[General] 312-50v12 Reliable Exam Test | Sample 312-50v12 Exam
93
General 312-50v12 Reliable Exam Test | Sample 312-50v12 Exam
Posted at 2/18/2026 17:48:05      View129 | Replies1        Print      Only Author   [Copy Link] 1#
What's more, part of that DumpsQuestion 312-50v12 dumps now are free: https://drive.google.com/open?id=1fKwYJ0-U7b-CDU1L7_s4Q-uZsI-3UUoG
All we want you to know is that people are at the heart of our manufacturing philosophy, for that reason, we place our priority on intuitive functionality that makes our 312-50v12 Exam Question to be more advanced. So with our 312-50v12 guide torrents, you are able to pass the exam more easily in the most efficient and productive way and learn how to study with dedication and enthusiasm, which can be a valuable asset in your whole life. It must be your best tool to pass your exam and achieve your target.
ECCouncil 312-50v12: Certified Ethical Hacker exam is a highly respected certification that demonstrates a professional's knowledge and skills in the field of ethical hacking. With the increasing demand for cybersecurity professionals, obtaining this certification can help individuals stand out in the job market and advance their careers.
Sample 312-50v12 Exam & 312-50v12 Latest Test CramThere are many benefits after you pass the 312-50v12 certification such as you can enter in the big company and double your wage. Our 312-50v12 study materials boost high passing rate and hit rate so that you neednt worry that you cant pass the test too much. We provide free tryout before the purchase to let you decide whether it is valuable or not by yourself. To further understand the merits and features of our 312-50v12 Practice Engine you could look at the introduction of our product in detail.
The Certified Ethical Hacker (CEH) certification is one of the most sought-after and recognized certifications in the field of cybersecurity. Certified Ethical Hacker Exam certification is offered by the International Council of E-Commerce Consultants (EC-Council) and is designed to equip individuals with the skills and knowledge to identify vulnerabilities in computer systems and networks and to develop effective countermeasures to prevent cyber-attacks. The CEH certification is highly valued by employers and is considered a benchmark for hiring professionals in the cybersecurity industry.
ECCouncil Certified Ethical Hacker Exam Sample Questions (Q238-Q243):NEW QUESTION # 238
A network admin contacts you. He is concerned that ARP spoofing or poisoning might occur on his network.
What are some things he can do to prevent it? Select the best answers.
  • A. Use a tool like ARPwatch to monitor for strange ARP activity.
  • B. Use a firewall between all LAN segments.
  • C. Use only static IP addresses on all PC's.
  • D. If you have a small network, use static ARP entries.
  • E. Use port security on his switches.
Answer: A,D,E
NEW QUESTION # 239
What type of a vulnerability/attack is it when the malicious person forces the user's browser to send an authenticated request to a server?
  • A. Session hijacking
  • B. Cross-site scripting
  • C. Server side request forgery
  • D. Cross-site request forgery
NEW QUESTION # 240
When configuring wireless on his home router, Javik disables SSID broadcast. He leaves authentication
"open" but sets the SSID to a 32-character string of random letters and numbers.
What is an accurate assessment of this scenario from a security perspective?
  • A. It is still possible for a hacker to connect to the network after sniffing the SSID from a successful wireless association.
  • B. Javik's router is still vulnerable to wireless hacking attempts because the SSID broadcast setting can be enabled using a specially crafted packet sent to the hardware address of the access point.
  • C. Since the SSID is required in order to connect, the 32-character string is sufficient to prevent brute-force attacks.
  • D. Disabling SSID broadcast prevents 802.11 beacons from being transmitted from the access point, resulting in a valid setup leveraging "security through obscurity".
NEW QUESTION # 241
Which of the following viruses tries to hide from anti-virus programs by actively altering and corrupting the chosen service call interruptions when they are being run?
  • A. Macro virus
  • B. Cavity virus
  • C. Stealth/Tunneling virus
  • D. Polymorphic virus
NEW QUESTION # 242
Robin, a professional hacker, targeted an organization's network to sniff all the traffic. During this process.
Robin plugged in a rogue switch to an unused port in the LAN with a priority lower than any other switch in the network so that he could make it a root bridge that will later allow him to sniff all the traffic in the network.
What is the attack performed by Robin in the above scenario?
  • A. DNS poisoning attack
  • B. ARP spoofing attack
  • C. STP attack
  • D. VLAN hopping attack
STP prevents bridging loops in a redundant switched network environment. By avoiding loops, you can ensure that broadcast traffic does not become a traffic storm.
STP is a hierarchical tree-like topology with a "root" switch at the top. A switch is elected as root based on the lowest configured priority of any switch (0 through 65,535). When a switch boots up, it begins a process of identifying other switches and determining the root bridge. After a root bridge is elected, the topology is established from its perspective of the connectivity. The switches determine the path to the root bridge, and all redundant paths are blocked. STP sends configuration and topology change notifications and acknowledgments (TCN/TCA) using bridge protocol data units (BPDU).
An STP attack involves an attacker spoofing the root bridge in the topology. The attacker broadcasts out an STP configuration/topology change BPDU in an attempt to force an STP recalculation. The BPDU sent out announces that the attacker's system has a lower bridge priority. The attacker can then see a variety of frames forwarded from other switches to it. STP recalculation may also cause a denial-of-service (DoS) condition on the network by causing an interruption of 30 to 45 seconds each time the root bridge changes. An attacker using STP network topology changes to force its host to be elected as the root bridge.
switch
NEW QUESTION # 243
Sample 312-50v12 Exam: https://www.dumpsquestion.com/312-50v12-exam-dumps-collection.html
2026 Latest DumpsQuestion 312-50v12 PDF Dumps and 312-50v12 Exam Engine Free Share: https://drive.google.com/open?id=1fKwYJ0-U7b-CDU1L7_s4Q-uZsI-3UUoG
Posted at 2/19/2026 02:13:21        Only Author  2#
ڟʲNأACFECFE-Financial-Transactions-and-Fraud-SchemesJCԇ᣿_CFE-Financial-Transactions-and-Fraud-SchemesԇһTyͨ^ĿԇҲ^֓ġֻҪmķpͨ^ԇҲDzܵġN֪ʲNmķ᣿ʹVCESoftCFE-Financial-Transactions-and-Fraud-SchemesYϾһNò^ķVCESoftһֱԁ˺ܶITJԇĿKҵõ˴ҵһºu@YϿԱCһͨ^ԇՈʹá
