New Topic
[Linux] How to rotate screen on Unbuntu 18.04? How to set landscape orientation ?
154
【Linux】 How to rotate screen on Unbuntu 18.04? How to set landscape orientation ?
Posted at 3/30/2023 22:52:04      View:5318 | Replies:10        Print      Only Author   [Copy Link] 1#
  • SDK Package Name: rk356x_linux_release_v1.3.0b_20221213
  • Modification Content: mipi 2 cam configuration
  • Log: no log (2).zip
How to rotate screen on Unbuntu 18.04?I have 800x1280 screen and it have book orientation.
I tryed find Display settings in Ubuntu 18 descktop environment for orientation but found nothing.
Auto rotate screen doesn't works.
How can i change DTS file to do it ?
no log (2).zip
22 Bytes, Down times: 0
Posted at 3/31/2023 09:43:55        Only Author  2#
Posted at 3/31/2023 13:51:29        Only Author  3#
zooora111 Posted at 3/31/2023 09:43
Hi, this may help: https://wiki.t-firefly.com/en/Firefly-Linux-Guide/manual_ubuntu.html#multi-screen ...
yes i saw it before, but it's not about SCREEN rotation, it's about touchscreen rotation.
Posted at 3/31/2023 17:17:39        Only Author  4#
Use xrandr  command  can rotate screen
xrandr --output --rotate <left|right|inverted|normal>
e.g.:
xrandr --output HDMI1 --rotate right
Posted at 3/31/2023 21:49:39        Only Author  5#
895816513 Posted at 3/31/2023 17:17
I tryed it before and it works fine but It's not a best solution.
I need to add 2nd screen settings 1280x800:
horisontal 1280
vertical 800
I need rotate my screen using DTS file, on the kernel level:
&dsi1{
disp_timings1: display-timings {
            native-mode = <&dsi1_timing0>;
            dsi1_timing0: timing0 {
                clock-frequency = <72600000>;//<80000000>;
                hactive = <800>;
                vactive = <1280>;
                hsync-len = <14>;   //20, 50,10
                hback-porch = <26>; //50, 56,10
                hfront-porch = <32>;//50, 30,180
                    vsync-len = <8>;//4
                    vback-porch = <20>;//4
                    vfront-porch = <80>;//8
                    hsync-active = <0>;
                    vsync-active = <0>;
                    de-active = <0>;
                pixelclk-active = <0>;
So i need to add 2nd dsi1_timing:
dsi1_timing1: timing1 {
                clock-frequency = ...;
                hactive = <1280>;
                vactive = <800>;
So probabaly i need enter new values for
clock-frequency,hactive,vactive,hsync-len,hback-porch,hfront-porch,vsync-len,vback-porch,vfront-porch
Can you help me ? How to do it ?
Posted at 4/1/2023 17:14:14        Only Author  6#
Maverick_by_ Posted at 3/31/2023 21:49
I need to add 2nd screen sett ...
Timings are given in the datasheet of a LCD screen, one DSI can only has one group of timings
They are hardware features of a LCD , so you can't just swap hactive and vactive to rotate
The only way is using xrandr
Posted at 3/30/2024 15:06:07        Only Author  7#
Maverick_by_ Posted at 3/31/2023 13:51
How did you solve it?
Posted at 1/9/2026 15:43:45        Only Author  8#
当社のウェブサイトCertShikenの購入手続きは安全です。 ダウンロード、インストール、および使用は安全であり、製品にウイルスがないことを保証します。 最高のサービスと最高のData-Cloud-Consultant-JPN試験トレントを提供し、製品の品質が良好であることを保証します。 電子的なData-Cloud-Consultant-JPNガイドトレントがウイルスを増幅するのではないかと心配する人が多く、ウイルスを誤って報告する専門家ではないアンチウイルスソフトウェアを使用する人もいます。 サービスとData-Cloud-Consultant-JPN学習教材はどちらも優れており、当社SalesforceのSalesforce Certified Data Cloud Consultant (Data-Cloud-Consultant日本語版)製品とウェブサイトはウイルスがなくても絶対に安全であると考えてください。
Posted at 2/1/2026 08:16:02        Only Author  9#
Your article was such a pleasant surprise, thank you! Unlock your career growth with free C-P2WFI-2023 useful dumps materials—promotion and salary increase!
Posted at 2/3/2026 16:47:51        Only Author  10#
私たちが提供するOracle NetSuite SuiteFoundation Specialist準備トレントは、精巧にコンパイルされ、非常に効率的です。 N16300GC10試験トレントを練習するのに20〜30時間しかかからず、試験に参加できます。仕事などで忙しいほとんどのお客様。ただし、N16300GC10テスト準備を使用する場合、短時間で試験を準備して試験内容をマスターするのにそれほど時間は必要ありません。彼らがする必要があるのは、毎日学習して練習するのに1〜2時間を費やし、N16300GC10テスト準備で簡単に試験に合格することです。試験に合格するための時間と労力はほとんどかかりません。
Return to List
12
