New Topic
[Hardware] Problems with new iHC-3308GW
31
【Hardware】 Problems with new iHC-3308GW
Posted at 2/23/2022 23:17:12      View:5169 | Replies:12        Print      Only Author   [Copy Link] 1#
Hello. I have got new device. I set up my PC as DHCP client. Directly connected to the device's port LAN2. PC does not get IP address. Documentation says "press recovery button", but there's no button named recovery on the body, and this does not show this button. I guess it is the one marked arrow up. I press it, nothing happens. Ok, this one having "recovery" word on the picture. I am not Chinese thus only guess two Chinese characters mean "button". On some other page (can not find it any more!) I have seen to press recovery button and turn on device holding the button - for factory reset, and red LED will not turn on. This does not work - LED turns on as I do not hold the button, and nothing changes.
Is my device faulty?
Is it possible to get specialist support for this device?
P.S. I get "错误:请点击滑块验证按钮,验证通过后再提交!" lucky it is copyable to clipboard, but there's no slider on the screen!
Posted at 2/24/2022 16:59:43        Only Author  2#
Hello, what is your firmware used in iHC3308GW?Ubuntu18  or Buildroot?
Posted at 2/24/2022 17:53:28        Only Author  3#
Factory default is buildroot system. Did you upgrade it to OpenWRT system?
This is where recovery button is :
Posted at 2/24/2022 19:09:24        Only Author  4#
I unboxed the device and unable to connect to it. Unable to find what and how should I proceed.
As a result I need OpenWrt in the box, but as I can not connect to the device, result is not achievable.
The picture you shared shows headphone input, not recovery button.
Posted at 2/25/2022 09:32:38        Only Author  5#
哦,对不起,我的错误。
Posted at 2/28/2022 21:56:47        Only Author  6#
I still unable to make this device working. Connected through serial port, but do not see the serial port setting for 1500000 baud. Nothing in the terminal at any speeds. Adapter does not show connect signal.
How to reach support for this device?
Posted at 3/2/2022 10:31:47        Only Author  7#
Posted at 3/2/2022 17:33:14        Only Author  8#
This new device I have is a brick. Does not respond to the serial port or LAN.
It was confirmed it does not have any image (even U-boot).
Posted at 3/5/2022 17:48:56        Only Author  9#
It is not possible for that!
Try this https://wiki.t-firefly.com/en/Core-3308Y/maskrom_mode.html , if you device actually be a brick.
Is the power light off?
Posted at 1/13/2026 21:08:15        Only Author  10#
That piece of writing really expanded my mind. The Reliable C_S4PM2_2507 exam camp questions exam is approaching. Hope I ace it!
Return to List
12
