[General] Latest MuleSoft MCD-Level-2 Test Questions | MCD-Level-2 Reliable Dumps
108
【General】 Latest MuleSoft MCD-Level-2 Test Questions | MCD-Level-2 Reliable Dumps
Posted at 1/12/2026 18:42:41      View:155 | Replies:3        Print      Only Author   [Copy Link] 1#
Your eligibility of getting a high standard of career situation will be improved if you can pass the exam, and our MCD-Level-2 study guide are your most reliable ways to get it. You can feel assertive about your exam with our 100 guaranteed professional MCD-Level-2 Practice Engine for you can see the comments on the websites, our high-quality of our MCD-Level-2 learning materials are proved to be the most effective exam tool among the candidates.
Maybe you often come up with great new ideas from daydream, but you can not do anything. Do you have some trouble passing MuleSoft MCD-Level-2 Exam? Turn on your computer, click PDF4Test. Then, you will find the dumps torrent you need. After you purchase our products, we provide free updates for a year. 100% guarantee to get the certification.
Top Latest MCD-Level-2 Test Questions & The Best Site PDF4Test to help you pass MCD-Level-2: MuleSoft Certified Developer - Level 2 (Mule 4)If you're looking to advance your career, passing the MuleSoft MCD-Level-2 Certification Exam is crucial. As with any certification exam, success requires time and effort. While there are many online study materials available, not all of them are accurate or reliable. Many professionals struggle with managing their time and studying effectively, making it difficult to pass the MuleSoft Certified Developer - Level 2 (Mule 4) (MCD-Level-2) Exam.
MuleSoft Certified Developer - Level 2 (Mule 4) Sample Questions (Q13-Q18):NEW QUESTION # 13
A Flight Management System publishes gate change notification events whenever a flight's arrival gate changes. Other systems, including Baggage Handler System. Inflight Catering System and Passenger Notifications System, must each asynchronously receive the same gate change notification to process the event according.
Which configuration is required in Anypoint MQ to achieve this publish/subscribe model?
  • A. Publish the gate change notification to an Anypoint MQ queue.
    Create different anypoint MQ exchange meant for each of the other subscribing systems Bind the queue with each of the exchanges
  • B. Publish the gate change notification to an Anypoint MQ exchanhe.
    Create different Anypoint MQ queues meant for each of the other subscribing systems.
    Bind the exchange with each of the queues.
  • C. Publish each client subscribe directly to the exchange.
    Have each client subscribe directly to the queue.
  • D. Publish the gate change notification to an Anypoint MC queue
To achieve a publish/subscribe model using Anypoint MQ, where each system receives the same gate change notification event, the developer should publish the gate change notification to an Anypoint MQ exchange, create different Anypoint MQ queues meant for each of the other subscribing systems, and bind the exchange with each of the queues. An exchange is a message routing agent that can send messages to different queues based on predefined criteria. By binding an exchange with multiple queues, each queue receives a copy of every message sent to that exchange. Therefore, each system can subscribe to its own queue and receive every gate change notification event. References:
https://docs.mulesoft.com/anypoint-mq/3.x/anypoint-mq-exchanges
NEW QUESTION # 14
A system API that communicates to an underlying MySQL database is deploying to CloudHub. The DevOps team requires a readiness endpoint to monitor all system APIs.
Which strategy should be used to implement this endpoint?
  • A. Create a dedicated endpoint that responds with the API status and health of the server
  • B. Create a dedicated endpoint that responds with the API status and reachability of the underlying systems
  • C. Create a dedicated endpoint that responds with the API status only
  • D. Use an existing resource endpoint of the API
To implement a readiness endpoint to monitor all system APIs, the developer should create a dedicated endpoint that responds with the API status and reachability of the underlying systems. This way, the DevOps team can check if the system API is ready to receive requests and if it can communicate with its backend systems without errors. References:
https://docs.mulesoft.com/mule-r ... es#readiness-probes
NEW QUESTION # 15
Multiple individual Mute application need to use the Mule Maven plugin to deploy to CloudHub.
The plugin configuration should .. reused where necessary and anything project, specific should be property-based.
Where should the Mule Maven details be configured?
