[General] Free PDF 2026 Fantastic 350-801: New Study Implementing and Operating Cisco Coll
99
General Free PDF 2026 Fantastic 350-801: New Study Implementing and Operating Cisco Coll
Posted at 2/10/2026 12:35:29      View122 | Replies0        Print      Only Author   [Copy Link] 1#
What's more, part of that TrainingQuiz 350-801 dumps now are free: https://drive.google.com/open?id=1-SyvKbTl3HtH3eNSrLGGMqKdo617HICA
Our TrainingQuiz devote themselves for years to develop the 350-801 exam software to help more people who want to have a better development in IT field to pass 350-801 exam. Although there are so many exam materials about 350-801 exam, the 350-801 exam software developed by our TrainingQuiz professionals is the most reliable software. Practice has proved that almost all those who have used the software we provide have successfully passed the 350-801 Exam. Many of them just use spare time preparing for 350-801 Cisco exam, and they are surprised to pass the certificated exam.
The authority of Cisco 350-801 exam questions rests on its being high-quality and prepared according to the latest pattern. TrainingQuiz is proud to announce that our Cisco 350-801 Exam Dumps help the desiring candidates of Cisco 350-801 certification to climb the ladder of success by grabbing the Cisco Exam Questions.
350-801 Reliable Test Cost, Reliable 350-801 Test PriceWith these two Implementing and Operating Cisco Collaboration Core Technologies 350-801 practice exams, you will get the actual Cisco 350-801 exam environment. Whereas the TrainingQuiz PDF file is ideal for restriction-free test preparation. You can open this PDF file and revise 350-801 Real Exam Questions at any time. Choose the right format of Implementing and Operating Cisco Collaboration Core Technologies 350-801 actual questions and start Cisco 350-801 preparation today.
Cisco 350-801 Exam is ideal for professionals who want to advance their careers in the field of Cisco collaboration technologies. Individuals who pass 350-801 exam not only earn the Cisco Certified Specialist - Collaboration Core certification but also demonstrate their expertise in implementing and operating Cisco collaboration solutions. Implementing and Operating Cisco Collaboration Core Technologies certification is recognized globally and is highly regarded by employers, making it a valuable asset for professionals who want to stand out in the job market.
Cisco Implementing and Operating Cisco Collaboration Core Technologies Sample Questions (Q395-Q400):NEW QUESTION # 395
Refer to the exhibit. An administrator configures a secure SIP trunk on Cisco UCM.
Which value is needed in the Secure Certificate Subject or Subject Alternate Name field to accomplish this task?
  • A. the common name of the Cisco UCM CallManager certificate
  • B. the fully qualified domain name of all Cisco UCM nodes that run the CallManager service
  • C. the fully qualified domain name of the remote device that is configured on the SIP trunk
  • D. the common name of the remote device certificates
NEW QUESTION # 396
A Cisco Unity Connection administrator configures LDAP integration and performs a full LDAP sync. The administrator must add all users with mailboxes from the LDAP directory to Unity Connection. What must the administrator do in Cisco Unity Connection Administration?
  • A. From LDAP, select LDAP Directory Configuration, and then click Perform Full Sync Now.
  • B. From Users, select Users, select New Users, and then click Import from LDAP.
  • C. From Users, select Import Users, set Find End Users In to LDAP Directory, and the click Find.
  • D. From Users, select Synch Users, set Find Imported Users In to LDAP Directory, and then click Find.
In Cisco Unity Connection, after performing an LDAP sync, the next step to import users with mailboxes is to manually import them from the LDAP directory into Unity Connection.
The correct process is to navigate to Users > Import Users, then select Find End Users In:
LDAP Directory, and click Find.
This action lists all LDAP-synced users, allowing the administrator to select users for import into Unity Connection.
Once imported, these users can have voicemail accounts provisioned and managed within Unity Connection.
NEW QUESTION # 397
Where is the default for maximum session Bit Rate for a region configured?
  • A. Service parameter configuration
  • B. Enterprise parameters configuration
  • C. Enterprise Phone configuration
  • D. Region configuration
NEW QUESTION # 398
Which service must be enabled when LDAP on Cisco UCM is used?
  • A. Cisco DirSync
  • B. Cisco AXL Web Service
  • C. Cisco CallManager SNMP Service
  • D. Cisco Bulk Provisioning Service
Section: Infrastructure and Design
Explanation/Reference: https://www.cisco.com/c/en/us/td ... m/cucm/im_presence/ configAdminGuide/10_5_1/CUP0_BK_CE43108E_00_config-admin-guide-imp-105/ CUP0_BK_CE43108E_00_config-admin-guide-imp-105_chapter_01000.html
NEW QUESTION # 399
A user forwards a corporate number to an international number. What are two methods to prevent this forwarded call? (Choose two.)
  • A. Configure all forced code on all router.
  • B. Set the call Classification to OnNet for the international route pattern.
  • C. Configure a Forced Authorization Code on the international route pattern.
  • D. Block international dial patterns in the SIP trunk CSS.
  • E. Set call forward All CSS to restrict international dial patterns.
Answer: C,E
NEW QUESTION # 400
After you practice our 350-801 study materials, you can master the examination point from the 350-801 exam torrent. Then, you will have enough confidence to pass your 350-801 exam. We can succeed so long as we make efforts for one thing. As for the safe environment and effective product, why dont you have a try for our 350-801 Test Question, never let you down! Before your purchase, there is a free demo of our 350-801 training material for you. You can know the quality of our 350-801 guide question earlier before your purchase.
350-801 Reliable Test Cost: https://www.trainingquiz.com/350-801-practice-quiz.html
BONUS!!! Download part of TrainingQuiz 350-801 dumps for free: https://drive.google.com/open?id=1-SyvKbTl3HtH3eNSrLGGMqKdo617HICA
