SAP C-ADBTP-2601 PDF Questions-Turn Your Exam Fear Into Confidence
Posted at 4/20/2026 08:16:08
We offer a money-back guarantee, which means we are obliged to return 100% of your sum (terms and conditions apply) in case of any unsatisfactory results. Even though the SAP experts who have designed C-ADBTP-2601 assure us that anyone who studies properly cannot fail the exam, we still offer a money-back guarantee. This way we prevent pre and post-purchase anxiety.
The Administrating SAP Business Technology Platform(C_ADBTP_2601) (C-ADBTP-2601) certification is one of the hottest career advancement credentials in the modern SAP world. The C-ADBTP-2601 certification can help you to demonstrate your expertise and knowledge level. With only one badge of C-ADBTP-2601 certification, successful candidates can advance their careers and increase their earning potential. The SAP C-ADBTP-2601 Certification Exam also enables you to stay updated and competitive in the market which will help you to gain more career opportunities.
Make Exam Preparation Simple SAP C-ADBTP-2601 Exam QuestionsC-ADBTP-2601 study guide is obviously your best choice. C-ADBTP-2601 certification training ' main advantage contains saving you a lot of time and improving your learning efficiency. With C-ADBTP-2601 guide torrent, you may only need to spend half of your time that you will need if you didn’t use our products successfully passing a professional qualification exam. In this way, you will have more time to travel, go to parties and even prepare for another exam. The benefits of C-ADBTP-2601 Study Guide for you are far from being measured by money. C-ADBTP-2601 guide torrent has a first-rate team of experts, advanced learning concepts and a complete learning model. You give us a trust and we reward you for a better future.
SAP Administrating SAP Business Technology Platform(C_ADBTP_2601) Sample Questions (Q10-Q15):NEW QUESTION # 10
SIMULATION
Establish Shared Services
Task 2: Entitle and Subscribe a Service in a Shared Subaccount
In your SAP BTP cockpit, in your SH Dev subaccount, entitle one standard (Application) service plan for the SAP Build Work Zone, advanced edition.
In the SH Dev subaccount, establish a trust to the agvlamkzw.accounts.ondemand.com identity provider.
In your SH Dev subaccount, create a service subscription for SAP Build Work Zone, advanced edition with the standard service plan.
See the Explanation below for complete solution.
Before you start
Log in to SAP BTP Cockpit.
Open your correct Global Account.
Go to the Shared Services directory.
Open the SH Dev subaccount.
This matters because all three required actions must be done inside SH Dev, not in the directory and not in another subaccount.
Part 1 - Entitle the service in SH Dev
Step 1 - Open the subaccount
In the cockpit, choose Directories.
Open Shared Services.
Select SH Dev.
You should now be on the SH Dev subaccount page.
Step 2 - Open Entitlements
In SH Dev, choose Entitlements.
SAP documents that service plans and quotas for a subaccount are added in the subaccount's Entitlements are a.
Step 3 - Add the required service plan
Click Configure Entitlements or Add Service Plans.
Search for SAP Build Work Zone, advanced edition.
Select the service.
Choose the plan standard (Application).
Set the quantity to 1 if a quota/amount field is shown.
Save the entitlement changes.
This task explicitly asks for one standard (Application) service plan. SAP Help also notes that SAP Build Work Zone usage depends on the correct entitlement being available in the subaccount first.
Verify
Under Entitlements, you should now see:
plan: standard (Application)
quantity: 1 if shown
Part 2 - Establish trust to the identity provider
Step 4 - Open Trust Configuration
In SH Dev, go to Security.
Choose Trust Configuration.
SAP Help states that trust to a custom identity provider is established from Security > Trust Configuration in the SAP BTP cockpit.
Step 5 - Create the trust
Click Establish Trust.
Enter or select the identity provider:
Continue through the wizard.
Save the trust configuration.
SAP documents that to use a custom identity provider, the subaccount must have a trust relationship to that provider. SAP also highlights that apps such as SAP Build Work Zone rely on SAP Cloud Identity Services trust configuration.
Verify
On the Trust Configuration page, you should see:
as a trusted identity provider.
