Amazon SAP-C02 PDF} - SAP-C02yԇ
Posted at 1/13/2026 19:13:47
View181
Replies2
2026 PDFExamDumpsµSAP-C02 PDF濼ԇ}SAP-C02ԇ}ʹMhttps://drive.google.com/open?id=1L44EgumyfswB_g9b57TX-fSr4gOYUviH
SAP-C02 }wµĿԇָϣ_һͨ^ SAP-C02 ԇAmazon JCҸ SAP-C02 ԇ}ӆmȫĿʹã߿ͨ^ʡAWS Certified Solutions Architect һW·JCȫJČIJCSAP-C02 JCҪĿW·̎ڬF׃ѸٵYӍW·hУպ͓MľW·gκΕrܱIλ
SAP-C02ԇwcAWSܘͷPďV}AWSOӋͲIɔUչxmAWSԝMضđó͘IAWSOӋͲe߿ϵyԼ}sĶӑówƵAWSԓԇ߀w˸}OӋ͌ʩػAܘcAWS녷ռɵĻϼܘAWSOӋ͌ʩȫͺҎԣԼAWSOӋ͌ʩɱQ
SAP-C02 JCԇһ헾Ժ͇ĿԇҪĜʂ͌WȻ@@JCc AWS ČIʿfһ׃Iĵijɾͨ͡^ SAP-C02 ԇx˿չʾOӋͲ}s AWS QČI֪R@DߵнˮõĹCԼИIӵu
SAP-C02yԇ & SAP-C02WY@W·ʢеĕrкܶķʽԂAmazonSAP-C02JCԇPDFExamDumpsṩɿӖԇ}𰸣Ԃͨ^AmazonSAP-C02JCԇ҂PDFExamDumpsAmazonSAP-C02ԇJCкܶN҂MPITJC
µ AWS Certified Solutions Architect SAP-C02 Mԇ} (Q395-Q400):} #395
A solutions architect is importing a VM from an on-premises environment by using the Amazon EC2 VM Import feature of AWS Import/Export. The solutions architect has created an AMI and has provisioned an Amazon EC2 instance that is based on that AMI. The EC2 instance runs inside a public subnet in a VPC and has a public IP address assigned. The EC2 instance does not appear as a managed instance in the AWS Systems Manager console. Which combination of steps should the solutions architect take to troubleshoot this issue? (Choose two.)
- A. Verify that Systems Manager Agent is installed on the instance and is running
- B. Verify the existence of a VPC endpoint on the VPC
- C. Verify that the instance is assigned an appropriate IAM role for Systems Manager
- D. Verify that the AWS Application Discovery Agent is configured
- E. Verify the correct configuration of service-linked roles for Systems Manager
𰸣A,C
}f
https://aws.amazon.com/premiumsu ... r-ec2-instance-not- appear/
} #396
A company has millions of objects in an Amazon S3 bucket. The objects are in the S3 Standard storage class. All the S3 objects are accessed frequently. The number of users and applications that access the objects is increasing rapidly. The objects are encrypted with server-side encryption with AWS KMS Keys (SSE-KMS).
A solutions architect reviews the company's monthly AWS invoice and notices that AWS KMS costs are increasing because of the high number of requests from Amazon S3. The solutions architect needs to optimize costs with minimal changes to the application.
Which solution will meet these requirements with the LEAST operational overhead?
- A. Create a new S3 bucket that has server-side encryption with Amazon S3 managed keys (SSE-S3) as the encryption type. Use S3 Batch Operations to copy the existing objects to the new S3 bucket. Specify SSE-S3.
- B. Use the S3 Intelligent-Tiering storage class for the S3 bucket. Create an S3 Intelligent-Tiering archive configuration to transition objects that are not accessed for 90 days to S3 Glacier Deep Archive.
- C. Use AWS CloudHSM to store the encryption keys. Create a new S3 bucket. Use S3 Batch Operations to copy the existing objects to the new S3 bucket. Encrypt the objects by using the keys from CloudHSM.
- D. Create a new S3 bucket that has server-side encryption with customer-provided keys (SSE-C) as the encryption type. Copy the existing objects to the new S3 bucket. Specify SSE-C.
