[Hardware] Exam 300-540 Certification Cost & 300-540 Valid Dumps Files
32
【Hardware】 Exam 300-540 Certification Cost & 300-540 Valid Dumps Files
Posted at 4/20/2026 11:39:29      View:85 | Replies:0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of Dumpkiller 300-540 dumps from Cloud Storage: https://drive.google.com/open?id=1106HxPkla0P__QspAuVcSQR08zVXHiBv
Our company has employed a lot of leading experts in the field to compile the Designing and Implementing Cisco Service Provider Cloud Network Infrastructure exam question. Our system of team-based working is designed to bring out the best in our people in whose minds and hands the next generation of the best 300-540 exam torrent will ultimately take shape. Our company has a proven track record in delivering outstanding after sale services and bringing innovation to the guide torrent. I believe that you already have a general idea about the advantages of our Designing and Implementing Cisco Service Provider Cloud Network Infrastructure exam question, but now I would like to show you the greatest strength of our 300-540 Guide Torrent --the highest pass rate. According to the statistics, the pass rate among our customers who prepared the exam under the guidance of our 300-540 guide torrent has reached as high as 98% to 100% with only practicing our 300-540 exam torrent for 20 to 30 hours.
Our 300-540 study quiz boosts many advantages and it is your best choice to prepare for the test. Our 300-540 learning prep is compiled by our first-rate expert team and linked closely with the real exam. And our 300-540 training materials provide three versions and multiple functions to make the learners have no learning obstacles. The passing rate of our 300-540 Guide materials is high and you don’t need to worry that you have spent money but can’t pass the test.
300-540 Valid Dumps Files - 300-540 Actual Exam DumpsWith the 300-540 certification exam you can climb up the corporate ladder faster and achieve your professional career objectives. Do you plan to enroll in the Cisco 300-540 certification exam? Looking for a simple and quick way to crack the 300-540 test? If your answer is yes then you need to start Cisco 300-540 Test Preparation with Cisco 300-540 PDF Questions and practice tests. With the Dumpkiller Designing and Implementing Cisco Service Provider Cloud Network Infrastructure 300-540 practice test questions you can prepare yourself shortly for the final Cisco 300-540 exam.
Cisco Designing and Implementing Cisco Service Provider Cloud Network Infrastructure Sample Questions (Q68-Q73):NEW QUESTION # 68
Refer to the exhibit. An engineer must deploy a standalone Cisco NFVIS. These configurations were performed already:
Deployed the virtual machine
Configured the hostname and IP address
Configured dual WAN support
When the engineer attempts to access the NFVIS portal, the API returns a 401 Unauthorized error. What is the cause of the issue?
  • A. The default admin password must be reset.
  • B. Portal access must be enabled via SSH.
  • C. The browser certificate must be renewed.
  • D. The Tomcat service must be restarted.
Cisco NFVIS follows strict security controls. After a fresh deployment:
* Thedefault admin credentials are considered insecure.
* NFVIS requires the administrator toreset the default password on first login(typically via console or SSH).
* Until the password is changed,REST API and web-portal access are denied, and attempts to access the portal or API returnHTTP 401 Unauthorized, even if the default credentials are provided.
This mechanism prevents use of factory-default passwords in production and is explicitly documented as a mandatory post-install step.
The other options are not the cause of a 401 error:
* Enabling portal via SSH (B) is not required; HTTPS access is enabled by default once credentials are valid.
* Restarting Tomcat (C) would address service availability issues (e.g., 5xx errors), not authentication.
* Browser certificates (D) affect trust warnings (e.g., HTTPS certificate errors), not 401 Unauthorized.
NEW QUESTION # 69
An engineer must add VNF implementation definitions and VNF service definitions to an OpenStack deployment data model to deploy virtual routers and firewalls to an enterprise network. After the virtual machine resources are prepared, which action must be taken next?
  • A. Configure key performance indicator monitoring.
  • B. Create the initial configuration for day zero.
  • C. Specify the operational characteristics.
  • D. Define the NFV network.
In an NFV environment following Cisco NFV Infrastructure and ETSI MANO architecture, the onboarding workflow for VNF deployment follows this high-level order:
* Define VNF descriptors (VNFD and NSD)- Includes implementation details and service definitions.
