Free PL-200 Questions That Will Get You Through the Exam
101
Posted at 1/24/2026 20:19:21      View181 | Replies1        Print      Only Author   [Copy Link] 1#
2026 Latest TestkingPDF PL-200 PDF Dumps and PL-200 Exam Engine Free Share: https://drive.google.com/open?id=1DN154As41lKLGGWpIaysTsOxDdbe5hLR
We are never satisfied with the present situation and expand and update the PL-200 exam practice guide by all means. We focus on the innovation and organize our expert team to compile new knowledge points and update the test bank. We treat our clients as our god and treat their supports to our PL-200 Study Materials as our driving forces to march forward. So the clients can enjoy the results of the latest innovation on PL-200 exam questions and achieve more learning resources. The credits belong to our diligent and dedicated professional innovation team and our experts.
Integrate Power Apps & Other Apps & Services: 15-20%
  • Integrating Power BI and Power Apps: the candidates should understand how to filter data, create visualization for Power BI, and develop data flows as well as scheduled runs for data flow.
  • Integrating Power Apps and Microsoft 365: the examinees should have the relevant skills in configuring and using Microsoft Excel & Microsoft Word templates as well as configuring app policies and creating Teams app making use of Power Apps app.
  • Implementing AI Builder: this subject area requires ones skills in consuming models making use of Power Apps & Power Automate; creating AI Builder models and preparing source data to be utilized by models.
Microsoft PL-200 Certification Exam is designed for individuals who want to demonstrate their expertise in implementing and customizing Microsoft Power Platform solutions. Microsoft Power Platform Functional Consultant certification is ideal for functional consultants who work with Power Platform to design, develop, and implement solutions that solve business problems. PL-200 exam measures the candidate's ability to configure, customize, extend, and support Power Platform solutions.
PL-200 Dumps Collection, PL-200 Free UpdatesThe TestkingPDF is one of the leading platforms that has been offering real and valid Microsoft Power Platform Functional Consultant (PL-200) exam practice test questions. These PL-200 exam questions are designed and verified by Microsoft PL-200 subject matter experts. They work closely together and put all their expertise to check the TestkingPDF PL-200 Exam Questions one by one. So we can say that the TestkingPDF PL-200 exam practice questions are real, valid, and updated Microsoft Power Platform Functional Consultant (PL-200) exam questions that will provide you with everything that you need to learn to prepare and pass the PL-200 exam.
Microsoft Power Platform Functional Consultant Sample Questions (Q270-Q275):NEW QUESTION # 270
Hotspot Question
You create a new Power Virtual Agents chatbot for an organization.
Testing and production deployment of the chatbot are not complete.
You need to ensure that appropriate users can access the chatbot.
Which methods should you use? To answer, select the appropriate options in the answer area.
Box 1: Use the demo website
When publishing the bot to the web, you can publish to a prebuilt demo website (which you can use to share the bot with your teammates and stakeholders) and to your own live website.
Box 2: Share the chatbot to each user individually
You can only share a bot with individual users, which means you can't share it with a security group or distribution group in your organization.
You also can't share with users or groups outside of your organization.
Box 3: Embed the chatbot code in an IFRame on your copany's public website You can add your bot to a live website as an IFrame. Your live website can be a customer-facing external website or an internal site, like a SharePoint or Yammer site.
https://docs.microsoft.com/en-us ... bot-to-web-channels
https://docs.microsoft.com/en-us ... uirements-licensing
https://docs.microsoft.com/en-us ... re-bots#share-a-bot
NEW QUESTION # 271
A company uses Power Apps with Microsoft Dataverse.
The company enables auditing on the Dataverse database. The company tenant reaches the maximum storage capacity.
You need to delete some auditing data.
Which three deletion options should you use? Each correct answer presents a complete solution.