Part 3 - Create the subscription
Step 6 - Open Instances and Subscriptions
In SH Dev, go to Services.
Choose Instances and Subscriptions.
Step 7 - Create the subscription
Click Create.
Choose Subscription if the cockpit asks for a type.
Select the service.
Choose the plan standard.
Confirm the creation.
SAP Help for SAP Build Work Zone scenarios indicates that the subaccount needs the correct entitlements and subscription flow to expose and use SAP Build Work Zone content.
Step 8 - Confirm subscription status
Stay on Instances and Subscriptions.
Check that the new subscription appears and is active.
Verify
You should see:
plan: standard
subscription created successfully
Final expected result
Inside SH Dev:
the entitlement for SAP Build Work Zone, advanced edition exists
the entitled plan is standard (Application)
trust is established to agvlamkzw.accounts.ondemand.com
a subscription exists for SAP Build Work Zone, advanced edition
the subscription uses the standard plan
Common mistakes to avoid
Doing the entitlement in Shared Services directory instead of SH Dev
Choosing SAP Build Work Zone, standard edition instead of advanced edition Choosing the wrong plan; the entitlement must be standard (Application) Forgetting the trust step to agvlamkzw.accounts.ondemand.com Trying to subscribe before the entitlement exists
NEW QUESTION # 11
SIMULATION
Enable a Cloud Foundry Environment
Task 2: Enable and Configure a Cloud Foundry Environment
In your SAP BTP cockpit, in the EU HCM Dev subaccount, enable the Cloud Foundry environment in the cf-eu10-004 landscape. Set the instance name to cf-eu-hcm-dev and the org name to btpops####-eu-hcm-dev.
In the EU HCM Dev subaccount, create a space with the name activity-recording.
In the EU HCM Dev subaccount, create a space quota with the name half-org-quot a. Halve the available org quota for memory, routes, service, and instance memory for an unlimited number of app instances. Assign the space quota to activity-recording.
Before you start
Open the correct Global Account.
Go to Directories.
Open Human Resources.
Open the EU HCM Dev subaccount.
This matters because the task must be completed specifically in EU HCM Dev. SAP documents that Cloud Foundry is enabled at subaccount level, and the system creates a Cloud Foundry org linked to that subaccount.
Part 1 - Enable the Cloud Foundry environment
Step 1 - Open the subaccount overview
In EU HCM Dev, go to Overview.
SAP Help describes the cockpit flow for enabling Cloud Foundry from the subaccount Overview page.
What to verify
You should see a Cloud Foundry section on the overview page.
Step 2 - Start enabling Cloud Foundry
In the Cloud Foundry section, click Enable Cloud Foundry.
This starts creation of the Cloud Foundry organization for the subaccount. SAP notes that when you enable Cloud Foundry in a subaccount, the system automatically creates a Cloud Foundry org for it.
Step 3 - Enter the required Cloud Foundry values
In the enablement dialog, enter:
Landscape: cf-eu10-004
Instance Name: cf-eu-hcm-dev
Org Name: btpops####-eu-hcm-dev
Then confirm by clicking Create or Enable.
The task gives you the exact landscape and naming values to use. SAP documentation shows that enabling Cloud Foundry in the cockpit requires naming the Cloud Foundry instance and org.
What to verify
After the process completes, the subaccount should show Cloud Foundry as enabled, with the org created for EU HCM Dev.
Part 2 - Create the space
Step 4 - Open Spaces
In EU HCM Dev, after Cloud Foundry is enabled, open:
Cloud Foundry
Spaces
SAP Help shows that spaces are created from the Spaces area after Cloud Foundry is enabled in the subaccount.
Step 5 - Create the space
Click Create Space.
Enter:
Space Name: activity-recording
Confirm by clicking Create.
This creates the required Cloud Foundry space inside the org for EU HCM Dev. SAP's cockpit documentation and setup guides show this as the standard next step after enabling the environment.
What to verify
You should now see:
activity-recording
in the list of Cloud Foundry spaces.
