤҪޤITIN¤Ƥ뤢ʤϡ_ɤ뤿ˤɤʷäĤǤgHˤϡITJԇYYJ^YȡΤһĤǤISACACISAԇYϷdz˚ݤΤJԇYǤʤ⤳ԇYJYȡäΤǤơϤ䤯ԇYꤷzߤޤ礦JPNTestϤʤ뤳ȤǤޤ顢䤹ҪʤǤ衣
Return to List
12