  • A. Pom, xml
  • B. A Bill of Materials (BOM) parent pm
  • C. Settings, xml
  • D. A parent pom.xml
To reuse Mule Maven plugin configuration across multiple individual Mule applications, the developer should use a parent pom.xml file. A parent pom.xml file defines common configuration for one or more child projects that inherit from it. The developer can specify common properties and dependencies for all child projects in the parent pom.xml file, such as Mule Maven plugin configuration, and then reference them in each child project's pom.xml file using placeholders. References:
https://docs.mulesoft.com/mule-runtime/4.3/mmp-concept#parent-pom
https://maven.apache.org/guides/ ... Project_Inheritance
NEW QUESTION # 16
A developer is working on a project that requires encrypting all data before sending it to a backend application. To accomplish this, the developer will use PGP encryption in the Mule 4 Cryptography module.
What is required to encrypt the data before sending it to the backend application?
  • A. The application needs the private key from the backend service to encrypt the data
  • B. The application needs to configure HTTPS TLS context information to encrypt the data
  • C. The application needs to both the private and public keys to encrypt the data
  • D. The application needs the public key from the backend service to encrypt the data
To encrypt the data before sending it to the backend application using PGP encryption, the application needs the public key from the backend service. PGP encryption uses a public-key cryptography system, which means that each party has a pair of keys: a public key and a private key. The public key is used to encrypt data, and the private key is used to decrypt data. Therefore, to encrypt data for a specific recipient (the backend service), the application needs to use the recipient's public key. The recipient can then use its own private key to decrypt the data. References: https://docs.mulesoft.com/mule-runtime/4.3/cryptography-pgp
NEW QUESTION # 17
When creating a new project, which API implementation allows for selecting the correct API version and scaffolding the flows from the API specification?
  • A. Download RAML from Design Center
  • B. Generate a local RAML from anypoint Studio
  • C. Import RAML from local file
  • D. Import a published API
To create a new project that selects the correct API version and scaffolds the flows from the API specification, the developer should import a published API. This option allows importing an API specification that has been published to Anypoint Exchange or Design Center, and selecting a specific version of that API specification.
The developer can also choose to scaffold flows based on that API specification.
References:https://docs.mulesoft.com/apikit/4.x/apikit-4-new-project-task
NEW QUESTION # 18
Considering all customers' sincere requirements, MCD-Level-2 test question persist in the principle of "Quality First and Clients Supreme" all along and promise to our candidates with plenty of high-quality products. Numerous advantages of MCD-Level-2 training materials are well-recognized, such as 99% pass rate in the exam, free trial before purchasing. From the customers' point of view, our MCD-Level-2 Test Question put all candidates' demands as the top priority. We treasure every customer' reliance and feedback to the optimal MCD-Level-2 practice test.
MCD-Level-2 Reliable Dumps: https://www.pdf4test.com/MCD-Level-2-dump-torrent.html
MuleSoft Latest MCD-Level-2 Test Questions It always pursues better even though it can be nominated as one of the best, MuleSoft Latest MCD-Level-2 Test Questions We always sell the latest exam materials based on new information only, If our candidates fail to pass MuleSoft MCD-Level-2 exam unluckily, it will be tired to prepare for the next exam, MuleSoft Latest MCD-Level-2 Test Questions Join us and realize your dream.
Use simple controls such as the Image control, text controls, and CheckBox MCD-Level-2 control, Paste a text frame before the tab character you just entered, It always pursues better even though it can be nominated as one of the best.
Updated MuleSoft MCD-Level-2 Practice Questions in PDF FormatWe always sell the latest exam materials based on new information only, If our candidates fail to pass MuleSoft MCD-Level-2 Exam unluckily, it will be tired to prepare for the next exam.
Join us and realize your dream, Moreover, we will send MCD-Level-2 Reliable Dumps you the update supplements or you can download them by yourself, which are some useful renewals for free.
Posted at 1/14/2026 18:47:56        Only Author  2#
I’m grateful for your article, it truly stood out to me. I’m sharing the New DA0-002 exam questions resources for free—best of luck to you!
Posted at 1/17/2026 00:24:34        Only Author  3#
The article is outstanding, thank you for sharing! The NSK300 real dumps free helped me earn a promotion and salary increase. I’m now sharing it for free with everyone. Wishing you all success in your careers!
Posted at 1/31/2026 21:26:57        Only Author  4#
Thank you for sharing such a powerful article, it really left an impression. With New 101-500 test registration, you get comprehensive material available for free to support you.
