ANS-C01 Valid Test Online | ANS-C01 Exam Topic
Posted at 1/11/2026 20:15:59
P.S. Free & New ANS-C01 dumps are available on Google Drive shared by PassLeaderVCE: https://drive.google.com/open?id=1K1Qi8YTk9Jxeh4kKdAG6UsLheKA9dWJV
Our ANS-C01 test braindumps are carefully developed by experts in various fields, and the quality is trustworthy. What's more, after you purchase our products, we will update our ANS-C01 exam questions according to the new changes and then send them to you in time to ensure the comprehensiveness of learning materials. We also have data to prove that 99% of those who use our ANS-C01 Latest Exam torrent to prepare for the exam can successfully pass the exam and get ANS-C01 certification. As long as you decide to choose our ANS-C01 exam questions, you will have an opportunity to prove your abilities, so you can own more opportunities to embrace a better life.
Our web backend is strong for our ANS-C01 study braindumps. No matter how many people are browsing our websites at the same time, you still can quickly choose your favorite ANS-C01 exam questions and quickly pay for it. There has no delay reaction of our website. So you can begin your pleasant selecting journey on our websites. And you will find our ANS-C01 practice materials are easy to download.
Amazon ANS-C01 Exam Topic & Braindumps ANS-C01 PdfThe Amazon ANS-C01 web-based practice exam software can be easily accessed through browsers like Safari, Google Chrome, and Firefox. The customers do not need to download or install excessive software or applications to take the AWS Certified Advanced Networking Specialty Exam (ANS-C01) web-based practice exam. The ANS-C01 web-based practice exam software format can be accessed through any operating system like Windows or Mac.
The ANS-C01 Exam is designed for network engineers, network architects, and other IT professionals who work with AWS and want to advance their skills in networking. ANS-C01 exam covers a broad range of topics, including network infrastructure, routing, security, and connectivity. It also tests the candidate's ability to use various AWS services such as VPC, Direct Connect, and Route 53 to implement complex networking solutions.
Amazon AWS Certified Advanced Networking Specialty Exam Sample Questions (Q104-Q109):NEW QUESTION # 104
A company's network engineer builds and tests network designs for VPCs in a development account. The company needs to monitor the changes that are made to network resources and must ensure strict compliance with network security policies. The company also needs access to the historical configurations of network resources.
- A. Create an Amazon EventBridge (Amazon CloudWatch Events) rule with a custom pattern to monitor the account for changes. Configure the rule to invoke an AWS Lambda function to identify noncompliant resources. Update an Amazon DynamoDB table with the changes that are identified.
- B. Record the current state of network resources by using AWS Systems Manager Inventory. Use Systems Manager State Manager to enforce the desired configuration settings and to carry out remediation for noncompliant resources.
- C. Record the current state of network resources by using AWS Config. Create rules that reflect the desired configuration settings. Set remediation for noncompliant resources.
- D. Create custom metrics from Amazon CloudWatch logs. Use the metrics to invoke an AWS Lambda function to identify noncompliant resources. Update an Amazon DynamoDB table with the changes that are identified.
Recording the current state of network resources by using AWS Config would enable auditing and assessment of resource configurations and compliance3. Creating rules that reflect the desired configuration settings would enable evaluation of whether the network resources comply with network security policies3. Setting remediation for noncompliant resources would enable automatic correction of undesired configurations3.
NEW QUESTION # 105
You need to create a baseline of normal traffic flow in order to implement some security changes to your organization. What two items would be best to use?
(Choose two.)
Response:
- A. CloudTrail
- B. CloudWatch
- C. Wireshark
- D. An IDS
NEW QUESTION # 106
A company is replatforming a legacy data processing solution to AWS. The company deploys the solution on Amazon EC2 Instances in private subnets that are in one VPC.
The solution uses Amazon S3 for abject storage. Both the data that the solution processes and the data the solution produces are stored in Amazon S3. The solution uses Amazon DynamoDB to save its own state. The company collects flow logs for the VPC. Thesolution uses one NAT gateway to register its license through the internet. A software vendor provides a specific hostname so the solution can register its license.
The company notices that the AWS bill exceeds the projected budget for the solution. A network engineer uses AWS Cost Explorer to investigate the bill. The network engineer notices that the USE2-NatGateway- Bytes($) usage type is the root cause of the higher than expected bill.
What should the network engineer do to resolve the issue? (Choose two.)
- A. Examine the VPC flow logs to identity the traffic that traverses the NAT gateway.
- B. Verify that the security groups attached to the EC2 instances allow outgoing traffic only to the IP addresses that the hostname resolves to, the VPC CIDR block, and the AWS IP address ranges for Amazon S3 and DynamoDB.
