Oracle 1z0-1060-25 Test Vce, 1z0-1060-25 Practice Tests
Posted at 1/9/2026 23:30:18
P.S. Free 2026 Oracle 1z0-1060-25 dumps are available on Google Drive shared by DumpsActual: https://drive.google.com/open?id=1V_9IOlNWK6FYNckxJrXyPwhLy4cslziD
To upgrade skills, hundreds of candidates attempt the Oracle Accounting Hub Cloud 2025Implementation Professional (1z0-1060-25) certification exam and try to be smart and more efficient than the rest. In that case, they are now finding ways by which they can get help to crack the Oracle Accounting Hub Cloud 2025Implementation Professional (1z0-1060-25) certification exams. Let's discuss the sources that can prove to be a major help if you are planning to take the exam.
We aim to provide our candidates with real Oracle vce dumps and learning materials to help you pass real exam with less time and money. Our valid 1z0-1060-25 top questions are written by our IT experts who are specialized in 1z0-1060-25 Study Guide for many years and check the updating of 1z0-1060-25 vce files everyday to make sure the best preparation material for you.
1z0-1060-25 Practice Tests - 1z0-1060-25 Latest Test AnswersYou will have good command knowledge with the help of our 1z0-1060-25 study materials. The certificate is of great value in the job market. Our 1z0-1060-25 learning prep can exactly match your requirements and help you pass 1z0-1060-25 exams and obtain certificates. As you can see, our products are very popular in the market. Time and tides wait for no people. Take your satisfied 1z0-1060-25 Actual Test guide and start your new learning journey. After learning our 1z0-1060-25 learning materials, you will benefit a lot. Being brave to try new things, you will gain meaningful knowledge.
Oracle Accounting Hub Cloud 2025Implementation Professional Sample Questions (Q53-Q58):NEW QUESTION # 53
You are assigned to troubleshoot a Create Accounting error.
Which is the first step that you need to perform to use the Diagnostics Framework feature?
- A. Run the Accounting Event Diagnostic report.
- B. Run Create Accounting again to generate journal entries for the events that ended in error.
- C. Set the 'SLA: Enable Diagnostic' profile option.
- D. Submit the Accounting Event Diagnostic process.
NEW QUESTION # 54
Your client, a banking organization, is currently using different transaction systems to take care of various types of loans, including vehicle loans, personal loans, education loans, and housing loans.
You recently uploaded the source system data that includes Loan Origination, Loan Interest Accrual, Loan Scheduled Payment, Loan Interest Adjusted, Loan Late Payment, and Loan Charge Off as event types.
Now the customer has asked you to add another transaction type called Loan Interest Accrual Reversal.
What should be your response to the customer?
- A. Loan Interest Accrual Reversal can be added as a new event type from the user interface.
- B. A new transaction type cannot be added after the source system is registered.
- C. Loan Interest Accrual Reversal can be added as a new event type by using the update spreadsheet template.
- D. The source system should be registered again by including the Loan Interest Accrual Reversal event type.
NEW QUESTION # 55
Your client has operations in both the US and the UK, and they currently use a third-party billing system to process transactions like Complete an Invoice, Record a Payment, Record Late Charges, and Recognize Revenue. You are part of the implementation team of the Accounting Hub solution, and they request you to generate a dynamic description based on the following scenario:
"When Invoice Date is greater than or equal to 1st January 2018, concatenate Project Number and Invoice Number else concatenate Customer Name and Invoice Number." In which format would you enter the date in the user-defined formula to achieve this requirement?
- A. YY-MON-DD
- B. YYYY-MON-DD
- C. DD-MON-YY
- D. DD-MON-YYYY
NEW QUESTION # 56
Your customer has four external systems to manage their home loan, auto loan, consumer loan, and personal loan businesses. They have decided to implement Accounting Hub to import the transactional data for generating journal entries from these source systems. While evaluating different possibilities, they ask you to provide your suggestion on sharing accounting rules for these external systems.
Which implementation setup allows the sharing of accounting rules for all four external systems?
- A. One subledger for all four source systems
- B. Two subledgers, one for home loan and auto loan and another for consumer loan and personal loan
- C. Three subledgers, one for home loan and auto loan, the second for consumer loan, and the third for personal loan
- D. Four subledgers, one for each source system
NEW QUESTION # 57
Challenge 2: Manage Account Rule
TASK
Create Account Rule with 3 priorities
Name of Account Rule: Revenue Account
Subledger Application: AHC Billing
Process Category: AHC Billing
Event Class: AHC Billing
Event Type: Customer Billing, Customer Pay In, Customer Refund, Customer Settlement See the Explanation below for all the solution.