  • A. between two specified dates
  • B. by record
  • C. older than a specified date
  • D. by table
  • E. by column
Answer: A,C,D
A) Deleting by table allows you to select specific tables in the Dataverse database for which you want to delete the auditing data. This can be done by going to the Power Apps portal, navigating to the Data tab, and selecting the table for which you want to delete the auditing data. You can then select the specific auditing data you want to delete and click the "Delete" button. This is useful if you want to only delete auditing data for specific tables and not for the entire database. Reference: https://docs.microsoft.com/en-us ... g#delete-audit-logs C) Deleting between two specified dates allows you to select a range of dates within which the auditing data will be deleted. This can be done by going to the Power Apps portal, navigating to the Data tab, and selecting the "Audit" option. From there, you can select the "Delete" button, and select the "Between two dates" option. Then you can specify the start and end date for which you want to delete the auditing data. This is useful if you want to delete auditing data for a specific time period and not for the entire database. Reference: https://docs.microsoft.com/en-us ... g#delete-audit-logs E) Deleting older than a specified date allows you to select a specific date, and any data older than that date will be deleted. This can be done by going to the Power Apps portal, navigating to the Data tab, and selecting the "Audit" option. From there, you can select the "Delete" button, and select the "Older than a specified date" option. Then you can specify the date for which you want to delete the auditing data. This is useful if you want to delete auditing data that is older than a certain date and not for the entire database. Reference: https://docs.microsoft.com/en-us ... g#delete-audit-logs It's always good to have a backup of Data before deletion and also check the retention period of the data you want to delete.
NEW QUESTION # 272
You need to design the guest check-in solution.
Which technologies should you use? To answer, select the appropriate options in the answer area.
NEW QUESTION # 273
A company plans to implement a voice-enabled Power Virtual Agents bot. The company has the following requirements for the bot:
* Recognize when a caller states Tennis or any variation of the word.
* Provide options when a caller states the name of a sport.
You need to configure the bot.
NEW QUESTION # 274
You are creating Power BI reports for a company.
A company that has a model-driven app wants to use Power BI reports within the app. You create the reports.
You need to ensure that these reports are available within the app.
Which two actions should you perform? Each correct answer presents a complete solution.
  • A. Add the Power Bl report to the Site Map dashboards.
  • B. Share the Power Bl report to all users.
  • C. Create a PCF file.
  • D. Use the native reports in model-driven apps.
  • E. Add the Power Bl report to a dashboard in the model-driven app.
Answer: A,E
You can create a quick Power BI report, a model-driven app, and then add the report as a dashboard in the app.
Create a new model-driven app and add the Power BI embedded report.
In this section, you create a model-driven app and add the Power BI embedded report created earlier.
1. Sign in to Power Apps, select the environment you want, and then on the left navigation pane, select Apps.
2. On the command bar, select +New app, and then select Model-driven.
3. Enter a Name for the model-driven app, and then select Done.
The model-driven app designer opens.
4. Select the Edit Site Map pencil icon, to open the sitemap designer. (B)
5. Select New subarea on the site map. Then select the following Properties, and then select Save:
Type: Dashboard -
Default Dashboard: Test Embedded BI Report
Title: Test Embedded BI -
Save and then Publish -
6. Select Publish, and then select Save and Close to close the sitemap designer.
7. On the app designer command bar select, Save, then Validate, and then select Publish.
Incorrect:
* PCF file
PCF (PowerApps component framework) empowers professional developers and app makers to create code components for model-driven apps and canvas apps to provide an enhanced user experience for the users to view and work with data in forms, views, and dashboards.
https://docs.microsoft.com/en-us ... /add-powerbi-visual
NEW QUESTION # 275
Thousands of PL-200 certification holders provide helpful input to TestkingPDF. It helps us to keep our PL-200 exam dumps preparation material polished, updated, and error-free. To achieve its mission, TestkingPDF offers a free demo of the Microsoft PL-200 exam questions.This free trial enables customers to evaluate the quality of the Microsoft PL-200 Dumps before making a purchase. You will also receive up to 1 year of free Microsoft PL-200 exam question updates. TestkingPDF guarantees that nothing will prevent you from clearing the PL-200 exam on your first attempt if you diligently study from our updated PL-200 exam questions.
PL-200 Dumps Collection: https://www.testkingpdf.com/PL-200-testking-pdf-torrent.html
P.S. Free & New PL-200 dumps are available on Google Drive shared by TestkingPDF: https://drive.google.com/open?id=1DN154As41lKLGGWpIaysTsOxDdbe5hLR
Posted at 1/25/2026 07:37:20        Only Author  2#
Your article was truly unforgettable, thank you for sharing it. C-P2W52-2410 exam study solutions provides excellent material, and it's entirely free of charge.
