Plat-UX-101 Test Practice - Plat-UX-101 Relevant Answers
Posted at 2/20/2026 10:30:44
PDF4Test is engaged in studying valid exam simulation files with high passing rate many years. If you want to find valid Salesforce Plat-UX-101 exam simulations, our products are helpful for you. Our Salesforce Plat-UX-101 Exam Simulations will assist you clear exams and apply for international companies or better jobs with better benefits in the near future.
Because many users are first taking part in the exams, so for the exam and test time distribution of the above lack certain experience, and thus prone to the confusion in the examination place, time to grasp, eventually led to not finish the exam totally. In order to avoid the occurrence of this phenomenon, the Salesforce Certified Platform User Experience Designer study question have corresponding products to each exam simulation test environment, users log on to their account on the platform, at the same time to choose what they want to attend the exam simulation questions, the Plat-UX-101 Exam Questions are automatically for the user presents the same as the actual test environment simulation test system, the software built-in timer function can help users better control over time, so as to achieve the systematic, keep up, as well as to improve the user's speed to solve the problem from the side with our Plat-UX-101 test guide.
Hot Plat-UX-101 Test Practice - How to Prepare for Salesforce Plat-UX-101 ExamYou can first download PDF4Test's free exercises and answers about Salesforce certification Plat-UX-101 exam as a try, then you will feel that PDF4Test give you a reassurance for passing the exam. If you choose PDF4Test to provide you with the pertinence training, you can easily pass the Salesforce Certification Plat-UX-101 Exam.
Salesforce Certified Platform User Experience Designer Sample Questions (Q66-Q71):NEW QUESTION # 66
Universal Containers (UC) operates worldwide with offices in more than 100 regions in 10 different countries role hierarchy to control data visibility. In the new fiscal year, UC is planned to reorganize the roles and reassign accounts owners. Which two points should an architect consider in this situation?
Which two point should an Architect consider in this situation?
Choose 2 answers
- A. Replacing Account records ownerships massively can cause data skew.
- B. Restricting the organization-sharing configurations to private.
- C. Using a temporary parking lot account to improve performance.
- D. Changing complex role hierarchy can cause a high level of sharing recalculation.
Answer: A,D
Changing the role hierarchy and reassigning account owners can have a significant impact on the data visibility and performance of Salesforce. An architect should consider the following points in this situation:
Changing complex role hierarchy can cause a high level of sharing recalculation.Depending on the sharing settings, roles can control the level of visibility that users have into the Salesforce data. Users at any given role level can view, edit, and report on all data owned by or shared with users below them in the role hierarchy, unless the sharing model for an object specifies otherwise. When the role hierarchy is changed, Salesforce must recalculate the sharing rules and group membership for all the affected users and records, which can take a long time and consume a lot of system resources.Therefore, changing a complex role hierarchy should be done carefully and preferably during off-peak hours1.
Replacing account records ownerships massively can cause data skew.Data skew occurs when more than 10,000 child records are related to the same parent record, or more than 10,000 records of any object are owned by a single user. This can cause performance issues, such as locking, timeouts, and failures, when updating or sharing those records. When account owners are reassigned massively, it can create or worsen data skew, especially if the accounts have many child records, such as contacts and opportunities.Therefore, replacing account records ownerships massively should be avoided or minimized23.
1: [Design Your Data Model Unit | Salesforce Trailhead]
2: [Data Skew in Salesforce - Why it Matters | Salesforce Ben]
3: [Ownership Data Skew | Designing Record Access for Enterprise Scale | Salesforce Developers]
NEW QUESTION # 67
A UX Designer is creating a custom To-Do List component to replace the standard Salesforce one.Their developer is using a parent-child Lightning Web Component (LWC) structure to build the component, creating a parent component for the list and a single repeated child component for each To-Do Item within the list.
Which two impacts of the LWC's Shadow DOM should be considered when designing or developing the stylesheets for these components?
Choose 2 answers
- A. Any needed Saleforce Lightning Design System (SLDS) classes and styles must be imported into both the parent list and child items.
- B. The CSS style defined in the parent list component are inherited by the child items
- C. Any custom shared between the list and child items should be imported from a shared CSS file.
- D. The CSS styles defined in the parent list component are not shared with the child items.
Shadow DOM is a web standard that encapsulates the internal document object model (DOM) structure of a web component. It isolates the component's markup and styles from the rest of the page, and prevents the component from being affected by or affecting the global DOM. When designing or developing the stylesheets for a parent-child LWC structure, the following impacts of the shadow DOM should be considered:
The CSS styles defined in the parent list component are not shared with the child items.This is because the shadow DOM creates a boundary between the parent and the child components, and the styles defined in the parent component do not cascade down to the child components. This means that each component needs to define its own styles, or import them from a common source.This also means that the parent component cannot directly style the child components, or vice versa12.
