[General] 220-1202 real test engine & 220-1202 exam training vce & 220-1202 practi
87
【General】 220-1202 real test engine & 220-1202 exam training vce & 220-1202 practi
Posted at 2/10/2026 18:11:43      View:102 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 CompTIA 220-1202 dumps are available on Google Drive shared by Actualtests4sure: https://drive.google.com/open?id=1WOmfn-2TPn71DQdTW7tGX1ikhrmnRUKH
The pass rate is 98.75% for 220-1202 learning materials, and we will help you pass the exam just one time if you choose us. In order to build up your confidence for 220-1202 training materials, we are pass guarantee and money back guarantee, if you fail to pass the exam, we will give you full refund. In addition, you can receive the download link and password within ten minutes for 220-1202 Training Materials, if you don’t receive, you can contact with us, and we will solve this problem for you immediately. We offer you free update for 365 days for you, and the update version for 220-1202 exam materials will be sent to your email automatically.
It is not a time to get scared of taking any difficult certification exam such as 220-1202. The excellent study guides, practice questions and answers and dumps offered by Actualtests4sure are your real strength to take the test with confidence and pass it without facing any difficulty. Passing an 220-1202 exam rewards you in the form of best career opportunities. A profile rich with relevant credentials opens up a number of career slots in major enterprises. Actualtests4sure's 220-1202 Questions and answers based study material guarantees you career heights by helping you pass as many exams as you want.
100% Pass Quiz Fantastic CompTIA 220-1202 Exam LearningWe are committed to provide you the best and the latest 220-1202 training materials for you. Quality of the 220-1202 exam dumps has get high evaluation among our customers, they think highly of it, since we help them pass the exam easily. Furthermore if we have the updated version, our system will send the Latest 220-1202 Exam Dumps to your email address automatically, you don’t need to worry about missing the latest version, you just need to concentrate your attention on practicing, and we will do the rest for you.
CompTIA A+ Certification Exam: Core 2 Sample Questions (Q80-Q85):NEW QUESTION # 80
A technician wants to prevent electrical damage while disassembling a device. The technician turns off the device. Which of the following should the technician do next?
  • A. Connect a wrist strap to a metal frame
  • B. Place the computer on an antistatic mat
  • C. Work on a plastic surface
  • D. Place components in antistatic bags
NEW QUESTION # 81
A user recently installed an application that accesses a database from a local server. When launching the application, it does not populate any information. Which of the following command-line tools is the best to troubleshoot the issue?
  • A. curl
  • B. ipconfig
  • C. netstat
  • D. nslookup
The scenario involves an application that should retrieve data from a local database server but is failing to do so. This likely indicates a problem in communication between the application and the database server (such as a network issue, port misconfiguration, or service unavailability). The correct troubleshooting approach involves testing the network/service connectivity between the client and the database.
Let's examine the options:
* A. ipconfig:This command displays IP configuration details for Windows systems, such as IP address, subnet mask, and default gateway. While useful for diagnosing general networkissues, it does not test service connectivity or the availability of a specific application port/service.
* B. nslookup:Used to query DNS servers to resolve domain names to IP addresses. However, since the question references a local server (likely accessed via IP or static hostname), DNS is probably not involved. Also, it does not test application/service availability.
* C. netstatisplays active TCP connections, listening ports, and routing tables. It helps determine whether the local system is listening for or maintaining any network connections, but it does not initiate a connection to test availability. It's diagnostic but not interactive for service testing.
* D. curl:This is the most appropriate tool for this scenario. curl is used to test connectivity to services over protocols like HTTP, HTTPS, FTP, and more. If the application retrieves data via a web interface or API (common in database-driven applications), curl can be used to test if the application can successfully reach and retrieve data from the server. It provides immediate, testable feedback on whether the server and service are available and responsive.
Example usage:
curlhttp://localhost:8080/api/data
This command would test whether a local server's application programming interface (API) is available and responding on port 8080.
CompTIA A+ 220-1102 Reference Points:
* Objective 2.4: Given a scenario, use appropriate tools to troubleshoot and support Windows OS issues.
* Objective 3.3: Use appropriate tools to troubleshoot and resolve issues.
