[Hardware] Plat-Dev-301 Valid Test Test & Online Plat-Dev-301 Lab Simulation
112
【Hardware】 Plat-Dev-301 Valid Test Test & Online Plat-Dev-301 Lab Simulation
Posted at 1/30/2026 06:25:12      View:115 | Replies:1        Print      Only Author   [Copy Link] 1#
The DumpsTorrent is a leading platform that is committed to making the Plat-Dev-301 exam dumps preparation simple, quick, and successful. To achieve this objective DumpsTorrent is offering real, valid, and updated Salesforce Plat-Dev-301 practice questions in three different formats. These formats are DumpsTorrent Salesforce Plat-Dev-301 PDF Dumps Files, desktop practice test software, and web-based practice test software. All these DumpsTorrent Salesforce Certified Platform Developer II - Multiple Choice exam questions formats are easy to use and compatible with all web browsers, operating systems, and devices.
Our company is widely acclaimed in the industry, and our Plat-Dev-301 learning dumps have won the favor of many customers by virtue of their high quality. Started when the user needs to pass the qualification test, choose the Plat-Dev-301 real questions, they will not have any second or even third backup options, because they will be the first choice of our practice exam materials. Our Plat-Dev-301 practice guide is devoted to research on which methods are used to enable users to pass the test faster. Therefore, through our unremitting efforts, our Plat-Dev-301 Real Questions have a pass rate of 98% to 100%. Therefore, our company is worthy of the trust and support of the masses of users, our Plat-Dev-301 learning dumps are not only to win the company's interests, especially in order to help the students in the shortest possible time to obtain qualification certificates.
Online Plat-Dev-301 Lab Simulation | Exam Plat-Dev-301 Questions AnswersThe main reason why people look for Salesforce Plat-Dev-301 practice test is that these help them to prepare for the exam. Even if you study well but with no idea of the Salesforce Certified Platform Developer II - Multiple Choice Plat-Dev-301 exam pattern, it will be tough to crack the nut. You shall waste your time thinking about the pattern and how to attempt the Salesforce Certified Platform Developer II - Multiple Choice Plat-Dev-301 Exam Questions. On the other hand, if you know the Salesforce Certified Platform Developer II - Multiple Choice Plat-Dev-301 exam questions well, you can use that time to solve the queries and improve your chances to score well in the exam.
Salesforce Certified Platform Developer II - Multiple Choice Sample Questions (Q89-Q94):NEW QUESTION # 89
Which use case can be performed only by using asynchronous Apex?
  • A. Querying tens of thousands of records
  • B. Updating a record after the completion of an insert
  • C. Making a call to schedule a batch process to complete in the future
  • D. Calling a web service from an Apex trigger
Making a callout from an Apex trigger is not allowed synchronously; hence, such callouts must be performed in an asynchronous context. The only way to perform this within the Salesforce platform is by using asynchronous Apex, such as @future methods or Queueable Apex.
NEW QUESTION # 90
An Apex class does not achieve expected code coverage. The testsetup method explicitly calls a method In the Apex class..
How can the developer generate the code coverage?
  • A. Use system.assert() in testSetup to verify the values are being returned.
  • B. Call the Apex class method from a testsetup Instead of the testsetup methed.
  • C. Add @testvisible to the method in the class the developer is testing.
  • D. Verify the user has permissions passing a user into System,.runds().
When an Apex class does not achieve the expected code coverage, it suggests that the test methods are not executing parts of the class. The @testvisible annotation can be used to increase code coverage by allowing test methods to access private or protected members of another class. This enables the test method to call methods that may not be directly accessible, but it is not a direct means to generate code coverage. The code coverage is actually achieved when the test methods execute the code within these methods. Therefore, to properly generate code coverage, the developer must ensure that the test methods call the relevant portions of the code that need to be covered. The use of @testvisible can facilitate this process by making otherwise inaccessible code available for testing.
