100% Pass 2026 Microsoft MB-820–Valid Test Topics Pdf
Posted at 1/13/2026 03:35:02
2026 Latest PDFDumps MB-820 PDF Dumps and MB-820 Exam Engine Free Share: https://drive.google.com/open?id=1kJzduVJ7Xwbzob_uedzGOBHoRYh7tODk
Microsoft MB-820 practice materials are highly popular in the market compared with other materials from competitors whether on the volume of sales or content as well. All precise information on the Microsoft Dynamics 365 Business Central Developer MB-820 Exam Questions and high accurate questions are helpful. To help you have a thorough understanding of our MB-820 training prep, free demos are provided for your reference.
Microsoft MB-820 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Integrate Business Central with other applications: Accessing Representational State Transfer (REST) services is discussed in this topic. It also explains implementation of APIs.
| | Topic 2 | - Work with development tools: Implementing semi-automated test processes and managing and assessing telemetry are its sub-topics.
| | Topic 3 | - Describe Business Central: Describing the components and capabilities of Business Central, and describing the core solution and extensions approach for Business Central are focal points of this topic. It also explains the difference between Business Central Online and Business Central on-premises features.
| | Topic 4 | - Develop by using AL: How to Customize the UI experience and Use AL for business central extension is discussed here. It also delves into explaining the essential development standards.
| | Topic 5 | - Install, develop, and deploy for Business Central: It delves into the installation and configuration of a Business Central development environment. Moreover, it discusses creating, debugging, and deploying an extension in Business Central.
MB-820 Study Demo - MB-820 Latest ExamAs you know, we are now facing very great competitive pressure. We need to have more strength to get what we want, and MB-820 free exam guide may give you these things. After you use our study materials, you can get Microsoft Dynamics 365 certification, which will better show your ability, among many competitors, you will be very prominent. Using MB-820 practice files is an important step for you to improve your soft power. I hope that you can spend a little time understanding what our MB-820 study materials have to attract customers compared to other products in the industry.
Microsoft Dynamics 365 Business Central Developer Sample Questions (Q48-Q53):NEW QUESTION # 48
A company is setting up a sandbox environment.
You observe the following issues in Visual Studio Code:
* When you open the User Settings window, no AL command is available
* In the Problems tab. the error 'The target page Customer List for the extension object is not found' is displayed.
You need to identify a solution for each issue.
Which solutions should you use? To answer, select the appropriate options in the answer area.
NEW QUESTION # 49
You are developing a codeunit for a company that uses Business Central.
The code unit must be run only during installation of an extension package.
You need to create the codeunit.
How should you complete the code' To answer, select the appropriate options in the answer area.
Subtype: Install
Trigger: OnInstallAppPerCompany
You are developing a codeunit that should only run during the installation of an extension package.
Options:
* Subtype: The correct subtype is Install, as it indicates that the codeunit runs only when the extension is being installed.
* Trigger: The correct trigger for running during installation is OnInstallAppPerCompany, which handles code execution when the app is installed for a specific company.
NEW QUESTION # 50
A company plans to customize its per tenant extension reports. The company has the following requirements for the customization:
* Child data items must not be displayed on the request page for some master detail reports.
* Selecting key filter fields takes users too much time. The customization must decrease the amount of time to select the fields.
You need to optimize the report request page.
Which actions should you configure? To answer, select the appropriate options in the answer area.
For the given requirements, you should configure the following actions:
* For child data items not to be displayed on the request page for some master-detail reports, set the DataItemLinkReference property to the parent data item.
* To decrease the amount of time to select key filter fields, specify the RequestFilterHeading property.
In Dynamics 365 Business Central, when customizing report request pages, certain properties can be set to control the behavior and display of the report options:
* Hiding Child Data Items:The DataItemLinkReference property is used to link a child data item to a parent data item in the data model of a report. Setting this property correctly will ensure that the child data items are related to the correct parent data item and will be displayed or hidden accordingly on the request page. If the goal is to prevent child data items from being displayed, you need to make sure they are correctly linked and configured to not appear.
* Optimizing Filter Field Selection:The RequestFilterHeading property is used to group filter fields on the request page. By specifying this property, you can create a more organized and user-friendly interface, which can significantly speed up the process of selecting filters. This property allows you to categorize filters into headings, making it quicker and easier for users to find and set the necessary filters for the report.
By adjusting these properties on the report request page as part of the per tenant extension customization, you will address the company's requirements to optimize the user experience when running reports.
NEW QUESTION # 51
After you answer a question in this section, you will NOT be able to return to it. As a result, these questions will not appear on the review screen.
A company creates a Business Central app and a table named MyTable to store records when sales orders are posted.
Users report the following issues:
* The users receive permission errors related lo MyTable.
* Users are no longer able to post sales orders since installing the new app.
* The users cannot access the list page created in MyTable.
You need to resolve the user issues without creating new permission sets. You must use the principle of least privilege.
Solution: In the MyTable object add the property InherentPermissions = Rl. Does the solution meet the goal?
