New Topic
[General] i2c detect not found
79
General i2c detect not found
Posted at 8/30/2022 14:12:32      View5662 | Replies10        Print      Only Author   [Copy Link] 1#
Hi,
I am using AIO-3399J EVK and connected some sensors to I2C4.
I am trying to use i2cdetect command it gives an error saying -
i2c detect not found.
I also tried to use sudo also but sudo also not working.
I tried to use su but su also not working.
EVK - AIO-3399J
BSP - Andriod 7.1 from firefly
Command - rk3399_firefly_aio_lvds_box_userdebug
Any suggestion on how I can enable i2c detect in BSP.
vip
Rank: 6Rank: 6
Posted at 9/5/2022 11:25:10        Only Author  2#
You can download the attachment file i2cdetect and push it to the /data i2cdetect.zip (247.35 KB, Down times: 2)
Posted at 9/5/2022 22:29:41        Only Author  3#
jpchen Posted at 9/5/2022 11:25
Hi, jpchen,
Thanks for your reply.
I am able to build and use i2c detect using the below links -
https://cdmana.com/2021/12/202112270710526342.html
https://mirrors.edge.kernel.org/pub/software/utils/i2c-tools/
https://blog.csdn.net/m0_38022615/article/details/110229742
Posted at 9/5/2022 22:32:23        Only Author  4#
Hi jpchen,
can you suggest how I can use evtest command?
vip
Rank: 6Rank: 6
Posted at 9/6/2022 10:01:27        Only Author  5#
maneesh.singh Posted at 9/5/2022 22:32
Hi jpchen,
i2cdetect -r -y 0    //The number represents the I2C channel
Posted at 9/12/2022 16:27:11        Only Author  6#
jpchen Posted at 9/6/2022 10:01
Hi @jpchchen,
I2C detect I am able to do.
can you suggest how I can use the evtest tool to test input events?
Thanks
Posted at 1/12/2026 02:56:37        Only Author  7#
Your article was so enlightening, thank you for this wonderful insight. The AP-226 latest study guide sheet material is very good, and its free to access.
Posted at 1/13/2026 05:31:41        Only Author  8#
Your article was such a breath of fresh air, thank you. The Reliable test Salesforce-MuleSoft-Associate collection pdf exam played a major role in my promotion and raiseget it for free today!
Posted at 1/25/2026 03:41:28        Only Author  9#
F5 F5CAB2 덤프는F5 F5CAB2시험문제변경에 따라 주기적으로 업데이트를 진행하여 저희 덤프가 항상 가장 최신버전이도록 보장해드립니다. 고객님들에 대한 깊은 배려의 마음으로 고품질F5 F5CAB2덤프를 제공해드리고 디테일한 서비스를 제공해드리는것이 저희의 목표입니다.
Posted at 1/31/2026 03:55:42        Only Author  10#
This article is a real treasure, thank you for sharing it with us. My promotion and raise were made possible by the Reliable Operations-Management dumps files questionstoday, Im sharing them with you at no cost!
Return to List
12
