Pass Guaranteed Quiz 2026 Accurate CMAA Construction-Manager: Certified Construc
Posted at 2/6/2026 18:48:45
Many students often start to study as the exam is approaching. Time is very valuable to these students, and for them, one extra hour of study may mean 3 points more on the test score. If you are one of these students, then Construction-Manager exam tests are your best choice. Because students often purchase materials from the Internet, there is a problem that they need transport time, especially for those students who live in remote areas. When the materials arrive, they may just have a little time to read them before the exam. However, with Construction-Manager Exam Questions, you will never encounter such problems, because our materials are distributed to customers through emails. After you have successfully paid, you can immediately receive Construction-Manager test guide from our customer service staff, and then you can start learning immediately.
The users of Construction-Manager exam dumps cover a wide range of fields, including professionals, students, and students of less advanced culture. This is because the language format of our study materials is easy to understand. No matter what information you choose to study, you don’t have to worry about being a beginner and not reading data. Construction-Manager test questions are prepared by many experts. The content is very rich, and there are many levels. Whatever you want to choose, you want to learn from which stage. In our study materials, you can find the right one for you. At the same time, the Construction-Manager Exam Prep is constantly updated. After you have finished learning a part, you can choose a new method according to your own situation. Our study materials are so easy to understand that no matter who you are, you can find what you want here.
Here's the Simple and Quick Way to Pass CMAA Construction-Manager ExamNowadays the requirements for jobs are higher than any time in the past. The job-hunters face huge pressure because most jobs require both working abilities and profound major knowledge. Passing Construction-Manager exam can help you find the ideal job. If you buy our Construction-Manager Test Prep you will pass the exam easily and successfully,and you will realize you dream to find an ideal job and earn a high income. Your satisfactions are our aim of the service and please take it easy to buy our Construction-Manager quiz torrent.
CMAA Certified Construction Manager (CCM) Sample Questions (Q13-Q18):NEW QUESTION # 13
Who owns the float in a typical project critical path schedule?
- A. Construction manager
- B. Project
- C. Owner
- D. Contractor
According toCMAA Time Managementstandards,floatis defined as the amount of time an activity can be delayed without affecting the overall project completion date. The SOP specifies:
"Float is a shared resource belonging to the project as a whole. It is not owned exclusively by any single party
- owner, contractor, or construction manager."
This principle ensures fair schedule management and prevents disputes. Both the CM and the contractor should work collaboratively to optimize float use for the benefit of the entire project. Contract documents (e.
g., general conditions) may further define float management policies, but unless specified otherwise, float is treated asa project resource, not the property of any one participant.
Therefore, the correct answer isC. Project.
CMAA Construction Management Standards of Practice, 2010 Edition, Chapter 5 - Time Management, Section: "Float Ownership." CMAA CM Study Guide, Time Management Domain, Objective 5.3: "Manage schedule float as a shared project resource."
NEW QUESTION # 14
When applying BIM to a project, which method checks for interferences by searching for intersecting volumes?
- A. Clash Detection
- B. Virtual Design and Construction (VDC)
- C. Parametric Modeling
- D. BIM Integration
In the BIM domain,clash detectionis the process by which software analyses models to findgeometric interferences-i.e. overlapping or intersecting volumes between different building elements or systems. This method helps reveal conflicts in the spatial design (for example, a pipe intersecting a beam) before construction, thus avoiding costly corrections in the field.
None of the other options specifically address the detection of intersecting volumes:
BIM Integrationrefers to the combining of different discipline models into a shared environment, not necessarily the conflict checking itself.
Parametric Modelingis a method of defining model geometry through parameters and rules, but does not inherently detect clashes.
Virtual Design and Construction (VDC)is a broader process of using digital modeling and simulation across the design/construction lifecycle; clash detection is a component of it, but the specific method for interference checking is "clash detection."
NEW QUESTION # 15
As the owner's rep, you are providing on-site construction management services to a municipality for their new design-build city mall project.
During your review of the design-build team's schedule update, you discover the project is five weeks behind schedule. What is your recommendation to the owner regarding the document needed from the design-build team to correct the situation?
- A. Short interval schedule
- B. Baseline schedule
- C. Contract modification
- D. Recovery plan
According to theCMAA Standards of Practice (Chapter 4 - Time Management), when a schedule update shows significant delay or variance, the CM should require the contractor or design-build team to prepare a recovery plan. The SOP explains:
"If schedule performance indicates delay or slippage beyond acceptable limits, the contractor shall prepare a recovery schedule or recovery plan demonstrating the specific actions to be taken to regain lost time and complete the project within the contract duration." Thebaseline scheduleestablishes the original plan; it is not revised to reflect recovery actions. Ashort interval schedulemay assist with detailed weekly planning, but the required formal corrective document is the recovery plan.