Part 3 - Create the space quota
Step 6 - Open Cloud Foundry Space Quotas
In EU HCM Dev, open:
Cloud Foundry
Space Quotas
SAP Help states that, in the Cloud Foundry environment, the quotas allocated to a subaccount can be further distributed by creating space quota plans, and these are managed from the Cloud Foundry Space Quotas area.
Step 7 - Create a new space quota
Click Create Space Quota or New Space Quota.
Enter the quota name:
half-org-quota
This creates a quota plan that you will assign to the required space. SAP Help describes creating space quota plans in the subaccount and then assigning them to spaces.
Step 8 - Set quota values to half of the org quota
In the quota form, set the values to half of the available org quota for:
Memory
Routes
Services
Instance Memory
For App Instances, set:
Unlimited
Then save the quota.
The simulation asks you to halve the available org quota for those four dimensions. SAP Help confirms that space quotas are used to limit resource consumption inside the org by defining values such as memory, routes, and service instances, and that these plans can then be assigned to spaces.
How to calculate "half"
Use the current org quota values shown in the Cloud Foundry quota screens and divide each by 2 before entering it.
Examples:
If org memory = 2 GB, enter 1 GB
If routes = 20, enter 10
If services = 200, enter 100
If instance memory = 2 GB, enter 1 GB
What to verify
The new quota plan should exist as:
half-org-quota
with the reduced values saved.
Part 4 - Assign the quota to the space
Step 9 - Assign the quota to activity-recording
Open the newly created quota:
half-org-quota
Choose Assign Spaces or Assign to Spaces
Select:
activity-recording
Save the assignment
SAP Help states that after creating a space quota, you assign it to one or more spaces from the space quota management flow.
What to verify
The quota half-org-quota should now be assigned to:
activity-recording
Inside EU HCM Dev:
landscape is cf-eu10-004
instance name is cf-eu-hcm-dev
org name is btpops####-eu-hcm-dev
space activity-recording exists
space quota half-org-quota exists
memory, routes, services, and instance memory are each set to half of the available org quota app instances are unlimited quota half-org-quota is assigned to activity-recording Common mistakes to avoid Enabling Cloud Foundry in the wrong subaccount; it must be EU HCM Dev.
Using the wrong landscape; the task explicitly requires cf-eu10-004.
Typing the wrong org name; use exactly btpops####-eu-hcm-dev.
Forgetting to create the space before assigning the quota.
Entering full org quota instead of half.
Limiting app instances to a number instead of leaving them unlimited.
Creating the quota but not assigning it to activity-recording.
NEW QUESTION # 12
SIMULATION
Enable Service Subscriptions
Task 2: Entitle and Subscribe a Service in a Subaccount
In your AM PA Prod subaccount, entitle the standard (Application) service plan for SAP Build Work Zone, standard edition.
In the AM PA Prod subaccount, establish a trust to the agvlamkzw.accounts.ondemand.com identity provider.
In your AM PA Prod subaccount, create a service subscription for SAP Build Work Zone, standard edition with the standard service plan .
Part A - Entitle the Service Plan in AM PA Prod
Step 1 - Open the AM PA Prod Subaccount
What to do
In the SAP BTP Cockpit, go to Directories.
Open the Partner directory.
Select the subaccount AM PA Prod.
This opens the exact subaccount where the entitlement and subscription must be created.
What to verify
You should now be on the AM PA Prod subaccount page.
Step 2 - Open Entitlements in the Subaccount
What to do
In AM PA Prod, open Entitlements.
SAP documents that subaccount entitlements are configured in the subaccount's entitlement area, where you add service plans and quotas available to that subaccount.
What to verify
You should see the Entitlements screen for AM PA Prod.
Step 3 - Add the Required Service Plan
What to do
Search for:
Select the service.
Choose the plan:
Add the service plan.
The task requires the standard (Application) plan specifically. SAP's entitlement flow requires you to add the service plan to the subaccount before you can subscribe to the application.
What to verify
Part B - Establish Trust to the Identity Provider
What to do
In the AM PA Prod subaccount, go to:
Security
Trust Configuration
SAP Help states that trust to a custom identity provider is established from the cockpit in Security > Trust Configuration.
What to verify
You should be on the Trust Configuration page of AM PA Prod.
