Microsoft AZ-104 Reliable Braindumps Book & Exam AZ-104 Guide
64
Posted at 1/10/2026 18:28:50      View115 | Replies1        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of Free4Dump AZ-104 dumps for free: https://drive.google.com/open?id=1TMxglaI0ElXHpiLyuC4-Ud7xctoH8WVQ
Feedbacks of many IT professionals who have passed Microsoft certification AZ-104 exam prove that their successes benefit from Free4Dump's help. Free4Dump's targeted test practice questions and answers to gave them great help, which save their valuable time and energy, and allow them to easily and smoothly pass their first Microsoft Certification AZ-104 Exam. So Free4Dump a website worthy of your trust. Please select Free4Dump, you will be the next successful IT person. Free4Dump will help you achieve your dream.
Microsoft AZ-104 certification exam is designed for professionals who want to prove their expertise in Microsoft Azure administration. AZ-104 exam is a part of the Microsoft Certified: Azure Administrator Associate certification, which is recognized globally by various organizations. AZ-104 exam tests the knowledge and skills of candidates in implementing, managing, and monitoring Azure solutions.
Microsoft AZ-104 Certification Exam is ideal for IT professionals who want to demonstrate their knowledge and skills in Azure administration. Microsoft Azure Administrator certification is suitable for individuals who have experience with Azure technologies and want to take their skills to the next level. It is also suitable for IT professionals who are looking to transition into Azure administration from other IT roles.
PrerequisitesBefore going for the Microsoft AZ-104 Exam, you should have a minimum of six months of practical experience in administering Azure. Additionally, you should possess an in-depth understanding of Azure workloads, core Azure services, governance, and security. The applicants also need to have experience with PowerShell, Azure Resource Manager templates, Azure portal, and Azure CLI. The candidates for the test are the Microsoft Azure Administrators who have the ability to complete the technical tasks highlighted in the domains of the exam objectives.
100% Pass-Rate AZ-104 Reliable Braindumps Book C Correct Exam Guide for AZ-104As usual, you just need to spend little time can have a good commend of our study materials, then you can attend to your AZ-104 exam and pass it at your first attempt. We also hire a team of experts, and the content of AZ-104 question torrent is all high-quality test guidance materials that have been accepted by experienced professionals. AZ-104 practice materials will be the most professional and dedicated tutor you have ever met.
Microsoft Azure Administrator Sample Questions (Q83-Q88):NEW QUESTION # 83
You have an Azure Active Directory (Azure AD) tenant named contoso.com that contains the users shown in the following table:
User3 is the owner of Group1.
Group2 is a member of Group1.
You configure an access review named Review1 as shown in the following exhibit:
https://docs.microsoft.com/en-us ... reate-access-review
NEW QUESTION # 84
You have an Azure subscription that has the Azure container registries shown in the following table.
You plan to use ACR Tasks and configure endpoint connections.
NEW QUESTION # 85
You have an Azure subscription named Subscription1 that has a subscription ID of c276fc76-9cd4-44c9-99a7-
4fd71546436e.
You need to create a custom RBAC role named CR1 that meets the following requirements:
Can be assigned only to the resource groups in Subscription1
Prevents the management of the access permissions for the resource groups Allows the viewing, creating, modifying, and deleting of resource within the resource groups What should you specify in the assignable scopes and the permission elements of the definition of CR1? To answer, select the appropriate options in the answer area.
Box 1: "/subscription/c276fc76-9cd4-44c9-99a7-4fd71546436e"
In the assignableScopes you need to mention the subscription ID where you want to implement the RBAC Box 2: "Microsoft.Authorization/*" Microsoft.Authorization/* is used to Manage authorization
https://docs.microsoft.com/en-us ... /resource-provider- operations#microsoftauthorization
https://docs.microsoft.com/en-us ... trol/built-in-roles References:
https://docs.microsoft.com/en-us ... ontrol/custom-roles
https://docs.microsoft.com/en-us ... /resource-provider- operations#microsoftresources
NEW QUESTION # 86
You have an Azure subscription that contains the following resources:
* a virtual network named VNet1
* a replication policy named ReplPolicy1
* a Recovery Services vault named Vault1
* an Azure Storage account named Storage1
You have an Amazon Web Services (AWS) EC2 virtual machine named VM1 that runs Windows Server
2019.
You need to migrate VM1 to VNet1 by using Azure Site Recovery.
Step 1: Deploy an EC2 virtual machine as a configuration server
Prepare source include:
* Use an EC2 instance that's running Windows Server 2012 R2 to create a configuration server and register it with your recovery vault.
* Configure the proxy on the EC2 instance VM you're using as the configuration server so that it can access the service URLs.
Step 2: Install Azure Site Recovery Unified Setup.
Download Microsoft Azure Site Recovery Unified Setup. You can download it to your local machine and then copy it to the VM you're using as the configuration server.
Step 3: Enable replication for VM1.
Enable replication for each VM that you want to migrate. When replication is enabled, Site Recovery automatically installs the Mobility service.
https://docs.microsoft.com/en-us ... -tutorial-aws-azure
NEW QUESTION # 87
You have an Azure subscription that contains a storage account named storage1. The subscription is linked to an Azure Active Directory (Azure AD) tenant named contoso.com that syncs to an on-premises Active Directory domain.
The domain contains the security principals shown in the following table.
In Azure AD, you create a user named User2.
The storage1 account contains a file share named share1 and has the following configurations.
https://docs.microsoft.com/en-us ... s?tabs=azure-portal
NEW QUESTION # 88
To improve our products quality we employ first-tier experts and professional staff and to ensure that all the clients can pass the test we devote a lot of efforts to compile the AZ-104 learning guide. Even if you unfortunately fail in the test we wont let you suffer the loss of the money and energy and we will return your money back at the first moment. After you pass the AZ-104 test you will enjoy the benefits the certificate brings to you such as you will be promoted by your boss in a short time and your wage will surpass your colleagues. In short, buying the AZ-104 exam guide deserves your money and energy spent on them.
Exam AZ-104 Guide: https://www.free4dump.com/AZ-104-braindumps-torrent.html
Posted at 1/20/2026 07:55:43        Only Author  2#
I appreciate your article, it really gave me a new perspective. Wish me good luck for the Dump L4M6 file exam!