References (CMAA Construction Manager Documents / Study Guide):
CMAA Construction Management Standards of Practice, 2010 Edition, Chapter 4 - Time Management, Section "Schedule Updates and Recovery Plans." CMAA CM Study Guide, Time Management Domain, Objective 4.3: "Evaluate schedule performance and develop recovery plans when required."
NEW QUESTION # 16
Which schedule process determines the earliest times that schedule activities can start and Finish, and the total project duration?
- A. Backward Pass
- B. Forward Pass
- C. Schedule Update
- D. Master Schedule Review
In theCMAA Construction Management Standards of Practice (SOP), underChapter 4 - Time Management, the process known as theForward Passis defined as the method used in Critical Path Method (CPM) scheduling to determine theearliest possible start (ES)andearliest possible finish (EF)dates for all schedule activities. It also calculates thetotal project durationby progressing through the schedule network from the project start date to the project completion date.
The CMAA explains that:
"A Forward Pass calculates the earliest start and finish times for each activity in a schedule network diagram, thereby identifying the earliest date the project can be completed." This calculation is essential for establishing thecritical path-the sequence of activities that determines the project's overall duration. The Forward Pass is always followed by theBackward Pass, which calculates the latest allowable start and finish times to identify float.
CMAA Construction Management Standards of Practice, Chapter 4 - Time Management, Section: "Schedule Development and Analysis," pp. 47-50.
CMAA CM Study Guide, Time Management Domain, Objective 4.3: "Perform forward and backward pass calculations to determine the critical path."
NEW QUESTION # 17
An inexperienced client on a design-bid-build project states that they do not want the designer to assist in the review of submittals, respond to Requests for Information (RFIs). or conduct any site inspections during the construction phase. How should the CM respond to the client's request?
- A. Agree with the client that this will save the project from unnecessary costs and report that the design documents should be error-free.
- B. Review the Project Procedures Manual (PPM) and then discuss with the client why their approach may add more risk to the project.
- C. Ignore the client and continue coordinating with the design professional to provide these necessary services as part of their contract.
- D. Review the Project Management Plan (PMP) and proceed accordingly.
CMAA's Standards of Practice assert the importance of properly defining roles, responsibilities, and risk allocations in the early planning phases (in the Project Procedures Manual and/or Project Management Plan).
The CM's role includes advising the owner of risks associated with the chosen approach. The CM should use the PPM (or the procedures already established) to inform the owner that omitting design professional services during construction (submittals review, RFI responses, inspections) increases the owner's exposure to errors, claims, and omissions.
Choosing option A means referring back to the formal procedures already agreed upon, educating the client about added risks, and working collaboratively to preserve necessary design-phase involvement. Option B would be insubordinate to the client's direction, C is naively optimistic (design documents are rarely perfect), and D is too passive-it doesn't confront the risk issue effectively.
Thus, reviewing the PPM and discussing the risks with the client is the proper CM response.
NEW QUESTION # 18
Do you want to pass the CMAA Construction-Manager exam better and faster? Then please select the FreePdfDump. It can help you achieve your dreams. FreePdfDump is a website that provide accurate exam materials for people who want to participate in the IT certification. FreePdfDump can help a lot of IT professionals to enhance their career blueprint. Our strength will make you incredible. You can try a part of the questions and answers about CMAA Construction-Manager Exam to test our reliability.
Construction-Manager Practice Exam: https://www.freepdfdump.top/Construction-Manager-valid-torrent.html
Here, our Construction-Manager latest exam dumps will help you to achieve your goals, Experience gives you a clear insight into everything you study for your CMAA Construction-Manager Practice Exam certification exam, CMAA Construction-Manager Free Practice Exams So you will be able to find what you need easily on our website, But you are lucky, we can provide you with well-rounded services on Construction-Manager practice Construction-Manager test materials to help you improve ability and come over difficulties when you have trouble studying, CMAA Construction-Manager Free Practice Exams Keep track of your scores in each exam and apply Kaizen (continuous improvement) to raise the bar on the target score you want to achieve.
When you're ready to purchase items in your basket, tap My Page in the menu bar, Using format strings, Here, our Construction-Manager Latest Exam Dumps will help you to achieve your goals.