The property InherentPermissions is used to automatically grant permissions to the table object it is applied to, but setting it to Rl (which seems to be a typo and should likely be 'RL' for Read and Insert permissions) is not sufficient in this scenario. The issues reported by the users suggest that they need more than just read and insert permissions on MyTable. Since users are unable to post sales orders, they likely need Modify, Delete, or Execute permissions on certain tables or objects related to the sales order process. Additionally, the inability to access the list page created in MyTable could be due to lacking Read permissions on other related objects or pages. Therefore, merely setting InherentPermissions = RL on MyTable does not comprehensively address the users' permission issues, especially when considering the principle of least privilege. A more tailored approach to permissions, potentially involving adjustments to the app's code or configuration to ensure proper permissions are applied where necessary, would be needed.
NEW QUESTION # 52
You need to implement the Issue Management module and expose the Postlssue method.
Which four actions should you perform in sequence? To answer, move the appropriate actions from the list of actions to the answer area and arrange them in the correct order.
NOTE: Note than one order of answer choices is correct. You will receive credit for any of the correct orders you select.
Topic 2, Alpine Ski House
Overview
Alpine Ski House is a company that owns and operates hotels, restaurants, and stores. Currently, the company uses the following software and interlace:
* Property management software (PMS) to manage hotel rooms
* On-premises accounting software to generate sales invoices and create purchase orders
* An API that allows restaurants and stores to obtain necessary information Restaurants and stores use standalone software for point of sale (POS) devices. Each day, the POS terminals generate a text file of sales data and save the files in a serval folder. An account assistant must manually import the files to the current software tables to be processed by the system.
The general manager receives several reports monthly from department managers. The reports take too much time to prepare.
The company is moving from a different system to Business Central online to manage the whole company.
The company plans to increase efficiency in every department by using APIs to obtain or share information between the different systems.
Each department involved in purchasing must be able to make purchase requests automatically and easily. The departments do not need access to the full ERP management system.
Alpine Ski House requires the development of several extensions for the planned improvements. Business Central design patterns must be used to develop all extensions.
Alpine Ski House must develop the following pages:
* Pages that provide multiple configurations in a multistep dialog, like a wizard, to provide required information when the extensions are first installed
* Department-specific Role Center pages to show relevant information and pages with additional information The IT department plans to use Power 61 to analyze departmental information. The database must be configured to provide optimal performance.
The housekeeping department requires the following to increase efficiency and help avoid data entry errors:
* A Housekeeping Role Center to minimize navigation to relevant areas In Business Central online and to show relevant information in it
* Pages to embed into a new Room page to show additional information about the Room entity
* A table named Room Incident for the housekeeping team to enter room issue information
* A Housekeeping canvas app that connects to an extension
The department requires the development of an extension with a new API page named RoomsAPI.
* The housekeeping team will use RoomsAPI to publish room details, update when work is complete, or provide repair notifications from the canvas app.
* This custom API page must expose a custom table named Rooms and have an ID 50000. The table must be able to update from the PMS. The PMS team must know the end to connect to the custom API.
* A developer provides the following details for the API page:
APIPublisher = 'alpine';
APIGroup - 'integration';
APIVersion - 'v2.6';
fntityName - 'room';
EntitySetName = 'rooms';
* The extension must be published in Business Central online and include a list page named Room List that includes all hotel rooms.
* Installation or updates to this extension must meet the following requirements:
o Some web services must be published automatically.
o The version of the specified application's metadata must be obtained in AL language.
o The code required to perform tasks cannot be accessible from other parts of the application.
The Room Incident table information must include the following fields:
* Incident entry: An incremental number
* Room No.: A room from the Room table
* Incident Date: The work date
o The table definition in the Room Incident table must autofill the Incident Date when the housekeeping team inserts a new record, o The value for Incident Date must be the work date configured in the Business Central online client.
* Status: Includes the following options lo identify the status of the incident:
o Open: When the Room Incident is created
o In Progress: When someone starts repair work
o Closed: When the incident is solved
* Incident Closing Date: Auto-updating field (when the status passes to Closed, the field will update with the work date)
* Incident Description: Text
* Image. Media data type
o The stored picture must be downloadable from a menu action.
o A Room Incident page must be developed to contain the download action.
To increase efficiency, the new system must manage the generated data from the restaurants and stores directly by using the API on the POS terminals.
* The company requires a code unit called from a job queue to read the information from the POS terminal APIs.
* The POS terminal information must be stored in a table named POS Information, have an ID 50100. and be editable on a page.
* The account manager requires an option on the menu of the page to run the process manually.
To analyze the information received from the POS terminals, the company requires:
* A custom API named ticketAPI to export the information to Power BI
* Use of the Read Scale-Out feature to improve database performance
The purchasing department requites a new entity in Business Central online to log non-conformities of goods received from vendors. The entity must be set up as follows:
* The non-conformity entity must have two tables:
o a header with common information
o one or more lines with the detailed received items that are non-conforming
* The entity requires a page named Non-conformity and a subpage named Non-Conformity Lines to store the information.