* Prepare virtual machine resources- Flavor, image, CPU/memory/storage, and placement.
* Define the NFV network- This step builds the underlay/overlay connectivity needed for the VNF.- It includes virtual network creation, interfaces, VLs (Virtual Links), connection points, and mapping into OpenStack (Neutron networks, subnets, ports).- No VNF can be deployed until the NFV service networks (management, control, data, HA) are defined.
* Apply Day-0 configuration- Bootstrapping/initial config.
* Apply Day-1 operational characteristics- Routing, services, policies.
* Configure operational monitoring (KPIs)- Performance and fault measurements.
Since the question states"after the VM resources are prepared", the next mandatory stage is defining the virtual network connectivity on which the VNFs will operate.
NEW QUESTION # 70
BGP multi-path is used in ECMP to enable __________ routing paths for traffic.
  • A. dual
  • B. single
  • C. multiple
  • D. no
NEW QUESTION # 71
Network segmentation in a service provider cloud environment is important for:
  • A. Centralizing all resources
  • B. Decreasing performance
  • C. Increasing complexity
  • D. Isolating resources and reducing attack surfaces
NEW QUESTION # 72
What is a valid connection method between carrier-neutral facilities within the same metro area?
  • A. private wireless connection
  • B. DWDM ring
  • C. OSPF backbone area adjacency
  • D. CAT6e connection
Comprehensive and Detailed Explanation Based on Designing and Implementing Cisco Service Provider Cloud Network Infrastructure Knowledge When connectingcarrier-neutral facilities (CNFs)ordata centerswithin the same metropolitan area, service providers typically usehigh-bandwidth, low-latency optical transport methods. The most appropriate and commonly deployed interconnection technology is:
DWDM (Dense Wavelength Division Multiplexing) ring, which provides:
* High capacity (10G, 40G, 100G, 400G)
* Low latency
* Redundancy through ring or mesh topologies
* Multi-wavelength multiplexing for cost efficiency
* Carrier-grade reliability for metro interconnect services
This aligns with cloud interconnect and metro transport design used in service provider environments.
Evaluation of the Options
A). OSPF backbone area adjacency
This is a routing protocol adjacency, not a physical connection method. It requires a transport link underneath but does not represent the physical interconnect itself.
B). Private wireless connection
Not suitable for CNF or metro DC interconnect because it lacks the bandwidth, reliability, and deterministic performance required for large-scale carrier-grade interconnects.
C). DWDM ring
This is the correct method. DWDM-based metro fiber rings are the standard for connecting carrier-neutral facilities in the same metro region.
D). CAT6e connection
This is limited to short-distance copper Ethernet (tens of meters). It is not used for metro-scale interconnects or between CNFs.
NEW QUESTION # 73
With Dumpkiller user-friendly Designing and Implementing Cisco Service Provider Cloud Network Infrastructure (300-540) PDF format, you can prepare for the exam from any location at any time via laptops, tablets, and smartphones. In this Cisco 300-540 PDF document, we have included latest and 300-540 Real Exam Questions. Dumpkiller has made the 300-540 PDF format to make it easier for students to acquire knowledge they need to ace the Cisco exam.
300-540 Valid Dumps Files: https://www.dumpkiller.com/300-540_braindumps.html
If they do discover any renewal in our 300-540 torrent VCE, they will in the first time inform the customers of the renewal by sending the downloading of 300-540 dumps torrent to the customers, Cisco Exam 300-540 Certification Cost How The Guarantee Works, ExamsLead is providing actual study material for the 300-540 exam and has made things very easier for candidates to get themselves prepare for the 300-540 exam, Cisco Exam 300-540 Certification Cost It is really time-consuming & money-saving.
Problem Solving Illustrated, There are Web sites that act 300-540 Valid Dumps Files as corporate directories, and others that function as direct-mail catalogs, If they do discover any renewalin our 300-540 Torrent VCE, they will in the first time inform the customers of the renewal by sending the downloading of 300-540 dumps torrent to the customers.
3 Formats of Cisco 300-540 Dumps that Suit your Study StyleHow The Guarantee Works, ExamsLead is providing actual study material for the 300-540 exam and has made things very easier for candidates to get themselves prepare for the 300-540 exam.
It is really time-consuming & money-saving, 300-540 All international orders must be paid for at the time of purchase.
