[General] 新版1z1-076考古題 -您最好的助力Oracle Database 19c: Data Guard Administration熱門認證
80
【General】 新版1z1-076考古題 -您最好的助力Oracle Database 19c: Data Guard Administration熱門認證
Posted at 1/12/2026 22:08:22      View:195 | Replies:1        Print      Only Author   [Copy Link] 1#
P.S. PDFExamDumps在Google Drive上分享了免費的、最新的1z1-076考試題庫:https://drive.google.com/open?id=1nmh4yNKkZj_5lvdc4XQY9HOvXk5gP06K
如果你想在短時間內,以最小的努力,達到最有效果的結果Oracle的1z1-076考試準備,你可以使用PDFExamDumps Oracle的1z1-076考試培訓資料,PDFExamDumps的培訓資料是通過實踐檢驗了的,也是通過眾多考生證明了它確實可以百分百通過考試,利用了它,你將達到你的目的,得到最佳的效果。
Oracle 1z1-076 考試大綱:
主題簡介
主題 1
  • Using Flashback Database in a Data Guard Configuration: This topic covers the configuration and advantages of using Flashback Database in a Data Guard setup, as well as the process of enabling fast-start failover for seamless role changes.
主題 2
  • Managing Oracle Net Services in a Data Guard Environment: The section focuses on Oracle Net Services and its role in Data Guard networking setup.
主題 3
  • Performing Role Transitions: Here, the concept of database roles is explained, along with the steps for performing switchovers, failovers, and maintaining physical standby sessions during role transitions.
主題 4
  • Patching and Upgrading Databases in a Data Guard Configuration: This section provides guidance on patching and upgrading databases in a Data Guard environment, along with performance optimization techniques and monitoring considerations.
主題 6
  • Backup and Recovery Considerations in an Oracle Data Guard Configuration: In this topic, Backup and recovery procedures in a Data Guard configuration are discussed, including RMAN backups, offloading to physical standby, and network-based recovery.
主題 7
  • Enhanced Client Connectivity in a Data Guard Environment: This topic focuses on enhancing client connectivity in a Data Guard setup and implementing failover procedures for seamless client redirection. It also covers application continuity to ensure uninterrupted operations during role transitions.
主題 8
  • Creating a Logical Standby Database: This topic guides users through the process of creating and managing a logical standby database, including SQL Apply filtering.
最實用的1z1-076認證考試的參考資料在這個競爭激烈的IT行業中,擁有一些認證證書是可以幫助你步步高升的。很多公司升職加薪的依據就是你擁有的認證證書的含金量。Oracle 1z1-076認證考試就是個含金量很高的考試。Oracle 1z1-076 認證證書能滿足很多正在IT行業拼搏的人的需求。PDFExamDumps可以為你提供Oracle 1z1-076認證考試的針對性訓練。你可以先在網上免費下載PDFExamDumps為你提供的關於Oracle 1z1-076 認證考試的培訓工具的試用版和部分練習題及答案作為嘗試。
最新的 Oracle Database 19c 1z1-076 免費考試真題 (Q83-Q88):問題 #83
You are using Data Guard in conjunction with Global Database Services.
You have a Data Guard Broker configuration called Sales and a GDS pool called Prod.
Which three are true concerning the management of the broker configuration when using GDS?
  • A. DGMGRL may be used to add the Sales configuration to the Prod pool in gds.
  • B. DGMGRL may be used to add a single database to the Sales configuration even if Sales is a member of the Prod pool.
  • C. Adding a database to the Sales configuration with DGMGRL automatically adds the database to the Prod Pool.
  • D. Performing a role change with DGMGRL automatically notifies GDS which in turn activates the appropriate services.
  • E. Adding a database to the Sales configuration with DGMGRL requires that the Sales configuration be disabled first. It must then be enabled after the new database is added to the configuration.
答案:A,B,D
解題說明:
In the context of Oracle Data Guard and Global Database Services (GDS):
* DGMGRL may be used to add the Sales configuration to the Prod pool in gds (A): Data Guard Broker's command-line interface DGMGRL can be utilized to manage configurations with GDS, allowing the addition of Data Guard Broker configurations to GDS pools.
* Performing a role change with DGMGRL automatically notifies GDS which in turn activates the appropriate services (B): When a role change is executed using DGMGRL, GDS is automatically notified, and it then activates the services that are appropriate for the new database roles.
* DGMGRL may be used to add a single database to the Sales configuration even if Sales is a member of the Prod pool (C): DGMGRL provides the capability to manage individual databases within a broker configuration, including adding databases to a configuration that is already part of a GDS pool.References:
* Oracle Data Guard Broker documentation
* Oracle Global Data Services documentation
問題 #84
Your Data Guard environment has two remote physical standby databases.
Client applications use the local naming method to connect to the primary database instance.
You want applications to automatically connect to the new primary database instance in case of a switchover or a failover.
Which set of actions will fulfill this requirement?
  • A. Set DB_NAME and DB_UNIQUE_NAME identically on all databases; modify the connection descriptors on client applications to include all the standby hosts and connect to the database instance using that service name.
  • B. Create a database service on the primary database that is started automatically by a trigger, when the database role is PRIMARY; modify the connection descriptors used by client applications to include all the standby hosts and connect to the database instance using that service name.
  • C. Set the LOCAL_LISTENER parameter for all the database instance to register services with the default listener on the primary database host.
  • D. Set the INSTANCE NAME parameter identically on all databases; modify the connection descriptor on client applications to include all the standby hosts and connect to the database instance using that service name.
答案:B
解題說明:
For seamless client redirection in a Data Guard environment, the following steps should be taken:
Create a database service on the primary database that is started automatically by a trigger when the database role is PRIMARY (B): This ensures that the service is only available on the primary database and is automatically started after a role transition due to switchover or failover.