- C. Set up an AWS Cost and Usage Report in the AWS Billing and Cost Management console. Examine the report to find more details about the NAT gateway charges.
- D. Set up Amazon VPC Traffic Mirroring. Analyze the traffic to identify the traffic that the NAT gateway processes.
- E. Verify that the gateway VPC endpoints for Amazon S3 and DynamoDB are both set up and associated with the route tables of the private subnets.
Answer: A,E
NEW QUESTION # 107
A network engineer is managing two AWS Direct Connect connections. Each connection has a public virtual interface configured with a private ASN. The engineer wants to configure active/passive routing between the Direct Connect connections to access Amazon public endpoints.
What BGP configuration is required for the on-premises equipment? (Select two.)
- A. Use Local Pref to control outbound traffic.
- B. Use eBGP multi-hop between loopback interfaces.
- C. Advertise more specific prefixes over one Direct Connect connection.
- D. Use AS Prepending to control inbound traffic.
- E. Use BGP Communities to control outbound traffic.
https://docs.aws.amazon.com/dire ... tml#createvirtualin terface.
A public or private Border Gateway Protocol (BGP) Autonomous System Number (ASN) for your side of the BGP session. If you are using a public ASN, you must own it. If you are using a private ASN, it must be in the 64512 to 65535 range. Autonomous System (AS) prepending does not work if you use a private ASN for a public virtual interface. An MD5 BGP authentication key. You can provide your own, or you can let Amazon generate one for you. (Public virtual interface only) Prefixes you want to advertise: Public IPv4 routes or IPv6 routes to advertise over BGP. You must advertise at least one prefix using BGP, up to a maximum of 1,000 prefixes.
NEW QUESTION # 108
AnyCompany has acquired Example Corp. AnyCompany's infrastructure is all on premises, and Example Corp's infrastructure is completely in the AWS Cloud. The companies are using AWS Direct Connect with AWS Transit Gateway to establish connectivity between each other.
Example Corp has deployed a new application across two Availability Zones in a VPC with no internet gateway. The CIDR range for the VPC is 10.0.0.0/16. Example Corp needs to access an application that is deployed on premises by AnyCompany. Because of compliance requirements, Example Corp must access the application through a limited contiguous block of approved IP addresses (10.1.0.0/24).
A network engineer needs to implement a highly available solution to achieve this goal. The network engineer starts by updating the VPC to add a new CIDR range of
10.1.0.0/24.
What should the network engineer do next to meet the requirements?
- A. In each Availability Zone in the VPC, create a subnet that uses part of the allowed IP address range.
Create a private NAT gateway in each of the new
subnets. Update the route tables that are associated with other subnets to route application traffic to the private NAT gateway in the corresponding Availability Zone. Add a route to the route table that is associated with the subnets of the private NAT gateways to send traffic destined for the application to the transit gateway. - B. In the VPC, create a subnet that uses the allowed IP address range. Create a private NAT gateway in the new subnet. Update the route tables that are associated with other subnets to route application traffic to the private NAT gateway. Add a route to the route table that is associated with the subnet of the private NAT gateway to send traffic destined for the application to the transit gateway.
- C. In the VPC, create a subnet that uses the allowed IP address range. Create a public NAT gateway in the new subnet. Update the route tables that are associated with other subnets to route application traffic to the public NAT gateway. Add a route to the route table that is associated with the subnet of the public NAT gateway to send traffic destined for the application to the transit gateway.
- D. In each Availability Zone in the VPC, create a subnet that uses part of the allowed IP address range.
Create a public NAT Sateway in each of the new
subnets. Update the route tables that are associated with other subnets to route application traffic to the public NAT gateway in the corresponding Availability Zone. Add a route to the route table that is associated with the subnets of the public NAT gateways to send traffic destined for the application to the transit gateway.
The correct answer is B. In each Availability Zone in the VPC, create a subnet that uses part of the allowed IP address range. Create a private NAT gateway in each of the new subnets. Update the route tables that are associated with other subnets to route application traffic to the private NAT gateway in the corresponding Availability Zone. Add a route to the route table that is associated with the subnets of the private NAT gateways to send traffic destined for the application to the transit gateway.
This solution meets the requirements because:
*It uses a private NAT gateway, which can route traffic to other VPCs or on-premises networks through a transit gateway or a virtual private gateway1.
*It creates a subnet in each Availability Zone that uses part of the approved IP address range, which ensures high availability and compliance.
*It updates the route tables to send traffic from the other subnets to the private NAT gateway in the same Availability Zone, which reduces latency and improves performance.
*It adds a route to the route table of the private NAT gateway subnets to send traffic destined for the application to the transit gateway, which enables connectivity to the on-premises network.