Step-by-Step Guide to Create an Account Rule with 3 Priorities in Oracle Fusion Step 1: Navigate to Manage Account Rules
* Log into Oracle Fusion with appropriate privileges for Subledger Accounting.
* Go toSetup and Maintenance.
* In theFunctional Setup Manager (FSM), navigate to:
* Financials
* Subledger Accounting
* Manage Account Rules.
Step 2: Create the Account Rule
* ClickCreateto add a newAccount Rule.
* Enter the following details:
* Name: Revenue Account
* Subledger Application: AHC Billing
* Process Category: AHC Billing
* Event Class: AHC Billing
* Event Type: Customer Billing, Customer Pay In, Customer Refund, Customer Settlement
* Rule Type: Account
* ClickSave, then proceed to definePriorities.
Step 3: Define Three Priorities for the Revenue Account Rule
Now, define three priorities for determining the revenue account:
Priority 1: Derived from Transaction Type
* ClickAdd Rowto definePriority 1.
* SetPriority Orderas1.
* DefineCondition:
* IfTransaction Type = "Customer Billing", thenAccount = 4000 (Revenue Account)
* Source Type: UseTransaction Typeas the basis.
* ClickSave.
Priority 2: Derived from Customer
* ClickAdd Rowto definePriority 2.
* SetPriority Orderas2.
* DefineCondition:
* IfCustomer Category = "Wholesale", thenAccount = 4010 (Wholesale Revenue)
* Source Type: UseCustomer Categoryas the basis.
* ClickSave.
Priority 3: Default Revenue Account
* ClickAdd Rowto definePriority 3.
* SetPriority Orderas3.
* DefineCondition:
* Default Revenue Account = 4999(for any other transactions)
* Source Type: UseConstant Value.
* ClickSave.
Step 4: Validate and Assign the Account Rule
* ClickValidateto ensure the rule has no errors.
* Navigate toManage Journal Entry Rule Sets.
* Locate theAHC BillingJournal Entry Rule Set.
* Assign the newly createdRevenue Account Ruleto theappropriate Journal Line Rule(such as Revenue or Income).
* ClickSave and Close.
Step 5: Test the Account Rule
* Go toSubledger Accounting > Accounting Entries.
* Generate accounting for different transactions:
* Customer Billingshould deriveAccount 4000.
* Wholesale Customer Billingshould deriveAccount 4010.
* Other transactionsshould deriveAccount 4999.
* Review and confirm that the correct accounts are assigned.
NEW QUESTION # 58
Our Oracle Exam Questions greatly help Oracle Accounting Hub Cloud 2025Implementation Professional (1z0-1060-25) exam candidates in their preparation. Our Oracle 1z0-1060-25 practice questions are designed and verified by prominent and qualified Oracle Accounting Hub Cloud 2025Implementation Professional (1z0-1060-25) exam dumps preparation experts. The qualified Oracle Accounting Hub Cloud 2025Implementation Professional (1z0-1060-25) exam questions preparation experts strive hard and put all their expertise to ensure the top standard and relevancy of 1z0-1060-25 exam dumps topics.
1z0-1060-25 Practice Tests: https://www.dumpsactual.com/1z0-1060-25-actualtests-dumps.html
Oracle 1z0-1060-25 Test Vce This innovative tool provides them with lots of practice tests that are replica of the actual exam, Oracle 1z0-1060-25 Test Vce Compared to other training dumps, our exam dumps will definitely have high hit rate, The acquiring of 1z0-1060-25 braindumps files requires certain level of expertise, skills and experience, but our study materials will ensure you pass exam in a smartest and effective way, Oracle 1z0-1060-25 Test Vce Moreover, to resolve your issues and queries related to our products, we offer 24/7 customer support for you.
You've probably thought about a number of ways you can do your job better, 1z0-1060-25 Downloading Audio and Video Files, This innovative tool provides them with lots of practice tests that are replica of the actual exam.
