[Hardware] Confluent CCAAK Dumps - New CCAAK Exam Notes
93
【Hardware】 Confluent CCAAK Dumps - New CCAAK Exam Notes
Posted at 2/1/2026 09:03:40      View:138 | Replies:2        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Confluent CCAAK dumps are available on Google Drive shared by ExamDiscuss: https://drive.google.com/open?id=1KUOTzwo3GbtO2mZMZcsM-EZSKkTn0943
For candidates who will buy CCAAK exam cram online, they may pay much attention to privacy protection. If you choose us, your personal information such as your name and email address will be protected well. After your payment for CCAAK exam cram, your personal information will be concealed. Besides, we won’t send junk mail to you. We offer you free demo for CCAAK Exam Dumps before buying, so that you can have a deeper understanding of what you are going to buy.
Confluent CCAAK Exam Syllabus Topics:
  • Deployment Architecture: This section of the exam measures skills of a Kafka Administrator and covers different Kafka deployment topologies. It evaluates understanding of high availability, disaster recovery, multi-data center replication, and the roles of Zookeeper or KRaft in the cluster architecture.
  • Kafka Connect: This section of the exam measures skills of a Site Reliability Engineer and addresses the use and management of Kafka Connect for data integration. It includes setting up connectors, managing configurations, and ensuring efficient movement of data between Kafka and external systems.
  • Apache Kafka® Cluster Configuration: This section of the exam measures skills of a Kafka Administrator and includes configuring broker properties, tuning for performance, managing topic-level settings, and applying best practices for production-grade environments.
The Benefits of CCAAK CertificationNew questions will be added into the study materials, unnecessary questions will be deleted from the CCAAK exam simulation. Our new compilation will make sure that you can have the greatest chance to pass the exam. If you compare our CCAAK training engine with the real exam, you will find that our study materials are highly similar to the real exam questions. So you just need to memorize our questions and answers of the CCAAK Exam simulation, you are bound to pass the exam.
Confluent Certified Administrator for Apache Kafka Sample Questions (Q20-Q25):NEW QUESTION # 20
A Kafka administrator notices that their consumers of Topic X are starting to fall behind. The administrator sees that Topic X has four partitions, and the consumer group has two consumers.
Which change can increase the performance of the Consumer Group?
  • A. Decrease the consumer acknowledgment property to increase throughput.
  • B. Increase the partitions in Topic X.
  • C. Create a new consumer group for Topic X containing two (2) consumers.
  • D. Increase the number of consumers in the consumer group.
With 4 partitions and only 2 consumers, some consumers are handling multiple partitions, which may cause lag if processing is slow. By increasing the number of consumers in the group (up to 4), Kafka can assign one partition per consumer, improving parallelism and throughput.
NEW QUESTION # 21
A topic 'recurring payments' is created on a Kafka cluster with three brokers (broker id '0', '1', '2') and nine partitions. The 'min.insync replicas' is set to three, and producer is set with 'acks' as 'all'. Kafka Broker with id '0' is down.
Which statement is correct?
  • A. Producers will only be able to write messages to the topic where the Leader for the partition is on Broker id T.
  • B. Consumers can read committed messages from partitions on broker id T, "2
  • C. Producers and consumers will have no impact on six of the nine partitions.
  • D. Producers can write messages to all the partitions, because new leaders for the partitions will be elected.
With 9 partitions spread across 3 brokers, each broker typically hosts 3 leaders (assuming even distribution). When Broker 0 fails, the partitions for which it was leader will elect new leaders on brokers 1 or 2 if enough in-sync replicas (ISRs) remain. But since min.insync.replicas=3 and only 2 brokers are up, no partition can meet the minimum in-sync replica requirement, so producers with acks=all will fail to write. However, for partitions where Broker 0 is not the leader, consumers can still read committed messages. Given that only 3 partitions likely had Broker 0 as leader, six partitions remain accessible for reads, but not writes.