𰸣A
}f
To reduce the volume of Amazon S3 calls to AWS KMS, use Amazon S3 bucket keys, which are protected encryption keys that are reused for a limited time in Amazon S3. Bucket keys can reduce costs for AWS KMS requests by up to 99%. You can configure a bucket key for all objects in an Amazon S3 bucket, or for a specific object in an Amazon S3 bucket. https://docs.aws.amazon.com/fr_f ... de/services-s3.html
} #397
A company is migrating some of its applications to AWS. The company wants to migrate and modernize the applications quickly after it finalizes networking and security strategies. The company has set up an AWS Direct Connection connection in a central network account.
The company expects to have hundreds of AWS accounts and VPCs in the near future. The corporate network must be able to access the resources on AWS seamlessly and also must be able to communicate with all the VPCs. The company also wants to route its cloud resources to the internet through its on-premises data center.
Which combination of steps will meet these requirements? (Choose three.)
- A. Provision only private subnets. Open the necessary route on the transit gateway and customer gateway to allow outbound internet traffic from AWS to flow through NAT services that run in the data center.
- B. Provision an internet gateway. Attach the internet gateway to subnets. Allow internet traffic through the gateway.
- C. Create a Direct Connect gateway and a transit gateway in the central network account. Attach the transit gateway to the Direct Connect gateway by using a transit VIF.
- D. Share the transit gateway with other accounts. Attach VPCs to the transit gateway.
- E. Create a Direct Connect gateway in the central account. In each of the accounts, create an association proposal by using the Direct Connect gateway and the account ID for every virtual private gateway.
- F. Provision VPC peering as necessary.
𰸣A,C,D
}f
Option A is incorrect because creating a Direct Connect gateway in the central account and creating an association proposal by using the Direct Connect gateway and the account ID for every virtual private gateway does not enable active-passive failover between the regions. A Direct Connect gateway is a globally available resource that enables you to connect your AWS Direct Connect connection over a private virtual interface (VIF) to one or more VPCs in any AWS Region. A virtual private gateway is the VPN concentrator on the Amazon side of a VPN connection. You can associate a Direct Connect gateway with either a transit gateway or a virtual private gateway. However, a Direct Connect gateway does not provide any load balancing or failover capabilities by itself Option B is correct because creating a Direct Connect gateway and a transit gateway in the central network account and attaching the transit gateway to the Direct Connect gateway by using a transit VIF meets the requirement of enabling the corporate network to access the resources on AWS seamlessly and also to communicate with all the VPCs. A transit VIF is a type of private VIF that you can use to connect your AWS Direct Connect connection to a transit gateway or a Direct Connect gateway. A transit gateway is a network transit hub that you can use to interconnect your VPCs and on-premises networks. By using a transit VIF, you can route traffic between your on-premises network and multiple VPCs across different AWS accounts and Regions through a single connection23 Option C is incorrect because provisioning an internet gateway, attaching the internet gateway to subnets, and allowing internet traffic through the gateway does not meet the requirement of routing cloud resources to the internet through its on-premises data center. An internet gateway is a horizontally scaled, redundant, and highly available VPC component that allows communication between your VPC and the internet. An internet gateway serves two purposes: to provide a target in your VPC route tables for internet-routable traffic, and to perform network address translation (NAT) for instances that have been assigned public IPv4 addresses. By using an internet gateway, you are routing cloud resources directly to the internet, not through your on-premises data center.
Option D is correct because sharing the transit gateway with other accounts and attaching VPCs to the transit gateway meets the requirement of enabling the corporate network to access the resources on AWS seamlessly and also to communicate with all the VPCs. You can share your transit gateway with other AWS accounts within the same organization by using AWS Resource Access Manager (AWS RAM). This allows you to centrally manage connectivity from multiple accounts without having to create individual peering connections between VPCs or duplicate network appliances in each account.
You can attach VPCs from different accounts and Regions to your shared transit gateway and enable routing between them.
