[General] CIS-PA New Study Guide - Reliable CIS-PA Real Test
91
【General】 CIS-PA New Study Guide - Reliable CIS-PA Real Test
Posted at 1/31/2026 14:15:31      View:158 | Replies:1        Print      Only Author   [Copy Link] 1#
At the moment you come into contact with our CIS-PA learning guide you can enjoy our excellent service. You can ask our staff about what you want to know. After full understanding, you can choose to buy our CIS-PA exam questions. If you use the CIS-PA study materials, you have problems that you cannot solve. Just contact with us via email or online, we will deal with you right away. And we offer 24/7 online service. So if you have any problem, you can always contact with us no matter any time it is.
We want to provide our customers with different versions of CIS-PA test guides to suit their needs in order to learn more efficiently. Our CIS-PA qualification test can help you make full use of the time and resources to absorb knowledge and information. If you are accustomed to using the printed version of the material, we have a PDF version of the CIS-PA study tool for you to download and print, so that you can view the learning materials as long as you have free time. If you choose to study online, we have an assessment system that will make an assessment based on your learning of the CIS-PA qualification test to help you identify weaknesses so that you can understand your own defects of knowledge and develop a dedicated learning plan. Moreover our CIS-PA test guides provide customers with supplement service-mock test, which can totally inspire them to study hard and check for defects during their learning process. Our commitment is not frank, as long as you choose our CIS-PA study tool you will truly appreciate the benefits of our products.
Reliable CIS-PA Real Test & CIS-PA Valid Exam PapersNot only we provide the most valued CIS-PA study materials, but also we offer trustable and sincere after-sales services. As we all know, it’s hard to delight every customer. But we have successfully done that. Our CIS-PA practice materials are really reliable. In a word, our CIS-PA Exam Questions have built good reputation in the market. We sincerely hope that you can try our CIS-PA learning quiz. You will surely benefit from your correct choice.
ServiceNow Certified Implementation Specialist - Platform Analytics Sample Questions (Q38-Q43):NEW QUESTION # 38
What should thetargetfor theIndexand its supporting indicators be set to when creating anIndex Indicator?
  • A. 0% and Minimize
  • B. 100% and Maximize
  • C. 0% and Maximize
  • D. 100% and Minimize
AnIndex Indicatorin Platform Analytics represents a composite score calculated from multiple supporting indicators. According to ServiceNow best practices, both theIndex and its supporting indicatorsshould be normalized so thathigher values represent better performance. Therefore, the correct configuration is a target of 100%with aMaximizedirection.
This standardization ensures consistent weighting and scoring logic across all contributing indicators. If supporting indicators were set to Minimize or had inconsistent targets, the index calculation would produce misleading or inverted results. Options involving a 0% target are incorrect because index scores are designed to trend toward full achievement, represented as 100%. ServiceNow documentation clearly states that index indicators assume maximization logic for proper normalization and aggregation, making option D the correct and documented choice.
NEW QUESTION # 39
There is a Summed Duration of wait time Indicator that stores duration in milliseconds.
Which action accurately configures the displayed duration in hours without creating a separate Formula Indicator?
  • A. Use a Performance Analytics script to convert milliseconds to hours and recollect
  • B. Add / 3600000 to the Formula box and check Use formula
  • C. Set the Unit in the Indicator to Hours
  • D. Use the API method getHours() in the Formula box
Platform Analytics supports unit conversion for duration-based indicators through the Unit field on the Indicator record. When an indicator stores duration values (such as milliseconds), setting the Unit to Hours automatically converts and displays the values correctly without modifying the underlying data or recollecting scores.
Using formulas or scripts is unnecessary and discouraged when a built-in unit conversion is available. The Formula box is intended for mathematical aggregation logic, not unit conversion. ServiceNow documentation explicitly states that duration indicators should rely on the Unit setting to control how values are displayed, making option A the correct and supported approach.
NEW QUESTION # 40
How candashboard filtersretain their values acrosslogins and page refreshes?
