[General] Pass Guaranteed Quiz ISQI - Latest CTFL-AT Reliable Test Materials
78
【General】 Pass Guaranteed Quiz ISQI - Latest CTFL-AT Reliable Test Materials
Posted at 1/22/2026 01:05:21      View:127 | Replies:1        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of VCEDumps CTFL-AT dumps from Cloud Storage: https://drive.google.com/open?id=1g-BTw2UxaPgsErth9BR2tqBnZ39JpxU5
Three versions of CTFL-AT exam guide are available on our test platform, including PDF version, PC version and APP online version. As a consequence, you are able to study the online test engine ofCTFL-AT study materials by your cellphone or computer, and you can even study CTFL-AT Actual Exam at your home, company or on the subway whether you are a rookie or a veteran, you can make full use of your fragmentation time in a highly-efficient way to study with our CTFL-AT exam questions and pass the CTFL-AT exam.
ISQI CTFL-AT (ISTQB Certified Tester - Foundation Level Extension - Agile Tester) Exam is an excellent certification for software testers who want to demonstrate their knowledge and skills in agile testing methodologies. CTFL-AT exam covers essential topics related to agile development principles, testing in agile projects, and tools and techniques for agile testing. Passing the CTFL-AT Exam can enhance your career prospects and open up new opportunities in the software testing industry.
Vce CTFL-AT Test Simulator & CTFL-AT Reliable Real TestIt is estimated conservatively that the passing rate of the exam is over 98 percent with our CTFL-AT study materials as well as considerate services. We not only provide all candidates with high pass rate study materials, but also provide them with good service. The thoughtfulness of our CTFL-AT Study Materials services is insuperable. What we do surly contribute to the success of CTFL-AT practice materials.
The CTFL-AT exam is a multiple-choice exam that consists of 40 questions. Candidates have 60 minutes to complete the exam and must score at least 65% to pass. CTFL-AT Exam is available in several languages, including English, German, French, Spanish, Portuguese, and Japanese.
ISQI ISTQB Certified Tester - Foundation Level Extension - Agile Tester Sample Questions (Q18-Q23):NEW QUESTION # 18
You are working in a software development company which, for many years, used a sequential development model and was organized into separate departments for each functional group (e.g. business analysts, developers, testers) located within their own office space. Your organization has recently changed to a SCRUM agile framework.Which of the following is an important organizational and behavioral best practice for a tester in the SCRUM team that should have also been practiced when using the sequential model?
  • A. Cross-functional teamwork means that all team members contribute to testing in various ways. For example, involving people with the test strategy, test planning and execution as well as test reporting.
  • B. Credibility means that the tester must share information with the stakeholders about the test process so that they find the selected test strategy and testing activities trustworthy.
  • C. Co-located teamwork means that all team members, including developers and testers, must sit together in the same office, so they can quickly communicate face-to-face.
  • D. Resilient testing means that the testing process is capable of dealing with rapid changes throughout the development process with test plans being updated during each iteration.
NEW QUESTION # 19
You are developing the code that controls an industrial Espresso machine which will be operated by waiting staff in restaurants.
The machine is rather complicated and has lots of switches and buttons, so in the next iteration instructions will be provided to the operator on a small LCD screen.
A User Story for the Operator-Instructions module is as follows:
"As an operator of the Espresso machine, I would like to know how to steam milk, so I can add steamed milk to the coffee." The following is a list of risks identified for this story, with assigned probability and impact.
  • A. The instructions may be incorrect or appear in the wrong order. Probability: Low. Impact: High
  • B. An untrained customer will attempt to use the coffee machine. Probability: High. Impact: High
  • C. A small child may try to steam milk. Probability: High. Impact: Low
  • D. Operators will not read the instructions and will try various switches and buttons until something works.