* The CompTIA A+ Core 2 study guide references curl as a useful command-line utility for testing connectivity and troubleshooting application access to services.
NEW QUESTION # 82
Various alerts on a user's Windows 11 laptop are continually interrupting the user during videoconference calls. Which of the following should a support technician recommend to best solve the issue?
  • A. Configure the Sounds option in Control Panel to be set to No Sounds
  • B. Set Windows Notifications settings to Do Not Disturb
  • C. Disable all notifications in different applications in the order they appear
  • D. Use multiple sound output devices for the various source applications
Windows 11 features a"Do Not Disturb"mode under Notification settings, which is designed to suppress interruptions during tasks like videoconferencing.
NEW QUESTION # 83
A user frequently misplaces their Windows laptop and is concerned about it being stolen. The user would like additional security controls on their laptop. Which of the following is a built-in technology that a technician can use to enable full drive encryption?
  • A. Active Directory
  • B. New Technology File System
  • C. Encrypting File System
  • D. BitLocker
BitLocker is Microsoft's full disk encryption technology built into Windows Pro and Enterprise editions. It encrypts the entire drive, protecting data if the device is lost or stolen. BitLocker can use TPM (Trusted Platform Module) and can be configured with PINs or USB keys for added security.
A: Active Directory is for centralized user and policy management in domains.
B: NTFS is the file system format and doesn't provide encryption by itself.
C: EFS (Encrypting File System) encrypts individual files or folders, not the entire drive.
CompTIA A+ 220-1102 Objective 2.2: Compare and contrast security measures and encryption tools.
Study Guide Section: Encryption options - BitLocker vs. EFS
NEW QUESTION # 84
A user's application only works with a legacy version of the OS. The OS is reaching its end-of-life date. For security reasons, the company is migrating to the current version of the OS. Which of the following is the most efficient way to complete the migration while maintaining accessibility to the application?
  • A. Bare-metal server
  • B. Terminal server
  • C. Multiboot
  • D. Virtualization
Virtualizationallows the legacy OS to be run in a virtual machine (VM) on top of the newer OS. This method provides backward compatibility without requiring outdated operating systems on physical hardware.
FromQuentin Docter - CompTIA A+ Complete Study Guide:
"Using virtualization is a preferred method when legacy applications are needed after migrating to newer operating systems. It allows legacy environments to exist securely within a modern OS framework."
NEW QUESTION # 85
Now we can say that CompTIA A+ Certification Exam: Core 2 (220-1202) exam questions are real and top-notch CompTIA 220-1202 exam questions that you can expect in the upcoming CompTIA 220-1202 exam. In this way, you can easily pass the CompTIA A+ Certification Exam: Core 2 (220-1202) exam with good scores. The countless 220-1202 Exam candidates have passed their dream CompTIA 220-1202 certification exam and they all got help from real, valid, and updated 220-1202 practice questions, You can also trust on Actualtests4sure and start preparation with confidence.
Reliable 220-1202 Exam Pattern: https://www.actualtests4sure.com/220-1202-test-questions.html
CompTIA 220-1202 Exam Learning The arrival of the information age will undoubtedly have a profound influence on our lives especially on our jobs, Reliable CompTIA 220-1202 guide torrent will help prepare your exam easily, They are actually very productive to use for these reasons: All 220-1202 exam questions are latest and verified by Industry experts, Our Actualtests4sure always updates the exam dumps and the content of our exam software in order to ensure the 220-1202 exam software that you have are the latest and comprehensive version.
Using the enhanced for statement to total 220-1202 Best Vce integers in an array, Get directions to the Ryman Auditorium in Nashville, Tennessee, The arrival of the information age 220-1202 will undoubtedly have a profound influence on our lives especially on our jobs.
100% Pass CompTIA - 220-1202 - CompTIA A+ Certification Exam: Core 2 Newest Exam LearningReliable CompTIA 220-1202 guide torrent will help prepare your exam easily, They are actually very productive to use for these reasons: All 220-1202 exam questions are latest and verified by Industry experts.
In this case, we need a professional 220-1202 certification, which will help us stand out of the crowd and knock out the door of great company.
DOWNLOAD the newest Actualtests4sure 220-1202 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1WOmfn-2TPn71DQdTW7tGX1ikhrmnRUKH
