Fortinet FCSS_NST_SE-7.6 Questions PDF File
57
Posted at 2/10/2026 00:10:06      View106 | Replies0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest Pass4sures FCSS_NST_SE-7.6 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1Dg9DdDgJRuwfjpo1Vugr_nhapoX1e0Cf
This pdf covers all of the FCSS_NST_SE-7.6 Exam Questions from the previous exams as well as those that will appear in the upcoming Fortinet FCSS_NST_SE-7.6 exam. The FCSS_NST_SE-7.6 PDF exam questions are compiled according to the latest exam syllabus to ensure your success. The Fortinet FCSS_NST_SE-7.6 PDF exam questions are also printable to make handy notes.
Fortinet FCSS_NST_SE-7.6 Exam Syllabus Topics:
  • VPN: This section is aimed at IT Professionals and includes diagnosing and addressing issues with IPsec VPNs, specifically IKE version 1 and 2, to secure remote and site-to-site connections within the network infrastructure.
  • System troubleshooting: This section of the exam measures the skills of Network Security Support Engineers and addresses diagnosing and correcting issues within Security Fabric setups, automation stitches, resource utilization, general connectivity, and different operation modes in FortiGate HA clusters. Candidates work with built-in tools to effectively find and resolve faults.
  • Security profiles: This part measures skills of Security Operations Specialists and covers identifying and resolving problems linked to FortiGuard services, web filtering configurations, and intrusion prevention systems to maintain protection across network environments.
  • Routing: This section focuses on Network Engineers and involves tackling issues related to packet routing using static routes, as well as OSPF and BGP protocols to support enterprise network traffic flow.
Topic 5
  • Authentication: This section evaluates the abilities of System Administrators and requires troubleshooting both local and remote authentication methods, including resolving Fortinet Single Sign-On (FSSO) problems for secure network access.
Sure FCSS_NST_SE-7.6 Pass, FCSS_NST_SE-7.6 Free Pdf GuideYou don't have to worry about passing rates of our FCSS_NST_SE-7.6 exam questions because of the short learning time. We have always been trying to shorten your study time on the premise of ensuring the passing rate. Perhaps after you have used FCSS_NST_SE-7.6 real exam once, you will agree with this point. Our FCSS_NST_SE-7.6 Study Materials are really a time-saving and high-quality product! As long as you buy and try our FCSS_NST_SE-7.6 practice braindumps, then you will want to buy more exam materials.
Fortinet FCSS - Network Security 7.6 Support Engineer Sample Questions (Q94-Q99):NEW QUESTION # 94
Consider the scenario where the server name indication (SNI) does not match either the common name (CN) or any of the subject alternative names (SAN) in the server certificate.
Which action will FortiGate take when using the default settings for SSL certificate inspection?
  • A. FortiGate uses the CN information from the Subject field in the server certificate.
  • B. FortiGate closes the connection because this represents an invalid SSL/TLS configuration.
  • C. FortiGate uses the first entry listed in the SAN field in the server certificate.
  • D. FortiGate uses the SNI from the user's web browser.
NEW QUESTION # 95
What are two reasons you might see iprope_in check () check failed, drop when using the debug How?
(Choose two.)
  • A. The packet was dropped because the requested service is not enabled on FortiGate
  • B. The packet was dropped because there is no route to the source.
  • C. The packet was dropped because the trusted host list is misconfigured
  • D. The packet was dropped because it is not allowed by any firewall policy.
The debug flow message iprope_in_check() check failed, drop specifically indicates a failure in the Local-In Policy check. The "iprope" (IP ROouting Policy Enforcement) engine handles policy lookups. The _in_check suffix confirms that the decision is regarding traffic destined to the FortiGate itself (Local-In traffic), rather than traffic passing through it.
* D. The packet was dropped because the requested service is not enabled on FortiGate:
* Explanation: This is the most common cause. When a packet arrives destined for the FortiGate's interface IP (e.g., an HTTPS or SSH request), the kernel checks if that specific service is enabled in the interface settings (set allowaccess). If the service is not enabled (e.g., trying to Ping an interface where PING access is disabled), the iprope_in_check function fails and drops the packet immediately.
* C. The packet was dropped because the trusted host list is misconfigured:
* Explanation: Even if the service (e.g., HTTPS) is enabled on the interface, the FortiGate checks the Administrator settings. If Trusted Hosts are configured, the source IP of the incoming packet is compared against the allowed list. If the IP is not on the list, the Local-In policy check (iprope_in_check) fails, and the packet is dropped to secure the management plane.
* A: If traffic is dropped by a standard Firewall Policy (traffic passing through the device from one interface to another), the debug message will typically state denied by policy x or no matching policy. It would generally be a forward check (iprope_fwd_check or similar), not an _in_check.
* B: If there is no route to the source, the error is a Reverse Path Forwarding (RPF) failure. The debug flow logs this explicitly as reverse path check fail, drop.
FortiGate Troubleshooting Guide (Debug Flow): "The message iprope_in_check() check failed indicates the packet was denied by the Local-In policy. This occurs when traffic destined to the FortiGate is not allowed by the allowaccess configuration or is blocked by Trusted Host settings."
NEW QUESTION # 96
Exhibit 1.
Exhibit 2.
Refer to the exhibits, which show the configuration on FortiGate and partial internet session information from a user on the internal network.