Modify the connection descriptors used by client applications to include all the standby hosts and connect to the database instance using that service name (B): Client applications use the connection descriptors that include all potential primary hosts (i.e., the current primary and all standbys). This enables clients to connect to whichever database is currently acting as the primary using the service name.
Oracle Data Guard Concepts and Administration Guide
Oracle Real Application Clusters Administration and Deployment Guide
問題 #85
You must propose an Oracle Data Guard configuration for a database supporting an OLTP workload that meets these permanent requirements:
Data loss is not permitted.
Read-only applications should not connect to the primary database instance.
Additionally, there are these requirements, only one of which is ever done at any one time:
It should be possible to apply and test designated patches with a minimum amount of downtime.
Upgrading to a new database release should be performed with the least possible amount of downtime.
New application software releases should be tested against an exact up-to-date replica of the production database.
You propose a primary database with one physical standby database configured in Maximum Protection mode.
Which requirements do you meet?
  • A. Only requirement 5
  • B. 1 and 2
  • C. 2, 3, 4, and 5
  • D. 1, 2, 3, 4, and 5
  • E. Only requirement 1
答案:E
問題 #86
Which three are prerequisites for enabling Fast-Start Failover?
  • A. Flashback Database must be enabled only on the Fast-Start Failover target standby database.
  • B. The configuration must be operating in either Maximum Performance or Maximum Protection mode.
  • C. The maximum protection mode can be used, but with two or more standby databases.
  • D. You can specify only one standby database as the fast-start failover target.
  • E. Flashback Database must be enabled on both the primary database and the Fast-Start Failover target standby database.
  • F. The Data Guard environment must be managed by the Data Guard Broker.
答案:D,E,F
解題說明:
To enable Fast-Start Failover in a Data Guard environment, the following conditions must be in place:
* The Data Guard environment must be managed by the Data Guard Broker (A): The Broker simplifies management tasks and is required to enable fast-start failover, which is an automatic failover mechanism provided by Data Guard.
* You can specify only one standby database as the fast-start failover target (C): Fast-start failover is designed to fail over to a single, predetermined standby database, known as the target standby.
* Flashback Database must be enabled on both the primary database and the Fast-Start Failover target standby database (F): Flashback Database provides a quick way to revert a database to a point
* in time before a logical or physical corruption or error occurred. It must be enabled on both the primary and target standby databases to allow for the possibility of reinstating the old primary as a standby after a failover.References:
* Oracle Data Guard Concepts and Administration Guide
* Oracle Database High Availability Overview
問題 #87
Examine the Data Guard configuration:
DGMGRL> show configuration;
Configuration - Animals
Protection Mode: Max Availability
Databases:
dogs - Primary database sheep
- Physical standby database cats
Fast-Start Failover: DISABLED
Configuration Status: SUCCESS
An attempt to enable fast-start failover raises an error:
DGMGRL> enable fast_start failover;
Error: ORA-16693: requirements not met for enabling fast-start failover Failed.
Identify three possible reasons for this error.
  • A. The LogXptMode property is set to async on Dogs.
  • B. The LogXptMode property is set to fastsync on Dogs.
  • C. The LogXptMode property is set to FASTSYNC on Cats while Sheep is the target standby database.
  • D. The LogxptModr property is set to async on Sheep while Sheep is the target standby database.
  • E. The fastStartFailoverTarget property is not set on Dogs.
答案:A,D,E
解題說明:
When enabling fast-start failover, certain conditions must be met:
The fastStartFailoverTarget property is not set on Dogs (A): The primary database (Dogs) needs to have a fast-start failover target configured for the operation to succeed.
The LogXptMode property is set to ASYNC on Sheep while Sheep is the target standby database (B): Fast-start failover requires synchronous redo transport (SYNC or FASTSYNC) to ensure zero data loss, which is a prerequisite for enabling the feature.
The LogXptMode property is set to ASYNC on Dogs (D): Similar to the previous point, the primary database must be configured to use synchronous redo transport for the fast-start failover to be possible.
Oracle Database Error Messages Guide
問題 #88
我們都知道在現在這個競爭激烈的IT行業,擁有一些IT相關認證證書是很有必要的。IT認證證書是對你的IT專業知識和經驗的最好證明。在IT行業中Oracle 1z1-076 認證考試是一個很重要的認證考試,但是通過Oracle 1z1-076 認證考試是有一定難度的。但是為了能讓工作職位有所提升花點金錢選擇一個好的培訓機構來幫助你通過考試是值得的。PDFExamDumps擁有最新的針對Oracle 1z1-076認證考試的培訓資料,與真實的考試很95%相似性。如果你使用PDFExamDumps提供的培訓,你可以100%通過考試。如果你考試失敗,我們會全額退款。
1z1-076熱門認證: https://www.pdfexamdumps.com/1z1-076_valid-braindumps.html
P.S. PDFExamDumps在Google Drive上分享了免費的2026 Oracle 1z1-076考試題庫:https://drive.google.com/open?id=1nmh4yNKkZj_5lvdc4XQY9HOvXk5gP06K
Posted at 2/23/2026 18:54:31        Only Author  2#
Microsoft인증 AZ-500-KR시험패스는 IT업계종사자들이 승진 혹은 연봉협상 혹은 이직 등 보든 면에서 날개를 가해준것과 같습니다.IT업계는 Microsoft인증 AZ-500-KR시험을 패스한 전문가를 필요로 하고 있습니다. DumpTOP의Microsoft인증 AZ-500-KR덤프로 시험을 패스하고 자격증을 취득하여 더욱더 큰 무대로 진출해보세요.
