[Hardware] Fortinet FCP_FAC_AD-6.5 Latest Study Plan | FCP_FAC_AD-6.5 Valid Exam Format
92
【Hardware】 Fortinet FCP_FAC_AD-6.5 Latest Study Plan | FCP_FAC_AD-6.5 Valid Exam Format
Posted at 1/15/2026 20:58:06      View:156 | Replies:3        Print      Only Author   [Copy Link] 1#
P.S. Free & New FCP_FAC_AD-6.5 dumps are available on Google Drive shared by ExamsLabs: https://drive.google.com/open?id=11PfWcoLLKneToCeuClxN_KLWBi6KCM0J
Our Software version has the advantage of simulating the real FCP_FAC_AD-6.5 exam environment. Many candidates can't successfully pass their real FCP_FAC_AD-6.5 exams for the reason that they are too nervous to performance rightly as they do the practices. This Software version of FCP_FAC_AD-6.5 practice materials will exactly help overcome their psychological fear. Besides, the scores will show out when you finish the practice, so after a few times, you will definitely do it better and better. You will be bound to pass your FCP_FAC_AD-6.5 Exam since you have perfected yourself in taking the FCP_FAC_AD-6.5 exam.
Fortinet FCP_FAC_AD-6.5 Exam Syllabus Topics:
  • PKI and FortiAuthenticator as a CA: This section of the exam measures the skills of a PKI Specialist and covers the use of FortiAuthenticator as a Certificate Authority (CA) within a Public Key Infrastructure (PKI).
  • Managing Users and Troubleshooting Authentication: This section of the exam measures the skills of a Technical Support Specialist and covers advanced user management techniques and methods for diagnosing and resolving authentication issues.
  • Administering and Authenticating Users: This section of the exam measures the skills of a Security Administrator and covers the processes for creating, managing, and authenticating user accounts within the FortiAuthenticator system.
  • 802.1X Authentication
Topic 5
  • OAuth and SAML:This section of the exam measures the skills of an Identity and Access Management (IAM) Specialist and covers the implementation of OAuth services and SAML-based single sign-on configurations.
Topic 6
  • FSSO Process and Methods: This section of the exam measures the skills of a Network Architect and covers the Fortinet Single Sign-On (FSSO) framework, including its processes and various deployment methods.
Topic 7
  • Certificate Management: This section of the exam measures the skills of a Certificate Manager and covers the administration of digital certificates, including issuance, renewal, and revocation processes.
Topic 8
  • This section of the exam measures the skills of a Network Security Engineer and covers the configuration of FortiAuthenticator for wired and wireless 802.1X authentication using supported EAP methods.
Topic 9
  • Administrative Users and High Availability: This section of the exam measures the skills of a System Engineer and covers the management of administrative user accounts and the implementation of high availability configurations to ensure system reliability and redundancy.
Topic 10
  • Portal Services: This section of the exam measures the skills of a Portal Administrator and covers the configuration and management of self-service portals for guest and local user access.
Topic 11
  • Introduction and Initial Configuration: This section of the exam measures the skills of a Network Security Administrator and covers the foundational setup and basic configuration of FortiAuthenticator, including initial deployment steps and system preparation for identity management services.
Topic 12
  • Two-Factor Authentication: This section of the exam measures the skills of a Security Engineer and covers the implementation and configuration of two-factor authentication using FortiTokens and other verification methods.
Pass Guaranteed Quiz Fortinet Marvelous FCP_FAC_AD-6.5 Latest Study PlanThe companies do not want to lose them and they offer a good package to convince the candidate to become a part of their organization. So, to fit in the game, you must go for the ExamsLabs Fortinet FCP_FAC_AD-6.5 Practice Exam that will show you where you stand and how hard you need to work to get the FCP—FortiAuthenticator 6.5 Administrator (FCP_FAC_AD-6.5) certification exam.
Fortinet FCP—FortiAuthenticator 6.5 Administrator Sample Questions (Q33-Q38):NEW QUESTION # 33
At a minimum, which two configurations are required to enable captive portal services on FortiAuthenticator?
(Choose two.)
  • A. Configuring a portal policy
  • B. Configuring a RADIUS client
  • C. Configuring an external authentication portal
  • D. Configuring at least one pre-login service
Answer: A,D
A pre-login service must be configured to define how users can access the portal before authentication.
A portal policy is required to determine authentication rules and behavior for captive portal access.
NEW QUESTION # 34
You are the administrator of a large network that includes a large local user datadabase on the current Fortiauthenticatior. You want to import all the local users into a new Fortiauthenticator device.
Which method should you use to migrate the local users?
  • A. Import the current directory structure.
  • B. Import users from RADUIS.
  • C. Import users using a CSV file.
  • D. Import users using RADIUS accounting updates.
NEW QUESTION # 35
Which interface services must be enabled for the SCEP client to connect to Authenticator?
  • A. OCSP
  • B. SSH
  • C. HTTP/HTTPS
  • D. REST API
NEW QUESTION # 36
What is the advantage of using FortiToken for two-factor authentication?
  • A. It can be easily integrated with any third-party authentication service
  • B. It's a physical token made of solid gold
  • C. It doesn't require user interaction for authentication
  • D. It can generate unlimited tokens for free
NEW QUESTION # 37
How can tags be used to generate Fortinet Single Sign-On (FSSO) events?
  • A. By automatically categorizing logon events using predefined labels
  • B. By attaching physical tags to users' devices
  • C. By sending notifications to users about authentication events
  • D. By creating custom login screens
NEW QUESTION # 38
All these three ExamsLabs FCP—FortiAuthenticator 6.5 Administrator (FCP_FAC_AD-6.5) exam questions formats are easy to use and perfectly work with all devices, operating systems, and the latest web browsers. So rest assured that with the ExamsLabs FCP_FAC_AD-6.5 Exam Dumps you will get everything that you need to learn, prepare and pass the challenging FCP—FortiAuthenticator 6.5 Administrator (FCP_FAC_AD-6.5) exam with good scores.
FCP_FAC_AD-6.5 Valid Exam Format: https://www.examslabs.com/Fortinet/FCP-in-Network-Security/best-FCP_FAC_AD-6.5-exam-dumps.html
BTW, DOWNLOAD part of ExamsLabs FCP_FAC_AD-6.5 dumps from Cloud Storage: https://drive.google.com/open?id=11PfWcoLLKneToCeuClxN_KLWBi6KCM0J
Posted at 1/16/2026 03:59:41        Only Author  2#
Your article has made a real difference to me, thank you! Sending me all the positive vibes for the C-THR82-2505 latest test papers exam!
Posted at 1/31/2026 21:42:17        Only Author  3#
Through reading this article, I feel that I have made great progress. Free Reliable 6V0-21.25 test questions available to improve your IT skills. Best of luck!
Posted at 2/1/2026 00:23:00        Only Author  4#
This article is absolutely top-tier, thank you for sharing. Improve your IT abilities—free New test FCP_GCS_AD-7.6 camp sheet now available! Good luck!
