Realistic Study DP-420 Reference, Valid DP-420 Exam Online
Posted at 1/31/2026 16:52:02
View106
Replies0
P.S. Free 2026 Microsoft DP-420 dumps are available on Google Drive shared by TestValid: https://drive.google.com/open?id=1sNwpBaMtcFnFZ-gvHTh4nClVSAMHLFpi
Students are given a fixed amount of time to complete each test, thus Microsoft Exam Questions candidate's ability to control their time and finish the Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB (DP-420) exam in the allocated time is a crucial qualification. Obviously, this calls for lots of practice. Taking TestValid DP-420 Practice Exam helps you get familiar with the Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB (DP-420) exam questions and work on your time management skills in preparation for the real Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB (DP-420) exam.
Earning the DP-420 certification can help professionals advance their careers in cloud computing and demonstrate their expertise to potential employers. It can also help them stay up-to-date with the latest trends and best practices in cloud-native application development. With the growing demand for cloud-native applications, the DP-420 certification is a valuable credential for developers who want to stand out in the job market and advance their careers.
The DP-420 Certification Exam is intended for individuals who have experience with Azure Cosmos DB and want to showcase their expertise in designing and implementing cloud-native applications. DP-420 exam is ideal for professionals who have experience working with Azure Cosmos DB, but who want to deepen their knowledge and gain a deeper understanding of how to design and implement cloud-native applications using this technology.
2026 DP-420 C 100% Free Study Reference | Valid DP-420 Exam OnlineThis is a simple and portable document of real Microsoft DP-420 Exam Questions. It contains actual Microsoft DP-420 exam questions and answers and can be helpful for quick revision or for studying on the go. It is also printable so you can easily study on a hard copy of the pdf having a break from staring.
Microsoft DP-420 Certification Exam is designed for professionals who want to demonstrate their skills in designing and implementing cloud-native applications using Microsoft Azure Cosmos DB. DP-420 exam is intended for individuals who have a strong understanding of Azure Cosmos DB and its core features, as well as experience with designing and implementing cloud-native applications.
Microsoft Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB Sample Questions (Q129-Q134):NEW QUESTION # 129
You are creating a database in an Azure Cosmos DB Core (SQL) API account. The database will be used by an application that will provide users with the ability to share online posts. Users will also be able to submit comments on other users' posts.
You need to store the data shown in the following table.
The application has the following characteristics:
Users can submit an unlimited number of posts.
The average number of posts submitted by a user will be more than 1,000.
Posts can have an unlimited number of comments from different users.
The average number of comments per post will be 100, but many posts will exceed 1,000 comments.
Users will be limited to having a maximum of 20 interests.
Box 1: Yes
Non-relational data increases write costs, but can decrease read costs.
Box 2: Yes
Box 3: No
NEW QUESTION # 130
You have a container named container1 in an Azure Cosmos DB Core (SQL) API account.
You need to make the contents of container1 available as reference data for an Azure Stream Analytics job.
Solution: You create an Azure function that uses Azure Cosmos DB Core (SQL) API change feed as a trigger and Azure event hub as the output.
Does this meet the goal?
The Azure Cosmos DB change feed is a mechanism to get a continuous and incremental feed of records from an Azure Cosmos container as those records are being created or modified. Change feed support works by listening to container for any changes. It then outputs the sorted list of documents that were changed in the order in which they were modified.
The following diagram represents the data flow and components involved in the solution:
Reference: https://docs.microsoft.com/en-us ... -ecommerce-solution
NEW QUESTION # 131
You have an application named App1 that reads the data in an Azure Cosmos DB Core (SQL) API account.
App1 runs the same read queries every minute. The default consistency level for the account is set to eventual.
You discover that every query consumes request units (RUs) instead of using the cache.
You verify the IntegratedCacheiteItemHitRate metric and the IntegratedCacheQueryHitRate metric. Both metrics have values of 0.
You verify that the dedicated gateway cluster is provisioned and used in the connection string.
You need to ensure that App1 uses the Azure Cosmos DB integrated cache.
What should you configure?
- A. the indexing policy of the Azure Cosmos DB container
- B. the default consistency level of the Azure Cosmos DB account
- C. the connectivity mode of the App1 CosmosClient
- D. the consistency level of the requests from App1
Because the integrated cache is specific to your Azure Cosmos DB account and requires significant CPU and memory, it requires a dedicated gateway node. Connect to Azure Cosmos DB using gateway mode.
Reference: https://docs.microsoft.com/en-us ... ntegrated-cache-faq
NEW QUESTION # 132
You need to provide a solution for the Azure Functions notifications following updates to con-product. The solution must meet the business requirements and the product catalog requirements.
