Pass4sure ADA-C01 Dumps Pdf - Latest ADA-C01 Exam Experience
105
Posted at 1/24/2026 04:50:26      View122 | Replies1        Print      Only Author   [Copy Link] 1#
2026 Latest ExamBoosts ADA-C01 PDF Dumps and ADA-C01 Exam Engine Free Share: https://drive.google.com/open?id=1I3q4c4SoGad57cToCI2FoCYfOobZyfrc
As we enter into such a competitive world, the hardest part of standing out from the crowd is that your skills are recognized then you will fit into the large and diverse workforce. The ADA-C01 certification is the best proof of your ability. However, its not easy for those work officers who has less free time to prepare such an ADA-C01 Exam. Here comes ADA-C01 exam materials which contain all of the valid ADA-C01 study questions. You will never worry about the ADA-C01 exam.
Snowflake ADA-C01 test braindump will be the right key to your exam success. As long as the road is right, success is near. Don't be over-anxious, wasting time is robbing oneself. Our Snowflake ADA-C01 test braindump will be definitely useful for your test and 100% valid. Money Back Guaranteed!
100% Pass Quiz 2026 Snowflake ADA-C01: Latest Pass4sure SnowPro Advanced Administrator Dumps PdfIn order to let you understand our products in detail, our SnowPro Advanced Administrator test torrent has a free trail service for all customers. You can download the trail version of our ADA-C01 study torrent before you buy our products, you will develop a better understanding of our products by the trail version. In addition, the buying process of our ADA-C01 exam prep is very convenient and significant. You will receive the email from our company in 5 to 10 minutes after you pay successfully; you just need to click on the link and log in, then you can start to use our ADA-C01 study torrent for studying. Immediate download after pay successfully is a main virtue of our SnowPro Advanced Administrator test torrent. At the same time, you will have the chance to enjoy the 24-hours online service if you purchase our products, so we can make sure that we will provide you with an attentive service.
Snowflake SnowPro Advanced Administrator Sample Questions (Q17-Q22):NEW QUESTION # 17
What are characteristics of data replication in Snowflake? (Select THREE).
  • A. Users must be granted REPLICATIONADMIN privileges in order to enable replication.
  • B. To start replication run the ALTER DATABASE ... REFRESH command on the account where the secondary database resides.
  • C. Users can have unlimited primary databases and they can be replicated to an unlimited number of accounts if all accounts are within the same organization.
  • D. The ALTER DATABASE ... ENABLE REPLICATION TO ACCOUNTS command must be issued from the primary account.
  • E. Databases created from shares can be replicated.
  • F. Replication can only occur within the same cloud provider.
Answer: C,D,E
*Option A is correct because the ALTER DATABASE ... ENABLE REPLICATION TO ACCOUNTS command must be issued from the primary account that owns the database to be replicated1.
*Option B is incorrect because users must be granted REPLICATIONGRANTER privileges in order to enable replication1.
*Option C is incorrect because to start replication, the ALTER DATABASE ... REFRESH command must be run on the primary database, not the secondary database1.
*Option D is incorrect because replication can occur across different cloud providers, as well as across regions2.
*Option E is correct because databases created from shares can be replicated, as long as the share is active and the database is not dropped or altered1.
*Option F is correct because users can have unlimited primary databases and they can be replicated to an unlimited number of accounts if all accounts are within the same organization1.
NEW QUESTION # 18
A Snowflake customer is experiencing higher costs than anticipated while migrating their data warehouse workloads from on-premises to Snowflake. The migration workloads have been deployed on a single warehouse and are characterized by a large number of small INSERTs rather than bulk loading of large extracts. That single warehouse has been configured as a single cluster, 2XL because there are many parallel INSERTs that are scheduled during nightly loads.
How can the Administrator reduce the costs, while minimizing the overall load times, for migrating data warehouse history?
  • A. There should be another 2XL warehouse deployed to handle a portion of the load queries.
  • B. The INSERTS should be converted to several tables to avoid contention on large tables that slows down query processing.
  • C. The 2XL warehouse should be changed to 4XL to increase the number of threads available for parallel load queries.
  • D. The warehouse should be kept as a SMALL or XSMALL and configured as a multi-cluster warehouse to handle the parallel load queries.
According to the Snowflake Warehouse Cost Optimization blog post, one of the strategies to reduce the cost of running a warehouse is to use a multi-cluster warehouse with auto-scaling enabled. This allows the warehouse to automatically adjust the number of clusters based on the concurrency demand and the queue size. A multi-cluster warehouse can also be configured with a minimum and maximum number of clusters, as well as a scaling policy to control the scaling behavior. This way,the warehouse can handle the parallel load queries efficiently without wasting resources or credits. The blog post also suggests using a smaller warehouse size, such as SMALL or XSMALL, for loading data, as it can perform better than a larger warehouse size for small INSERTs. Therefore, the best option to reduce the costs while minimizing the overall load times for migrating data warehouse history is to keep the warehouse as a SMALL or XSMALL and configure it as a multi-cluster warehouse to handle the parallel load queries. The other options are incorrect because:
*A. Deploying another 2XL warehouse to handle a portion of the load queries will not reduce the costs, but increase them. It will also introduce complexity and potential inconsistency in managing the data loading process across multiple warehouses.
*B. Changing the 2XL warehouse to 4XL will not reduce the costs, but increase them. It will also provide more compute resources than needed for small INSERTs, which are not CPU-intensive but I/O-intensive.