Step 5 - Start the Trust Setup
What to do
Click Establish Trust or New Trust Configuration.
This opens the wizard or form to add a trusted identity provider for the subaccount. SAP documents this as the standard cockpit flow for custom identity provider trust.
Step 6 - Enter the Identity Provider
What to do
In the trust configuration, use the identity provider:
Continue through the wizard and confirm the trust setup.
Save the configuration.
The simulation explicitly requires trust to that identity provider domain. For SAP Build Work Zone, standard edition, SAP also notes that the subaccount must trust an identity provider before subscription use cases for business users are completed.
What to verify
On the Trust Configuration page, the identity provider
agvlamkzw.accounts.ondemand.com should appear as trusted.
Part C - Create the Service Subscription
Step 7 - Open the Subscription Area
What to do
In AM PA Prod, go to:
Services
SAP Help for SAP Build subscriptions points to the subaccount subscription flow after the entitlement is available. In current cockpit usage, subscriptions are created from the subaccount's services are a.
What to verify
You should see the Instances and Subscriptions page.
Step 8 - Create the Subscription
What to do
Click Create.
Choose Subscription if a type selection appears.
Search for:
Select the plan:
standard
Then confirm the creation.
SAP's getting-started guidance for SAP Build Work Zone, standard edition says that once the subaccount has the required entitlement, you can subscribe to the application from the subaccount.
What to verify
You should now see a subscription entry for:
plan: standard
Step 9 - Confirm the Subscription Is Active
What to do
Check the status of the new subscription in Instances and Subscriptions.
The subscription should be visible and active in the subaccount after creation.
What to verify
You should see:
SAP's guidance for subscription-based applications consistently uses this subaccount subscription flow after entitlement is present.
Final Expected Result for Task 2
Inside AM PA Prod:
the entitlement SAP Build Work Zone, standard edition is assigned
a subscription exists for SAP Build Work Zone, standard edition
the subscription uses the standard service plan
Common Mistakes to Avoid
1. Doing the entitlement in the wrong place
This task must be done in:
Not only in:
Partner directory
Directory entitlement and subaccount entitlement are different scopes in the cockpit.
2. Choosing the wrong service or wrong plan
Use exactly:
standard (Application) for entitlement
standard for the subscription selection screen
SAP's service subscription flow starts only after the correct entitlement exists.
3. Skipping trust configuration
The simulation explicitly requires trust to:
Trust is configured in Security > Trust Configuration.
4. Looking for subscription creation before entitlement
The entitlement must be added first, otherwise the service may not appear in the subscription creation flow.
Quick Validation Checklist
Confirm all of the following in AM PA Prod:
Entitlements contains SAP Build Work Zone, standard edition
the plan is standard (Application)
Trust Configuration shows agvlamkzw.accounts.ondemand.com
Instances and Subscriptions shows SAP Build Work Zone, standard edition the subscription is created successfully
NEW QUESTION # 13
SIMULATION
Task 1: Create a Shared Services Directory and Subaccounts
In your SAP BTP cockpit, create the directory Shared Services (Description: Shared Accounts) with your global account as the parent.
In the Shared Services directory, create the subaccount SH Dev (Description: Shared Services Development) with subdomain btpops####-sh-dev in the region Amazon Web Services (AWS) → Europe (Frankfurt) cf-eu10.
In the Shared Services directory, create the subaccount SH Ops (Description: Shared Services Operations) with subdomain btpops####-sh-ops in the region Amazon Web Services (AWS) → Europe (Frankfurt) cf-eu10.
Before You Start
Log in to the SAP BTP Cockpit.
Make sure you are working in the correct global account before creating anything.
Why this matters:
The new directory and both subaccounts must be created inside the correct global account hierarchy.
Part A - Create the Shared Services Directory
Step 1 - Open Directories
What to do
In the SAP BTP Cockpit, open your Global Account.
In the left navigation menu, click Directories.
This is where you create and manage directory structures under the global account.
What to verify
You should now see the list of existing directories.
Step 2 - Create the Directory Shared Services
What to do
Click Create or Create Directory.
Enter the following values:
Parent: your Global Account
Click Create.