Any custom styles shared between the list and child items should be imported from a shared CSS file.This is a recommended practice to avoid duplicating the same styles in multiple components, and to maintain consistency and reusability. A shared CSS file can be created as a static resource, and imported into the components using theloadStyle()method from theplatformResourceLoadermodule.Alternatively, a shared CSS file can be created as a LWC component, and imported into the components using the@importdirective134.
1: [Shadow DOM | Lightning Web Components Developer Guide | Salesforce Developers]
2: [Light DOM | Lightning Web Components Developer Guide | Salesforce Developers]
3: [Understanding Shadow DOM and Template in LWC - SFDC Lightning]
4: [Shadow DOM, CSS and Styling Hooks in LWC what you need to know]
5: [How to Share CSS Between Lightning Web Components | Salesforce Developers Blog]
6: [How to Use a Shared CSS File in a Lightning Web Component | Salesforce Developers Blog]
NEW QUESTION # 68
A UX Designer atCloud Kicks is having difficulty getting its developers to see why the design changes would improve the user experience.
How should the designer help mitigate pushback from developers?
- A. Ask a manager or superior to doit.
- B. Hand them a printout of the design
- C. Invite them to user testing.
- D. Let them know the designer is the expert.
Inviting developers to user testing is a good way to help them see the value of the design changes and understand the user needs and pain points. User testing is a method of evaluating a product or service by observing how real users interact with it and collecting feedback. By witnessing the user testing sessions, developers can see how the design changes improve the user experience, such as increasing usability, satisfaction, engagement, or conversion. User testing can also help developers empathize with the users and collaborate better with the designer.Reference:
[User Testing]
NEW QUESTION # 69
A UX Designer is creating an experience to help organize content into collapsible sections.
Which Lightning component should be used?
- A. Highlights Panel
- B. Lightning Toggle
- C. Accordion
- D. Einstein Next Best Action
The Lightning component that should be used to organize content into collapsible sections is theAccordioncomponent. The Accordion component displays vertically stacked sections of content that can be expanded and collapsed by clicking on the section headers. Users can control how much content is visible at once, and don't need to scroll as much to see the content of a page. The Accordion component can also be configured to allow multiple sections to be open at the same time. The Accordion component implements the accordion blueprint in the Salesforce Lightning Design System (SLDS).Reference:
:lightning-accordion - documentation - Salesforce Lightning Component Library
:Collapsible Related List in Lightning Experience
:How To Create Expand/Collapse Sections In SFDC Lightning Component
The Lightning Accordion component isdesigned to help create an organized, collapsible display of content. It is composed of a header and a body, which can be used to display different sections of content in an organized way. The body of the Accordion is hidden until the header is clicked, allowing the user to quickly and easily access the content they need. Salesforce provides a detailed guide to using the Accordion component, including examples and code snippets, which can be found here:https://developer.salesforce.com ... /lwc.use_accordion.
NEW QUESTION # 70
Cloud Kicks wants to improve its Salesforce org to provide tailored functionality that enables sales representatives to provide quick, competitive pricing and close deals faster.
What is the benefit of Lightning Console Apps in this scenario for the sales representatives?
- A. They can complete actions with a single click.
- B. They can organize items in the utility bar.
- C. They can add records to Favorites.
Lightning console apps are designed to help users work faster and more efficiently by providing a workspace where they can access multiple records and their related records on the same screen. Users can complete actions with a single click, such as creating records, logging calls, sending emails, and updating fields, without losing context or switching tabs. Lightning console apps also support keyboard shortcuts, macros, and quick text to speed up common tasks. Lightning console apps are especially useful for sales representatives who need to provide quick, competitive pricing and close deals faster. They can also use Lightning console apps to view and manage their pipeline, collaborate with team members, and track their performance. Organizing items in the utility bar and adding records to Favorites are features that are available in any Lightning app, not just Lightning console apps.Salesforce Console in Lightning Experience,Create and Edit a Custom Lightning Console App,Create a Lightning Console App
NEW QUESTION # 71
Salesforce Plat-UX-101 is a certification exam to test IT expertise and skills. If you find a job in the IT industry, many human resource managers in the interview will reference what Salesforce related certification you have. If you have Salesforce Plat-UX-101 Certification, apparently, it can improve your competitiveness.
Plat-UX-101 Relevant Answers: https://www.pdf4test.com/Plat-UX-101-dump-torrent.html
To address the problems of Plat-UX-101 exam candidates who are busy, PDF4Test has made the Plat-UX-101 dumps PDF format of real Salesforce Certified Platform User Experience Designer (Plat-UX-101) exam questions, Salesforce Plat-UX-101 Test Practice So even if you are a newcomer, you don't need to worry that you can’t understand the contents, Salesforce Plat-UX-101 Test Practice We support you excellent and reliable after-sale service for you, Now our Plat-UX-101 actual test guide can make you the whole relax down, with all the troubles left behind.
