[Hardware] Quiz Fortinet - FCP_FGT_AD-7.6 - FCP - FortiGate 7.6 Administrator¨CValid Pass4su
113
¡¾Hardware¡¿ Quiz Fortinet - FCP_FGT_AD-7.6 - FCP - FortiGate 7.6 Administrator¨CValid Pass4su
Posted at 2/19/2026 01:57:18      View£º121 | Replies£º0        Print      Only Author   [Copy Link] 1#
P.S. Free & New FCP_FGT_AD-7.6 dumps are available on Google Drive shared by PDFTorrent: https://drive.google.com/open?id=1LAInPK8fvAfwrYrCRRiZhPPVmukBak-6
The FCP_FGT_AD-7.6 exam questions are being offered in three different formats. The names of these formats are FCP - FortiGate 7.6 Administrator (FCP_FGT_AD-7.6) desktop practice test software, web-based practice test software, and PDF dumps file. The Fortinet desktop practice test software and web-based practice test software both give you real-time Fortinet FCP_FGT_AD-7.6 Exam environment for quick and complete exam preparation.
Fortinet FCP_FGT_AD-7.6 Exam Syllabus Topics:
  • Routing: This section of the exam measures the skills of firewall administrators and covers the configuration of routing features on FortiGate devices. It includes defining and applying static routes for directing traffic within and outside the network, as well as setting up Software-Defined WAN (SD-WAN) to distribute and balance traffic loads across multiple WAN connections efficiently.
  • Firewall policies and authentication: This section of the exam measures the skills of firewall administrators and covers the implementation and management of security policies. It involves configuring basic and advanced firewall rules, applying Source NAT (SNAT) and Destination NAT (DNAT) options, and enforcing various firewall authentication methods. The section also includes deploying and configuring Fortinet Single Sign-On (FSSO) to streamline user access across the network.
  • Deployment and system configuration: This section of the exam measures the skills of network security engineers and covers essential tasks for setting up a FortiGate device in a production environment. Candidates are expected to perform the initial configuration, establish basic connectivity, and integrate the device within the Fortinet Security Fabric. They must also be able to configure a FortiGate Cluster Protocol (FGCP) high availability setup and troubleshoot resource and connectivity issues to ensure system readiness and network uptime.
  • Content inspection: This section of the exam measures the skills of network security engineers and covers the setup and management of content inspection features on FortiGate. Candidates must demonstrate an understanding of encrypted traffic inspection using digital certificates, identify and apply FortiGate inspection modes, and configure web filtering policies. The ability to implement application control for monitoring and regulating network application usage, configure antivirus profiles to detect and block malware, and set up Intrusion Prevention Systems (IPS) to shield the network from threats and vulnerabilities is also assessed.
Topic 5
  • VPN: This section of the exam measures the skills of network security engineers and covers the configuration and deployment of Virtual Private Network (VPN) solutions. Candidates are required to implement SSL VPNs to grant secure remote access to internal resources and configure IPsec VPNs in either meshed or partially redundant topologies to ensure encrypted communication between distributed network locations.
Pdf FCP_FGT_AD-7.6 Format, FCP_FGT_AD-7.6 Reliable DumpThe Fortinet FCP_FGT_AD-7.6 web-based practice test software is very user-friendly and simple to use. It is accessible on all browsers (Chrome, Firefox, MS Edge, Safari, Opera, etc). It will save your progress and give a report of your mistakes which will surely be beneficial for your overall FCP_FGT_AD-7.6 Exam Preparation.
Fortinet FCP - FortiGate 7.6 Administrator Sample Questions (Q41-Q46):NEW QUESTION # 41
An administrator has created a new firewall address to use as the destination for a static route.
Why is the administrator not able to select the new address in the Destination field of the new static route?
  • A. In the new firewall address, Routing configuration must be enabled.
  • B. In the new static route, the administrator must select Named Address.
  • C. In the new static route, the administrator must first set the interface to port2.
  • D. In the new firewall address, the FQDN address must first beresolved.
To use an FQDN-based address object as a destination in a static route, the "Routing configuration" option must be enabled in the firewall address settings. Without this, the address cannot be selected for routing.
NEW QUESTION # 42
Refer to the exhibits, which show the firewall policy and an antivirus profile configuration.
Why is the user unable to receive a block replacement message when downloading an infected file for the first time?
  • A. The firewall policy performs a full content inspection on the file.
  • B. The option to send files to FortiSandbox for inspection is enabled.
  • C. The intrusion prevention security profile must be enabled when using flow-based inspection mode.
  • D. Flow-based inspection is used, which resets the last packet to the user.
When flow-based inspection is used, FortiGate scans packets as they flow through, and if a virus is detected, the connection is reset immediately. Because the infected file is blocked mid-transfer, the user does not receive a block replacement message - only the last packet is dropped to terminate the connection.
Replacement messages are shown only in proxy-based inspection, where FortiGate can buffer and fully analyze the file before sending a response page.
NEW QUESTION # 43
Refer to the exhibit. The NOC team connects to the FortiGate GUI with the NOC_Access admin profile. They request that their GUI sessions do not disconnect too early during inactivity. What must the administrator configure to answer this specific request from the NOC team?
  • A. Move NOC_Access to the top of the list to ensure all profile settings take effect.
  • B. Ensure that all NOC_Access users are assigned the super_admin role to guarantee access
  • C. Increase the admintimeout value under config system accprofile NOC_Access.
  • D. Increase the offline value of the Override Idle Timeout parameter in the NOC_Access admin profile.
The admintimeout setting in the admin access profile controls the inactivity timeout for GUI sessions. Increasing this value will extend the session duration before automatic disconnection.
NEW QUESTION # 44
Refer to the exhibits.
An administrator configured both members of an HA cluster at the same time. After one week of monitoring, the administrator wants to verify the HA failover performance.
How can the administrator force a failover?
  • A. The administrator must set the parameter override to enable on HQ-NGFW-2.
  • B. The administrator must set the monitored port to down on HQ-NGFW-1.
  • C. The administrator must reset the HA uptime on HQ-NGFW-1.
  • D. The administrator must increase the HA priority on HQ-NGFW-2.
NEW QUESTION # 45
FortiGate is integrated with FortiAnalyzer and FortiManager.
When creating a firewall policy, which attribute must an administrator include to enhance functionality and enable log recording on FortiAnalyzer and FortiManager?
  • A. Universally Unique Identifier
  • B. Sequence ID
  • C. Policy ID
  • D. Log ID
FortiGate uses a Universally Unique Identifier (UUID) for each firewall policy. This UUID is synchronized with FortiAnalyzer and FortiManager, allowing them to reliably identify the policy even if the policy ID or sequence changes. This ensures consistent log recording and enhanced functionality across integrated devices.
NEW QUESTION # 46
Comparing to other training institution, our valid FCP_FGT_AD-7.6 vce dumps are affordable, latest and cost-effective, which can overcome the difficulty of valid FCP_FGT_AD-7.6 Actual Test and ensure you pass the exam. It can not only save your time and money, but also help you clear Fortinet practice exam with high rate.
Pdf FCP_FGT_AD-7.6 Format: https://www.pdftorrent.com/FCP_FGT_AD-7.6-exam-prep-dumps.html
