[General] 2026 Microsoft First-grade MS-721: Collaboration Communications Systems Engineer
【General】 2026 Microsoft First-grade MS-721: Collaboration Communications Systems Engineer
Posted at 1/9/2026 07:45:26      View:139 | Replies:2        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of Real4test MS-721 dumps from Cloud Storage: https://drive.google.com/open?id=1NRV04W22JGcW_12XpKQgpiVVI5kiHgh1
Among all learning websites providing IT certification MS-721 dumps and training methods, whose MS-721 exam dumps and training materials are the most reliable? Of course, MS-721 exam dumps and certification training questions on Real4test site are the most reliable. Our Real4test have professional team, certification experts, technician and comprehensive language master, who always research the Latest MS-721 Exam Dumps and update MS-721 certification training material, so you can be fully sure that our MS-721 test training materials can help you pass the MS-721 exam.
Microsoft MS-721 (Collaboration Communications Systems Engineer (beta)) Certification Exam is a valuable credential for professionals in the field of collaboration and communications systems engineering. With its focus on testing the candidate's knowledge of collaboration tools and technologies, as well as their ability to design and implement solutions that meet the specific needs of an organization, this certification exam provides a comprehensive assessment of the candidate's skills and expertise in this area.
MS-721 Valid Exam Book - Top MS-721 Exam DumpsUsers can start using the product of Real4test instantly after purchasing it, so they can start preparing for Microsoft certification test quickly. Three formats are being provided to customers so that they can access them in every possible way according to their needs. After discussing it with many Microsoft professionals and getting their positive feedback, the study material has been made. Many exam applicants have used the prep material and rated it the best because they have passed the Microsoft MS-721 Certification Exam in a single try.
Microsoft Collaboration Communications Systems Engineer Sample Questions (Q97-Q102):NEW QUESTION # 97
You are deploying Direct Routing by using a certified Session Border Controller (SBC). The FQDN of the SBC is sbc1.contoso.com. You use signaling port 5067.
You cannot place calls and receive an error message in the Microsoft Teams admin center as shown in the following exhibit.
What is a possible cause of the issue?
  • A. The Digicert root certificate is missing on the SBC.
  • B. Location-Based Routing is enabled for the SBC.
  • C. The SIP options are disabled.
  • D. The Forward P-Asserted Identify (PAI) header is disabled.
NEW QUESTION # 98
You have a Microsoft Teams Phone deployment.
You have a call queue named Customer Service.
You need to ensure that when the agents of Customer Service make calls, the outbound calling name appears as Contoso, and the caller ID shows the phone number of Customer Service.
Other users must NOT be affected.
Which three actions should you perform? Each correct answer presents a part of the solution.
  • A. From the Microsoft Teams admin center, configure a new caller ID policy.
  • B. Set Calling Party Name to the organization name.
  • C. Set Replace the caller ID with to Resource account.
  • D. Set Override the caller ID policy to On.
  • E. From the Microsoft Teams admin center, modify the global (Org-wide default) caller ID policy.
Answer: A,B,C
https://learn.microsoft.com/en-u ... /caller-id-policies
NEW QUESTION # 99
Hotspot Question
You use Microsoft Teams live events.
You configure a live events policy as shown in the following exhibit.
Use the drop-down menus to select the answer choice that completes each statement based on the information presented in the graphic.
https://learn.microsoft.com/en-u ... r-teams-live-events
NEW QUESTION # 100
You have a Teams Phone deployment that contains a Session Border Controller (SBC) named SBC1.
You deploy a second SBC named SBC2 that is configured as shown in the following exhibit.
You discover that SBC2 fails to receive SIP Options packets from Microsoft SIP gateways and you notice that calls take a long time to connect.
Use the drop down menus to select the answer choice that completes each statement based on the information presented in the graphic.
NEW QUESTION # 101
Normalization rules are configured as shown in the following exhibit.
Box 1: +61270105000
Note:
Teams traverses the list of normalization rules from the top down and uses the first rule that matches the dialed number. If you set up a dial plan so that a dialed number can match more than one normalization rule, make sure the more restrictive rules are sorted above the less restrictive ones.
Box 2: AU-Premium
https://learn.microsoft.com/en-u ... d-manage-dial-plans
NEW QUESTION # 102
With Real4test's Microsoft MS-721 Exam Training materials you can pass the Microsoft MS-721 exam easily. The training tools which designed by our website can help you pass the exam the first time. You only need to download the Real4test Microsoft MS-721 exam training materials, namely questions and answers, the exam will become very easy. Real4test guarantee that you will be able to pass the exam. If you are still hesitant, download our sample of material, then you can know the effect. Do not hesitate, add the exam material to your shopping cart quickly. If you miss it you will regret for a lifetime.
MS-721 Valid Exam Book: https://www.real4test.com/MS-721_real-exam.html
Posted at 1/9/2026 09:52:58        Only Author  2#
This article is mind-blowing, thank you for sharing! Latest Project-Management exam dumps.zip questions for free! Best of luck to everyone sitting for the exam!
Posted at 1/21/2026 17:39:19        Only Author  3#
This article has made me reflect on many things, and I’ve learned quite a bit. The New F5CAB3 test sample test questions are now available for free—your career success is just a step away!
