[Hardware] Valid HPE7-A01 Test Answers - New HPE7-A01 Test Vce
75
【Hardware】 Valid HPE7-A01 Test Answers - New HPE7-A01 Test Vce
Posted at 1/12/2026 04:09:28      View:220 | Replies:2        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of GetValidTest HPE7-A01 dumps from Cloud Storage: https://drive.google.com/open?id=1KFp0wz51o_YsSPwYb76ZQKjyv3XjCaCN
The only aim of our company is to help each customer pass their exam as well as getting the important certification in a short time. If you want to pass your exam and get the HPE7-A01 certification which is crucial for you successfully, I highly recommend that you should choose the HPE7-A01 certification preparation materials from our company so that you can get a good understanding of the exam that you are going to prepare for. We believe that if you decide to buy the HPE7-A01 Exam Materials from our company, you will pass your exam and get the certification in a more relaxed way than other people.
The HP HPE7-A01 exam consists of 60 multiple-choice questions that cover a range of topics related to wireless networking, including network fundamentals, wireless LAN design, installation and configuration, troubleshooting, and security. HPE7-A01 Exam is timed and candidates have 90 minutes to complete it. To pass the exam, candidates must score at least 65%.
New HPE7-A01 Test Vce | HPE7-A01 Free Exam QuestionsImprovement in HPE7-A01 science and technology creates unassailable power in the future construction and progress of society. HPE7-A01 practice test can be your optimum selection and useful tool to deal with the urgent challenge. With over a decade's striving, our HPE7-A01 training materials have become the most widely-lauded and much-anticipated products in industry. We have full technical support from our professional elites in planning and designing HPE7-A01 Practice Test. Do not hesitate anymore. You will never regret buying HPE7-A01 study engine!
HP Aruba Certified Campus Access Professional Exam Sample Questions (Q103-Q108):NEW QUESTION # 103
What are the requirements to ensure that WMM is working effectively'? (Select two)
  • A. The APs and the controller are Wi-Fi CERTIFIED for WMM which is enabled
  • B. All APs need to be from the AP-5xx series and AP-6xx series which are Wi-Fi CERTIFIED 6.
  • C. The Client must be Wi-Fi CERTIFIED for WMM and configured for WMM marking.
  • D. The Aruba AOS10 APs installed have to be converted to controlled mode
  • E. The AP needs to be connected via a tagged VLAN to the wired port
These are the correct requirements to ensure that WMM (Wi-Fi Multimedia) is working effectively. WMM is a standard that provides quality of service (QoS) for wireless networks by prioritizing traffic into four categories: voice, video, best effort, and background. To use WMM, both the APs and the controller must be Wi-Fi CERTIFIED for WMM, which means they have passed interoperability tests and comply with the standard. WMM must also be enabled on the APs and the controller, which is usually the default setting. The client device must also be Wi-Fi CERTIFIED for WMM and configured for WMM marking, which means it can tag its traffic with the appropriate priority level based on the application type. The other options are incorrect because they are either not related to WMM or not required for WMM to work. References:
https://www.arubanetworks.com/te ... ions/wlan-qos/wmm.h
https://www.wi-fi.org/discover-wi-fi/wi-fi-certified-wmm
NEW QUESTION # 104
A customer is using a legacy application that communicates at layer-2. The customer would like to keep this application working across the campus which is connected via layer-3. The legacy devices are connected to Aruba CX 6300 switches throughout the campus. Which technology minimizes flooding so the legacy application can work efficiently?
  • A. Ethernet over IP (EolP)
  • B. EVPN-VXLAN
  • C. Static VXLAN
  • D. Generic Routing Encapsulation (GRE)
EVPN-VXLAN is a technology that allows layer-2 communication across layer-3 networks by using Ethernet VPN (EVPN) as a control plane and Virtual Extensible LAN (VXLAN) as a data plane. EVPN-VXLAN can be used to support legacy applications that communicate at layer-2 across different campuses or data centers that are connected via layer-3. EVPN-VXLAN minimizes flooding by using BGP to distribute MAC addresses and IP addresses of hosts across different VXLAN segments. EVPN-VXLAN also provides benefits such as loop prevention, load balancing, mobility, and scalability.
NEW QUESTION # 105
What is the best practice for handling voice traffic with dynamic segmentation on AOS-CX switches?
