Complete ACP-120 Exam Dumps, Exam ACP-120 Topics
Posted at 1/12/2026 23:57:25
DOWNLOAD the newest It-Tests ACP-120 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1U7TnxJ8hUno6ma3uSXVZe4RSb7tcMe1j
There are different versions of our ACP-120 learning materials: PDF version, Soft version and APP version. Whether you like to study on the computer or like to read paper materials, our ACP-120 learning materials can meet your needs. If you are used to reading paper study materials for most of the time, you can eliminate your concerns. Our ACP-120 Exam Quiz takes full account of customers' needs in this area. Because our versions of the ACP-120 learning material is available for customers to study, so that your free time is fully utilized, and you can often consolidate your knowledge.
ATLASSIAN ACP-120 (Jira Cloud Administrator) Certification Exam is a rigorous exam that requires a solid understanding of Jira Cloud administration. ACP-120 exam consists of 68 multiple-choice questions that must be completed within 180 minutes. ACP-120 Exam is designed to test an individual’s knowledge and skills across a range of Jira Cloud administration topics.
Exam ATLASSIAN ACP-120 Topics - Test ACP-120 OnlineMany students did not perform well before they use Jira Cloud Administrator actual test. They did not like to study, and they disliked the feeling of being watched by the teacher. They even felt a headache when they read a book. There are also some students who studied hard, but their performance was always poor. Basically, these students have problems in their learning methods. ACP-120 prep torrent provides students with a new set of learning modes which free them from the rigid learning methods. You can be absolutely assured about the high quality of our products, because the content of Jira Cloud Administrator actual test has not only been recognized by hundreds of industry experts, but also provides you with high-quality after-sales service.
To take the ACP-120 exam, candidates should have a minimum of six months of experience in administering Jira Cloud. They should also possess a solid understanding of Jira Cloud's features, such as project and issue management, workflows, and customizations. ACP-120 Exam includes 60 multiple-choice questions that must be completed within 2 hours. Candidates who successfully pass the exam will receive an ACP-120 certification, which is valid for two years.
ATLASSIAN Jira Cloud Administrator Sample Questions (Q66-Q71):NEW QUESTION # 66
A company-managed project uses a single issue type. When must a second issue type be added to the project?
- A. When adding a new resolution
- B. When adding a new status
- C. When adding a new custom field
- D. When adding a new security level
- E. When adding a new workflow
Answer: E
In a company-managed project with a single issue type, adding a second issue type is necessary when a configuration requires issue type-specific behavior that cannot be applied to the existing issue type. The requirement that necessitates a second issue type iswhen adding a new workflow(Option B), as different workflows for different issue types require separate issue types to be mapped in the project's workflow scheme.
* Explanation of the Correct Answer (Option B):
* In a company-managed project, aworkflow schememaps workflows to issue types. If the project currently uses a single issue type with one workflow, adding a new workflow (e.g., for a different process) requires a second issue type to associate with the new workflow. Without a second issue type, the new workflow cannot be applied, as a single issue type can only be mapped to one workflow in a given scheme. Adding a second issue type allows the project to use both the existing workflow (for the current issue type) and the new workflow (for the new issue type).
* Exact Extract from Documentation:
Configure workflow schemes
A workflow scheme maps workflows to issue types in a company-managed project.
To use a new workflow:
* Create or select a new workflow inSettings > Issues > Workflows.
* Update the project's workflow scheme inProject settings > Workflowsto assign the new workflow to a specific issue type.Note: To use multiple workflows in a project, you must have multiple issue types, as each issue type can only be associated with one workflow in a scheme.(Source: Atlassian Support Documentation, "Configure workflow schemes")
* Why This Fits: Adding a new workflow requires a second issue type to map the new workflow in the workflow scheme, as a single issue type cannot use multiple workflows, making Option B the correct answer.
* Why Other Options Are Incorrect:
* When adding a new resolution (Option A):
* Resolutionsare global settings (Settings > Issues > Resolutions) that apply to all issues in a project, regardless of issue type. Adding a new resolution does not require a new issue type, as resolutions are managed at the workflow level and can be used by the existing issue type.
* Extract from Documentation:
Resolutions are global and apply to all issue types. Adding a new resolution does not require new issue types.
(Source: Atlassian Support Documentation, "Manage resolutions in Jira Cloud")
* When adding a new status (Option C):
* A newstatuscan be added to the existing workflow for the single issue type without needing a new issue type. Statuses are part of a workflow, and the existing issue type can use the updated workflow with the new status.
Statuses are added to workflows, not issue types. A new status can be used by the existing issue type's workflow.
(Source: Atlassian Support Documentation, "Configure advanced work item workflows")
* When adding a new custom field (Option D):
* A newcustom fieldcan be applied to the existing issue type via itscustom field contextor screen configuration. It does not require a new issue type, as fields can be shared across or restricted to specific issue types within the same project.
Custom fields can be added to existing issue types via contexts or screens. New issue types are not required.
(Source: Atlassian Support Documentation, "Manage custom fields in Jira Cloud")
* When adding a new security level (Option E):
* A newsecurity levelin the issue security scheme applies to all issues in the project, regardless of issue type. It does not require a new issue type, as security levels are project- wide and not tied to specific issue types.
Security levels apply to all issues in a project and are not issue type-specific. Adding a new level does not require new issue types.
(Source: Atlassian Support Documentation, "Configure issue security schemes")
* Additional Notes:
* Steps to add a second issue type for a new workflow:
* Add a new issue type to the project's issue type scheme inProject settings > Issue types.
* Update the workflow scheme inProject settings > Workflowsto map the new workflow to the new issue type.
