[General] No Need to Installing Software for the Salesforce Mule-Arch-201 Web-Based Pracit
102
General No Need to Installing Software for the Salesforce Mule-Arch-201 Web-Based Pracit
Posted at 2/10/2026 23:36:33      View125 | Replies1        Print      Only Author   [Copy Link] 1#
With a higher status, your circle of friends will expand. You will become friends with better people. With higher salary, you can improve your quality of life by our Mule-Arch-201 learning guide. The future is really beautiful, but now, taking a crucial step is even more important! Buy Mule-Arch-201 Exam Prep and stick with it. You can get what you want! You must believe that no matter what you do, as long as you work hard, there is no unsuccessful. Mule-Arch-201 study materials are here waiting for you!
Actualtests4sure has focus on offering the accurate and professional exam dumps for Salesforce certification test. All questions and answers of Mule-Arch-201 are written by our IT experts who has more than 10 years' experience in IT filed. With the help of our Mule-Arch-201 Dumps Torrent, you will get high passing score in the test with less time and money.
Mule-Arch-201 Test Preparation - Mule-Arch-201 Reliable Exam SimsWe strongly recommend using our Salesforce Mule-Arch-201 exam dumps to prepare for the Salesforce Mule-Arch-201 certification. It is the best way to ensure success. With our Salesforce Mule-Arch-201 practice questions, you can get the most out of your studying and maximize your chances of passing your Salesforce Mule-Arch-201 Exam. Actualtests4sure Salesforce Mule-Arch-201 practice test software is the answer if you want to score higher in the Salesforce Mule-Arch-201 exam and achieve your academic goals.
Salesforce Certified MuleSoft Platform Architect Sample Questions (Q37-Q42):NEW QUESTION # 37
A business process is being implemented within an organization's application network. The architecture group proposes using a more coarse-grained application network design with relatively fewer APIs deployed to the application network compared to a more fine-grained design.
Overall, which factor typically increases with a more coarse-grained design for this business process implementation and deployment compared with using a more fine-grained design?
  • A. The number of possible connections between API implementations in the application network
  • B. The number of discoverable assets related to APIs deployed in the application network
  • C. The usage of network infrastructure resources by the application network
  • D. The complexity of each API implementation
Understanding Coarse-Grained vs. Fine-Grained API Design:
A coarse-grained design consolidates multiple operations within a single API, leading to fewer APIs but with more complex implementations. Conversely, a fine-grained design breaks down functionalities into smaller, more specific APIs, resulting in simpler implementations but a larger number of APIs.
Evaluating the Options:
Option A (Correct Answer): With a coarse-grained design, each API handles more functionalities, increasing the complexity of each API implementation as it needs to manage more use cases and logic.
Option B: A coarse-grained design typically reduces the number of APIs, so fewer discoverable assets are available.
Option C: Fewer APIs generally mean fewer connections between them in the application network.
Option D: Network infrastructure usage may actually decrease with fewer APIs, as there are fewer calls between APIs.
Conclusion:
Option A is the correct answer, as the complexity of each API implementation increases in a coarse-grained design due to the consolidation of multiple functionalities into single APIs.
Refer to MuleSoft's documentation on API design principles and best practices for coarse-grained vs. fine-grained API implementation.
NEW QUESTION # 38
An organization makes a strategic decision to move towards an IT operating model that emphasizes consumption of reusable IT assets using modern APIs (as defined by MuleSoft).
What best describes each modern API in relation to this new IT operating model?
  • A. Each modem API must be treated like a product and designed for a particular target audience (for instance, mobile app developers)
  • B. Each modern API must be easy to consume, so should avoid complex authentication mechanisms such as SAML or JWT D
  • C. Each modern API has its own software development lifecycle, which reduces the need for documentation and automation
  • D. Each modern API must be REST and HTTP based
Correct Answers:
1. Each modern API must be treated like a product and designed for a particular target audience (for instance mobile app developers)
Bottom of Form
Top of Form
NEW QUESTION # 39
An auto manufacturer has a mature CI/CD practice and wants to automate packaging and deployment of any Mule applications to various deployment targets, including CloudHub workers/replicas, customer-hosted Mule runtimes, and Anypoint Runtime Fabric.
Which MuleSoft-provided tool or component facilitates automating the packaging and deployment of Mule applications to various deployment targets as part of the company's CI/CD practice?
  • A. Anypoint Platform REST APIs
  • B. Mule Maven plugin
  • C. Anypoint Runtime Manager
  • D. Anypoint Platform CLI
For organizations with established CI/CD practices, the Mule Maven plugin is the recommended tool for automating packaging and deployment across multiple environments, including CloudHub, on-premise Mule runtimes, and Anypoint Runtime Fabric. Here's why:
Automation with Maven:
The Mule Maven plugin allows for CI/CD integration by supporting automated build and deployment processes. It is commonly used in CI/CD pipelines to handle application packaging and deployment directly through Maven commands, making it ideal for teams that want consistent deployment automation across different MuleSoft environments.
Supported Deployment Targets:
The Mule Maven plugin supports deployment to various targets, including CloudHub, Runtime Fabric, and on-premises servers, thus meeting the needs of environments with diverse deployment destinations.