  • A. Switch authentication and local forwarding of the voice traffic
  • B. Switch authentication and user-based tunneling of the voice traffic.
  • C. Controller authentication and port-based tunneling of all traffic
  • D. Central authentication and port-based tunneling of the voice traffic.
This is the best practice for handling voice traffic with dynamic segmentation on AOS-CX switches. Dynamic segmentation is a feature that allows AOS-CX switches to tunnel user traffic to a controller or another switch based on user roles and policies. For voice traffic, it is recommended to use switch authentication and local forwarding, which means the voice devices are authenticated by the switch and their traffic is forwarded locally without tunneling. This reduces latency and jitter for voice traffic and improves voice quality. The other options are incorrect because they either use central authentication or tunneling, which are not optimal for voice traffic. References:
https://www.arubanetworks.com/te ... 6728/bk01-ch05.html
https://www.arubanetworks.com/assets/ds/DS_AOS-CX.pdf
NEW QUESTION # 106
When setting up an Aruba CX VSX pair, which information does the Inter-Switch Link Protocol configuration use in the configuration created?
  • A. MAC tables
  • B. QSVI
  • C. UDLD
  • D. RPVST+
UDLD (Unidirectional Link Detection) is the information that the Inter-Switch Link Protocol configuration uses in the configuration created for Aruba CX VSX pair inter-switch-link. UDLD is a protocol that detects unidirectional links between switches and prevents loops or black holes in the network. UDLD is enabled by default on all ports that are part of the inter-switch-link between VSX peers. The other options are incorrect because they are either not related to inter-switch-link or not supported by Aruba CX VSX.
NEW QUESTION # 107
The customer needs a network hardware refresh to replace an aging Aruba 5406R core switch pair using spanning tree configuration with Aruba CX 8360-32YC switches What is the benefit of VSX clustering with the new solution?
  • A. dual Aruba AP LAN port connectivity for PoE redundancy
  • B. dual control plane provides better resiliency
  • C. stacked data-plane
  • D. faster MSTP converge processing
VSX clustering is a feature that allows two Aruba CX switches to operate as a single logical device, providing high availability, scalability, and simplified management. VSX clustering has several benefits over spanning tree configuration, such as:
Dual control plane provides better resiliency. Unlike stacking, where switches share a single control plane, VSX switches have independent control planes that synchronize their states over an inter-switch link (ISL). This means that if one switch fails or reboots, the other switch can continue to operate without affecting traffic flows or network services.
Active-active forwarding provides better performance. Unlike spanning tree, where some links are blocked to prevent loops, VSX switches use all available links for forwarding traffic, providing load balancing and increased bandwidth utilization.
Multichassis LAG provides better redundancy. Unlike single-chassis LAG, where all member ports belong to one switch, VSX switches can form multichassis LAGs with downstream or upstream devices, where member ports are distributed across both switches. This provides link redundancy and seamless failover in case of switch or port failure.
NEW QUESTION # 108
Aruba Certified Campus Access Professional Exam HPE7-A01 practice test not only gives you the opportunity to practice with real exam questions but also provides you with a self-assessment report highlighting your performance in an attempt. GetValidTest keeps an eye on changes in the HP HPE7-A01 exam syllabus and updates Aruba Certified Campus Access Professional Exam HPE7-A01 Exam Dumps accordingly to make sure they are relevant to the latest exam topics. After making the payment for Aruba Certified Campus Access Professional Exam HPE7-A01 dumps questions you'll be able to get free updates for up to 365 days.
New HPE7-A01 Test Vce: https://www.getvalidtest.com/HPE7-A01-exam.html
P.S. Free & New HPE7-A01 dumps are available on Google Drive shared by GetValidTest: https://drive.google.com/open?id=1KFp0wz51o_YsSPwYb76ZQKjyv3XjCaCN
Posted at 1/18/2026 04:44:08        Only Author  2#
The content is too good not to like. Get your hands on the Test Service-Con-201 dumps free test that helped me achieve a promotion and salary increase, and it’s available for free today. I hope you hit your career goals soon!
Posted at 2/21/2026 08:23:58        Only Author  3#
This article is absolutely amazing, thank you for sharing! Free Valid H12-841_V1.5 test cost questions—unlock promotions and salary raises in your career!
