Analytics-DA-201 Test Guide - Analytics-DA-201 Actual Exam & Analytics-DA-20
Posted at 1/10/2026 02:09:35
P.S. Free 2026 Salesforce Analytics-DA-201 dumps are available on Google Drive shared by ExamsTorrent: https://drive.google.com/open?id=1n3M0SVvjvz7dXu_qSxHdn9qiUhLkW1Ou
Our company’s top Analytics-DA-201 exam braindumps are meant to deliver you the best knowledge on this subject. If you study with our Analytics-DA-201 study guide, you will find that not only you can get the most professional and specialized skills to solve the problems in you dialy work, but also you can pass the exam without difficulty and achieve the certification. What is more, the prices of our Analytics-DA-201 training engine are quite favorable.
Everyone wants to have a good job and decent income. But if they don’t have excellent abilities and good major knowledge they are hard to find a decent job. Passing the test Analytics-DA-201 certification can make you realize your dream and find a satisfied job. Our Analytics-DA-201 study materials are a good tool that can help you pass the Analytics-DA-201 Exam easily. You needn't spend too much time to learn it. Our Analytics-DA-201 exam guide is of high quality and if you use our product the possibility for you to pass the Analytics-DA-201 exam is very high as 99% to 100%.
Analytics-DA-201 Practice Online | Analytics-DA-201 Valid Exam AnswersAnother outstanding quality is that you can print out the Salesforce Analytics-DA-201 questions. The hard copy will enable you to prepare for the Salesforce Analytics-DA-201 exam questions comfortably. ExamsTorrent adds another favor to its users by ensuring them a money-back deal. The unparalleled authority of the ExamsTorrent lies in its mission to provide its users with the updated material of the actual Salesforce Analytics-DA-201 Certification Exam.
Salesforce Analytics-DA-201 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - ABAP SQL and Code Pushdown: This section of the exam measures the competencies of the SAP ABAP Cloud Developer related to performance optimization through ABAP SQL and code pushdown techniques. It ensures that the developer understands how to shift logic to the database layer using efficient SQL scripting to enhance performance in data-intensive applications.
| | Topic 2 | - Object-Oriented Design: This section of the exam evaluates the SAP ABAP Cloud Developer's understanding of object-oriented principles in the ABAP context. It focuses on class-based programming, inheritance, interfaces, and polymorphism, all crucial for building modular and maintainable ABAP cloud applications.
| | Topic 3 | - SAP Clean Core Extensibility and ABAP Cloud: This part of the exam targets the SAP S
- 4HANA Technical Consultant and covers concepts of clean core extensibility using ABAP in the cloud. The focus is on in-app and side-by-side extensibility techniques, ensuring that custom code complies with cloud-readiness principles and does not compromise the upgrade stability of core systems.
Salesforce Certified Tableau Data Analyst Sample Questions (Q98-Q103):NEW QUESTION # 98
A Data Analyst has the following sets in a Tableau workbook:
* Top N Customers
* Customers of 2024
* Top N Products
* Sellers of 2024
Which two sets can the analyst combine? (Choose two.)
- A. Top N Products
- B. Customers of 2024
- C. Top N Customers
- D. Sellers of 2024
NEW QUESTION # 99
Open the link to Book1 found on the desktop. Open Disciplines worksheet.
Filter the table to show the Top 10 NOC based on the number of medals won.
check the steps below in explanation.
To filter the table to show the Top 10 NOC based on the number of medals won, you need to do the following steps:
* Open the link to Book1 found on the desktop. This will open the Tableau workbook that contains the Disciplines worksheet.
* Click on the Disciplines tab at the bottom of the workbook to open the worksheet. You will see a table that shows the NOC, discipline, and medals for each country.
* Drag Medals from the Measures pane to the Filters shelf. This will open a dialog box that allows you to filter by different criteria.
* Select Top from the dialog box. This will show you options to filter by the top or bottom values of a field.
* Enter 10 in the text box next to By field. This will filter by the top 10 values of Medals.
* Select NOC from the drop-down list next to By field. This will filter by the top 10 values of NOC based on Medals.
