[General] Quiz 2026 Avaya 71301T: Efficient Avaya Aura Communication Applications Implemen
110
【General】 Quiz 2026 Avaya 71301T: Efficient Avaya Aura Communication Applications Implemen
Posted at 2/22/2026 08:21:30      View:93 | Replies:0        Print      Only Author   [Copy Link] 1#
Our 71301T test guide keep pace with contemporary talent development and makes every learner fit in the needs of the society. There is no doubt that our 71301T latest question can be your first choice for your relevant knowledge accumulation and ability enhancement. Moreover, 71301T exam questions have been expanded capabilities through partnership with a network of reliable local companies in distribution, software and product referencing for a better development. That helping you pass the 71301T Exam with our 71301T latest question successfully has been given priority to our agenda.
The pass rate is 98.85% for 71301T training materials. If you choose us, we can ensure you pass the exam just one time. We are pass guarantee and money back guarantee. If you fail to pass the exam, we will refund your money to your payment account. Moreover, 71301T exam dumps are high quality, because we have experienced experts to compile them. We offer you free update for 365 days, and our system will send the latest version for 71301T Training Materials automatically. We have online chat service, if you have any questions about 71301T exam materials, just contact us.
Latest Avaya 71301T Exam Labs & Latest 71301T Exam MaterialsBraindumpQuiz have made customizable Avaya Aura Communication Applications Implement (71301T) practice tests so that users can take unlimited tests and improve Avaya Aura Communication Applications Implement (71301T) exam preparation day by day. These Avaya 71301T practice tests are based on the real examination scenario so the students can feel the pressure and learn to deal with it. The customers can access the result of their previous given Avaya Aura Communication Applications Implement (71301T) exam history and try not to make any excessive mistakes in the future.
Avaya Aura Communication Applications Implement Sample Questions (Q12-Q17):NEW QUESTION # 12
Which statement about the SIP Entities to support Avaya Aura Presence Services is true?
  • A. Only one SIP Entity is built of Type = "Presence Services", which uses the SM100 IP address of the Avaya BreezeTM node.
  • B. Two SIP Entities are built to the same SM100 IP address of each node. One is of Type =
    "Engagement Development Platform", and the other is of Type = "Other".
  • C. Two SIP Entities are built to the same SM100 IP address of each node. One is of Type =
    "Engagement Development Platform", and the other is of Type = "Presence Services".
  • D. Only one SIP Entity is built of Type = "Engagement Development Platform", which uses the SM100 IP Address of the Avaya BreezeTM node.
NEW QUESTION # 13
Which two options describe the purpose of TraceSM in the Avaya Aura Presence Services?
(Choose two.)
  • A. It captures Contact details from every user connected to Avaya Aura?Presence Services.
  • B. It captures Voice and Video Calls media packets in real-time.
  • C. It captures real-time XMPP traffic.
  • D. It captures Packet-Size statistics from every telephone call in Avaya Aura 7.
  • E. It captures live traces for both SIP and H323/XMPP clients.
Answer: C,E
It's important to know that traceSM is a real-time capture tool. traceSM is an interactive perl script that allows an administrator to capture, view, and save call processing activity on a Session Manager. While not as powerful or versatile as wireshark, traceSM is absolutely essential when it comes to working with Avaya SIP. First off, it allows you to view SIP messages even if they have been encrypted with TLS.
https://andrewjprokop.wordpress. ... ya-tracesm-utility/
NEW QUESTION # 14
In Avaya Session Border Controller for Enterprise (SBCE) 7.x, you need to download the
46xxsettings.txt file to a Remote Worker device.
What needs to be configured under DMZ Services > Relay Services?
  • A. Application Relay and Reverse Proxy
  • B. Application Relay
  • C. Application Relay and File Transfer
  • D. Reverse Proxy
Relay Services are used to define how file transfers (e.g., for phone firmware upgrades and configuration), are routed to the Remote Worker endpoints.
Example: For accessing the file server using HTTPS protocol. The following screenshot shows the newly created Relay Services
NEW QUESTION # 15
How does the integration of Presence Services impact the user experience on the Avaya Breeze platform?
  • A. Increases system setup time
  • B. Reduces system reliability
  • C. Limits customization options
  • D. Simplifies communication workflows
NEW QUESTION # 16
You need to connect Avaya BreezeTM platform that is hosting Avaya Aura Presence Services Snap-in with Avaya Aura Session Manager (SM). Which three are needed? (Choose three.)
  • A. one Entity Link from SM to Avaya BreezeTM
  • B. ports UDP 5060 and TLS 5061
  • C. TLS 5061 and TLS 5062
  • D. ports TCP 5060 and UDP 5060
  • E. one Entity Link from SM to Avaya Aura Presence Services Snap-in
Answer: A,C,E
BD: Administering Entity Link between Presence Services Cluster SIP Entity and Session Manager Procedure
1. On the System Manager web console, navigate to Elements > Routing > Entity Links.
2. In the Name field, enter a name for Entity Link.
3. In the SIP Entity 1 field, select the Session Manager instance.
4. In the Protocol field, select TLS.
5. In the Port field, type 5062.
Note: Note that this port number cannot be the same as the port number administered in
"Administering Entity Link between Avaya Breeze and Session Manager".
CD: Administering Entity Link between Avaya Breeze and Session Manager. About this task Create an En2tity Link to connect Session Manager to Avaya Breeze. You must administer separate Entity Links for Avaya Breeze servers in order to open SIP listeners on the designated ports. Session Manager requires a Listen Port with the Listen Port as 5061, Protocol as TLS, and Default Domain as the login domain of endpoint devices. Without this, PPM will fail for SIP endpoints.
NEW QUESTION # 17
No matter on any condition, our company will not use your information to make profits. As already mentioned above, our 71301T learning materials attach great importance to the interests of customers. A product can develop for so many years, and ultimately the customer's trust and support. Many of the users of 71301T training prep were introduced by our previous customers. They truly trust our 71301T exam questions. And as long as you buy our 71301T practice guide, we believe you will trust them as well.
Latest 71301T Exam Labs: https://www.braindumpquiz.com/71301T-exam-material.html
Avaya 71301T Practice Braindumps No matter on any condition, our company will not use your information to make profits, Before you buy our 71301T exam preparation, you can try the free demo firstly to assess the quality and confirm whether it is the study material you need, Our 71301T - Avaya Aura Communication Applications Implement Dumps study guide is the most reliable and popular exam product in the marcket for we only sell the latest 71301T - Avaya Aura Communication Applications Implement Dumps practice engine to our clients and you can have a free trial before your purchase, Our IT elites design the best 71301T practice exam by collecting the complex questions and analyzing the key points of the actual test over years.
He is currently working as a technical leader in the Worldwide 71301T Security Services Practice of Advanced Services for Network Security, For others, the tricks will improve system performance.
Free PDF Quiz 2026 Avaya 71301T – Reliable Practice BraindumpsNo matter on any condition, our company will not use your information to make profits, Before you buy our 71301T Exam Preparation, you can try the free demo firstly Valid 71301T Exam Format to assess the quality and confirm whether it is the study material you need.
Our 71301T - Avaya Aura Communication Applications Implement Dumps study guide is the most reliable and popular exam product in the marcket for we only sell the latest 71301T - Avaya Aura Communication Applications Implement Dumps practice engine to our clients and you can have a free trial before your purchase.
Our IT elites design the best 71301T practice exam by collecting the complex questions and analyzing the key points of the actual test over years, Our 71301T pass4sure cram can assist you pass the exam in a short time due to high quality and convenience.
