[General] Latest AZ-400 Examprep | AZ-400 Exam Registration
81
【General】 Latest AZ-400 Examprep | AZ-400 Exam Registration
Posted at 1/18/2026 22:58:59      View:238 | Replies:1        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of DumpsReview AZ-400 dumps from Cloud Storage: https://drive.google.com/open?id=1fTkDOJA9auK5rAf4dbqHNMront1W_1qH
Please believe that our company is very professional in the research field of the AZ-400 training questions, which can be illustrated by the high passing rate of the examination. Despite being excellent in other areas, we have always believed that quality and efficiency should be the first of our AZ-400 real exam. For study materials, the passing rate is the best test for quality and efficiency. There may be some other study materials with higher profile and lower price than our products, but we can assure you that the passing rate of our AZ-400 Learning Materials is much higher than theirs. And this is the most important. According to previous data, 98 % to 99 % of the people who use our AZ-400 training questions passed the exam successfully. If you are willing to give us a trust, we will give you a success.
Prestigious Job RolesAfter passing the Microsoft AZ-400 exam and obtaining the certificate, you will get a lot of benefits as a certified IT expert. Thus, you can become a Technical Sales Engineer, a DevOps Engineer, a Senior Mobility Engineer, a Development Ops Engineer, or a Software Engineer.
Microsoft AZ-400 Certification Exam is designed for professionals who are responsible for designing and implementing DevOps solutions using Microsoft technologies. It is a highly sought-after certification that validates the skills and knowledge required to create and maintain DevOps workflows with Microsoft Azure.
Microsoft AZ-400 Exam Registration & Test AZ-400 Cram PdfDumpsReview has designed AZ-400 pdf dumps format that is easy to use. Anyone can download Microsoft AZ-400 pdf questions file and use it from any location or at any time. Microsoft PDF Questions files can be used on laptops, tablets, and smartphones. Moreover, you will get actual Microsoft AZ-400 Exam Questions in this Microsoft AZ-400 pdf dumps file.
Microsoft Designing and Implementing Microsoft DevOps Solutions Sample Questions (Q350-Q355):NEW QUESTION # 350
You have an approval process that contains a condition. The condition requires that releases be approved by a team leader before they are deployed.
You have a policy stating that approvals must occur within eight hours.
You discover that deployment fail if the approvals take longer than two hours.
You need to ensure that the deployments only fail if the approvals take longer than eight hours.
Solution: From Pre-deployment conditions, you modify the Time between re-evaluation of gates option.
Does this meet the goal?
  • A. Yes
  • B. No
NEW QUESTION # 351
You have the following Azure policy.
  • A. prevents HTTPS traffic to new Azure Storage accounts when the accounts are accessed over the internet
  • B. prevents all HTTP traffic to wasting Azure Storage accounts
  • C. ensures that at) data for new Azure Storage accounts is encrypted at rest
  • D. ensures that all traffic to new Azure Storage accounts is encrypted
NEW QUESTION # 352
You need to create an instance of Azure Application Insights named az400-9940427-main and configure the instance to receive telemetry data from an Azure web app named az400-9940427-main.
To complete this task, sign in to the Microsoft Azure portal.
  • A. See solution below
Step 1: Create an instance of Azure Application Insights
1. Open Microsoft Azure Portal
2. Log into your Azure account, Select Create a resource > Developer tools > Application Insights.
3. Enter the following settings, and then select Review + create.
Step 2: Configure App Insights SDK
4. Open your ASP.NET Core Web App project in Visual Studio > Right-click on the AppName in the Solution Explorer > Select Add > Application Insights Telemetry.
5. Click the Get Started button
6. Select your account and subscription > Select the Existing resource you created in the Azure portal > Click Register.
https://docs.microsoft.com/bs-la ... -start?view=vs-2017
NEW QUESTION # 353
You add the virtual machines as managed nodes in Azure Automation State Configuration.
You need to configure the computer in Group7.
What should you do?
  • A. Modify the ConfigurationMode property of the Local Configuration Manager (LCM).
  • B. Modify the RefreshMode property of the Local Configuration Manager (LCM).
  • C. Install PowerShell Core.
  • D. Run the Register-AzureRmAutomationDscNode Azure Powershell cmdlet.
The Register-AzureRmAutomationDscNode cmdlet registers an Azure virtual machine as an APS Desired State Configuration (DSC) node in an Azure Automation account.
Scenario: The Azure DevOps organization includes:
The Docker extension
A deployment pool named Pool7 that contains 10 Azure virtual machines that run Windows Server 2016
References: https://docs.microsoft.com/en-us ... rmautomationdscnode
NEW QUESTION # 354
How should you confrere the release retention policy for the investment planning depletions suite? To answer, select the appropriate options in the answer area.
Every request made against a storage service must be authorized, unless the request is for a blob or container resource that has been made available for public or signed access. One option for authorizing a request is by using Shared Key.
Scenario: The mobile applications must be able to call the share pricing service of the existing retirement fund management system. Until the system is upgraded, the service will only support basic authentication over HTTPS.
The investment planning applications suite will include one multi-tier web application and two iOS mobile application. One mobile application will be used by employees; the other will be used by customers.
References: https://docs.microsoft.com/en-us ... ize-with-shared-key
Topic 2, Overview
Existing Environment
Contoso, Ltd. is a manufacturing company that has a main office in Chicago.
Requirements
Contoso plans to improve its IT development and operations processes implementing Azue DevOps principles. Contoso has an Azure subscription and creates an Azure DevOPs organization.
* The Docker extension
* A deployment pool named Pool7 that contains 10 Azure virtual machines that run Windows Server 2016.
The Azure subscription contains an Azure Automation account.
Planned Changes
Contoso plans to create projects in Azure DevOps as shown in the following table.
Technical Requirements
Contoso identities the following technical requirements:
* Implement build agents rot Project 1.
* Whenever possible, use Azure resources
* Avoid using deprecated technologies
* Implement a code flow strategy for Project2 that will:
* Enable Team 2 to submit pull requests for Project2.
* Enable Team 2 to work independently on changes to a copy of Project?
* Ensure that any intermediary changes performed by Tram2 on a copy of Project2 will be subject to the same restrictions as the ones defied in the build policy of Project2.
* Whenever possible. Implement automation and minimize administrative effort.
* Implement Protect3, Project5, Project6, and Project7 based on the planned changes.
* Implement Project4 and configure the project to push Docker images to Azure Container Reentry.
NEW QUESTION # 355
AZ-400 practice questions and pass it with confidence. As far as the top features of AZ-400 exam dumps are concerned, these Microsoft AZ-400 latest questions are real and verified by Microsoft AZ-400 certification exam experts. With the Microsoft AZ-400 Practice Test questions you will get everything that you need to learn, prepare and get success in the final Designing and Implementing Microsoft DevOps Solutions certification exam.
AZ-400 Exam Registration: https://www.dumpsreview.com/AZ-400-exam-dumps-review.html
P.S. Free & New AZ-400 dumps are available on Google Drive shared by DumpsReview: https://drive.google.com/open?id=1fTkDOJA9auK5rAf4dbqHNMront1W_1qH
Posted at 2/23/2026 20:23:54        Only Author  2#
This article is outstanding, I’m so grateful for your sharing. I used the NESTA-PFT valid exam guide files to get promoted and raise my salary. It’s free for everyone now. Wishing you quick career growth!