* Click OK to apply the filter. You will see that the table now shows only 10 rows, one for each NOC with the highest number of medals.
References: https://help.tableau.com/current/pro/desktop/en-us/filtering.htm https://help.tableau.com/current
/pro/desktop/en-us/filtering_topn.htm
NEW QUESTION # 100
You create the following story that contains two story point.
You want to change the story point format to show the current story point number out of the total number of story points.
Which Layout option should you use?
- A. Caption boxes
- B. Dots
- C. Numbers
- D. Arrows only
To change the story point format to show the current story point number out of the total number of story points, you should use the Numbers option in the Layout tab. This option will display the story points as numbers in a horizontal or vertical sequence, such as 1/2, 2/2. You can also choose to show or hide the next and previous arrows for navigation. The Numbers option will help you indicate the progress and order of your story points more clearly than the other options. References:
* Creating a Story - Tableau
* New in 9.0: Formatting the Story Points Navigator - Tableau
* Tableau Certified Data Analyst Study Guide
NEW QUESTION # 101
You have the following dashboard.
Currently the map is used as a filter that affects the data on the otter sheets of the dashboard You need to configure the dashboard to ensure that selecting a data point on the map only tillers the Detail table What should you do?
- A. From the context menu of Sales over time select Deselect
- B. From the context menu of Sales over time select Ignore Actions
- C. From the context menu of Sales over lime select Remove Dashboard Item
- D. From the context menu of Profits by Stale deselect Use as Filter
To configure the dashboard to ensure that selecting a data point on the map only filters the Detail table, you should select Ignore Actions from the context menu of Sales over time. Ignore Actions is a feature that allows you to exclude a sheet from being affected by any actions on the dashboard, such as filters or highlights. You can select Ignore Actions by right-clicking on a sheet on the dashboard and selecting Ignore Actions from the menu.
In this case, you want to exclude Sales over time from being filtered by the map, so you should select Ignore Actions from its context menu. This will make Sales over time ignore any selections on the map and show all values. The Detail table will still be filtered by the map as usual.
The other options are not correct for this scenario. Removing Dashboard Item will delete Sales over time from the dashboard, which is not what you want. Deselecting Use as Filter will disable the map as a filter for any sheet on the dashboard, which is not what you want. Selecting Deselect will clear any selections on the map, but it will not prevent Sales over time from being filtered by future selections. References: https://help.tableau.
com/current/pro/desktop/en-us/actions.htm https://help.tableau.com/current ... -us/actions_ignore.
htm
On a Tableau dashboard, when a map is used as a filter, it affects all other sheets in the dashboard by default.
To restrict the filter action to only affect the Detail table and not the 'Sales over time' chart, you would modify the action settings. By selecting "Ignore Actions" from the context menu of the 'Sales over time' chart, it will no longer respond to the filtering action initiated by selecting data points on the map.
NEW QUESTION # 102
A Data Analyst has the following chart.
The analyst needs to enable the drilldown from Category to Subcategory as shown in the following chart.
What should the analyst create?
- A. A hierarchy of Category and Subcategory
- B. A group of Category and Subcategory
- C. A bin for Category and a bin for Subcategory
- D. A combined set for Category and Subcategory
NEW QUESTION # 103
Before buying the Salesforce Certified Tableau Data Analyst (Analytics-DA-201) exam questions, ExamsTorrent also offers a Salesforce Analytics-DA-201 exam questions demo of the Salesforce Certified Tableau Data Analyst (Analytics-DA-201) exam. You can test out the Salesforce Analytics-DA-201 pdf questions product with this Analytics-DA-201 questions demo before purchasing the full package. The Salesforce Analytics-DA-201 PDF Questions demo provides an overview of the Salesforce Certified Tableau Data Analyst (Analytics-DA-201) exam study product and how it can assist you in passing the Salesforce Certified Tableau Data Analyst (Analytics-DA-201) exam.