Apex Developer Guide - Testing Best Practices
Apex Developer Guide - @testVisible Annotation
NEW QUESTION # 91
Consider the Apex controller below, that is called from an Aura component.
What is wrong with this code?
  • A. Line 6: method must be static
  • B. Line 8: method must first serialize the list to JSON before returning
  • C. Line 1: class must be global8. Lines 1 and 6: class and method must be global
The method defined in the Apex class must be static to be used as an Aura-enabled method. Aura-enabled methods need to be static because they are called by the Lightning framework without instantiating the class.
NEW QUESTION # 92
A developer used custom settings to store some configuration data that changes occasionally. However, tests are now Failing in some of the sandboxes that were recently refreshed.
What should be done to eliminate this issue going forward?
  • A. Set the setting type on the custom setting to Hierarchy.
  • B. Replace custom settings with custom metadata.
  • C. Replace custom settings with static resources.
  • D. Set the setting type on the custom setting to List.
Replacing custom settings with custom metadata types is a good solution to ensure that test data is consistent across environments. Custom metadata types are deployable, and their records are available in test methods by default, unlike List Custom Settings which need to be manually recreated in each environment after a refresh.
NEW QUESTION # 93
A developer is trying to access org data from within a test class.
Which sObject type requires the test class to have the (seeAllData=true) annotation?
  • A. User
  • B. Report
  • C. RecordType
  • D. Profile
https://salesforce.stackexchange ... use-seealldata-true
NEW QUESTION # 94
With "reliable credit" as the soul of our Plat-Dev-301 study tool, "utmost service consciousness" as the management philosophy, we endeavor to provide customers with high quality service. Our customer service staff, who are willing to be your little helper and answer your any questions about our Plat-Dev-301 qualification test, fully implement the service principle of customer-oriented service on our Plat-Dev-301 Exam Questions. Any puzzle about our Plat-Dev-301 test torrent will receive timely and effective response, just leave a message on our official website or send us an e-mail for our Plat-Dev-301 study guide.
Online Plat-Dev-301 Lab Simulation: https://www.dumpstorrent.com/Plat-Dev-301-exam-dumps-torrent.html
Then you will concentrate on learning our Plat-Dev-301 study materials, As our company is main business in the market that offers high quality and accuracy Plat-Dev-301 practice materials, we gain great reputation for our Salesforce Developer Plat-Dev-301 practice training, Our Plat-Dev-301 dumps VCE will help you pass exam and obtain a certification, Salesforce Plat-Dev-301 Valid Test Test If you still cannot trust our training material, you will miss a great chance to move forward.
If stuck on a particular question one could Plat-Dev-301 use such clues to make an educated guess therefore decreasing the chances of pointing out the wrong answer, They can find it difficult Exam Plat-Dev-301 Questions Answers to identify their customers when someone shows up at their web site to log in.
Latest Salesforce Plat-Dev-301 Questions – Key To Success In First TryThen you will concentrate on learning our Plat-Dev-301 Study Materials, As our company is main business in the market that offers high quality and accuracy Plat-Dev-301 practice materials, we gain great reputation for our Salesforce Developer Plat-Dev-301 practice training.
Our Plat-Dev-301 dumps VCE will help you pass exam and obtain a certification, If you still cannot trust our training material, you will miss a great chance to move forward.
However, you do not have to worry about the exam now.
Posted at 2/4/2026 09:47:30        Only Author  2#
MO-210トレーニング資料を用意しました。これらは、保証期間中の専門的な練習資料です。参考のために許容できる価格に加えて、3つのバージョンのすべての資料は、10年以上にわたってこの分野の専門家によって編集されています。さらに、一連の利点があります。したがって、MO-210の実際のテストの重要性は言うまでもありません。今すぐご注文いただいた場合、1年間無料の更新をお送りします。これらのサプリメントはすべて、MO-210模擬試験にも役立ちます。