Which two actions should you perform? Each correct answer presents part of the solution.
- A. Configure the trigger for each function to use the same leaseCollectionPrefix
- B. Configure the trigger for each function to use the same leaseCollectionNair.e
- C. Configure the trigger for each function to use a different leaseCollectionName
- D. Configure the trigger for each function to use a different leaseCollectionPrefix
leaseCollectionPrefix: when set, the value is added as a prefix to the leases created in the Lease collection for this Function. Using a prefix allows two separate Azure Functions to share the same Lease collection by using different prefixes.
Scenario: Use Azure Functions to send notifications about product updates to different recipients.
Trigger the execution of two Azure functions following every update to any document in the con-product container.
https://docs.microsoft.com/en-us ... cosmosdb-v2-trigger
NEW QUESTION # 133
You provision Azure resources by using the following Azure Resource Manager (ARM) template.
Box 1: No
An alert is triggered when the DB key is regenerated, not when it is used.
Note: The az cosmosdb keys regenerate command regenerates an access key for a Azure Cosmos DB database account.
Box 2: No
Only an SMS action will be taken.
Emailreceivers is empty so no email action is taken.
Box 3: Yes
Yes, an alert is triggered when the DB key is regenerated.
Reference: https://docs.microsoft.com/en-us/cli/azure/cosmosdb/keys
NEW QUESTION # 134
Valid DP-420 Exam Online: https://www.testvalid.com/DP-420-exam-collection.html
- DP-420 Valid Cram Materials 🗜 DP-420 Pass Exam 🌒 DP-420 Reliable Exam Pdf ☢ Open website ➽ [url]www.prepawaypdf.com 🢪 and search for DP-420 for free download ❗DP-420 Latest Dumps[/url]
- Professional Microsoft Study DP-420 Reference | Try Free Demo before Purchase 🦅 Go to website [ [url]www.pdfvce.com ] open and search for ▷ DP-420 ◁ to download for free 🤶DP-420 Latest Dumps[/url]
- Study DP-420 Plan ♣ DP-420 Valid Cram Materials ✍ DP-420 Latest Dumps 🏝 Download [ DP-420 ] for free by simply entering [url]www.verifieddumps.com website 🔪DP-420 Latest Dumps[/url]
- DP-420 Latest Dumps 👪 DP-420 Pass Exam 🥿 DP-420 Mock Test 🕑 Open [ [url]www.pdfvce.com ] and search for ▛ DP-420 ▟ to download exam materials for free 🦘DP-420 Mock Test[/url]
- Best DP-420 : Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB Exam Torrent Provide Three Versions for choosing 🚜 Copy URL ▶ [url]www.prepawaypdf.com ◀ open and search for [ DP-420 ] to download for free ⛵Dumps DP-420 PDF[/url]
- DP-420 Valid Test Answers 🍊 Certification DP-420 Dumps 💯 Mock DP-420 Exam ▶ Download ▷ DP-420 ◁ for free by simply entering ▶ [url]www.pdfvce.com ◀ website 🎬Study DP-420 Plan[/url]
- Professional Microsoft Study DP-420 Reference | Try Free Demo before Purchase 🤮 Enter ✔ [url]www.prep4sures.top ️✔️ and search for DP-420 to download for free 🚊Valid DP-420 Test Duration[/url]
- Study DP-420 Reference - 2026 First-grade Microsoft Valid DP-420 Exam Online 💚 Easily obtain free download of ➤ DP-420 ⮘ by searching on ▛ [url]www.pdfvce.com ▟ 🦨DP-420 Mock Test[/url]
- Free PDF Quiz Trustable Microsoft - DP-420 - Study Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB Reference 🤬 Copy URL [url]www.torrentvce.com open and search for DP-420 to download for free ⛵Online DP-420 Version[/url]
- Enhance Your Exam Preparation with Microsoft DP-420 Questions 🧾 Open [url]www.pdfvce.com and search for DP-420 to download exam materials for free 📣Valid DP-420 Test Duration[/url]
- Free PDF Quiz Microsoft - High Hit-Rate Study DP-420 Reference L ☀ [url]www.testkingpass.com ️☀️ is best website to obtain DP-420 for free download 📧Valid DP-420 Test Duration[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.bandlab.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
BTW, DOWNLOAD part of TestValid DP-420 dumps from Cloud Storage: https://drive.google.com/open?id=1sNwpBaMtcFnFZ-gvHTh4nClVSAMHLFpi