Option E is incorrect because provisioning VPC peering as necessary does not meet the requirement of enabling the corporate network to access the resources on AWS seamlessly and also to communicate with all the VPCs. VPC peering is a networking connection between two VPCs that enables you to route traffic between them using private IPv4 addresses or IPv6 addresses. You can create a VPC peering connection between your own VPCs, or with a VPC in another AWS account within a single Region.
However, VPC peering does not allow you to route traffic from your on-premises network to your VPCs or between multiple Regions. You would need to create multiple VPN connections or Direct Connect connections for each VPC peering connection, which increases operational complexity and costs.
Option F is correct because provisioning only private subnets, opening the necessary route on the transit gateway and customer gateway to allow outbound internet traffic from AWS to flow through NAT services that run in the data center meets the requirement of routing cloud resources to the internet through its on-premises data center. A private subnet is a subnet that's associated with a route table that has no route to an internet gateway. Instances in a private subnet can communicate with other instances in the same VPC but cannot access resources on the internet directly. To enable outbound internet access from instances in private subnets, you can use NAT devices such as NAT gateways or NAT instances that are deployed in public subnets. A public subnet is a subnet that's associated with a route table that has a route to an internet gateway. Alternatively, you can use your on-premises data center as a NAT device by configuring routes on your transit gateway and customer gateway that direct outbound internet traffic from your private subnets through your VPN connection or Direct Connect connection. This way, you can route cloud resources to the internet through your on-premises data center instead of using an internet gateway.
References: 1:
https://docs.aws.amazon.com/dire ... gateways-intro.html 2:
https://docs.aws.amazon.com/dire ... ual-interfaces.html 3:
https://docs.aws.amazon.com/vpc/ ... ransit-gateway.html :
https://docs.aws.amazon.com/vpc/ ... ternet_Gateway.html :
https://docs.aws.amazon.com/vpc/latest/tgw/tgw-sharing.html :
https://docs.aws.amazon.com/vpc/ ... is-vpc-peering.html :
https://docs.aws.amazon.com/vpc/ ... /VPC_Scenario2.html :
https://docs.aws.amazon.com/vpc/ ... /VPC_Scenario3.html :
https://docs.aws.amazon.com/vpc/ ... C_NAT_Instance.html :
https://docs.aws.amazon.com/vpc/ ... PC_NAT_Gateway.html
} #398
A solutions architect is designing the data storage and retrieval architecture for a new application that a company will be launching soon. The application is designed to ingest millions of small records per minute from devices all around the world. Each record is less than 4 KB in size and needs to be stored in a durable location where it can be retrieved with low latency. The data is ephemeral and the company is required to store the data for 120 days only, after which the data can be deleted.
The solutions architect calculates that, during the course of a year, the storage requirements would be about
10-15 TB.
Which storage strategy is the MOST cost-effective and meets the design requirements?
- A. Design the application to batch incoming records before writing them to an Amazon S3 bucket. Update the metadata for the object to contain the list of records in the batch and use the Amazon S3 metadata search feature to retrieve the data. Configure a lifecycle policy to delete the data after 120 days.
- B. Design the application to store each incoming record in a single table in an Amazon RDS MySQL database. Run a nightly cron job that executes a query to delete any records older than 120 days.
- C. Design the application to store each incoming record in an Amazon DynamoDB table properly configured for the scale. Configure the DynamoOB Time to Live (TTL) feature to delete records older than 120 days.
- D. Design the application to store each incoming record as a single .csv file in an Amazon S3 bucket to allow for indexed retrieval. Configure a lifecycle policy to delete data older than 120 days.
𰸣C
}f
DynamoDB with TTL, cheaper for sustained throughput of small items + suited for fast retrievals. S3 cheaper for storage only, much higher costs with writes. RDS not designed for this use case.
} #399
A company is in the process of implementing AWS Organizations to constrain its developers to use only Amazon EC2. Amazon S3 and Amazon DynamoDB. The developers account resides In a dedicated organizational unit (OU). The solutions architect has implemented the following SCP on the developers account:
When this policy is deployed, IAM users in the developers account are still able to use AWS services that are not listed in the policy. What should the solutions architect do to eliminate the developers' ability to use services outside the scope of this policy?
