輕松過ADX-211認證的考古題 -是最有效的Administer, Extend, and Automate Salesforce-ADX-211考試備考資料
Posted at 2/11/2026 11:18:23
P.S. PDFExamDumps在Google Drive上分享了免費的、最新的ADX-211考試題庫:https://drive.google.com/open?id=1ZdbteKD4DEm_G4iJoBnI5pomoiDW1ba4
PDFExamDumps為Salesforce ADX-211 認證考試準備的培訓包括Salesforce ADX-211認證考試的模擬測試題和當前考試題。在互聯網上你也可以看到幾個也提供相關的培訓的網站,但是你比較之後,你就會發現PDFExamDumps的關於Salesforce ADX-211 認證考試的培訓比較有針對性,不僅品質是最高的,而且內容是最全面的。
該考試旨在為具有Salesforce管理經驗且希望擴展其知識和技能的專業人士而設計。建議考生在參加ADX-211考試之前至少具有六個月的Salesforce管理經驗。該認證對於希望在Salesforce管理領域中發展職業生涯並成為專家的專業人士非常理想。
快速下載的Salesforce ADX-211:新版Administer, Extend, and Automate Salesforce考古題 - 高質量的PDFExamDumps ADX-211資訊在短短幾年內,Salesforce ADX-211 認證考試已經成為比較有影響力電腦能力認證考試。然而如何簡單順利地通過Salesforce ADX-211認證考試?我們的PDFExamDumps在任何時間下都可以幫您快速解決這個問題。我們在PDFExamDumps中為您提供了可以成功通過ADX-211認證考試的培訓工具。ADX-211認證考試培訓工具的內容是由IT行業專家帶來的最新的考試研究材料組成
最新的 Salesforce Certified Advanced Administrator ADX-211 免費考試真題 (Q28-Q33):問題 #28
Cloud Kicks needs to create 10 separate environments for various projects. A developer sandbox has been created with the necessary configuration and dat a. The administrator needs to create 10 now environments with the same metadata and data for each user.
What should the administrator do to meet the requirements?
- A. Use refresh sandbox without Auto Activate.
- B. Use a scratch org definition to copy sandbox.
- C. Use the existing sandbox as a sandbox template.
- D. Use clone a sandbox option from the existing sandbox.
答案:C
問題 #29
Cloud Kicks has been tracking how many participants wear the company's shoes in each marathon. The administrator creates two custom objects: Races and Runners. There is a master-detail relationship between them as well as a Roll-up Summary field on the Races object to show the count of runners in each race. Requirements have changed, and the administrator wants to delete the Master-detail Relationship field without deleting the Runners records.
What action should an administrator take before the Relationship field can be deleted?
- A. Select the Allow Reparenting' checkbox on the Master-detail field.
- B. Delete the Roll-up Summary field on the parent.
- C. Uncheck 'Delete this record also' to turn off cascading deletes.
- D. Change the field type to a Lookup Relationship.
答案:D
解題說明:
Changing the field type to a Lookup Relationship will allow deleting the Relationship field without deleting the Runners records. A lookup relationship creates a loose association between two objects, where the child records do not depend on the parent records for their existence. A lookup relationship can be deleted without affecting the child records, unlike a master-detail relationship that enforces cascading deletes. Reference: https://help.salesforce.com/s/ar ... ions.htm&type=5
問題 #30
Which two tools should an administrator use to required data to be entered in a field and improve data quality on a record in Salesrorce?
Choose 2 answers
- A. Dashboards
- B. validation Rules
- C. Page Layouts
- D. Workflow Rules
答案:B,C
問題 #31
While reviewing the quarterly forecast, a manager notices the newest team member is missing in the forecast- After looking at a few the manager can see where the sales representative has closed six opportunities this month and has three additional opportunities m progress.
Where should the administrator start troubleshooting?
- A. Verify the app the user is selecting and adjust tabs as needed.
- B. Chide Allow Forecasting under general Information for user.
- C. Assign View All Forecasting permission to the sales profile.
- D. Create a permission set with View All Forecasting permission.
答案:C
問題 #32
At Cloud Kicks, the Sales team uses a specific dashboard to see how they are doing daily. The team has asked the administrator for an easier way to see this dashboard.
