Valid DVA-C02 Exam Syllabus, DVA-C02 Visual Cert Exam
Posted at 1/22/2026 07:39:24
View163
Replies2
P.S. Free 2026 Amazon DVA-C02 dumps are available on Google Drive shared by TroytecDumps: https://drive.google.com/open?id=1U7eURDgxmjTtfGmyb_2Jzg7uYGiueTka
We have handled professional DVA-C02 practice materials for over ten years. Our experts have many years experience in this particular line of business, together with meticulous and professional attitude towards jobs. Their abilities are unquestionable, besides, DVA-C02 Exam Questions are priced reasonably with three kinds: the PDF, Software and APP online. Though the content is the same, but their displays are totally different and functionable.
The DVA-C02 exam is designed to assess the developer's ability to develop, deploy, and maintain AWS-based applications using AWS SDKs, APIs, and AWS CLI. DVA-C02 exam is also designed to test the developer's understanding of AWS services such as AWS Lambda, Amazon Elastic Beanstalk, Amazon EC2, and Amazon RDS. DVA-C02 Exam requires the candidate to have a deep understanding of AWS services and how they can be used to create robust and scalable applications.
100% Pass Quiz 2026 DVA-C02: Efficient Valid AWS Certified Developer - Associate Exam SyllabusNowadays the competition in the society is fiercer and if you dont have a specialty you cant occupy an advantageous position in the competition and may be weeded out. Passing the test DVA-C02 certification can help you be competent in some area and gain the competition advantages in the labor market. If you buy our DVA-C02 Study Materials you will pass the DVA-C02 exam smoothly. You will feel grateful for choosing us!
Amazon AWS Certified Developer - Associate Sample Questions (Q63-Q68):NEW QUESTION # 63
A developer has code that is stored in an Amazon S3 bucket. The code must be deployed as an AWS Lambda function across multiple accounts in the same AWS Region as the S3 bucket. An AWS CloudFormation template that runs for each account will deploy the Lambda function.
What is the MOST secure way to allow CloudFormation to access the Lambda code in the S3 bucket?
- A. Use a service-based link to grant the Lambda function the S3 ListBucket and GetObject permissions by explicitly adding the S3 bucket's account number in the resource.
- B. Grant the CloudFormation service role the S3 GetObject permission. Add a bucket policy to Amazon S3 with the principal of "*:".
- C. Use a service-based link to grant the Lambda function the S3 GetObject permission. Add a resource of "*" to allow access to the S3 bucket.
- D. Grant the CloudFormation service role the S3 ListBucket and GetObject permissions. Add a bucket policy to Amazon S3 with the principal of "AWS": [account numbers].
Option (A) is the safest way to allow CloudFormation to access the Lambda code in the S3 bucket because it limits access to the specific accounts that need to deploy the Lambda functions. The bucket policy grants S3 ListBucket and GetObject permissions to the CloudFormation service role only for the accounts specified in the principal.
NEW QUESTION # 64
A developer accesses AWS CodeCommit over SSH. The SSH keys configured to access AWS CodeCommit are tied to a user with the following permissions:
The developer needs to create/delete branches
Which specific IAM permissions need to be added based on the principle of least privilege?
- A. Option B
- B. Option A
- C. Option D
- D. Option C
This solution allows the developer to create and delete branches in AWS CodeCommit by granting the codecommit:CreateBranch and codecommit eleteBranch permissions. These are the minimum permissions required for this task, following the principle of least privilege. Option B grants too many permissions, such as codecommit ut*, which allows the developer to create, update, or delete any resource in CodeCommit.
Option C grants too few permissions, such as codecommit:Update*, which does not allow the developer to create or delete branches. Option D grants all permissions, such as codecommit:*, which is not secure or recommended.
NEW QUESTION # 65
A company has a multi-node Windows legacy application that runs on premises. The application uses a network shared folder as a centralized configuration repository to store configuration files in .xml format. The company is migrating the application to Amazon EC2 instances. As part of the migration to AWS, a developer must identify a solution that provides high availability for the repository.
Which solution will meet this requirement MOST cost-effectively?
- A. Deploy a micro EC2 instance with an instance store volume. Use the host operating system to share a folder. Update the application code to read and write configuration files from the shared folder.
- B. Create an Amazon S3 bucket to host the repository. Migrate the existing .xml files to the S3 bucket.
Update the application code to use the AWS SDK to read and write configuration files from Amazon S3. - C. Create an Amazon S3 bucket to host the repository. Migrate the existing .xml files to the S3 bucket.
Mount the S3 bucket to the EC2 instances as a local volume. Update the application code to read and write configuration files from the disk. - D. Mount an Amazon Elastic Block Store (Amazon EBS) volume onto one of the EC2 instances. Deploy a file system on the EBS volume. Use the host operating system to share a folder. Update the application code to read and write configuration files from the shared folder.
Amazon S3 is a service that provides highly scalable, durable, and secure object storage. The developer can create an S3 bucket to host the repository and migrate the existing .xml files to the S3 bucket. The developer can update the application code to use the AWS SDK to read and write configuration files from S3. This solution will meet the requirement of high availability for the repository in a cost-effective way.
* [Amazon Simple Storage Service (S3)]
* [Using AWS SDKs with Amazon S3]
NEW QUESTION # 66
A company introduced a new feature that should be accessible to only a specific group of premium customers. A developer needs the ability to turn the feature on and off in response to performance and feedback. The developer needs a solution to validate and deploy these configurations quickly without causing any disruptions.
What should the developer do to meet these requirements?
