[General] Reliable NCP-MCA Exam Pdf - Valid NCP-MCA Test Blueprint
87
General Reliable NCP-MCA Exam Pdf - Valid NCP-MCA Test Blueprint
Posted at 1/12/2026 00:17:48      View149 | Replies3        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of PassReview NCP-MCA dumps from Cloud Storage: https://drive.google.com/open?id=1QD3F74moFLngEDepW14vAoTMBoNLbRFR
If you are also facing the same problem then you are at the trusted spot. PassReview offers updated and real Nutanix NCP-MCA Exam Dumps for Nutanix Certified Professional - Multicloud Automation (NCP-MCA 6.10) (NCP-MCA) test takers who want to prepare quickly for the Nutanix Certified Professional - Multicloud Automation (NCP-MCA 6.10) (NCP-MCA) examination. These actual NCP-MCA exam questions have been compiled by a team of professionals after a thorough analysis of past papers and current content of the NCP-MCA test. If students prepare with these valid Nutanix Certified Professional - Multicloud Automation (NCP-MCA 6.10) (NCP-MCA) questions, they will surely become capable of clearing the Nutanix Certified Professional - Multicloud Automation (NCP-MCA 6.10) (NCP-MCA) examination within a few days.
Nutanix NCP-MCA Certification is a highly valuable certification for IT professionals who are responsible for deploying and managing Nutanix clusters in a multicloud environment. Nutanix Certified Professional - Multicloud Automation (NCP-MCA 6.10) certification validates the skills and expertise of IT professionals in deploying, managing, and scaling Nutanix clusters across multiple public and private clouds. Nutanix Certified Professional - Multicloud Automation (NCP-MCA 6.10) certification is recognized globally and is highly valued in the industry, providing IT professionals with a competitive edge in the job market.
Reliable NCP-MCA Exam Pdf Is The Useful Key to Pass Nutanix Certified Professional - Multicloud Automation (NCP-MCA 6.10)The pass rate is 98.75%, and we can ensure you pass the exam successfully if you buying NCP-MCA exam braindumps from us. Most candidates can pass the exam just one time. And we ensure you that if you cant pass the exam, you just need to send us the failure scanned, we will refund your money. We can ensure you that your money can receive rewards. In addition, we have three versions for NCP-MCA Training Materials, and you can buy the most suitable in accordance with your own needs.
Nutanix NCP-MCA Certification Exam covers a range of topics such as deployment and management of Nutanix clusters, automation of tasks using Nutanix Calm, configuration of Nutanix clusters across multiple clouds, troubleshooting of Nutanix clusters, and much more. This comprehensive exam is designed to test the skills and knowledge of IT professionals in deploying and managing Nutanix clusters in a multicloud environment.
Nutanix Certified Professional - Multicloud Automation (NCP-MCA 6.10) Sample Questions (Q16-Q21):NEW QUESTION # 16
Which method will result in unique names per VM when scaling out a Service in a Calm Blueprint?
  • A. Guest OS customization using sysprep contains <ComputerName>@@{name}@@</ComputerName>.
  • B. Service VM Name field contains the macro variable @@{calm_array_index}@@.
  • C. Set the VM Name field to allow user edits at launch so the user can enter a custom value at launch.
  • D. Call an external Python eScript that uses an IPAM API to register the VM name in DNS.
The correct method to result in unique names per VM when scaling out a Service in a Calm Blueprint is to use the macro variable @@{calm_array_index}@@ in the Service VM Name field (Option B). This variable will append a unique index number to each VM name based on the scale-out count. For example, if the Service VM Name is MyAppVM-@@{calm_array_index}@@ and the scale-out count is 3, the resulting VM names will be MyAppVM-0, MyAppVM-1, and MyAppVM-2. Option A is incorrect because the <ComputerName> tag in the sysprep file will only affect the hostname of the guest OS, not the VM name in the cloud provider.
Option C is incorrect because calling an external Python eScript to register the VM name in DNS will not change the VM name in the cloudprovider either. Option D is incorrect because setting the VM Name field to allow user edits at launch will require manual input from the user for each VM, which is not scalable or automated.
References: The information can be verified from Nutanix official training and certification documents available at Nutanix Training & Certification. You can also check out the Nutanix Certified Professional - Multicloud Automation (NCP-MCA) 6.5 Exam guide for more details on the exam objectives and format.
Additionally, you can watch the Nutanix Calm - Multicloud Automation playlist on YouTube for some video tutorials on Nutanix Calm features and functionalities.
NEW QUESTION # 17
An administrator is testing multiple Blueprints to see which one is best when deploying an application requiring four VMs. The VMs must reference which Blueprint created them or the test will be meaningless.
How should the administrator most efficiently complete this goal?
  • A. Set the VM name using the @@{calm_blueprint_name}@@ macro in a multi-VM blueprint.