*D. Converting the INSERTs to several tables will not reduce the costs, but increase them. It will also create unnecessary data duplication and fragmentation, which will affect the query performance and data quality.
NEW QUESTION # 19
What access control policy will be put into place when future grants are assigned to both database and schema objects?
  • A. An access policy combining both the database object and the schema object will be used, with the most permissive policy taking precedence.
  • B. Schema privileges will take precedence over database privileges.
  • C. Database privileges will take precedence over schema privileges.
  • D. An access policy combining both the database object and the schema object will be used, with the most restrictive policy taking precedence.
When future grants are defined on the same object type for a database and a schema in the same database, the schema-level grants take precedence over the database level grants, and the database level grants are ignored4.
This behavior applies to privileges on future objects granted to one role or different roles4. Future grants allow defining an initial set of privileges to grant on new (i.e. future) objects of a certain type in a database or a schema3. As soon as the new objects are created inside the database or schema, the predefined set of privileges are assigned to the object automatically without any manual intervention3.
NEW QUESTION # 20
When future grants are defined on the same object type for a database and a schema in the same database, the schema-level grants take precedence over the database level grants, and the database level grants are ignored4. This behavior applies to privileges on future objects granted to one role or different roles4. Future grants allow defining an initial set of privileges to grant on new (i.e. future) objects of a certain type in a database or a schema3. As soon as the new objects are created inside the database or schema, the predefined set of privileges are assigned to the object automatically without any manual intervention3.
NEW QUESTION # 21
An Administrator wants to delegate the administration of a company's data exchange to users who do not have access to the ACCOUNTADMIN role.
How can this requirement be met?
  • A. Grant ownership on data exchange EXCHANGE_NAME to ROLE NAME;
  • B. Grant usage on data exchange EXCHANGE_NAME to ROLE_NAME;
  • C. Grant modify on data exchange EXCHANGE_NAME to ROLE_NAME;
  • D. Grant imported privileges on data exchange EXCHANGE_NAME to ROLE_NAME;
According to the [GRANT MODIFY] documentation, the MODIFY privilege on a data exchange allows a role to perform administrative tasks on the data exchange, such as inviting members, approving profiles, and reviewing listings. This privilege can be granted by the ACCOUNTADMIN role or a role that already has the MODIFY privilege on the data exchange. Therefore, to delegate the administration of a company's data exchange to users who do not have access to the ACCOUNTADMIN role, the best option is to grant the MODIFY privilege on the data exchange to a role that the users can assume. The other options are incorrect because:
*A. There is no such privilege as IMPORTED PRIVILEGES in Snowflake. The correct privilege name is IMPORT SHARE, which allows a role to create a database from a share. This privilege is not related to the administration of a data exchange, but to the consumption of shared data.
*C. There is no such privilege as OWNERSHIP in Snowflake. The correct privilege name is OWNED BY, which indicates the role that owns an object and has full control over it. However, this privilege cannot be granted or revoked, but only transferred by the current owner to another role using the GRANT OWNERSHIP command. Therefore, this option is not feasible for delegating the administration of a data exchange.
*D. The USAGE privilege on a data exchange allows a role to access the data exchange and view the available data listings. This privilege does not allow a role to perform administrative tasks on the data exchange, such as inviting members, approving profiles, and reviewing listings. Therefore, this option is not sufficient for delegating the administration of a data exchange.
NEW QUESTION # 22
With the development of the times, the pace of the society is getting faster and faster. If we don't try to improve our value, we're likely to be eliminated by society. Under the circumstances, we must find ways to prove our abilities. For example, getting the ADA-C01 Certification is a good way. If we had it, the chances of getting a good job would be greatly improved. However, obtaining the ADA-C01 certification is not an easy task.
Latest ADA-C01 Exam Experience: https://www.examboosts.com/Snowflake/ADA-C01-practice-exam-dumps.html
Here, please do not worry any more, you can enjoy the privilege for one year free update about Latest ADA-C01 Exam Experience - SnowPro Advanced Administrator pdf study exam, With the help of our ADA-C01 exam preparation, you can be confident that you will pass the IT exam and get the IT certification as easy as turning over your hands, They have been analyzing many real exam questions and actual tests answers to get the new ADA-C01 test dump version.
There is information here you won't find anywhere else, but if it is not Test ADA-C01 Simulator Fee enough to satisfy your craving for how we test, there is more available on the Web, You just grab the screen shots and use them in the classroom.
Pass4sure ADA-C01 Dumps Pdf - 100% Pass Quiz 2026 First-grade ADA-C01: Latest SnowPro Advanced Administrator Exam ExperienceHere, please do not worry any more, you can enjoy ADA-C01 the privilege for one year free update about SnowPro Advanced Administrator pdf study exam, With the help of our ADA-C01 exam preparation, you can be confident Latest ADA-C01 Exam Experience that you will pass the IT exam and get the IT certification as easy as turning over your hands.
They have been analyzing many real exam questions and actual tests answers to get the new ADA-C01 test dump version, Passing Snowflake certification ADA-C01 exam can improve your IT skills.
You can feel exam pace and hold time to test with our ADA-C01 practice questions.
P.S. Free 2026 Snowflake ADA-C01 dumps are available on Google Drive shared by ExamBoosts: https://drive.google.com/open?id=1I3q4c4SoGad57cToCI2FoCYfOobZyfrc
Posted at 1/26/2026 12:14:39        Only Author  2#
Thank you for your article, it was so insightful and inspiring. Enhance your IT knowledge and get free New 300-820 test cram pdf. Wishing you success!