- A. Use AWS AppConfig to manage the feature configuration and to validate and deploy changes.
Use feature flags to turn the feature on and off. - B. Use AWS Systems Manager Parameter Store to store and validate the configuration settings for the feature. Enable lifecycle rules to turn the feature on and off.
- C. Use AWS Config to manage the feature configuration and validation. Set up AWS Config rules to turn the feature on and off based on predefined conditions.
- D. Use AWS Secrets Manager to securely manage and validate the feature configurations. Enable lifecycle rules to turn the feature on and off.
NEW QUESTION # 67
A company has a serverless application that uses Amazon API Gateway backed by AWS Lambda proxy integration. The company is developing several backend APIs. The company needs a landing page to provide an overview of navigation to the APIs.
A developer creates a new /LandingPage resource and a new GET method that uses mock integration.
What should the developer do next to meet these requirements?
- A. Configure the integration request mapping template with Content-Type of text/html. In the integration request mapping template, include the LandingPage HTML code that references the APIs. Configure the integration response mapping template with Content-Type of application/json and statusCode of 200.
- B. Configure the Integration request mapping template with Content-Type of application/json. In the integration request mapping template, include the LandingPage HMTL code that references the APIs.
Configure the integration response mapping template with Content-Type of text/html and statusCode of
200. - C. Configure the integration request mapping template with Content-Type of application/json and statusCode of 200. Configure the integration response mapping template with Content-Type of text
/html. In the integration response mapping template, include the LandingPage HTML code that references the APIs. - D. Configure the integration request mapping template with Content-Type of text/html and statusCode of
200. Configure the integration response mapping template with Content-Type of application/json. In the integration response mapping template, include the LandingPage HTML code that references the APIs.
NEW QUESTION # 68
Our goal is to help you save both time and money by providing you with the DVA-C02 updated exam questions. Keep up the good work on preparing for the Amazon DVA-C02 test with our actual Amazon DVA-C02 Dumps. We are so confident that you will succeed on the first try that we will return your money according to the terms and conditions if you do not.
DVA-C02 Visual Cert Exam: https://www.troytecdumps.com/DVA-C02-troytec-exam-dumps.html
- Valid DVA-C02 Exam Syllabus - Provide Valid Material to pass AWS Certified Developer - Associate 👌 Search for ⏩ DVA-C02 ⏪ on [ [url]www.prep4sures.top ] immediately to obtain a free download ☢DVA-C02 Latest Exam Labs[/url]
- DVA-C02 Test Pattern 🏁 DVA-C02 Test Valid ⏰ DVA-C02 Latest Exam Practice 🐔 Search for ➥ DVA-C02 🡄 and download exam materials for free through ⏩ [url]www.pdfvce.com ⏪ 🤥DVA-C02 Dump File[/url]
- Free PDF 2026 DVA-C02: AWS Certified Developer - Associate High Hit-Rate Valid Exam Syllabus 🟩 Open website ▶ [url]www.practicevce.com ◀ and search for DVA-C02 for free download 🔴DVA-C02 Guaranteed Passing[/url]
- Formats of Pdfvce Updated Amazon DVA-C02 Exam Practice Questions ⛄ Search for DVA-C02 and download exam materials for free through ✔ [url]www.pdfvce.com ️✔️ 🥋Related DVA-C02 Certifications[/url]
- Free PDF 2026 DVA-C02: AWS Certified Developer - Associate High Hit-Rate Valid Exam Syllabus 😤 Download ▶ DVA-C02 ◀ for free by simply entering ⇛ [url]www.troytecdumps.com ⇚ website 👺DVA-C02 Valid Exam Camp Pdf[/url]
- Amazon - DVA-C02 CTrustable Valid Exam Syllabus 🚋 Search for DVA-C02 and easily obtain a free download on [url]www.pdfvce.com 🍓DVA-C02 Latest Test Cram[/url]
- Updated Amazon Valid DVA-C02 Exam Syllabus Are Leading Materials - Effective DVA-C02: AWS Certified Developer - Associate 🚐 Search for ☀ DVA-C02 ️☀️ and easily obtain a free download on ☀ [url]www.validtorrent.com ️☀️ 🌲DVA-C02 Exam Tutorials[/url]
- DVA-C02 Exam Tutorials 🎤 DVA-C02 Latest Exam Practice 🏵 DVA-C02 Latest Exam Labs 🙅 The page for free download of DVA-C02 on { [url]www.pdfvce.com } will open immediately 😮New DVA-C02 Exam Questions[/url]
- 100% Pass Amazon - The Best Valid DVA-C02 Exam Syllabus 🔜 Open ✔ [url]www.testkingpass.com ️✔️ enter [ DVA-C02 ] and obtain a free download 🙄New DVA-C02 Exam Pass4sure[/url]
- Formats of Pdfvce Updated Amazon DVA-C02 Exam Practice Questions 🌿 Search for ➽ DVA-C02 🢪 and download it for free on { [url]www.pdfvce.com } website 💫Test DVA-C02 Collection Pdf[/url]
- 100% Pass Amazon - The Best Valid DVA-C02 Exam Syllabus ⏭ Copy URL ☀ [url]www.troytecdumps.com ️☀️ open and search for { DVA-C02 } to download for free 🙈New DVA-C02 Exam Questions[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, disqus.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.dkcomposite.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
What's more, part of that TroytecDumps DVA-C02 dumps now are free: https://drive.google.com/open?id=1U7eURDgxmjTtfGmyb_2Jzg7uYGiueTka
