[General] Answers Salesforce AP-202 Real Questions & AP-202 Reliable Test Questions
89
【General】 Answers Salesforce AP-202 Real Questions & AP-202 Reliable Test Questions
Posted at 2/1/2026 23:54:52      View:118 | Replies:0        Print      Only Author   [Copy Link] 1#
One of our outstanding advantages is our high passing rate, which has reached 99%, and much higher than the average pass rate among our peers. Our high passing rate explains why we are the top AP-202 prep guide in our industry. One point does farm work one point harvest, depending on strength speech! The source of our confidence is our wonderful AP-202 exam questions. Passing the exam won’t be a problem as long as you keep practice with our AP-202 Study Materials about 20 to 30 hours. Considered many of the candidates are too busy to review, our experts designed the AP-202 question dumps in accord with actual examination questions, which would help you pass the exam with high proficiency.
Perhaps you agree that strength is very important, but there are doubts about whether our AP-202 study questions can really improve your strength. It does not matter, we can provide you with a free trial version of our AP-202 exam braindumps. You can free downlod the demos of our AP-202 learning prep easily on our website, and there are three versions according to the three versions of ourAP-202 practice engine. It is really as good as we say, you can experience it yourself.
AP-202 Reliable Test Questions, Official AP-202 Study GuideHave you learned Dumpkiller Salesforce AP-202 exam dumps? Why do the people that have used Dumpkiller dumps sing its praises? Do you really want to try it whether it have that so effective? Hurry to click Dumpkiller.com to download our certification training materials. Every question provides you with demo and if you think our exam dumps are good, you can immediately purchase it. After you purchase AP-202 Exam Dumps, you will get a year free updates. Within a year, only if you would like to update the materials you have, you will get the newer version. With the dumps, you can pass Salesforce AP-202 test with ease and get the certificate.
Salesforce B2B Commerce for Developers Accredited Professional Sample Questions (Q154-Q159):NEW QUESTION # 154
What are two common and maintainable ways the content layout of a Lightning Web Component can be implemented?
  • A. Applying SLDS classes to internal elements
  • B. Spreading layout styles across several separate components
  • C. Styling the :host pseudo-element (or other elements) via the CSS file
  • D. Using inline styles
For maintainable and scalable Lightning Web Component development, it's recommended to style components by targeting the :host pseudo-element in the component's CSS file and by applying Salesforce Lightning Design System (SLDS) classes to internal elements. These practices ensure consistent styling that aligns with Salesforce's design standards and provides a clear separation of concerns between component structure and styling.
NEW QUESTION # 155
What is likely to happen if a developer leaves debug mode turned on in an environment?
  • A. The org will turn off debug mode after 72 hours
  • B. A banner will be displayed to the user indicating that the org is in debug mode
  • C. The performance of the org will become slower each day
  • D. The user will begin getting JavaScript limit exceptions
If a developer leaves debug mode turned on in an environment, the user will begin getting JavaScript limit exceptions. Debug mode is a setting that enables more detailed logging and error reporting for Lightning web components. However, it also increases the size and complexity of the JavaScript code that is delivered to the browser, which can cause performance issues and JavaScript limit exceptions. The JavaScript limit exceptions are errors that occur when the browser reaches its maximum capacity for executing JavaScript code, such as memory heap size or script execution time. The performance of the org will not become slower each day, as debug mode only affects the client-side performance, not the server-side performance. The org will not turn off debug mode after 72 hours, as debug mode is a persistent setting that can only be changed manually by an administrator. A banner will not be displayed to the user indicating that the org is in debug mode, as debug mode is a transparent setting that does not affect the user interface. Salesforce Lightning Web Components Developer Guide: Debug Your Code, Lightning Web Components Developer Guide: JavaScript Limit Exceptions
NEW QUESTION # 156
A developer has just deployed a new Lightning Web Component to an authorized org. What should the developer do next to use the new component on apage?
  • A. Create a Metadata API (MDAPI) conversion file with the Command Line interface (CLI) then go to the page and adjust the positioning.
  • B. Navigate 3 to the Page, Click on the "Custom Component Editor,' Click "Publish" on the new component in the list and adjust the positioning.
  • C. Go to the page, edit it, and drag the new component onto the page.
  • D. Go to "Deploy LWC" in Setup.
After deploying a new Lightning Web Component (LWC) to an org, the typical next step to use the component on a page involves navigating to that page, entering the edit mode (usually through App Builder or a similar interface), and then dragging the new component from the components palette onto the desired location on the page. This process is consistent with Salesforce's modular design approach, allowing for easy integration and configuration of components within the Salesforce ecosystem.
NEW QUESTION # 157
What are two guidelines for logging that are used within the core Salesforce B2B Commerce product? (2 answers)
  • A. No calls to ccrz.ccLog can be made before cc_CallContext.initRemoteContext is executed.
