[General] New NCP-CN Test Syllabus, Exam Cram NCP-CN Pdf
99
General New NCP-CN Test Syllabus, Exam Cram NCP-CN Pdf
Posted at 1/20/2026 21:33:39      View167 | Replies1        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest DumpsReview NCP-CN PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1_zpjbYp5vnmemW55QjbKU7EUUEOiHFcC
If you are searching for an easy and rewarding study content to get through the NCP-CN Exam, you are at the right place to get success. Our NCP-CN exam questions can help you pass the exam and achieve the according certification with ease. If you study with our NCP-CN Practice Guide for 20 to 30 hours, then you will be bound to pass the exam with confidence. And the price for our NCP-CN training engine is quite favourable. What are you waiting for? Just come and buy it!
Nutanix NCP-CN Exam Syllabus Topics:
  • Conduct NKP Fleet Management: This section tests the abilities of platform administrators and cloud operations engineers in managing multiple clusters as a fleet. It focuses on configuring workspaces to organize clusters, deploying workload clusters within these workspaces, and attaching or detaching clusters as needed. Additionally, candidates must be able to configure projects for workload segmentation and manage platform applications that support the overall NKP environment.
  • Manage Building an NKP Cluster: This section evaluates the skills of Kubernetes administrators and platform engineers in customizing and deploying NKP clusters. Candidates must show proficiency in tailoring cluster configurations to meet specific requirements and deploying Kommander, the management platform, while applying the appropriate licenses to enable cluster features and management capabilities.
  • Perform Day 2 Operations: This part assesses the expertise of site reliability engineers and cluster operators in ongoing cluster management tasks after deployment. It includes configuring authentication and authorization mechanisms, setting up logging systems, and implementing cluster backup and recovery procedures. Candidates also need to demonstrate skills in monitoring cluster performance and health, configuring autoscaling to handle workload changes, and performing lifecycle management functions such as upgrades and maintenance.
  • Prepare the Environment for an NKP Deployment: This section of the exam measures the skills of infrastructure engineers and cloud administrators and covers the initial setup tasks needed for NKP deployment. Candidates must demonstrate the ability to seed a private container registry, create a bootstrap Kubernetes cluster, and determine license tiers suitable for clusters. They also need to prepare a bastion host for secure access, build machine images or prepare nodes for deployment, and gather all necessary information to build a cluster on the target cloud or on-premises provider.
DumpsReview Nutanix NCP-CN PDFMaybe you are still having trouble with the Nutanix NCP-CN exam; maybe you still dont know how to choose the NCP-CN exam materials; maybe you are still hesitant. But now, your search is ended as you have got to the right place where you can catch the finest NCP-CN exam materials. Here you can answer your doubts; you can easily pass the exam on your first attempt. All applicants who are working on the NCP-CN exam are expected to achieve their goals, but there are many ways to prepare for exam. Everyone may have their own way to discover. Some candidates may like to accept the help of their friends or mentors, and some candidates may only rely on some NCP-CN books. But none of these ways are more effective than our NCP-CN exam material. In summary, choose our exam materials will be the best method to defeat the exam.
Nutanix Certified Professional - Cloud Native v6.10 Sample Questions (Q71-Q76):NEW QUESTION # 71
A developer asked a Platform Engineer to review a deployment in the cluster called iot-1 in the workspace iot-plant-3, but the engineer does not have the kubeconfig file. Which command is valid for generating the kubeconfig file to review the Kubernetes cluster?
  • A. kubectl get kubeconfig --cluster-name=iot-1 -w iot-plant-3 > iot-1.conf
  • B. kubectl get secret iot-1 -n kommander > iot-1.conf
  • C. nkp get kubeconfig -c iot-1 -w iot-plant-3 > iot-1.conf
  • D. nkp get configmaps -n iot-plant-3 -c iot-1 > iot-1.conf
NEW QUESTION # 72
A Cloud Engineer manages an NKP environment and is preparing a machine image to become an NKP cluster node.
Which statement is regarding the default node preparation process?
  • A. Goss is used to validate the OS image is capable of running NKP.
  • B. Ansible is used to validate the OS image is capable of running NKP.
  • C. Shell scripts are used to harden the OS image for use as an NKP node.
  • D. Goss is used to make the OS image CAPI compliant for use as an NKP node.
NEW QUESTION # 73
A Platform Engineer has deployed NKP and wants to utilize its OOB data storage feature.
What should the engineer enable to support backups within the NKP environment?
  • A. Rook Ceph
  • B. Volumes iSCSI
  • C. MinIO
  • D. Objects S3
NEW QUESTION # 74
Some time ago, an EKS cluster was attached to be managed with NKP (Fleet Management). Now, a Platform Engineer has been asked to disconnect the EKS cluster from NKP for licensing reasons. After disconnecting the cluster, the developers realized that application changes are still being reflected in the EKS cluster, despite the fact that the EKS cluster was successfully detached from NKP. How should the engineer resolve this issue?
  • A. Forcefully detach EKS cluster: nkp detach cluster -c detached-cluster-name --force
  • B. Detached cluster's Flux installation must be manually disconnected from the management Git repository: kubectl -n kommmander-flux patch gitrepo management -p '{"spec":{"suspend":true}}' --type merge
  • C. Developers must have some bad configuration in the deployment config files. Ask for revision or call AWS technical support.
  • D. Detached cluster must also be deleted from NKP: nkp delete cluster -c detached-cluster-name
NEW QUESTION # 75
A Platform Engineer wants to deploy a custom OS image for multiple NKP clusters for Nutanix AHV and AWS. Which two tools come bundled to facilitate creating and placing a custom image into the respective image repository?
  • A. Ansible
  • B. Terraform
  • C. Konvoy Image Builder
  • D. Nutanix Image Builder
NEW QUESTION # 76
In the world of industry, NCP-CN certification is the key to a successful career. If you have achieved credential such as NCP-CN then it means a bright future is waiting for you. Avail the opportunity of NCP-CN dump at DumpsReview.com that helps you in achieving good scores in the exam. Due to these innovative methodologies students get help online. The NCP-CN Exam Questions Answers PDF is very effective and greatly helpful in increasing the skills of students. They can easily cover the exam topics with more practice due to the unique set of NCP-CN exam dump. The NCP-CN certification learning is getting popular with the passage of time.
Exam Cram NCP-CN Pdf: https://www.dumpsreview.com/NCP-CN-exam-dumps-review.html
What's more, part of that DumpsReview NCP-CN dumps now are free: https://drive.google.com/open?id=1_zpjbYp5vnmemW55QjbKU7EUUEOiHFcC
Posted at 2/21/2026 08:45:20        Only Author  2#
CGOAģMԇYκϸʤϤۤ100Ǥϸ񤷤ʤԤϤϡȫ~𤹤뤳ȤǤޤBץ}j䤹ҪϤޤäޤ󡣷dz˥ץˤƤޤ CGOAʹԇY˲ϸˤʤäȤ^ṩƤС˷ǤޤBץФˆ}kϤϡĤǤ⥫ީ``ӥåդBj뤳ȤǤޤ}Ǥ礯QΤޤĤޤꡢCGOAԇY}ϡԇY˺ϸ񤹤뤳Ȥܱۤ^ޤ