* These changes requireJira administratorprivileges.
* The need for a second issue type arises specifically from the workflow scheme's one-to-one mapping of workflows to issue types.
Atlassian Support Documentation:Configure workflow schemes
Atlassian Support Documentation:Manage resolutions in Jira Cloud
Atlassian Support Documentation:Configure advanced work item workflows
Atlassian Support Documentation:Manage custom fields in Jira Cloud
Atlassian Support Documentation:Configure issue security schemes
NEW QUESTION # 67
You are setting up a new Jira instance and three new projects with shared configuration. There are many managers at the company and you need to structure their permissions accordingly.
Which requirement can only be met with a Managers project role?
- A. Any manager should be able to view the development tools in any project.
- B. Different managers need to delete issues in different projects.
- C. Only some managers must be selectable from a custom field, depending on the project.
- D. Managers need to be able to create shared dashboards.
- E. Only managers who are project leads can see the restricted security level in their own projects.
Answer: E
NEW QUESTION # 68
You performed the following steps:
* Created a new filter with the JQL query project IN projectsWhereUserHasRole("Sales")
* Created a filter subscription for the filter and set the recipients to the Sales group.
Leila is a member of the Sales group. Which issues will Leila receive in her subscription?
- A. Issues from projects where Leila is in the Sales role
- B. Issues assigned to anyone in the Sales group
- C. Issues from projects where Leila is in the Sales group
- D. Issues assigned to anyone in the Sales role
The JQL query project IN projectsWhereUserHasRole("Sales") filters for issues in projects wherethe user running the query has theSalesproject role. Since Leila is a member of theSales groupand receives the filter subscription, the issues she receives are those from projects whereLeila is in the Sales role(Option A).
* Explanation of the Correct Answer (Option A):
* The JQL functionprojectsWhereUserHasRole("Sales")returns a list of projects where the user executing the query is a member of theSalesproject role. The query project IN projectsWhereUserHasRole("Sales") selects all issues from those projects.
* Leila, as a member of theSales group, receives the filter subscription. When the subscription runs for Leila, the JQL query is evaluated in her context, meaning it returns issues from projects where Leilahas theSalesproject role.
Advanced searching - functions reference
TheprojectsWhereUserHasRole("role")function returns projects where the user running the query is a member of the specified project role.
Example:
* project IN projectsWhereUserHasRole("Sales") returns issues from projects where the user has theSalesproject role.Note: For filter subscriptions, the query is executed in the context of each recipient, so results depend on the recipient's role membership.(Source: Atlassian Support Documentation, "Advanced searching - functions reference")
* Why This Fits: The filter subscription runs the JQL query for Leila, returning issues from projects whereLeila is in the Sales role, making Option A the correct answer.
* Issues assigned to anyone in the Sales group (Option B):
* The JQL query does not filter byassigneeor group membership. It only selects issues based on the projects where the user has theSalesrole, regardless of who the issues are assigned to.
To filter by assignee, use assignee in membersOf("group"). TheprojectsWhereUserHasRolefunction filters by project, not assignee.
(Source: Atlassian Support Documentation, "Advanced searching - fields reference")
* Issues from projects where Leila is in the Sales group (Option C):
* The query usesprojectsWhereUserHasRole("Sales"), which checks for theSalesproject role, not a group. Project roles and groups are distinct, and the query does not reference group membership.
Project roles are project-specific and distinct from groups. UseprojectsWhereUserHasRolefor roles, not membersOffor groups.
* Issues assigned to anyone in the Sales role (Option D):
* The query does not filter byassigneeor role membership of the assignee. It selects issues from projects where the user (Leila) has theSalesrole, not issues assigned to users in that role.
To filter by assignees in a role, additional JQL or scripting is needed.projectsWhereUserHasRoleonly filters by project.
* Additional Notes:
* TheSalesproject role must exist in the relevant projects, and Leila must be added to it inProject settings > Peoplefor those projects.
* The subscription sends emails to theSales group, and each recipient (like Leila) seesissues based on their own role membership in the JQL query's context.
* Leila must haveBrowse Projectspermission for the projects returned by the query to see the issues.
Atlassian Support Documentation:Advanced searching - functions reference Atlassian Support Documentation:Advanced searching - fields reference Atlassian Support Documentation:Manage filters in Jira Cloud
NEW QUESTION # 69
Some of your project owners would like to make their projects publicly accessible over the Internet.
These projects will not require login.
You could support this by allowing read-only anonymous access to the projects.
Which two additional factors should you take into consideration when setting this up? (Choose two.)
- A. Spam bots could add comments.
- B. Anonymous users could export all issues from Jira.
- C. Licensed users might accidentally comment anonymously rather than logging in first.
- D. Internet search engines could index data.
- E. Anonymous users could see other users' names.
- F. Anonymous users could find a full list of all your projects.
NEW QUESTION # 70
Your management team needs to see a list of only those issues that were resolved in the previous week, from Sunday to Saturday. The list needs to be sent to them each week on Tuesdays. You plan to create a saved filter and filter subscription to do this.
Which JQL query will Mum the correct results?
- A. resolved>=startOfDay(-7) AND resolved < startOfDay()
- B. resolved end0fWeek(1)
- C. resolved ,= start0fWeek(-1) AND resolved start0fWeek0
- D. status changed TO RESOLVED BEFORE startOfWeek()
A). Incorrect. -resolved >. end0fWeek(1. will return all issues resolved this week, up until Tuesday when the filter is sent.
B). Correct.
What's more, part of that It-Tests ACP-120 dumps now are free: https://drive.google.com/open?id=1U7TnxJ8hUno6ma3uSXVZe4RSb7tcMe1j