*Option A uses a public NAT gateway, which is not necessary for connecting to other VPCs or on-premises networks. A public NAT gateway also requires an elastic IP address, which is not part of the approved IP address range.
*Option C creates only one subnet and one private NAT gateway, which does not provide high availability across multiple Availability Zones.
*Option D uses a public NAT gateway, which is not necessary for connecting to other VPCs or on-premises networks. A public NAT gateway also requires an elastic IP address, which is not part of the approved IP address range. Additionally, option D creates only one subnet and one public NAT gateway, which does not provide high availability across multiple Availability Zones.
NEW QUESTION # 109
PassLeaderVCE is a trusted and reliable platform that has been helping AWS Certified Advanced Networking Specialty Exam (ANS-C01) exam candidates for many years. Over this long time period countless Amazon ANS-C01 exam questions candidates have passed their dream ANS-C01 Certification Exam. They all got help from PassLeaderVCE Amazon Exam Questions and easily passed their challenging ANS-C01 pdf exam.
ANS-C01 Exam Topic: https://www.passleadervce.com/AWS-Certified-Specialty/reliable-ANS-C01-exam-learning-guide.html
- Exam ANS-C01 Cost 🥋 Interactive ANS-C01 EBook 🆎 ANS-C01 Latest Braindumps Ebook 🧘 Search for ➤ ANS-C01 ⮘ and download exam materials for free through ( [url]www.prepawayexam.com ) 🕳New ANS-C01 Exam Vce[/url]
- ANS-C01 Study Materials: AWS Certified Advanced Networking Specialty Exam - ANS-C01 Actual Questions - ANS-C01 Quiz Guide 🐭 Open [ [url]www.pdfvce.com ] enter 「 ANS-C01 」 and obtain a free download 🤳ANS-C01 Complete Exam Dumps[/url]
- Get Free 365 Days Update on Amazon ANS-C01 Dumps 🈵 The page for free download of ⏩ ANS-C01 ⏪ on ⇛ [url]www.testkingpass.com ⇚ will open immediately 🟥Exam ANS-C01 Introduction[/url]
- ANS-C01 Valid Test Bootcamp 🔗 New ANS-C01 Exam Test 🛂 Pdf Demo ANS-C01 Download 🎡 Simply search for ✔ ANS-C01 ️✔️ for free download on ▛ [url]www.pdfvce.com ▟ 😏Exam ANS-C01 Guide Materials[/url]
- Pass Guaranteed Quiz ANS-C01 - The Best AWS Certified Advanced Networking Specialty Exam Valid Test Online 👯 Easily obtain free download of ⇛ ANS-C01 ⇚ by searching on ➡ [url]www.prep4sures.top ️⬅️ 🏪
ass ANS-C01 Rate[/url] - Exam ANS-C01 Guide Materials 🧺 Latest ANS-C01 Exam Simulator 🟤 New ANS-C01 Real Exam 🎧 Search for ☀ ANS-C01 ️☀️ and obtain a free download on ➽ [url]www.pdfvce.com 🢪 ➿Exam ANS-C01 Guide Materials[/url]
- Pass Guaranteed Quiz ANS-C01 - The Best AWS Certified Advanced Networking Specialty Exam Valid Test Online 🙍 Easily obtain free download of ➽ ANS-C01 🢪 by searching on ➡ [url]www.pass4test.com ️⬅️ 🌅
ass ANS-C01 Rate[/url] - Pdf Demo ANS-C01 Download 😇 ANS-C01 Complete Exam Dumps 🌃 New ANS-C01 Real Exam 🗻 Download ⏩ ANS-C01 ⏪ for free by simply entering ☀ [url]www.pdfvce.com ️☀️ website 🚪Latest ANS-C01 Exam Simulator[/url]
- Benefits of Preparing with the ANS-C01 🌹 Simply search for ➠ ANS-C01 🠰 for free download on ☀ [url]www.examcollectionpass.com ️☀️ 🤲Exam ANS-C01 Cost[/url]
- Benefits of Preparing with the ANS-C01 👇 The page for free download of { ANS-C01 } on ▶ [url]www.pdfvce.com ◀ will open immediately 📖Latest ANS-C01 Exam Simulator[/url]
- Benefits of Preparing with the ANS-C01 🐁 Search for ➥ ANS-C01 🡄 and obtain a free download on ➽ [url]www.pass4test.com 🢪 🛬ANS-C01 Complete Exam Dumps[/url]
- www.stes.tyc.edu.tw, eduduct.com, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.slideshare.net, Disposable vapes
BTW, DOWNLOAD part of PassLeaderVCE ANS-C01 dumps from Cloud Storage: https://drive.google.com/open?id=1K1Qi8YTk9Jxeh4kKdAG6UsLheKA9dWJV