What should the administrator recommend?
- A. Email the dashboard to the Sales Team every morning.
- B. Add the dashboard to the Sales team's home page.
- C. Create a custom app with a dashboard.
- D. Update the Sales team's app with a new dashboard.
答案:B
解題說明:
A dashboard is a visual display of key metrics and trends for records in your org. Dashboards allow users to quickly monitor performance and identify trends or issues at a glance. To make it easier for users to see a dashboard they use frequently, administrators can add it to their home page using Lightning App Builder. This way, users can see their dashboard every time they log in or go to their home tab without having to navigate elsewhere. Reference: https://help.salesforce.com/s/ar ... view.htm&type=5 https://help.salesforce.com/s/ar ... page.htm&type=5
問題 #33
我們PDFExamDumps Salesforce的ADX-211考試培訓資料是最佳的培訓資料,如果你是IT人員,它將是你必選的培訓資料,不要拿你的未來來賭明天,PDFExamDumps Salesforce的ADX-211考試培訓資料絕對值得信賴,我們是專門給全世界的IT認證的考生提供培訓資料的,包括試題及答案,實現 Salesforce的ADX-211考試認證,是許多IT和網路專業人士的目標,PDFExamDumps的合格率是難以置信的高,在PDFExamDumps,我們致力於你不斷的取得成功。
ADX-211資訊: https://www.pdfexamdumps.com/ADX-211_valid-braindumps.html
我们能為很多參加 Salesforce ADX-211 認證考試的考生提供具有針對性的培訓方案,包括考試之前的模擬測試,針對性教學課程,和與真實考試有95%相似性的練習題及答案,所以,在練習ADX-211問題集之前,首先要確保的就是這份ADX-211問題集的質量,我們提供最新的PDF和軟件版本的問題和答案,可以保證考生的ADX-211考試100%通過,PDFExamDumps通過活用前輩們的經驗將歷年的考試資料編輯起來,製作出了最好的ADX-211考古題,如果你想通過Salesforce的ADX-211考試認證使自己在當今競爭激烈的IT行業中地位更牢固,在IT行業中的的專業技能更強大,你的需要很強的專業知識和日積月累的努力,而且通過Salesforce的ADX-211考試認證也不是簡單的,或許通過Salesforce的ADX-211考試認證是你向IT行業推廣自己的時候,但是不一定需要花費大量的時間和精力來學習專業知識,你可以選擇我們PDFExamDumps Salesforce的ADX-211考試培訓資料,專門是針對IT相關考試認證研究出來的培訓產品,在IT行業中工作的人們現在最想參加的考試好像是Salesforce ADX-211資訊的認證考試吧。
哦,都有些什麽獎品呢,而圖紙上的東西正是妳手中的那枚戒指,我们能為很多參加 Salesforce ADX-211 認證考試的考生提供具有針對性的培訓方案,包括考試之前的模擬測試,針對性教學課程,和與真實考試有95%相似性的練習題及答案。
綜合全面新版ADX-211考古題,最好的考試題庫幫助妳壹次性通過ADX-211考試所以,在練習ADX-211問題集之前,首先要確保的就是這份ADX-211問題集的質量,我們提供最新的PDF和軟件版本的問題和答案,可以保證考生的ADX-211考試100%通過,PDFExamDumps通過活用前輩們的經驗將歷年的考試資料編輯起來,製作出了最好的ADX-211考古題。
如果你想通過Salesforce的ADX-211考試認證使自己在當今競爭激烈的IT行業中地位更牢固,在IT行業中的的專業技能更強大,你的需要很強的專業知識和日積月累的努力,而且通過Salesforce的ADX-211考試認證也不是簡單的,或許通過Salesforce的ADX-211考試認證是你向IT行業推廣自己的時候,但是不一定需要花費大量的時間和精力來學習專業知識,你可以選擇我們PDFExamDumps Salesforce的ADX-211考試培訓資料,專門是針對IT相關考試認證研究出來的培訓產品。