NEW QUESTION # 22
A broker in the Kafka cluster is currently acting as the Controller.
  • A. It can have topic partitions.
  • B. All consumers are allowed to fetch messages only from this server.
  • C. It is responsible for sending leader information to all producers.
  • D. It is given precedence for replication to and from replica followers.
The Controller broker is a regular broker that also takes on additional responsibilities for managing cluster metadata, such as leader elections and partition assignments. It still hosts topic partitions and participates in replication like any other broker.
NEW QUESTION # 23
A Kafka cluster with three brokers has a topic with 10 partitions and a replication factor set to three. Each partition stores 25 GB data per day and data retention is set to 24 hours.
How much storage will be consumed by the topic on each broker?
  • A. 300 GB
  • B. 250 GB
  • C. 75 GB
  • D. 750 GB
10 partitions × 25 GB/day = 250 GB total per day for the topic (primary data).
With a replication factor of 3, there are 3 full copies of the data: 250 GB × 3 = 750 GB total across the entire cluster.
The cluster has 3 brokers, and Kafka tries to distribute replicas evenly among them: 750 GB ÷ 3 brokers = 250 GB per broker on average.
However, due to replication, some partitions have leaders and followers, so there's some overlap and not-perfect distribution. Each broker stores approximately 2/3 of the total topic data (since each broker holds replicas for around 2/3 of the partitions).
2/3 × 750 GB = 500 GB, but this is shared, so each broker ends up storing ~300 GB of replicated data, including its share of leaders and followers.
NEW QUESTION # 24
An employee in the reporting department needs assistance because their data feed is slowing down. You start by quickly checking the consumer lag for the clients on the data stream.
Which command will allow you to quickly check for lag on the consumers?
  • A. bin/kafka-consumer-groups.sh
  • B. bin/kafka-consumer-group-throughput.sh
  • C. bin/kafka-consumer-lag.sh
  • D. bin/kafka-reassign-partitions.sh
The kafka-consumer-groups.sh script is used to inspect consumer group details, including consumer lag, which indicates how far behind a consumer is from the latest data in the partition.
The typical usage is bin/kafka-consumer-groups.sh --bootstrap-server <broker> --describe --group <group_id>
NEW QUESTION # 25
Our delivery speed is also highly praised by customers. Our CCAAK exam dumps won’t let you wait for such a long time. As long as you pay at our platform, we will deliver the relevant CCAAK test prep to your mailbox within 5-10 minutes. Our company attaches great importance to overall services, if there is any problem about the delivery of CCAAK Test Braindumps, please let us know, a message or an email will be available. We are pleased that you can spare some time to have a look for your reference about our CCAAK test prep.
New CCAAK Exam Notes: https://www.examdiscuss.com/Confluent/exam/CCAAK/
BTW, DOWNLOAD part of ExamDiscuss CCAAK dumps from Cloud Storage: https://drive.google.com/open?id=1KUOTzwo3GbtO2mZMZcsM-EZSKkTn0943
Posted at 2/4/2026 12:50:16        Only Author  2#
Loved it immediately, clicking that like. Sharing New Maryland-Real-Estate-Salesperson cram materials exam questions for free—open the door to promotions and salary increases!
Posted at 2/12/2026 02:29:39        Only Author  3#
Viele Leute meinen, man braucht viel fachliche IT-Kenntnisse, um die schwierigen Salesforce Data-Con-101 IT-Zertifizierungsprüfung zu bestehen. Nur diejenigen, die umfassende IT-Kenntnisse besitzen, sind qualifiziert dazu, sich an der Salesforce Data-Con-101 Prüfung zu beteiligen. Jetzt gibt es viele Methoden, die Ihre unausreichenden Fachkenntnisse wettmachen. Sie können sogar mit weniger Zeit und Energie als die fachlich gutqualifizierten die Salesforce Data-Con-101 Prüfung auch bestehen. Wie es heißt, viele Wege führen nach Rom.