When a purchase order with incorrect quantity 01 quality issues is received, the entity must create a non-conformity document in the system. The following information must be nick the document:
* Non-conformity Number: must use the No. Series table from Business Central online to manage this field and use these features:
o Alphanumeric values
o Number format that includes "NO and the year as part of the number: for example, NC24-001
* Non-conformity Date: stores only the creation date
* Vendor No.: stores the number of the vendor that sent the items; only vendors from the company must be included
* Owner: code of an employee defined in the company
* Receipt No.: must meet the following conditions:
o Be an existing receipt No.
o Be received from the vendor indicated in the Vendor No. field
* Comments: can include comments with rich text and pictures to illustrate quality problems
* Status: includes nonconformity statuses, such as:
o Open
o Notified
o Closed
* Lines must contain the following details:
o Item No.: item received (for existing inventory items only)
o Description: item description
0 Quantity: non-conforming quantity
0 Non-conformity Type:
Quality
Quantity
Delivery date
The serial numbers of the non-conformities and the period in which they can be created must be in a configuration table and its corresponding page to allow them to be modified for the users.
NEW QUESTION # 53
To become more powerful and struggle for a new self, getting a professional MB-820 certification is the first step beyond all questions. We suggest you choose our MB-820 test prep ----an exam braindump leader in the field. Since we release the first set of the MB-820 quiz guide, we have won good response from our customers and until now---a decade later, our products have become more mature and win more recognition. And our MB-820 Exam Torrent will also be sold at a discount from time to time and many preferential activities are waiting for you.
MB-820 Study Demo: https://www.pdfdumps.com/MB-820-valid-exam.html
- Real MB-820 Exams 🕚 MB-820 Reliable Test Book 🙅 MB-820 Latest Exam Cost 💗 Enter ➽ [url]www.vceengine.com 🢪 and search for ▶ MB-820 ◀ to download for free 📻Relevant MB-820 Exam Dumps[/url]
- Simplest Format of Microsoft MB-820 Exam PDF Practice Materials 🤼 Simply search for { MB-820 } for free download on “ [url]www.pdfvce.com ” 🈺MB-820 Reliable Test Book[/url]
- Real MB-820 Exams 🧴 Valid MB-820 Exam Dumps 🐪 MB-820 Technical Training 🕜 Open ✔ [url]www.troytecdumps.com ️✔️ and search for ➡ MB-820 ️⬅️ to download exam materials for free 🧦Test MB-820 Dumps.zip[/url]
- Prep MB-820 Guide 🤕 MB-820 Free Test Questions 🖊 MB-820 Technical Training 🐦 Open website ▶ [url]www.pdfvce.com ◀ and search for ✔ MB-820 ️✔️ for free download 🥿New MB-820 Braindumps Free[/url]
- High-quality MB-820 – 100% Free Test Topics Pdf | MB-820 Study Demo 🗯 Search for [ MB-820 ] and download it for free immediately on ⇛ [url]www.prepawaypdf.com ⇚ 🙄
rep MB-820 Guide[/url] - New MB-820 Braindumps Free 👯 MB-820 Exam Actual Questions 🚾 Relevant MB-820 Exam Dumps 🤾 Open ☀ [url]www.pdfvce.com ️☀️ enter ⇛ MB-820 ⇚ and obtain a free download 🎒Real MB-820 Exams[/url]
- MB-820 Valid Exam Experience 🥁 MB-820 Certification Sample Questions 🍣 MB-820 Latest Exam Cost 🦝 Enter ▶ [url]www.pdfdumps.com ◀ and search for { MB-820 } to download for free 🔟MB-820 Reliable Test Book[/url]
- MB-820 Exam Test Topics Pdf- First-grade MB-820 Study Demo Pass Success ♻ The page for free download of ✔ MB-820 ️✔️ on 「 [url]www.pdfvce.com 」 will open immediately ⌛MB-820 Certification Sample Questions[/url]
- MB-820 Certification Sample Questions 🧑 Test MB-820 Dumps.zip 😱 Exam MB-820 Prep 🔷 Go to website ➤ [url]www.examdiscuss.com ⮘ open and search for “ MB-820 ” to download for free 😲MB-820 Exam Actual Questions[/url]
- MB-820 Reliable Test Book 🏐 Real MB-820 Exams 🏨 Useful MB-820 Dumps 🔄 Search for “ MB-820 ” on ⮆ [url]www.pdfvce.com ⮄ immediately to obtain a free download 🛥Test MB-820 Dumps.zip[/url]
- Microsoft MB-820 Exam is Easy with Our Verified MB-820 Test Topics Pdf: Microsoft Dynamics 365 Business Central Developer 🛷 Easily obtain free download of { MB-820 } by searching on ➤ [url]www.prepawayete.com ⮘ 🐋MB-820 Valid Exam Experience[/url]
- wjhsd.instructure.com, bbs.t-firefly.com, cocoasr18.blogspot.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, kemono.im, bbs.t-firefly.com, eduhubx.com, learn.csisafety.com.au, freestyler.ws, Disposable vapes
P.S. Free & New MB-820 dumps are available on Google Drive shared by PDFDumps: https://drive.google.com/open?id=1kJzduVJ7Xwbzob_uedzGOBHoRYh7tODk
