[General] ROC-RK3588S-PC Which Firmware Supports UEFI Boot?
37
General ROC-RK3588S-PC Which Firmware Supports UEFI Boot?
Posted at 12/31/2022 08:51:11      View6121 | Replies7        Print      Only Author   [Copy Link] 1#
Hi I see on https://en.t-firefly.com/product/industry/rocrk3588spc, that "UEFI Boot is also available", but I don't see the bootefi command available in uboot:
  1. => bootefi
  2. Unknown command 'bootefi' - try 'help'
Copy the code
I've tried both the Ubuntu firmware and the Android12.0 firmware, but both give the same results. Does one of the official firmware downloads support UEFI boot, or do I need to build my own uboot?
ROC-RK3588S-PC-interrupt-uboot.zip
2.68 KB, Down times: 2
Posted at 1/1/2023 05:31:53        Only Author  2#
It seems that the Buildroot and Debian firmware also do not support UEFI.
administrator
Rank: 9Rank: 9Rank: 9
Posted at 1/3/2023 09:56:03        Only Author  3#
bpeckham Posted at 1/1/2023 05:31
Sorry for the late reply. UEFI Boot is still testing and ROC-RK3588S-PC will support it soon.
Posted at 1/5/2023 12:34:01        Only Author  4#
Thanks!
Posted at 1/10/2023 13:39:25        Only Author  5#
What are the instructions for building it? If I update to v1.0.4b and use the following commands:
  1. cd uefi
  2. bash -e make.sh
Copy the code
I get the following error:
  1. ...
  2. ********boot_merger ver 1.2********
  3. Info:Pack loader ok.
  4. pack loader okay! Input: /home/user/rk3588_repo_sdk_v1.0.2a/rkbin/RKBOOT/RK3588MINIALL.ini
  5. /home/user/rk3588_repo_sdk_v1.0.2a/u-boot
  6. ERROR: pack uboot.img failed! fit/uboot.itb actual: 2127872 bytes, max limit: 2097152 bytes
  7. cp: cannot stat 'uboot.img': No such file or directory
Copy the code
It looks like u-boot has overflowed its partition limit. Is there a patch for it?
super moderator
Rank: 8Rank: 8
Posted at 1/11/2023 09:27:23        Only Author  6#
uefi need uboot.img , you should build uboot by "./build.sh uboot.img"( UEFI Boot is still testing )
Posted at 1/21/2026 18:23:17        Only Author  7#
Fantasie kann einem helfen, viele schöne Ideen auszudenken. Aber sie kann nichts machen. Wenn Sie sich den Kopf zerbrechen, wie Sie die CIPS L5M15 Zertifizierungsprfung bestehen können, sollen Sie lieber Ihren Conputer öffnen und It-Pruefung klicken. Sie werden was sehen, wie Sie wollen. Außerdem ist It-Pruefung sehr preiswert und seine Produkte sind von guter Qualität. Wir versprechen, dass Sie die CIPS L5M15 Prfung 100% bestehen können.
Posted at 1/23/2026 00:49:00        Only Author  8#
I am so grateful for this inspiring article, thank you! Im offering the EMEA-Advanced-Support latest test tips test that helped me earn my promotion and raise. Its free todaywishing you all the best in your career endeavors.