This creates a new top-level directory directly under the global account.
It will be used to hold the shared-services subaccounts.
What to verify
You should now see:
Shared Services
Part B - Create the SH Dev Subaccount
Step 3 - Open the Shared Services Directory
What to do
In the directory list, select Shared Services.
Both required subaccounts must be created inside this directory.
What to verify
You should now be inside the Shared Services directory.
Step 4 - Open Subaccounts
What to do
Inside Shared Services, open Subaccounts.
Click Create → Subaccount.
This opens the subaccount creation screen.
Step 5 - Create SH Dev
What to do
Enter the following:
Display Name / Name: SH Dev
Subdomain: btpops####-sh-dev
Set the region as:
Cloud Provider: Amazon Web Services (AWS)
Region: Europe (Frankfurt)
Technical Region / Environment: cf-eu10
Then click Create.
This creates the shared services development subaccount in the required AWS Frankfurt region.
What to verify
After creation, you should see:
SH Dev
Part C - Create the SH Ops Subaccount
Step 6 - Start a New Subaccount
What to do
Still inside Shared Services, click Create → Subaccount again.
This opens the form for the second required subaccount.
Step 7 - Create SH Ops
What to do
Display Name / Name: SH Ops
Subdomain: btpops####-sh-ops
Set the region as:
Then click Create.
This creates the shared services operations subaccount in the same required region.
What to verify
SH Ops
Final Expected Result for Task 1
You should now have:
Directory
Shared Services
Parent: Global Account
Subaccounts inside Shared Services
SH Dev
Region: AWS → Europe (Frankfurt) cf-eu10
SH Ops
1. Creating the directory in the wrong place
Shared Services must be created with:
parent = Global Account
2. Creating the subaccounts outside the directory
Both subaccounts must be created inside:
Shared Services
3. Wrong subdomain values
Use exactly:
btpops####-sh-dev
btpops####-sh-ops
Only replace #### with your global account number.
4. Wrong region
Both subaccounts must use:
Europe (Frankfurt)
cf-eu10
5. Mixing up SH Dev and SH Ops
Be careful:
SH Dev = Shared Services Development
SH Ops = Shared Services Operations
NEW QUESTION # 14
We continually improve the versions of our C-ADBTP-2601 exam guide so as to make them suit all learners with different learning levels and conditions. The clients can use the APP/Online test engine of our C-ADBTP-2601 exam guide in any electronic equipment such as the cellphones, laptops and tablet computers. Our after-sale service is very considerate and the clients can consult our online customer service about the price and functions of our C-ADBTP-2601 Quiz materials. So our C-ADBTP-2601 certification files are approximate to be perfect and will be a big pleasant surprise after the clients use them.
C-ADBTP-2601 Real Dumps: https://www.exam-killer.com/C-ADBTP-2601-valid-questions.html
SAP C-ADBTP-2601 Clear Exam Shorter preparing period, SAP C-ADBTP-2601 Clear Exam Also if you want to feel test atmosphere, this version can simulate the scene similar like the real test, The importance of certification such as SAP C-ADBTP-2601 has been greatly improved than ever before, SAP C-ADBTP-2601 Clear Exam If the clients can't receive the mails they can contact our online customer service and they will help them solve the problem.
That is a very difficult question, and one that has not yet been answered Valid C-ADBTP-2601 Test Topics adequately for cybersecurity in general, We all listened and collectively came up with an idea that everyone agreed with.
SAP C-ADBTP-2601 Clear Exam Exam Pass Certify | C-ADBTP-2601: Administrating SAP Business Technology Platform(C_ADBTP_2601)Shorter preparing period, Also if you want to feel test atmosphere, this version can simulate the scene similar like the real test, The importance of certification such as SAP C-ADBTP-2601 has been greatly improved than ever before.
If the clients can't receive the mails they C-ADBTP-2601 can contact our online customer service and they will help them solve the problem, Exam-Killer C-ADBTP-2601 PDF Questions: The Administrating SAP Business Technology Platform(C_ADBTP_2601) (C-ADBTP-2601) PDF dumps are suitable for smartphones, tablets, and laptops as well.
