[General] HP HPE7-A01 Exam Dumps - Preparation Material For Best Result [2026]
95
【General】 HP HPE7-A01 Exam Dumps - Preparation Material For Best Result [2026]
Posted at 1/16/2026 05:49:41      View:132 | Replies:1        Print      Only Author   [Copy Link] 1#
P.S. Free & New HPE7-A01 dumps are available on Google Drive shared by Actual4dump: https://drive.google.com/open?id=1-8xlZ8k1vWuG6S7ki2IswGCO7TNFjQDR
The evergreen field of HP is so attractive that it provides non-stop possibilities for the one who passes the HP HPE7-A01 exam. So, to be there on top of the IT sector, earning the Aruba Certified Campus Access Professional Exam (HPE7-A01) certification is essential. Because of using outdated HPE7-A01 Study Material, many candidates don't get success in the HPE7-A01 exam and lose their resources. The HPE7-A01 PDF Questions of Actual4dump are authentic and real.
HP HPE7-A01 exam is a certification exam designed for IT professionals in the field of network infrastructure. Aruba Certified Campus Access Professional Exam certification is aimed at individuals who want to validate their skills in designing and deploying Aruba wireless and wired networks in campus environments. HPE7-A01 Exam is designed to test the candidate's knowledge of Aruba products and solutions, as well as their ability to configure, troubleshoot, and optimize Aruba networks.
The Best Accurate HPE7-A01 Test Online - Win Your HP Certificate with Top ScoreHow to get HP certification quickly and successfully at your fist attempt? Latest dumps from Actual4dump will help you pass HPE7-A01 actual test with 100% guaranteed. Our study materials can not only ensure you clear exam but also improve your professional IT expertise. Choosing HPE7-A01 Pass Guide, choose success.
To be eligible to take the HP HPE7-A01 Certification Exam, candidates must have a minimum of one year of experience in implementing and managing Aruba wireless networks. They must also have a basic understanding of networking concepts and protocols.
HP Aruba Certified Campus Access Professional Exam Sample Questions (Q108-Q113):NEW QUESTION # 108
You are deploying a bonded 40 MHz wide channel What is the difference in the noise floor perceived by a client using this bonded channel as compared to an unbonded 20MHz wide channel?
  • A. 4dB
  • B. 8dB
  • C. 3dB
  • D. 2dB
The difference in the noise floor perceived by a client using a bonded 40 MHz wide channel as compared to an unbonded 20 MHz wide channel is 3 dB. The noise floor is the level of background noise in a given frequency band. When two adjacent channels are bonded, the noise floor increases by 3 dB because the bandwidth is doubled and more noise is captured. The other options are incorrect because they do not reflect the correct relationship between bandwidth and noise floor. References:
https://www.arubanetworks.com/te ... rf-fundamentals.htm
https://www.arubanetworks.com/te ... channel-bonding.htm
NEW QUESTION # 109
Match each PoE power class to Its corresponding 802.3 standard. (Options may he used more than once or not at all)
* Class 3 (15.4W): 802.3af
* Class 4 (30W): 802.3at
* Class 6 (60W): 802.3bt
* Class 8 (90W): 802.3bt
NEW QUESTION # 110
A company recently upgraded its campus switching infrastructure with Aruba 6300 CX switches. They have implemented 802.1X authentication on edge ports where laptop and loT devices typically connect An administrator has noticed that for PoE devices the pons are delivering the maximum wattage instead of what the device actually needs Upon connecting the loT devices, the devices request their specific required wattage through information exchange
  • A. Concerned about this waste of electricity, what should the administrator implement to solve this problem?
  • B. implement a classifier policy with the correct power definitions.
  • C. Create device profiles with the correct power definitions.
  • D. Enable AAA authentication to exempt LLDP and/or CDP information
  • E. Globally enable the QoS trust setting for LLDP and/or CDP
According to the Aruba Documentation Portal1, the Aruba 6300 CX switches support various features to control the PoE devices on specific ports, such as device profiles and classifier policies. These features can help reduce the power consumption and improve the performance of the PoE devices.
1: https://www.arubanetworks.com/te ... fro-pan-led-630.htm 2: https://www.arubanetworks.com/products/switches/6300-series/ 3: https://docs.samsungknox.com/adm ... by-device-platform/
NEW QUESTION # 111
You must ensure the HPEAruba network you are configuring for a client is capable of piug-and-play provisioning of access points. What enables this capability?
  • A. LLDP-MED
  • B. CSMA
  • C. UCC Service
  • D. SRTP
The capability that enables plug-and-play provisioning of access points in an HPE Aruba network is the UCC Service. The UCC Service is a cloud-based service that allows the access points to automatically discover and connect to the Aruba Central management platform without any manual intervention. The UCC Service also provides zero-touch configuration, firmware updates, and monitoring for the access points1.
B: LLDP-MED: LLDP-MED is a protocol that enhances the interoperability between network devices and IP phones. It does not enable plug-and-play provisioning of access points2.
C: SRTP: SRTP is a protocol that provides encryption and authentication for voice and video traffic. It does not enable plug-and-play provisioning of access points3.
D: CSMA: CSMA is a protocol that regulates how devices share a common medium, such as a wireless channel. It does not enable plug-and-play provisioning of access points.
NEW QUESTION # 112
Which component is used by the Aruba Network Analytics Engine (NAE)?
  • A. Lisp-based agents
  • B. JSON-based scripts
  • C. Current State Database
  • D. Ruby-based scripts
The component that is used by the Aruba Network Analytics Engine (NAE) is D. Current State Database.
The Current State Database is a database that stores the configuration and state information of the switch, such as interfaces, VLANs, routing protocols, statistics, and more. The NAE can access this database through the AOS-CX REST API and monitor the values of any data point using monitors. The NAE can also track the history of the values in a time-series database and correlate them with network events or configuration changes1. The Current State Database provides NAE with direct visibility into the entire current state of the device, which enables intelligent troubleshooting and automation of network tasks1.
* A. JSON-based scripts: JSON is a data format that is used to exchange information between applications. It is not a scripting language that can be used by NAE. NAE scripts are written in Python, which is a popular and powerful programming language1.
* B. Lisp-based agents: Lisp is a family of programming languages that are mainly used for artificial intelligence and functional programming. It is not a language that can be used by NAE. NAE agents are instances of scripts that run on the switch and collect relevant network information and trigger alerts or actions1.
* C. Ruby-based scripts: Ruby is a general-purpose programming language that is known for its expressiveness and elegance. It is not a language that can be used by NAE. NAE scripts are written in Python, which is a popular and powerful programming language1.
NEW QUESTION # 113
HPE7-A01 Sample Questions Pdf: https://www.actual4dump.com/HP/HPE7-A01-actualtests-dumps.html
BONUS!!! Download part of Actual4dump HPE7-A01 dumps for free: https://drive.google.com/open?id=1-8xlZ8k1vWuG6S7ki2IswGCO7TNFjQDR
Posted at 1/23/2026 08:03:14        Only Author  2#
Thank you for the wonderful share, the article is truly eye-opening! Valid MC-101 exam camp file provides amazing content, and it's completely free.