    Probability: Low. Impact: Low
Risk-based testing is a technique that prioritizes testing activities based on the level of risk associated with each feature or requirement. The level of risk is usually calculated by multiplying the probability and impact of each risk. The higher the risk level, the more testing effort should be allocated to mitigate the risk. In this case, the risk level for each option is as follows: A. Risk level = Low x Low = Low B. Risk level = Low x High = Medium C. Risk level = High x High = High D. Risk level = High x Low = Medium Therefore, the highest risk level is C, followed by B and D, and then A. The User Story for the Operator-Instructions module should be tested according to this risk order, starting with C, then B, then D, and finally A. Hence, the answer is B, as it is the second highest risk level and should be tested after C. References: ISTQB Foundation Level Agile Tester Extension Syllabus1, page 16; ISTQB Agile Tester Sample Exam2, question 18.
NEW QUESTION # 20
Which of the following is the best example of a testable acceptance criterion for test-related activities?
  • A. The application shall calculate the volume of the solid shapes (cones, pyramids) with reasonable accuracy
  • B. The application's user interface for the checkout process shall be clear and intuitive to the users
  • C. The web application shall provide a response time lower than one second for 95% of the webpages when 100 concurrent users are working on it
  • D. 100% of the source code must be statically analyzed against some of the known major security vulnerabilities and no errors/warnings must be reported
FromCTFL-AT Syllabus v4.0, Section 2.1:
"Acceptance criteria should be testable, meaning they should define expected behavior or measurable outcomes that can be verified." Option Ais testable because it includesspecific, measurable conditions: response time, user load, and percentage of pages.
* Option Bis vague aboutwhich vulnerabilitiesandhow errors are defined.
* Option Cusessubjective language("clear and intuitive").
* Option Dis vague about what "reasonable accuracy" means.
Learning Objective (K2) - Identify examples of testable vs. non-testable acceptance criteria
NEW QUESTION # 21
What is the main benefit of the Test Pyramid?
  • A. It shows complexity of testing activities.
  • B. It acts as a metric for testing progress.
  • C. It helps in evaluating the amount of test cases needed.
  • D. It means testing is involved early in the development cycle.
The Test Pyramid is a model for organizing tests in a way to make the process of testing faster, efficient and cost-effective. This model focusses on getting maximum functional testing getting covered by faster and less brittle tests like Unit and API tests1. The main benefit of the Test Pyramid is that it helps in evaluating the amount of test cases needed for each level of testing. The Test Pyramid suggests that the number of test cases should decrease as we move up the pyramid, from unit tests to integration tests to end-to-end tests. This is because unit tests are more granular, isolated, and easy to write and maintain, while end-to-end tests are more complex, dependent, and brittle. The Test Pyramid also helps in balancing the test coverage and the test execution time, as unit tests provide high coverage and low execution time, while end-to-end tests provide low coverage and high execution time. By following the Test Pyramid, teams can optimize their testing efforts and resources, and ensure that they have a sufficient and effective test suite for their software. References:
ISTQB Foundation Level Agile Tester Syllabus, Section 2.2.1, page 16; ASTQB Agile Tester Certification Resources, Section 2.2.1, page 16; What is Test Pyramid : Getting started with Test Automation Pyramid, The Practical Test Pyramid - Martin Fowler, Testing Pyramid: What Is It and How To Use It | Solvd.
NEW QUESTION # 22
You are working on an Agile project and have been asked to implement exploratory testing for the current sprint. Which one of the following is a correct approach to adopt?
  • A. Ask experienced testers to try and find new defects by using the system without the constraint of documentation and tools.
  • B. Ask experienced testers to prepare test charters for time boxed sessions lasting no more than 2hours.
    Tests should be designed and executed within each session using heuristics, creativity and intuition.
  • C. Allocate independent testers to design exploratory tests using test charters in time boxed sessions. Plan to run all sessions in parallel with each session lasting more than 5hours.
  • D. Use testers who have not been involved in the sprint to write new test cases from the user stories. These test cases are then executed in a time boxed session for the sprint.
NEW QUESTION # 23
Vce CTFL-AT Test Simulator: https://www.vcedumps.com/CTFL-AT-examcollection.html
Posted at 1/22/2026 10:08:13        Only Author  2#
Thank you so much for your article, it’s something I’ll remember. Unlock your potential with free DS0-001 new free study questions questions—promotion and salary increases await!