- A. Modify the Full AWS Access SCP to explicitly deny all services
- B. Remove the Full AWS Access SCP from the developer account's OU
- C. Create an explicit deny statement for each AWS service that should be constrained
- D. Add an explicit deny statement using a wildcard to the end of the SCP
𰸣B
}f
https://docs.aws.amazon.com/orga ... heritance_auth.html
} #400
ǰ Amazon IYӍQҪԼoҪcվPĹCԽԽ࣬gҪҲԽԽIԇһ˜ʣԲĂИIAmazon ߶횲ҌWӖn̻DžӸʽČIJC䌍ԼʹԼڹϿԸӵđ֡ͨ^Amazon SAP-C02 JCԇCITI֪RкԄһݺܺõĹ
SAP-C02yԇ: https://www.pdfexamdumps.com/SAP-C02_valid-braindumps.html
- ֵهSAP-C02 PDF}YԇеIȹ̺¸SAP-C02AWS Certified Solutions Architect - Professional (SAP-C02) 🟠 ☀ [url]www.newdumpspdf.com ️☀️ǫ@ȡ⮆ SAP-C02 ⮄MdѾWվSAP-C02d[/url]
- °SAP-C02 PDF}죬wȫAWS Certified Solutions Architect - Professional (SAP-C02) SAP-C02ԇ} 🟩 ⏩ [url]www.newdumpspdf.com ⏪⮆ SAP-C02 ⮄pȡMdSAP-C02}[/url]
- µSAP-C02֤d - ṩȫSAP-C02} ✈ }uWַ [url]www.pdfexamdumps.com _K SAP-C02 MdSAP-C02ԇc[/url]
- °SAP-C02 PDF}죬wȫAWS Certified Solutions Architect - Professional (SAP-C02) SAP-C02ԇ} 🚖 [url]www.newdumpspdf.com ṩM➡ SAP-C02 ️⬅️}ռSAP-C02JC[/url]
- SAP-C02T} ⌛ SAP-C02JCԇ 💎 SAP-C02} 🔨 ➠ [url]www.vcesoft.com 🠰ь➠ SAP-C02 🠰KMdSAP-C02ͨ^ԇ[/url]
- Amazon SAP-C02 PDF} |һ·LԇpWKͨ^ԇSAP-C02AWS Certified Solutions Architect - Professional (SAP-C02) 🧨 _☀ [url]www.newdumpspdf.com ️☀️ь➤ SAP-C02 ⮘MdԇYSAP-C02}[/url]
- Amazon SAP-C02 PDF} |һ·LԇpWKͨ^ԇSAP-C02AWS Certified Solutions Architect - Professional (SAP-C02) 🔇 ➤ [url]www.testpdf.net ⮘☀ SAP-C02 ️☀️p@ȡMdSAP-C02JCԇ[/url]
- SAP-C02}d 🕡 SAP-C02T} 🌋 SAP-C02}Md 🔷 [url]www.newdumpspdf.com ▶ SAP-C02 ◀p@ȡMdSAP-C02}Md[/url]
- Amazon SAP-C02 PDF} |@ͨ^ʵĿԇ - SAP-C02AWS Certified Solutions Architect - Professional (SAP-C02) 💿 Md[ SAP-C02 ]ֻM⇛ [url]www.newdumpspdf.com ⇚WվSAP-C02JC[/url]
- SAP-C02ͨ^ԇ 🗽 SAP-C02JCԇ 🎎 SAP-C02T} 📼 Ո▷ [url]www.newdumpspdf.com ◁WվMd✔ SAP-C02 ️✔️}SAP-C02}[/url]
- SAP-C02}Y 🥮 SAP-C02}Y 🧫 SAP-C02ԇ} 🍐 { [url]www.pdfexamdumps.com } SAP-C02 p@ȡMdSAP-C02ͨ^ԇ[/url]
- dl.instructure.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, gedsimekong.org, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, paidforarticles.in, umsr.fgpzq.online, bbs.t-firefly.com, onlyofficer.com, Disposable vapes
BONUS!!! MdPDFExamDumps SAP-C02ԇ}棺https://drive.google.com/open?id=1L44EgumyfswB_g9b57TX-fSr4gOYUviH