  • B. Items or data within computational intensive loops shouldbe logged.
  • C. It is okay to log any data on the server that is already logged on the client side.
  • D. The close method of ccrz.ccLog must be called at the end of the remote action.
Answer: A,D
Two guidelines for logging that are used within the core Salesforce B2B Commerce product are:
The close method of ccrz.ccLog must be called at the end of the remote action. This method will flush the log messages to the browser console or to a custom object, depending on the logging mode. If this method is not called, the log messages may not be displayed or saved properly.
No calls to ccrz.ccLog can be made before cc_CallContext.initRemoteContext is executed. This method will initialize the call context object, which contains information such as the current user, cart, storefront, and configuration settings. These information are required for logging, so calling ccrz.ccLog before initializing the call context will result in an error. Salesforce B2B Commerce and D2C Commerce Developer Guide,Logging
NEW QUESTION # 158
Which two usages of ccLog should be avoided in Salesforce B2B Commerce? (2 answers)
  • A. crz.ccLog.log(System.LoggingLevel.WARN, 'D:something', 'Something unexpected occurred: The data we were expecting for pl was not there,')
  • B. crz.ccLog.log(System.LoggingLevel.DEBUG, 'D:myOrder', myOrder), where myOrder is an order object
  • C. crz.ccLog.log(System.LoggingLevel.DEBUG, 'D:myOrderList', myOrderList), where myOrderList is a list of orders
  • D. ccrz.ccLog.log(System.LoggingLevel.ERROR, 'D:something', myCallToGetMessage(pl) ), where myCallToGetMessage(pl) is a method invocation
You should avoid using ccLog in two scenarios. First, you should avoid using ccLog with System.LoggingLevel.ERROR when passing in a method invocation as the third parameter, such as ccrz.ccLog.log(System.LoggingLevel.ERROR, 'D:something', myCallToGetMessage(pl) ). This is because if an exception occurs within the method invocation, it will not be caught by ccLog and will cause an unhandled exception on the page. Instead, you should use a try-catch block around the method invocation and log the exception separately. Second, you should avoid using ccLog with System.LoggingLevel.DEBUG when passing in a large collection or object as the third parameter, such as ccrz.ccLog.log(System.LoggingLevel.DEBUG, 'D:myOrderList', myOrderList), where myOrderList is a list of orders. This is because logging large objects can cause performance issues and consume a lot of heap space. Instead, you should use a loop to log only the relevant fields or properties of the object or collection. You can use ccLog with System.LoggingLevel.WARN when passing in a string as the third parameter, such as ccrz.ccLog.log(System.LoggingLevel.WARN, 'D:something', 'Something unexpected occurred: The data we were expecting for pl was not there,'). This is a valid use case for logging a warning message. You can also use ccLog with System.LoggingLevel.DEBUG when passing in a small object as the third parameter, such as ccrz.ccLog.log(System.LoggingLevel.DEBUG, 'D:myOrder', myOrder), where myOrder is an order object. This is acceptable as long as the object is not too large or complex. Salesforce [B2B Commerce Developer Guide: Logging]
NEW QUESTION # 159
As to this fateful exam that can help you or break you in some circumstances, our company made these AP-202 practice materials with accountability. We understand you can have more chances being accepted by other places and getting higher salary or acceptance. Our AP-202 Training Materials are made by our responsible company which means you can gain many other benefits as well. You can enjoy free updates of AP-202 practice guide for one year after you pay for our AP-202 training questions.
AP-202 Reliable Test Questions: https://www.dumpkiller.com/AP-202_braindumps.html
Our study materials can give the user confidence and strongly rely on feeling, lets the user in the reference appendix not alone on the road, because we are to accompany the examinee on AP-202 Exam Sims exam, candidates need to not only learning content of teaching, but also share his arduous difficult helper, so believe us, we are so professional company, There is no doubt that we will never miss any key points in our AP-202 training materials.
Important Considerations When Using Movies and Sounds, The change AP-202 in mindset required of graphic designers in exploiting visual components" is explained clearly and practically.
Our study materials can give the user confidence and strongly New AP-202 Test Online rely on feeling, lets the user in the reference appendix not alone on the road, because we are to accompany the examinee on AP-202 Exam Sims exam, candidates need to not only learning content of teaching, but also share his arduous difficult helper, so believe us, we are so professional company.
100% Pass Pass-Sure Salesforce - AP-202 - Answers B2B Commerce for Developers Accredited Professional Real QuestionsThere is no doubt that we will never miss any key points in our AP-202 training materials, In doing so, you never worry to waste your money and have a free trial of our AP-202 exam quiz to know more about products and then you can choose whether buy AP-202 exam braindumps or not.
Just come and try, For those who prefer a traditional reading experience, Dumpkiller B2B Commerce for Developers Accredited Professional (AP-202) PDF questions also provides the option to print the AP-202 questions, and read it in a convenient paper format.
