New Topic
[Hardware] Custom LVDS display
117
【Hardware】 Custom LVDS display
Posted at 1/16/2022 16:59:25      View:3579 | Replies:11        Print      Only Author   [Copy Link] 1#
I want to connect LA103WF4-SL03 display. It have 60 pin LVDS connector and resolution 1920x720.
Can I use LVDS 60 to 40 pins adapter and connect it to MIPI1 slot?
Posted at 1/25/2022 09:36:22        Only Author  2#
You need to confirm whether the hardware line order is consistent. On this basis, it is also necessary to make some modifications to the driver so that the screen can be displayed normally.
Posted at 1/29/2022 16:19:07        Only Author  3#
Probably I need adapter on TC358775 chip or similar, because display have dual-link interface with 8 LVDS lines
Posted at 2/1/2022 13:03:49        Only Author  4#
时间的蝴蝶 Posted at 1/25/2022 09:36
You need to confirm whether the hardware line order is consistent. On this basis, it is also necessa ...
Dual Link LVDS need 8 dat lines. But as Iunderstand I can use only DSI0 port for LVDS and it have only 4 data lines. Is it possible to use DSI1 with DSI0 for connecting dual link LVDS?
Posted at 2/10/2022 15:40:42        Only Author  5#
Alexey83 Posted at 2/1/2022 13:03
Dual Link LVDS need 8 dat lines. But as Iunderstand I can use only DSI0 port for LVDS and it have  ...
Only DSI0 can be multiplexed as LVDS.
Posted at 2/14/2022 17:25:13        Only Author  6#
Is it possible to get adapter like https://developer.toradex.com/products/verdin-dsi-to-lvds-adapter#tab-features for our board?
Posted at 2/16/2022 15:11:23        Only Author  7#
Alexey83 Posted at 2/14/2022 17:25
Is it possible to get adapter like https://developer.toradex.com/products/verdin-dsi-to-lvds-adapter ...
I think that's doable.
Posted at 2/17/2022 04:33:48        Only Author  8#
Where I can ask about creating similar adapter for our board?
Posted at 2/21/2022 14:22:19        Only Author  9#
Alexey83 Posted at 2/17/2022 04:33
Are you going to make your own adapters? I'm not sure.
Posted at 2/21/2022 20:12:23        Only Author  10#
时间的蝴蝶 Posted at 2/21/2022 14:22
Well if it not possible to create public adapters for all then I will go to create my own adapters
Return to List
12
