[General] Valid Juniper JN0-683 Vce - High JN0-683 Quality
-2
restricted members
General Valid Juniper JN0-683 Vce - High JN0-683 Quality
Posted at 1/13/2026 03:33:01      View578 | Replies2        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Juniper JN0-683 dumps are available on Google Drive shared by Prep4sureGuide: https://drive.google.com/open?id=1OaEIcSxfcJZCyM18lkaJrHuPGkybSTiR
Review the products offered by us by downloading their free demos and compare them with the JN0-683 study material offered in online course free and vendors' files. You will find our products the better than our competitors such as exam collection and others. The excellent quality of our JN0-683 content, their relevance with the actual exam needs and their interactive and simple format will prove them superior and quite pertinent to your needs and requirements.
Juniper JN0-683 Exam Syllabus Topics:
  • VXLAN: This part requires knowledge of VXLAN, particularly how the control plane manages communication between devices, while the data plane handles traffic flow. Demonstrate knowledge of how to configure, Monitor, or Troubleshoot VXLAN.
  • Data Center Deployment and Management: This section assesses the expertise of data center networking professionals like architects and engineers, focusing on key deployment concepts. Topics include Zero-touch provisioning (ZTP), which automates device setup in data centers without manual input.
  • Data Center Multitenancy and Security: This section tests knowledge of single-tenant and multitenant data center setups. Candidates such as Data Center Professionals are evaluated on ensuring tenant traffic isolation at both Layer 2 and Layer 3 levels in shared infrastructure environments.
  • Data Center Interconnect: For Data Center Engineers, this part focuses on interconnecting data centers, covering Layer 2 and Layer 3 stretching, stitching fabrics together, and using EVPN-signaled VXLAN for seamless communication between data centers.
Topic 5
  • Layer 3 Fabrics: This section measures the knowledge of professionals managing IP-based networks in data centers. It covers IP fabric architecture and routing, ensuring candidates understand how the network is structured for scalability and how traffic is routed efficiently.
Go With Juniper JN0-683 Exam Dumps [2026] For Instant SuccessIf you study on our test engine, your preparation time of the JN0-683 guide braindumps will be greatly shortened. Firstly, the important knowledge has been picked out by our professional experts. You just need to spend about twenty to thirty hours before taking the Real JN0-683 Exam. In addition, the relevant knowledge will be easy to memorize. Learning our JN0-683 study quiz can also be a pleasant process. The saved time can be used to go sightseeing or have a rest.
Juniper Data Center, Professional (JNCIP-DC) Sample Questions (Q37-Q42):NEW QUESTION # 37
You are asked to configure telemetry on the OFX Series devices in your data center fabric. You want to use sensors that have a vendor-neutral data model Which type of sensor should you use in this scenario?
  • A. analog sensors
  • B. Python sensors
  • C. JTI OpenConfig sensors
  • D. JTI native sensors
* Telemetry in Data Centers:
* Telemetry allows for real-time monitoring of network devices by collecting and exporting data such as interface statistics, routing table updates, and other key metrics.
* Vendor-Neutral Data Models:
* Option A:JTI (Junos Telemetry Interface) OpenConfig sensors use a vendor-neutral data model, which is important for ensuring compatibility across different network devices and systems.
OpenConfig is an industry-standard model, which facilitates integration with various telemetry collection systems.
Conclusion:
* Option A:Correct-OpenConfig sensors provide a vendor-neutral solution for telemetry, ensuring broad compatibility and flexibility in data center environments.
NEW QUESTION # 38
You are asked to interconnect two of your company's data centers across the IP backbone. Both data centers have their own unique IP space and do not require any bridging. In this scenario, which two actions would accomplish this task? (Choose two.)
  • A. Configure a Type 2 EVPN route for each unique prefix.
  • B. Configure peering for EVPN between all leaf nodes within each data center.
  • C. Configure peering for EVPN between border leaf nodes in each data center.
  • D. Configure a Type 5 EVPN route for each unique prefix.
* Interconnecting Data Centers:
* The scenario requires interconnecting two data centers with unique IP spaces across an IP backbone. The key point is that bridging is not required, so Layer 3 routing methods must be used.
* EVPN Configuration:
* Option B:Establishing EVPN peering between the border leaf nodes in each data center is the most appropriate solution as it allows for exchanging routing information between the two data centers. This ensures that the routes are properly distributed without the need for L2 bridging.