1z0-1060-25 Test Vce 100% Pass | Latest Oracle Oracle Accounting Hub Cloud 2025Implementation Professional Practice Tests Pass for sureCompared to other training dumps, our exam dumps will definitely have high hit rate, The acquiring of 1z0-1060-25 braindumps files requires certain level of expertise, skills and experience, 1z0-1060-25 Latest Test Answers but our study materials will ensure you pass exam in a smartest and effective way.
Moreover, to resolve your issues and queries related to our products, we offer 24/7 customer support for you, By using 1z0-1060-25 exam dumps, you just have to spend 20-30 hours in preparation.
- Free PDF Quiz 1z0-1060-25 - Oracle Accounting Hub Cloud 2025Implementation Professional Test Vce 🤸 Search for “ 1z0-1060-25 ” and download it for free immediately on 【 [url]www.vce4dumps.com 】 ☕1z0-1060-25 100% Exam Coverage[/url]
- Dumps 1z0-1060-25 Download 🕐 1z0-1060-25 Actual Test Answers 🏅 Study Materials 1z0-1060-25 Review 🌶 Download “ 1z0-1060-25 ” for free by simply searching on ▛ [url]www.pdfvce.com ▟ 🛀Latest 1z0-1060-25 Study Materials[/url]
- 1z0-1060-25 Test Vce - Realistic Oracle Accounting Hub Cloud 2025Implementation Professional Practice Tests Free PDF 🦰 Download ✔ 1z0-1060-25 ️✔️ for free by simply searching on ▶ [url]www.pdfdumps.com ◀ 🍭1z0-1060-25 Passguide[/url]
- 1z0-1060-25 Test Vce - Realistic Oracle Accounting Hub Cloud 2025Implementation Professional Practice Tests Free PDF 🤎 Open website ➥ [url]www.pdfvce.com 🡄 and search for 《 1z0-1060-25 》 for free download 💖Online 1z0-1060-25 Lab Simulation[/url]
- Exam 1z0-1060-25 Flashcards 🤞 Exam 1z0-1060-25 Flashcards 🎠 1z0-1060-25 Valid Test Cram 👏 Search for ☀ 1z0-1060-25 ️☀️ and download it for free immediately on { [url]www.dumpsmaterials.com } 🧉1z0-1060-25 Passguide[/url]
- 1z0-1060-25 Test Vce | 100% Free 1z0-1060-25 Practice Tests 😼 Download ➡ 1z0-1060-25 ️⬅️ for free by simply searching on “ [url]www.pdfvce.com ” 💱1z0-1060-25 Questions[/url]
- 1z0-1060-25 Test Vce | 100% Free 1z0-1060-25 Practice Tests 🥕 Immediately open ➠ [url]www.vceengine.com 🠰 and search for [ 1z0-1060-25 ] to obtain a free download 🛸1z0-1060-25 Questions[/url]
- 1z0-1060-25 Quiz Prep Makes 1z0-1060-25 Exam Easy - Pdfvce 🎶 Search on ▷ [url]www.pdfvce.com ◁ for ▷ 1z0-1060-25 ◁ to obtain exam materials for free download ✔️1z0-1060-25 Actual Test Answers[/url]
- 1z0-1060-25 100% Exam Coverage 🍾 1z0-1060-25 Actual Test Answers 🐐 Study Materials 1z0-1060-25 Review 🗺 Download ➠ 1z0-1060-25 🠰 for free by simply entering ➡ [url]www.easy4engine.com ️⬅️ website 🥬1z0-1060-25 100% Exam Coverage[/url]
- 1z0-1060-25 Quiz Prep Makes 1z0-1060-25 Exam Easy - Pdfvce 📐 Open 《 [url]www.pdfvce.com 》 and search for { 1z0-1060-25 } to download exam materials for free 🦝1z0-1060-25 Valid Test Pass4sure[/url]
- 1z0-1060-25 Test Vce | 100% Free 1z0-1060-25 Practice Tests 🚀 Open ➡ [url]www.examcollectionpass.com ️⬅️ enter ➠ 1z0-1060-25 🠰 and obtain a free download 🔌1z0-1060-25 Official Cert Guide[/url]
- anonup.com, www.quora.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, pianowithknight.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.zylt.org, ar-ecourse.eurospeak.eu, www.kickstarter.com, www.stes.tyc.edu.tw, Disposable vapes
2026 Latest DumpsActual 1z0-1060-25 PDF Dumps and 1z0-1060-25 Exam Engine Free Share: https://drive.google.com/open?id=1V_9IOlNWK6FYNckxJrXyPwhLy4cslziD
