[General] 新版C_S4TM_2023題庫 & C_S4TM_2023新版題庫上線
87
【General】 新版C_S4TM_2023題庫 & C_S4TM_2023新版題庫上線
Posted at 1/25/2026 00:27:42      View:182 | Replies:1        Print      Only Author   [Copy Link] 1#
順便提一下,可以從雲存儲中下載NewDumps C_S4TM_2023考試題庫的完整版:https://drive.google.com/open?id=1nGKnF8RXclWNWxmvPP-xLFCuwPX_7fIc
長久以來,SAP 就是電腦的代名詞。無論在美國國內還是在世界的電腦領域裏,SAP 都有著極其深遠的影響。而 C_S4TM_2023 考試是 SAP 公司的 SAP Certified Associate - SAP S/4HANA Cloud Private Edition - Transportation Management 證照考試官方代號,也是現在最熱門的證照考試,含金量很高。而獲得 SAP 的 C_S4TM_2023 證照不僅僅能證明您的IT技術能力,更是您進入職場的敲門磚,也是提高您身價的另一捷徑。
NewDumps的C_S4TM_2023考古題是你準備C_S4TM_2023認證考試時最不能缺少的資料。這個資料的價值等同於其他一切的與考試相關的參考書。這種說法並不誇張。只要你用了它你就會發現,這一切都是真的。
C_S4TM_2023新版題庫上線,C_S4TM_2023認證題庫如果你擁有了NewDumps SAP的C_S4TM_2023考試培訓資料,我們將免費為你提供一年的更新,這意味著你總是得到最新的考試認證資料,只要考試目標有所變化,以及我們的學習材料有所變化,我們將在第一時間為你更新。我們知道你的需求,我們將幫助得到 SAP的C_S4TM_2023考試認證的信心,讓你可以安然無憂的去參加考試,並順利通過獲得認證。
SAP C_S4TM_2023 考試大綱:
主題簡介
主題 1
  • Transportation Planning: The sub-topics here include network setup, profile configuration, and VSR optimizer calibration for automatic planning, all essential for efficient transportation planning.
主題 2
  • Freight Order Management: Carrier selection, tendering, freight documents, and integrations are covered here. This topic also includes communication with external and internal parties, a key aspect of freight order management.
主題 3
  • SAP Transportation Management Overview and Fundamentals: This topic covers the general processes and functional areas of SAP Transportation Management, including external and embedded systems. It also discusses transportation tasks and their management.
主題 4
  • Managing Clean Core: This topic discusses the evaluation and application of clean core principles to maximize agility, reduce effort, and accelerate innovation in ERP systems.
主題 5
  • Transportation Management for Logistics Service Provider (LSP): This topic focuses on order management and transportation processes specific to LSPs, including forwarding orders.
最新的 SAP Certified Associate C_S4TM_2023 免費考試真題 (Q24-Q29):問題 #24
To which of the following can you assign a dimensional weight profile?
  • A. Calculation base
  • B. Charge type
  • C. Calculation profile
  • D. Charge profile
答案:C
問題 #25
A carrier has an agreement with a shipper on January 1st, for fuel price as 5% of the base freight. Fuel surcharge is pegged to the current price of 3 USD a gallon. The fuel surcharge can change proportionally based on the fuel price on the pricing date. How will you define fuel surcharge calculation in SAPTM? Note: there are 2 correct answers to this question.
  • A. Use a calculation reference for the fuel surcharge charge item
  • B. Use a rate table for fuel surcharge with pricing date as a scale
  • C. Use a rate table determination rule for fuel surcharge
  • D. Use an index table for the fuel surcharge charge item
答案:A,D
問題 #26
To which of the following document types can you assign change controller strategies?
  • A. Service order
  • B. Freight order
  • C. Order-based transportation requirement
  • D. Forwarding order
答案:C,D
問題 #27
Which of the following SAP TM and SAP ERP objects can you map?
  • A. SAP TM charge type to SAP ERP service master
  • B. SAP TM purchasing organization to SAP ERP plant
  • C. SAP TM charge category to SAP ERP G/L account
  • D. SAP TM charge type to SAP ERP service material group
答案:A,B
問題 #28
You run the report to delete a one-time location that was used in a forwarding order. After the report is finished the location is NOT deleted. What could be the reason for this?
  • A. There are still messages in the incoming queue.
  • B. SAP ERP is the leading system for the master data of this location
  • C. The location is part of an active core interface (CIF) integration model
  • D. There are still existing orders for the location
答案:D
問題 #29
面對競爭激勵的世界,唯有考取和別人不一樣的證照,才可以充實自己,知識就是力量。購買 SAP C_S4TM_2023 題庫,可以免費享受一年的更新題庫的售后服務,在購買前享有免費試用部分考題DEMO。我們提供PDF和軟體格式的考題,其中PDF版本可以列印,軟體版的題庫可以模擬真實的 SAP 的 C_S4TM_2023 考試。正確率100%,考生可以參照最新的 C_S4TM_2023 認證部分考題。
C_S4TM_2023新版題庫上線: https://www.newdumpspdf.com/C_S4TM_2023-exam-new-dumps.html
2026 NewDumps最新的C_S4TM_2023 PDF版考試題庫和C_S4TM_2023考試問題和答案免費分享:https://drive.google.com/open?id=1nGKnF8RXclWNWxmvPP-xLFCuwPX_7fIc
Posted at 1/25/2026 16:47:44        Only Author  2#
This article is absolutely stunning, thank you for sharing! Improve your IT skills and grab the free Real CSSBB dumps free. Best of luck with everything!