Analytics-DA-201 Practice Online: https://www.examstorrent.com/Analytics-DA-201-exam-dumps-torrent.html
- Reliable Analytics-DA-201 Braindumps Ebook 🥴 Passing Analytics-DA-201 Score Feedback 😵 Analytics-DA-201 Test King 🔉 Download ▷ Analytics-DA-201 ◁ for free by simply searching on ✔ [url]www.torrentvce.com ️✔️ ♻
assing Analytics-DA-201 Score Feedback[/url] - Latest Salesforce Analytics-DA-201 Dumps PDF - Quick And Proven Way To Pass Exam 🌕 Download ⏩ Analytics-DA-201 ⏪ for free by simply entering “ [url]www.pdfvce.com ” website 🐪Analytics-DA-201 Pass4sure[/url]
- Analytics-DA-201 Visual Cert Test 🛐 Analytics-DA-201 Dumps Questions 💽 Valid Analytics-DA-201 Mock Test 💟 Simply search for ( Analytics-DA-201 ) for free download on ⇛ [url]www.pdfdumps.com ⇚ 😵
DF Analytics-DA-201 Cram Exam[/url] - Analytics-DA-201 Test King 📨 Analytics-DA-201 Visual Cert Test ❣ New Analytics-DA-201 Test Braindumps 🥔 Search for [ Analytics-DA-201 ] on ➽ [url]www.pdfvce.com 🢪 immediately to obtain a free download 💑Analytics-DA-201 Vce Exam[/url]
- Analytics-DA-201 Reliable Exam Camp 💂 Valid Analytics-DA-201 Mock Test 🦐 Latest Analytics-DA-201 Exam Simulator 🌉 ➠ [url]www.prep4sures.top 🠰 is best website to obtain ⮆ Analytics-DA-201 ⮄ for free download 🧴Valid Analytics-DA-201 Mock Test[/url]
- Latest Salesforce Analytics-DA-201 Dumps PDF - Quick And Proven Way To Pass Exam ⛽ The page for free download of “ Analytics-DA-201 ” on ➥ [url]www.pdfvce.com 🡄 will open immediately 📥Reliable Analytics-DA-201 Test Simulator[/url]
- Analytics-DA-201 latest exam vce - Analytics-DA-201 test dumps - Analytics-DA-201 pdf torrent ↙ Simply search for ▛ Analytics-DA-201 ▟ for free download on { [url]www.prepawayete.com } 📽Analytics-DA-201 Reliable Dumps Free[/url]
- Reliable Analytics-DA-201 Braindumps Ebook 😕 PDF Analytics-DA-201 Cram Exam ⛹ Analytics-DA-201 Reliable Exam Camp 📬 Search for ⮆ Analytics-DA-201 ⮄ and easily obtain a free download on ➽ [url]www.pdfvce.com 🢪 🆘Trustworthy Analytics-DA-201 Source[/url]
- Analytics-DA-201 latest exam vce - Analytics-DA-201 test dumps - Analytics-DA-201 pdf torrent 🕞 Search for 「 Analytics-DA-201 」 and obtain a free download on ☀ [url]www.pass4test.com ️☀️ 🐍Valid Analytics-DA-201 Mock Test[/url]
- Latest Salesforce Analytics-DA-201 Dumps PDF - Quick And Proven Way To Pass Exam 🕥 The page for free download of ▛ Analytics-DA-201 ▟ on ⏩ [url]www.pdfvce.com ⏪ will open immediately 🐯Analytics-DA-201 Dumps Questions[/url]
- Analytics-DA-201 Vce Exam 🕋 Passing Analytics-DA-201 Score Feedback 🆚 Analytics-DA-201 Reliable Exam Camp 💻 Search for ➡ Analytics-DA-201 ️⬅️ and download it for free immediately on ⏩ [url]www.exam4labs.com ⏪ 📈Valid Analytics-DA-201 Exam Prep[/url]
- myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, connect.garmin.com, hashnode.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, bbs.28pk.com, bbs.hnlot.com.cn, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, lb.abcbbk.com, www.skudci.com, afrifin.co.za, Disposable vapes
DOWNLOAD the newest ExamsTorrent Analytics-DA-201 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1n3M0SVvjvz7dXu_qSxHdn9qiUhLkW1Ou