- C-ADBTP-2601 PDF Cram Exam 🏝 C-ADBTP-2601 Valid Exam Duration 💰 C-ADBTP-2601 Exam Papers 🧹 Open website ⮆ [url]www.easy4engine.com ⮄ and search for ➥ C-ADBTP-2601 🡄 for free download 📩Intereactive C-ADBTP-2601 Testing Engine[/url]
- Pass-Sure C-ADBTP-2601 Clear Exam, C-ADBTP-2601 Real Dumps 🐴 Search for ➤ C-ADBTP-2601 ⮘ and download exam materials for free through 「 [url]www.pdfvce.com 」 💔Reliable C-ADBTP-2601 Test Pass4sure[/url]
- Pass Guaranteed Quiz C-ADBTP-2601 - Administrating SAP Business Technology Platform(C_ADBTP_2601) Accurate Clear Exam 🚢 Open website ➡ [url]www.vce4dumps.com ️⬅️ and search for ▛ C-ADBTP-2601 ▟ for free download 😋Latest C-ADBTP-2601 Exam Questions Vce[/url]
- C-ADBTP-2601 Vce Exam 👒 Reliable C-ADBTP-2601 Test Pass4sure 🧵 C-ADBTP-2601 Book Free 🧜 ➡ [url]www.pdfvce.com ️⬅️ is best website to obtain ( C-ADBTP-2601 ) for free download 🔧Exam C-ADBTP-2601 Pattern[/url]
- Pass your C-ADBTP-2601 exam in 2026 Smoothly! 🧔 Easily obtain free download of ▷ C-ADBTP-2601 ◁ by searching on ▶ [url]www.prepawaypdf.com ◀ ⚓C-ADBTP-2601 Book Free[/url]
- Pass Guaranteed Quiz C-ADBTP-2601 - Administrating SAP Business Technology Platform(C_ADBTP_2601) Accurate Clear Exam 🌕 Download ✔ C-ADBTP-2601 ️✔️ for free by simply entering ▛ [url]www.pdfvce.com ▟ website 😒C-ADBTP-2601 PDF Cram Exam[/url]
- Intereactive C-ADBTP-2601 Testing Engine ⬇ C-ADBTP-2601 Valid Test Blueprint 📟 Latest C-ADBTP-2601 Exam Questions Vce 🍓 Search on ➤ [url]www.prep4away.com ⮘ for ✔ C-ADBTP-2601 ️✔️ to obtain exam materials for free download 🔡Latest C-ADBTP-2601 Exam Questions Vce[/url]
- Exam C-ADBTP-2601 Pattern 🏞 Exam C-ADBTP-2601 Pattern 😆 C-ADBTP-2601 Exam Dumps Free 🚀 Search for ➠ C-ADBTP-2601 🠰 and download it for free on 《 [url]www.pdfvce.com 》 website 🍲Reliable C-ADBTP-2601 Test Pass4sure[/url]
- C-ADBTP-2601 Test Questions - C-ADBTP-2601 Test Torrent - C-ADBTP-2601 Latest Torrents 📸 Immediately open ⇛ [url]www.prepawayete.com ⇚ and search for ➤ C-ADBTP-2601 ⮘ to obtain a free download 😯C-ADBTP-2601 Vce Exam[/url]
- C-ADBTP-2601 Test Questions - C-ADBTP-2601 Test Torrent - C-ADBTP-2601 Latest Torrents 🤗 Copy URL ⇛ [url]www.pdfvce.com ⇚ open and search for ➡ C-ADBTP-2601 ️⬅️ to download for free 📂Exam C-ADBTP-2601 Pattern[/url]
- New C-ADBTP-2601 Clear Exam | Latest SAP C-ADBTP-2601 Real Dumps: Administrating SAP Business Technology Platform(C_ADBTP_2601) 🤬 Search for 「 C-ADBTP-2601 」 and easily obtain a free download on ➤ [url]www.prepawaypdf.com ⮘ 🅱C-ADBTP-2601 Book Free[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, course.pdakoo.com, www.stes.tyc.edu.tw, sudnikksenya.alboompro.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