See What Your Clipboard Has to Offer, tech employment is expected to keep Plat-UX-101 growing, with the highest job growth found among software and web developers, followed by cybersecurity analysts and IT support specialists.
PDF4Test: Your Solution to Ace the Salesforce Plat-UX-101 ExamTo address the problems of Plat-UX-101 Exam candidates who are busy, PDF4Test has made the Plat-UX-101 dumps PDF format of real Salesforce Certified Platform User Experience Designer (Plat-UX-101) exam questions.
So even if you are a newcomer, you don't need to worry Plat-UX-101 Best Practice that you can’t understand the contents, We support you excellent and reliable after-sale service for you.
Now our Plat-UX-101 actual test guide can make you the whole relax down, with all the troubles left behind, What is more, we offer customer services 24/7.
- Plat-UX-101 Valid Exam Duration 💎 Plat-UX-101 Pass Test 🎉 Practice Plat-UX-101 Test Online 💾 Copy URL ➤ [url]www.torrentvce.com ⮘ open and search for ⇛ Plat-UX-101 ⇚ to download for free 🦍New Plat-UX-101 Test Papers[/url]
- Pass Guaranteed Salesforce - Authoritative Plat-UX-101 - Salesforce Certified Platform User Experience Designer Test Practice 🌘 Enter ⏩ [url]www.pdfvce.com ⏪ and search for ✔ Plat-UX-101 ️✔️ to download for free ▶
lat-UX-101 Hottest Certification[/url] - Plat-UX-101 Reliable Test Simulator 🏘 Plat-UX-101 Hottest Certification 💋 PDF Plat-UX-101 VCE 🪁 Search for ⇛ Plat-UX-101 ⇚ and download exam materials for free through “ [url]www.exam4labs.com ” 🧁
lat-UX-101 Popular Exams[/url] - Plat-UX-101 – 100% Free Test Practice | Valid Salesforce Certified Platform User Experience Designer Relevant Answers 😃 { [url]www.pdfvce.com } is best website to obtain ➥ Plat-UX-101 🡄 for free download 🚣
DF Plat-UX-101 VCE[/url] - Practice Plat-UX-101 Test Online 🦮 Plat-UX-101 Guide Torrent 🐬 Plat-UX-101 Reliable Test Simulator 🥿 Simply search for 「 Plat-UX-101 」 for free download on ( [url]www.practicevce.com ) 💯
lat-UX-101 Reliable Cram Materials[/url] - Pass Guaranteed Salesforce - Authoritative Plat-UX-101 - Salesforce Certified Platform User Experience Designer Test Practice 🧮 Open ▶ [url]www.pdfvce.com ◀ and search for [ Plat-UX-101 ] to download exam materials for free 👡
lat-UX-101 Hottest Certification[/url] - Exam Plat-UX-101 Labs 💋 Plat-UX-101 Popular Exams 📣 Plat-UX-101 Hottest Certification 🕰 Search for ➽ Plat-UX-101 🢪 and download exam materials for free through ➤ [url]www.prepawayexam.com ⮘ 👾
lat-UX-101 Popular Exams[/url] - [url=https://cndprinting.com/?s=Useful%20Salesforce%20-%20Plat-UX-101%20-%20Salesforce%20Certified%20Platform%20User%20Experience%20Designer%20Test%20Practice%20%f0%9f%8d%99%20Easily%20obtain%20{%20Plat-UX-101%20}%20for%20free%20download%20through%20[%20www.pdfvce.com%20]%20%f0%9f%92%aePDF%20Plat-UX-101%20VCE]Useful Salesforce - Plat-UX-101 - Salesforce Certified Platform User Experience Designer Test Practice 🍙 Easily obtain { Plat-UX-101 } for free download through [ www.pdfvce.com ] 💮
DF Plat-UX-101 VCE[/url] - Salesforce Plat-UX-101 Practice Exam Software For Windows Users 👪 Enter “ [url]www.easy4engine.com ” and search for ▶ Plat-UX-101 ◀ to download for free ‼
lat-UX-101 Popular Exams[/url] - Plat-UX-101 Hottest Certification 🥴 Plat-UX-101 Hottest Certification 🚓 PDF Plat-UX-101 VCE 🥫 Easily obtain free download of 【 Plat-UX-101 】 by searching on ⮆ [url]www.pdfvce.com ⮄ 🦮Dump Plat-UX-101 Collection[/url]
- Salesforce Plat-UX-101 Dumps PDF And Practice Test Software 🤒 Search for ➽ Plat-UX-101 🢪 and easily obtain a free download on 《 [url]www.dumpsmaterials.com 》 😺
lat-UX-101 Popular Exams[/url] - www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.hemantra.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, iatdacademy.com, Disposable vapes