* Option C:Configuring Type 5 EVPN routes is necessary for advertising IP prefixes (Layer 3 routes) across the EVPN. Type 5 routes allow for the exchange of IP prefixes between the two data centers, enabling the necessary routing functionality without the need for bridging.
Conclusion:
* Option B:Correct-Peering between border leaf nodes sets up the necessary route exchange between data centers.
* Option C:Correct-Type 5 EVPN routes are essential for exchanging Layer 3 prefixes between data centers.
NEW QUESTION # 39
Given the configuration shown in the exhibit, why has the next hop remained the same for the EVPN routes advertised to the peer 203.0.113.2?
  • A. The export policy is incorrectly configured.
  • B. The vpn-apply-export parameter must be applied to this peer.
  • C. EVPN routes cannot have the next hop changed.
  • D. The vrf-export parameter must be applied.
The vpn-apply-export parameter must be applied to this peer: In the given configuration, the policy statement CHANGE_NHis defined to change the next-hop IP for routes. However, the vpn- apply-exportparameter is missing, which is necessary for applying export policies to routes associated with a particular VPN. Without this parameter, the export policy does not apply to the EVPN routes, and thus the next-hop remains unchanged.
NEW QUESTION # 40
Exhibit.
You are troubleshooting an IP fabric (or your data center. You notice that your traffic is not being load balanced to your spine devices from your leaf devices. Referring to the configuration shown in the exhibit, what must be configured to solve this issue?
  • A. The multipast multiple -as configuration must be configured for each peer in the BGP spine group.
  • B. The load-balance policy must have a from statement that matches on protocol bgp.
  • C. The load-balance policy must be applied as an export policy to your BGP
  • D. The load-balance policy must be applied to the forwarding table under the routing-options hierarchy.
Step 1: Understand the Configuration in the Exhibit
The exhibit provides three configuration snippets from a leaf device (user@leaf#):
* Policy Options:
user@leaf# show policy-options
policy-statement load-balance {
term 1 {
then {
load-balance per-packet;
* A policy named load-balance is defined, which applies the load-balance per-packet action. In Juniper terminology, per-packet actually means per-flow load balancing (a common point of confusion). This policy is intended to enable load balancing across multiple paths.
* Routing Options:
user@leaf# show routing-options
router-id 192.168.100.11;
autonomous-system 65100;
* The router ID is set to 192.168.100.11, and the autonomous system (AS) number is 65100. There' s no mention of applying the load-balance policy here, which is a clue to the issue.
* BGP Configuration:
user@leaf# show protocols
bgp {
group spine {
type external;
export direct;
local-as 65003;
multipath {
multiple-as;
neighbor 172.16.1.5 {
peer-as 65001;
neighbor 172.16.1.17 {
peer-as 65002;
* BGP is configured with an external group spine, where the leaf device (local AS 65003) peers with spine devices (AS 65001 and 65002).
* The multipath multiple-as statement is enabled, which allows BGP to install multiple paths for the same prefix in the routing table, even if the paths come from different AS numbers. This is a prerequisite for load balancing in a multi-AS environment like an IP fabric.
* The export direct policy is applied, which likely exports directly connected routes to the spine devices.
Step 2: Identify the Problem
The issue is that traffic from the leaf to the spine devices is not being load-balanced, despite the presence of a load-balance policy and BGP multipath. For load balancing to work in this scenario:
* BGP multipath ensures multiple paths are installed in the routing table.
* The load-balance per-packet policy is meant to distribute traffic across those paths.
* However, the load-balance policy is defined but not applied anywhere in the configuration shown. For load balancing to take effect, the policy must be applied in the correct context.
Step 3: Evaluate the Options
Let's go through each option to determine the correct solution:
* A. The load-balance policy must be applied to the forwarding table under the routing-options hierarchy.
* In Junos, to enable load balancing across multiple paths for forwarding, the load-balance policy must be applied at the forwarding table level. This is done under the routing-options hierarchy using the forwarding-table export statement. For example:
set routing-options forwarding-table export load-balance
* This ensures that the load-balancing policy is applied to the forwarding table, allowing traffic to be distributed across multiple equal-cost paths installed by BGP.
* B. The multipath multiple-as configuration must be configured for each peer in the BGP spine group.
* The multipath multiple-as statement is already configured under the spine group, and it applies to all neighbors in that group (172.16.1.5 and 172.16.1.17). There's no need to configure it per peer, as the group-level configuration is sufficient. This option is incorrect because the required setting is already in place.
* C. The load-balance policy must be applied as an export policy to your BGP.