Why Option B is Correct:
The Mule Maven plugin is specifically designed for CI/CD pipelines and integrates with Jenkins, GitLab, and other CI/CD tools to facilitate continuous deployment. It is the most efficient MuleSoft-provided tool for this purpose.
of Incorrect Options:
Option A (Anypoint Runtime Manager) provides deployment management but does not automate CI/CD processes.
Option C (Anypoint Platform CLI) can script deployments but lacks direct integration with CI/CD tools.
Option D (Anypoint Platform REST APIs) requires custom scripting for deployment, which can be more complex than using the Mule Maven plugin.
Reference
For more details, refer to MuleSoft documentation on using the Mule Maven plugin for CI/CD.
NEW QUESTION # 40
What API policy would LEAST likely be applied to a Process API?
  • A. Client ID enforcement
  • B. Rate limiting
  • C. Custom circuit breaker
  • D. JSON threat protection
Correct Answe r: JSON threat protection
Fact: Technically, there are no restrictions on what policy can be applied in what layer. Any policy can be applied on any layer API. However, context should also be considered properly before blindly applying the policies on APIs.
That is why, this question asked for a policy that would LEAST likely be applied to a Process API.
From the given options:
>> All policies except "JSON threat protection" can be applied without hesitation to the APIs in Process tier.
>> JSON threat protection policy ideally fits for experience APIs to prevent suspicious JSON payload coming from external API clients. This covers more of a security aspect by trying to avoid possibly malicious and harmful JSON payloads from external clients calling experience APIs.
As external API clients are NEVER allowed to call Process APIs directly and also these kind of malicious and harmful JSON payloads are always stopped at experience API layer only using this policy, it is LEAST LIKELY that this same policy is again applied on Process Layer API.
NEW QUESTION # 41
An Order API must be designed that contains significant amounts of integration logic and involves the invocation of the Product API.
The power relationship between Order API and Product API is one of "Customer/Supplier", because the Product API is used heavily throughout the organization and is developed by a dedicated development team located in the office of the CTO.
What strategy should be used to deal with the API data model of the Product API within the Order API?
  • A. Start an organization-wide data modeling initiative that will result in an Enterprise Data Model that will then be used in both the Product API and the Order API
  • B. Convince the development team of the Product API to adopt the API data model of the Order API such that the integration logic of the Order API can work with one consistent internal data model
  • C. Implement an anti-corruption layer in the Order API that transforms the Product API data model into internal data types of the Order API
  • D. Work with the API data types of the Product API directly when implementing the integration logic of the Order API such that the Order API uses the same (unchanged) data types as the Product API
Correct Answe r: Convince the development team of the product API to adopt the API data model of the Order API such that integration logic of the Order API can work with one consistent internal data model
Key details to note from the given scenario:
>> Power relationship between Order API and Product API is customer/supplier So, as per below rules of "Power Relationships", the caller (in this case Order API) would request for features to the called (Product API team) and the Product API team would need to accomodate those requests.
NEW QUESTION # 42
Will you feel nervous for your exam? If you do, you can choose us, we will help you reduce your nerves as well as increase your confidence for the exam. Mule-Arch-201 Soft test engine can simulate the real exam environment, so that you can know the procedure for the exam, and your confidence for the exam will be strengthened. In addition, we offer you free demo to have try before buying, so that you can know the form of the complete version. Free update for one year is available for Mule-Arch-201 Exam Materials, and you can know the latest version through the update version. The update version for Mule-Arch-201 training materials will be sent to your email automatically.
Mule-Arch-201 Test Preparation: https://www.actualtests4sure.com/Mule-Arch-201-test-questions.html
With 100% Guaranteed of Success: Actualtests4sure's promise is to get you a wonderful success in Mule-Arch-201 certification exams, Mule-Arch-201 certifications establish your professional worth beyond your estimation, If you are preparing for the Mule-Arch-201 exam by the guidance of the Mule-Arch-201 study practice question from our company and take it into consideration seriously, you will absolutely pass the Mule-Arch-201 exam and get the related certification, Salesforce Preparation Mule-Arch-201 Store We believe that the study materials will keep the top selling products.
While guaranteeing success in the exam at the first attempt, Mule-Arch-201 we offer you compact study guide with to-the-point and pertinent questions, Lead time and cycle time.
With 100% Guaranteed of Success: Actualtests4sure's promise is to get you a wonderful success in Mule-Arch-201 Certification exams, Mule-Arch-201 certifications establish your professional worth beyond your estimation.
2026 Salesforce Mule-Arch-201: Valid Preparation Salesforce Certified MuleSoft Platform Architect StoreIf you are preparing for the Mule-Arch-201 exam by the guidance of the Mule-Arch-201 study practice question from our company and take it into consideration seriously, you will absolutely pass the Mule-Arch-201 exam and get the related certification.
We believe that the study materials will keep the Mule-Arch-201 Test Preparation top selling products, Then our PDF & soft version practice test will totally belong to you.
Posted at 3/4/2026 12:56:45        Only Author  2#
Im grateful for your article, it truly stood out to me. Get the Updated C_BCBAI_2509 dumps questions that helped me get promoted and earn moreoffered to you for free!
