[General] Certified Ethical Hacker Exam Exam Practice Dump Provide Best 312-50v12 Study Qu
90
General Certified Ethical Hacker Exam Exam Practice Dump Provide Best 312-50v12 Study Qu
Posted at 2/11/2026 01:02:21      View173 | Replies1        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of Pass4sures 312-50v12 dumps from Cloud Storage: https://drive.google.com/open?id=1iwoX3KQMUJbXLJXnz7eMDGHBb7kLGlO9
Pass4sures provides a high-quality ECCouncil 312-50v12 practice exam. The best feature of the ECCouncil 312-50v12 exam dumps is that they are available in PDF and a web-based test format. ECCouncil offer updated ECCouncil 312-50v12 Exam products to our valuable customers. Real ECCouncil 312-50v12 exam questions along with answers are being provided in two formats.
The 312-50v12 exam is designed for professionals who work in or want to transition into the cybersecurity field, such as security officers, auditors, network administrators, and ethical hackers. 312-50v12 Exam consists of 125 multiple-choice questions that must be completed within four hours. The passing score is 70% or higher, and the exam fee is $1,199.
Well-Prepared 312-50v12 Exams Torrent & Leading Offer in Qualification Exams & Updated ECCouncil Certified Ethical Hacker ExamMany candidates know our exam bootcamp materials are valid and enough to help them clear ECCouncil 312-50v12 exams. But they are afraid that purchasing on internet is not safe, money unsafe and information unsafe. In fact you may worry too much. Online sale is very common. Every year there are thousands of candidates choose our 312-50v12 Exam Bootcamp materials and pass exam surely. Money is certainly safe. PayPal will guarantee your money and your benefits safe. We have strict information secret system to guarantee that your information is safe too.
ECCouncil Certified Ethical Hacker Exam Sample Questions (Q299-Q304):NEW QUESTION # 299
While performing an Nmap scan against a host, Paola determines the existence of a firewall. In an attempt to determine whether the firewall is stateful or stateless, which of the following options would be best to use?
  • A. -sT
  • B. -sA
  • C. -sX
  • D. -sF
-sA (TCP ACK scan)
This scan is different than the others discussed so far in that it never determines open (or even open|filtered) ports. It is used to map out firewall rulesets, determining whether they are stateful or not and which ports are filtered.
The ACK scan probe packet has only the ACK flag set (unless you use --scanflags). When scanning unfiltered systems, open and closed ports will both return a RST packet. Nmap then labels them as unfiltered, meaning that they are reachable by the ACK packet, but whether they are open or closed is undetermined. Ports that don't respond, or send certain ICMP error messages back (type 3, code 0, 1, 2, 3, 9, 10, or 13), are labeled filtered.
https://nmap.org/book/man-port-scanning-techniques.html
NEW QUESTION # 300
Attacker Rony installed a rogue access point within an organization's perimeter and attempted to intrude into its internal network. Johnson, a security auditor, identified some unusual traffic in the internal network that is aimed at cracking the authentication mechanism. He immediately turned off the targeted network and tested for any weak and outdated security mechanisms that are open to attack. What is the type of vulnerability assessment performed by johnson in the above scenario?
  • A. Application assessment
  • B. Host-based assessment
  • C. Wireless network assessment
  • D. Distributed assessment
Wireless network assessment determines the vulnerabilities in an organization's wireless networks. In the past, wireless networks used weak and defective data encryption mechanisms. Now, wireless network standards have evolved, but many networks still use weak and outdated security mechanisms and are open to attack. Wireless network assessments try to attack wireless authentication mechanisms and gain unauthorized access. This type of assessment tests wireless networks and identifies rogue networks that may exist within an organization's perimeter. These assessments audit client-specified sites with a wireless network. They sniff wireless network traffic and try to crack encryption keys. Auditors test other network access if they gain access to the wireless network.
NEW QUESTION # 301
What does the -oX flag do in an Nmap scan?
  • A. Perform an eXpress scan
  • B. Output the results in truncated format to the screen
  • C. Perform an Xmas scan
  • D. Output the results in XML format to a file
https://nmap.org/book/man-output.html
-oX <filespec> - Requests that XML output be directed to the given filename.
NEW QUESTION # 302
Ethical hacker jane Smith is attempting to perform an SQL injection attach. She wants to test the response time of a true or false response and wants to use a second command to determine whether the database will return true or false results for user IDs. which two SQL Injection types would give her the results she is looking for?
  • A. Time-based and union-based
  • B. Time-based and boolean-based
  • C. Out of band and boolean-based
  • D. union-based and error-based
"Boolean based" we mean that it is based on Boolean values, that is, true or false / true and false. AND Time-based SQL Injection is an inferential SQL Injection technique that relies on sending an SQL query to the database which forces the database to wait for a specified amount of time (in seconds) before responding. The response time will indicate to the attacker whether the result of the query is TRUE or FALSE.
Boolean-based (content-based) Blind SQLi
Boolean-based SQL Injection is an inferential SQL Injection technique that relies on sending an SQL query to the database which forces the application to return a different result depending on whether the query returns a TRUE or FALSE result.
Depending on the result, the content within the HTTP response will change, or remain the same. This allows an attacker to infer if the payload used returned true or false, even though no data from the database is returned. This attack is typically slow (especially on large databases) since an attacker would need to enumerate a database, character by character.
Time-based Blind SQLi
Depending on the result, an HTTP response will be returned with a delay, or returned immediately. This allows an attacker to infer if the payload used returned true or false, even though no data from the database is returned. This attack is typically slow (especially on large databases) since an attacker would need to enumerate a database character by character.
https://www.acunetix.com/websitesecurity/sql-injection2/
NEW QUESTION # 303
Which of the following tools are used for enumeration? (Choose three.)
  • A. SolarWinds
  • B. DumpSec
  • C. SID2USER
  • D. Cheops
  • E. USER2SID
Answer: B,C,E
NEW QUESTION # 304
One of the best features of Pass4sures exam questions is free updates for up to 1 year. The Pass4sures has hired a team of experienced and qualified 312-50v12 exam trainers. They update the 312-50v12 exam questions as per the latest 312-50v12 Exam Syllabus. So rest assured that with the Pass4sures you will get the updated 312-50v12 exam practice questions all the time. Try a free demo if you to evaluate the features of our product. Best of luck!
Valid Braindumps 312-50v12 Pdf: https://www.pass4sures.top/CEH-v12/312-50v12-testking-braindumps.html
What's more, part of that Pass4sures 312-50v12 dumps now are free: https://drive.google.com/open?id=1iwoX3KQMUJbXLJXnz7eMDGHBb7kLGlO9
Posted at 2/16/2026 13:43:40        Only Author  2#
Data-Con-101ԇYYϤһĤϕrg򹝼sǤ뤳ȤǤԤQСYߤ϶̤rg򤫤㏊顢Data-Con-101ԇY˺ϸǤޤäơData-Con-101ԇYYϤ㏊rg̤Ƥ⤤ǤData-Con-101ԇYYϤϤʤˤƷιxӤޤ?ޤϤ`ӥṩޤData-Con-101YϤ㏊ȤΤ|ޤ顢BjǤޤ