An administrator would like to lest session failover between the two service provider connections.
Which two changes must the administrator make to force this existing session to immediately start using the other interface? (Choose two.)
  • A. Configure unset snat-route-change to return it to the default setting.
  • B. Change the priority of the port2 static route to 5.
  • C. Change the priority of the port! static route to 11.
  • D. Configure set snat-route-change enable.
NEW QUESTION # 97
Exhibit.
Refer to the exhibit, which shows a FortiGate configuration.
An administrator is troubleshooting a web filter issue on FortiGate. The administrator has configured a web filter profile and applied it to a policy; however the web filter is not inspecting any traffic that is passing through the policy.
What must the administrator do to fix the issue?
  • A. Disable webfilter-force-off.
  • B. Change protocol to TCP.
  • C. Enable fortiguard-anycast.
  • D. Increase webfilter-timeout.
The exhibit shows a FortiGate configuration under config system fortiguard related to web filtering and FortiGuard options. There is a line:
set webfilter-force-off enable
According to official Fortinet documentation, the "webfilter-force-off" option, when enabled, causes the FortiGate to bypass web filtering for all traffic-even if a web filter profile is applied to a policy.
This override is typically used for troubleshooting or performance reasons and is documented as an explicit bypass feature.
If an administrator wants to enforce web filtering inspection, this setting must be disabled. The correct way to restore web filtering functionality is to run:
set webfilter-force-off disable
Once done, traffic passing through policies with web filter profiles will be inspected and filtered as per configuration. Other settings such as timeout or cache TTL do not bypass web filtering; they only affect operational nuances.
FortiOS Administration Guide: Web Filtering, FortiGuard Options, "webfilter-force-off" CLI
NEW QUESTION # 98
Partial output of a real-time OSPF debug is shown.
Which two reasons explain why the two FortiGate devices are unable to form an adjacency? (Choose two.)
  • A. The local FortiGate does not have OSPF authentication configured
  • B. The remote peer has either OSPF cleartext or MD5 authentication configured.
  • C. The local FortiGate has either OSPF cleartext or MD5 authentication configured.
  • D. There is an OSPF authentication configuration mismatch.
To determine the correct reasons for the adjacency failure, we must analyze the standard OSPF real-time debug output (diagnose ip router ospf all enable or diagnose sniffer packet) typically provided in this exam exhibit.
Analyze the Debug Output:
The debug output in this specific question scenario typically displays an incoming Hello packet line: OSPF:
RECV[Hello]: ... auth-type 0 ...
"RECV": Indicates the packet is coming from the Remote peer.
"auth-type 0": Indicates the Remote peer is sending "Null" (No) authentication.
Analyze the Failure:
The adjacency fails because the Local FortiGate is rejecting this packet.
If the Local FortiGate accepts "No Authentication", it would match auth-type 0 and form the adjacency.
Since it is failing (and producing a debug log), the Local FortiGate must be expecting a different authentication type (Type 1 Cleartext or Type 2 MD5).
Evaluate the Options:
A). The remote peer has either OSPF cleartext or MD5 authentication configured.
Incorrect. The debug shows auth-type 0 (No Auth) coming from the remote peer.
B). There is an OSPF authentication configuration mismatch.
Correct. One side is sending "No Auth" (Remote), and the other expects "Auth" (Local). This is a definition of a mismatch.
C). The local FortiGate does not have OSPF authentication configured.
Incorrect. If the Local unit had "No Auth" configured, it would match the Remote's auth-type 0, and the adjacency would come up. The failure implies the Local unit does have auth configured.
D). The local FortiGate has either OSPF cleartext or MD5 authentication configured.
Correct. Because the Local unit is rejecting the "No Auth" packet from the remote peer, it confirms that the Local unit has authentication enabled (expecting Type 1 or 2).
Conclusion: The breakdown of the OSPF negotiation shows that the Remote peer is sending no authentication (Type 0), while the Local FortiGate expects authentication, resulting in a mismatch.
FortiGate Security 7.6 Study Guide (OSPF Troubleshooting): "Authentication mismatch is a common cause of OSPF adjacency failure. Debug commands (diagnose ip router ospf all enable) reveal the auth-type received versus expected." FortiGate CLI Reference: auth-type 0 = Null (None), auth-type 1 = Simple (Cleartext), auth-type 2 = MD5.
NEW QUESTION # 99
It is not hard to find that there are many different kinds of products in the education market now. It may be difficult for users to determine the best way to fit in the complex choices. We can tell you with confidence that the FCSS_NST_SE-7.6 practice materials are superior in all respects to similar products. First, users can have a free trial of FCSS_NST_SE-7.6 test prep, to help users better understand the FCSS_NST_SE-7.6 Study Guide. If the user discovers that the product is not appropriate for him, the user can choose another type of learning material. Respect the user's choice, will not impose the user must purchase the FCSS_NST_SE-7.6 practice materials. We can meet all the requirements of the user as much as possible, to help users better pass the qualifying exams.
Sure FCSS_NST_SE-7.6 Pass: https://www.pass4sures.top/Fortinet-Certified-Solution-Specialist/FCSS_NST_SE-7.6-testking-braindumps.html
BONUS!!! Download part of Pass4sures FCSS_NST_SE-7.6 dumps for free: https://drive.google.com/open?id=1Dg9DdDgJRuwfjpo1Vugr_nhapoX1e0Cf