  • A. By applyingsession-based persistence
  • B. By setting the filter as a global default
  • C. By configuring the filter to apply to the entire dashboard
  • D. By setting the filter as a Favorite in the user's page settings
Dashboard filters retain their values across page refreshes and user navigation throughsession-based persistence. When this option is enabled, filter selections are stored for the duration of the user's session and automatically reapplied as the user navigates or refreshes the page.
Favorites and global defaults define starting values, not persistence behavior. Applying a filter to the entire dashboard controls scope, not retention. ServiceNow documentation explains that session persistence is the mechanism that maintains filter state, making option C the correct answer.
NEW QUESTION # 41
Which method in ServiceNow can be used to calculate therate of performance per reporting periodusing time series aggregations?
  • A. pa.getIndicator()
  • B. gs.getDuration()
  • C. pa.getChange()
  • D. pa.getRate()
The pa.getRate() method is used in Platform Analytics to calculaterates of performance over time, such as incidents resolved per day, requests closed per week, or changes per reporting period. This method works on time series dataand applies aggregation logic to derive a rate rather than a raw count or sum.
pa.getChange() is used to calculate the difference between two data points, not a rate. pa.getIndicator() retrieves indicator metadata and does not perform calculations. gs.getDuration() is a general-purpose GlideSystem utility for calculating durations and is unrelated to analytics time series processing. ServiceNow documentation clearly identifies pa.getRate() as the appropriate API for rate-based calculations using historical indicator scores, making option D the correct answer.
NEW QUESTION # 42
What does the number of"Inserts"represent in aJob Logrecord?
  • A. The sum of the stored scores
  • B. The number of incidents inserted into the instance yesterday
  • C. The number of Indicator Source records examined
  • D. The number of Performance Analytics scores stored
In a Performance AnalyticsJob Log, theInsertsvalue represents the number ofanalytics score records written to the databaseduring that job run. These inserts typically correspond to new indicator scores added to theIndicator Factstable.
This value does not represent business records such as incidents, nor does it indicate how many source records were evaluated. Records examined and calculations performed may be far greater than the number of inserts, as only final score results are stored. ServiceNow documentation confirms that Job Log insert counts reflect stored analytics results, making option B the correct interpretation.
NEW QUESTION # 43
When new changes or knowledge are updated, our experts add additive content into our CIS-PA latest material. They have always been in a trend of advancement. Admittedly, our CIS-PA real questions are your best choice. We also estimate the following trend of exam questions may appear in the next exam according to syllabus. So they are the newest and also the most trustworthy CIS-PA Exam Prep to obtain.
Reliable CIS-PA Real Test: https://www.dumpsking.com/CIS-PA-testking-dumps.html
Over ten years of development has built our company more integrated and professional, increasingly number of faculties has enlarge our company scale and deepen our knowledge specialty (CIS-PA pdf questions), which both are the most critical factors that contribute to our high quality of services and more specialist CIS-PA exam training guide, We try our best to provide the most efficient and intuitive CIS-PA learning materials to the learners and help them learn efficiently.
Another two weeks in iteration zero, getting staffed, set up, and ready to deliver, DumpsKing offers professional skills, perfection utility and efficiency for beating ServiceNow CIS-Platform Analytics CIS-PA APP files.
Quiz 2026 ServiceNow Authoritative CIS-PA New Study GuideOver ten years of development has built our company more integrated CIS-PA and professional, increasingly number of faculties has enlarge our company scale and deepen our knowledge specialty (CIS-PA PDF Questions), which both are the most critical factors that contribute to our high quality of services and more specialist CIS-PA exam training guide.
We try our best to provide the most efficient and intuitive CIS-PA learning materials to the learners and help them learn efficiently, In this case, why not choosing to give us a chance and trusting our CIS-PA exam simulation materials?
As CIS-PA exam questions with high prestige and esteem in the market, we hold sturdy faith for you, Our mission is to provide a comprehensive, convenient, and cost-effective preparation material for individuals to prepare for the CIS-PA certification exam.
Posted at 3/9/2026 07:34:19        Only Author  2#
The article is full of inspiration, thank you for sharing it! Best of luck with your exams—free CIS-Discovery frenquent update exam papers are available now!