- Salesforce 新版ADX-211考古題:Administer, Extend, and Automate Salesforce考試即時下載|更新的ADX-211 👈 在▛ [url]www.vcesoft.com ▟上搜索[ ADX-211 ]並獲取免費下載ADX-211考試[/url]
- 精準的新版ADX-211考古題,最好的考試指南幫助妳壹次性通過ADX-211考試 ♿ 來自網站⇛ [url]www.newdumpspdf.com ⇚打開並搜索▛ ADX-211 ▟免費下載ADX-211考試心得[/url]
- ADX-211考試重點 🔯 ADX-211資料 😜 ADX-211熱門認證 😇 ⮆ [url]www.newdumpspdf.com ⮄上的《 ADX-211 》免費下載只需搜尋ADX-211 PDF題庫[/url]
- ADX-211題庫 🦉 ADX-211熱門認證 👘 ADX-211下載 🍊 打開✔ [url]www.newdumpspdf.com ️✔️搜尋( ADX-211 )以免費下載考試資料ADX-211通過考試[/url]
- ADX-211題庫 📕 ADX-211考試重點 🚠 ADX-211考題資訊 💳 在➤ tw.fast2test.com ⮘上搜索➤ ADX-211 ⮘並獲取免費下載ADX-211最新題庫資源
- 最新的ADX-211認證考試資料庫 🙎 到➥ [url]www.newdumpspdf.com 🡄搜索▛ ADX-211 ▟輕鬆取得免費下載ADX-211資料[/url]
- 最好的新版ADX-211考古題 |高通過率的考試材料|值得信賴的ADX-211資訊 🚠 在⏩ [url]www.newdumpspdf.com ⏪網站上查找➤ ADX-211 ⮘的最新題庫ADX-211考試重點[/url]
- [url=http://jonathanstephanoff.com/?s=%e6%96%b0%e7%89%88ADX-211%e8%80%83%e5%8f%a4%e9%a1%8c%ef%bc%9aAdminister,%20Extend,%20and%20Automate%20Salesforce100%ef%bc%85%e9%80%9a%e9%81%8e%e8%80%83%e8%a9%a6%ef%bc%8cSalesforce%20ADX-211%20%e8%aa%8d%e8%ad%89%20%f0%9f%90%90%20%e5%88%b0[%20www.newdumpspdf.com%20]%e6%90%9c%e5%b0%8b%e3%80%8c%20ADX-211%20%e3%80%8d%e4%bb%a5%e7%8d%b2%e5%8f%96%e5%85%8d%e8%b2%bb%e4%b8%8b%e8%bc%89%e8%80%83%e8%a9%a6%e8%b3%87%e6%96%99ADX-211%e8%bd%af%e4%bb%b6%e7%89%88]新版ADX-211考古題:Administer, Extend, and Automate Salesforce100%通過考試,Salesforce ADX-211 認證 🐐 到[ www.newdumpspdf.com ]搜尋「 ADX-211 」以獲取免費下載考試資料ADX-211软件版[/url]
- 最好的Salesforce ADX-211:新版Administer, Extend, and Automate Salesforce考古題 - 100%合格率[url]www.vcesoft.com ADX-211資訊 😁 ➡ www.vcesoft.com ️⬅️上的⮆ ADX-211 ⮄免費下載只需搜尋ADX-211通過考試[/url]
- Salesforce 新版ADX-211考古題:Administer, Extend, and Automate Salesforce考試即時下載|更新的ADX-211 💰 到⇛ [url]www.newdumpspdf.com ⇚搜索➥ ADX-211 🡄輕鬆取得免費下載最新ADX-211試題[/url]
- 最好的Salesforce ADX-211:新版Administer, Extend, and Automate Salesforce考古題 - 100%合格率[url]www.newdumpspdf.com ADX-211資訊 🐣 透過▶ www.newdumpspdf.com ◀搜索「 ADX-211 」免費下載考試資料免費下載ADX-211考題[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, letterboxd.com, academy.iluvquran.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, winningmadness.com, theduocean.org, www.stes.tyc.edu.tw, Disposable vapes
順便提一下,可以從雲存儲中下載PDFExamDumps ADX-211考試題庫的完整版:https://drive.google.com/open?id=1ZdbteKD4DEm_G4iJoBnI5pomoiDW1ba4