Experience gives you a clear insight into everything you Construction-Manager study for your CMAA certification exam, So you will be able to find what you need easily on our website.
High-Efficiency Construction-Manager Exam PDF Guide dumps materials - FreePdfDumpBut you are lucky, we can provide you with well-rounded services on Construction-Manager practice Construction-Manager test materials to help you improve ability and come over difficulties when you have trouble studying.
Keep track of your scores in each exam and apply Reliable Construction-Manager Study Notes Kaizen (continuous improvement) to raise the bar on the target score you want to achieve.
- Valid Construction-Manager Exam Prep 🥊 Valid Construction-Manager Exam Prep 🌭 Construction-Manager Valid Dump ⏺ Search for ▷ Construction-Manager ◁ and easily obtain a free download on ➡ [url]www.testkingpass.com ️⬅️ 🌘Construction-Manager Reliable Exam Tutorial[/url]
- Test Construction-Manager Collection 🦊 Construction-Manager Free Updates ❓ Construction-Manager New Real Test 🌳 Open ( [url]www.pdfvce.com ) enter ▷ Construction-Manager ◁ and obtain a free download 📉Questions Construction-Manager Pdf[/url]
- Exam Construction-Manager Simulations 🔨 Construction-Manager New Real Test 🥙 Construction-Manager Free Updates 🏞 Search for ⏩ Construction-Manager ⏪ and download exam materials for free through “ [url]www.prepawayexam.com ” 🦳Construction-Manager Test Dumps Demo[/url]
- Authoritative Construction-Manager Free Practice Exams - Win Your CMAA Certificate with Top Score 🙎 Search for ➠ Construction-Manager 🠰 and download it for free on [ [url]www.pdfvce.com ] website 🛄Construction-Manager New Real Test[/url]
- Construction-Manager Exams Training ⚜ New Construction-Manager Test Format 🔟 Latest Construction-Manager Test Format 🚪 Open ➠ [url]www.vce4dumps.com 🠰 enter ( Construction-Manager ) and obtain a free download 🌌Valid Construction-Manager Exam Prep[/url]
- Construction-Manager New Exam Materials 🥓 Questions Construction-Manager Pdf 🛫 Construction-Manager Reliable Dumps Questions 🖼 Search for ⮆ Construction-Manager ⮄ and download it for free immediately on 【 [url]www.pdfvce.com 】 🥺Construction-Manager Latest Exam Format[/url]
- Construction-Manager Free Updates 🍘 Exam Construction-Manager Simulations 🟥 Construction-Manager New Real Test 🔢 Search for 【 Construction-Manager 】 and obtain a free download on ➥ [url]www.prepawaypdf.com 🡄 🔋Construction-Manager Valid Dump[/url]
- Construction-Manager Latest Exam Format 🕷 Construction-Manager Latest Exam Format ☸ Construction-Manager Free Updates 💺 Open website ✔ [url]www.pdfvce.com ️✔️ and search for ➠ Construction-Manager 🠰 for free download ⌨Construction-Manager Exam Collection Pdf[/url]
- Latest Construction-Manager Test Practice 👷 Questions Construction-Manager Pdf 🪁 Construction-Manager Exam Collection Pdf 🧫 Search for ☀ Construction-Manager ️☀️ and download it for free immediately on ☀ [url]www.pdfdumps.com ️☀️ 🖼Construction-Manager Reliable Exam Tutorial[/url]
- [url=http://www.mycardiopad.net/?s=Will%20Pdfvce%20Construction-Manager%20Practice%20Questions%20help%20You%20to%20Pass%20the%20certification%20exam? 😽 Search on [ www.pdfvce.com ] for ➤ Construction-Manager ⮘ to obtain exam materials for free download 🚹Construction-Manager Exam Collection Pdf]Will Pdfvce Construction-Manager Practice Questions help You to Pass the certification exam? 😽 Search on [ www.pdfvce.com ] for ➤ Construction-Manager ⮘ to obtain exam materials for free download 🚹Construction-Manager Exam Collection Pdf[/url]
- Valid Construction-Manager Exam Prep 🏩 Construction-Manager New Exam Materials 📟 Construction-Manager Valid Dump 🅱 Open website ▶ [url]www.pass4test.com ◀ and search for ➠ Construction-Manager 🠰 for free download 👘Construction-Manager Exam Study Solutions[/url]
- bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, hhi.instructure.com, Disposable vapes