* Applying the load-balance policy as a BGP export policy (e.g., export load-balance under the BGP group) would affect the routes advertised to the spine devices. However, the load-balance per-packet action is a forwarding action, not a route advertisement action. Applying it as a BGP export policy would not achieve the desired load balancing for traffic forwarding and is incorrect.
* D. The load-balance policy must have a from statement that matches on protocol bgp.
* The load-balance policy currently applies the load-balance per-packet action unconditionally (no from statement). Adding a from protocol bgp condition would make the policy apply only to BGP routes, but this is unnecessary in this context. The policy needs to be applied to the forwarding table to affect traffic, not modified with a from statement. This option doesn't address the core issue of applying the policy.
Step 4: Determine the Correct Answer
The key issue is that the load-balance policy is defined but not applied. For load balancing to work, it must be applied to the forwarding table under routing-options. This matchesOption A:
Step 5: Provide Official Juniper Documentation Reference
Since I don't have direct access to Juniper's proprietary documents, I can provide an explanation based on standard Junos documentation practices and publicly available resources, such as the Juniper TechLibrary, which is the official source for Junos configuration guides.
In Juniper's official documentation, specifically in theJunos OS Routing Protocols and Policies Configuration Guide, the process for enabling load balancing is described as follows:
* Load Balancing in Junos: To enable per-flow load balancing across multiple paths, you must define a policy with the load-balance per-packet action and apply it to the forwarding table. The relevant configuration hierarchy is:
routing-options {
forwarding-table {
export <policy-name>;
* Explanation from Documentation: The load-balance per-packet action (which performs per-flow balancing) requires the policy to be applied at the forwarding-table level to influence how traffic is distributed across multiple paths in the forwarding table. Without this, even if BGP installs multiple paths (via multipath), the forwarding engine will not load-balance traffic.
This aligns with the JNCIP-DC exam objectives, which include understanding how to configure and troubleshoot load balancing in an IP fabric, such as applying policies for traffic distribution.
NEW QUESTION # 41
You are implementing seamless stitching between two data centers and have a proposedconfiguration for a border leafdevice.
In this scenario, which two statements are correct? {Choose two.)
  • A. The ESI must match in both data centers.
  • B. The translation-vni must match in both data centers.
  • C. The translation-vni must be different in each data center.
  • D. The ESI must be different in each data center.
* Understanding Seamless Stitching:
* Seamless stitching is used in EVPN to interconnect two data centers, allowing for consistent Layer 2 and Layer 3 connectivity across them. This is often achieved by translating VNIs (Virtual Network Identifiers) between the data centers.
* Translation-VNI:
* Option B:The translation VNI must be different in each data center to ensure that traffic can be correctly routed and distinguished as it crosses between the data centers. This differentiation helps to maintain the integrity of the traffic flows and prevents any potential overlap or conflict in VNIs.
* Ethernet Segment Identifier (ESI):
* Option D:The ESI must match in both data centers to ensure that the same Ethernet segment (which could be multihomed) is recognized consistently across the data centers. Matching ESIs are crucial for maintaining a unified view of the Ethernet segment across the interconnected fabric.
Conclusion:
* Option B:Correct-Translation VNIs must be unique to each data center for proper traffic distinction.
* Option D:Correct-Matching ESIs are necessary to maintain consistent Ethernet segment identification across both data centers.
NEW QUESTION # 42
As most of the people tend to use express delivery to save time, our JN0-683 preparation exam will be sent out within 5-10 minutes after purchasing. As long as you pay at our platform, we will deliver the relevant exam materials to your mailbox within the given time. Our company attaches great importance to overall services, if there is any problem about the delivery of JN0-683 Exam Materials: Data Center, Professional (JNCIP-DC), please let us know, a message or an email will be available.
High JN0-683 Quality: https://www.prep4sureguide.com/JN0-683-prep4sure-exam-guide.html
BTW, DOWNLOAD part of Prep4sureGuide JN0-683 dumps from Cloud Storage: https://drive.google.com/open?id=1OaEIcSxfcJZCyM18lkaJrHuPGkybSTiR
Posted at 1/26/2026 22:18:57        Only Author  2#
Im very thankful for your article, it left a lasting impression. This XSIAM-Analyst reliable exam cram helped me achieve career growth with a promotion and salary raise. Its free now for everyone. Wishing you success!
Posted at 1/31/2026 23:32:10        Only Author  3#
This is such an uplifting article, thanks for sharing! Free Latest C_BCSBS_2502 exam topics resourcesunlock promotions and salary increases today!