  • B. Name each VM for the single-VM Blueprint manually and using the @@{calm_now}@@ macro to track the creation time.
  • C. Include the @@{calm_application_name}@@ macro in the guest customization section in a multi-VM blueprint.
  • D. Use the @@{calm_blueprint_uuid}@@ macro in a single VM Blueprint and cloning the VMs.
To efficiently identify the source Blueprint for every VM created during a test, the administrator should utilize the built-inBlueprint Name Macrowithin a Multi-VM structure.
* Macro Usage:The macro @@{calm_blueprint_name}@@ automatically resolves to the name of the blueprint being deployed (e.g., "Test_BP_Version_A").
* Efficiency:By using aMulti-VM blueprint(which creates all four VMs in one deployment action) and configuring theVM Namefield in the service definition to include this macro (e.g., VM-@@
{calm_blueprint_name}@@-@@{calm_array_index}@@), the administrator ensures that every resulting VM is automatically tagged with its source blueprint name in the hypervisor (Prism Element
/Central) list.
* Why not others:
* Option Ainvolves "Single VM Blueprint" and "cloning," which is a manual or secondary process that is less efficient than a native Multi-VM definition.
* Option Cuses @@{calm_application_name}@@, which identifies the specificinstance(e.g.,
"App-1"), not theblueprint design(e.g., "Web-Server-v2") that is being tested.
NEW QUESTION # 18
Within a Calm blueprint, which two actions can an administrator apply to a Service under the Guest Customization section? (Choose two.)
  • A. Modify the base OS image
  • B. Choose UEFI or Legacy BIOS
  • C. Apply a Sysprep file
  • D. Apply a Cloudinit Script
Within a Calm blueprint, an administrator can apply two actions to a Service under the Guest Customization section: Apply a Cloudinit Script and Apply a Sysprep file. These actions allow the administrator to customize the configuration and behavior of the virtual machines that are provisioned from the blueprint. A Cloudinit Script is a set of commands or scripts that run on Linux-based virtual machines during the boot process. A Sysprep file is a configuration file that specifies the Windows settings and options for the virtual machines.
These actions can be used to perform tasks such as setting the hostname, network configuration, user accounts, software installation, and more. References:
* Nutanix Certified Professional - Multicloud Automation (NCP-MCA) v6.5, Section 2 - Deploy and Configure Nutanix Calm and Related Components, page 3
* Nutanix Multicloud Automation Administration (NMCAA), Module 2 - Nutanix Calm, Lesson 2.2 - Blueprint Management, page 9
* Nutanix Calm User Guide, Blueprint, Guest Customization
NEW QUESTION # 19
An administrator needs to add AWS as a usable destination for application deployments.
Where would the administrator perform the task?
  • A. Blueprints
  • B. Marketplace
  • C. Projects
  • D. Providers
The administrator needs to add AWS as a provider in Calm. A provider is a cloud platform or infrastructure that hosts the application VMs or services. Calm supports various providers such as Nutanix, AWS, Azure, GCP, VMware, and Kubernetes. To add a provider, the administrator needs to go to the Providers page in the Calm UI and click on the +Create Provider button. Then, the administrator needs to select the AWS provider type and enter the required information such as name, access key, secret key, and regions. References: Nutanix Certified Professional - Multicloud Automation (NCP-MCA) Exam Blueprint Guide, page 11; Nutanix Calm User Guide, section 3.1.
NEW QUESTION # 20
While creating a Runbook, which type should an administrator select to performed a REST API call?
  • A. Execute
  • B. While Loop
  • C. Decision
  • D. HTTP
When creating a Runbook in Nutanix Calm to perform a REST API call, the administrator should select the
"HTTP" task type. This task type is specifically designed to make HTTP requests, including REST API calls, allowing integration with external services and APIs.
* Nutanix Calm documentation on Runbook Task Types.
* Nutanix Best Practices for HTTP Task in Runbooks.
NEW QUESTION # 21
Valid NCP-MCA Test Blueprint: https://www.passreview.com/NCP-MCA_exam-braindumps.html
DOWNLOAD the newest PassReview NCP-MCA PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1QD3F74moFLngEDepW14vAoTMBoNLbRFR
Posted at 1/17/2026 09:25:24        Only Author  2#
The content is amazing, and Im liking it right away. The MLA-C01 Testking exam questions test questions are the key to career successavailable for free!
Posted at 1/22/2026 20:28:23        Only Author  3#
I gained a ton of value from the article. Strengthen your IT skills with free Valid test JN0-750 testking. Wishing you success!
Posted at 2/14/2026 23:18:18        Only Author  4#
Im in awe of your article, thank you so much for sharing! Boost your IT skills and enjoy free Test HPE7-A01 voucher sharing. Wishing you success!
